Using BingMap with printing
I need to use bingMap or googleMap in print (PrinterInteractiveOverlay).
Is there any sample for this ?
thanks
Hi Maryam,
I think the below codes should be fit for you:
private void DisplayMap_Load(object sender, EventArgs e)
    PrinterInteractiveOverLay printerOverlay = new PrinterInteractiveOverLay();
    winformsMap1.InteractiveOverlays.Add(“PrintPreviewOverlay”, printerOverlay);
    winformsMap1.InteractiveOverlays.MoveToBottom(“PrintPreviewOverlay”);
    PagePrinterLayer pagePrinterLayer = new PagePrinterLayer(PrinterPageSize.AnsiA, PrinterOrientation.Portrait);
    pagePrinterLayer.Open();
    printerOverlay.PrinterLayers.Add(“PageLayer”, pagePrinterLayer);
    AddMapLayer();
    winformsMap1.CurrentExtent = RectangleShape.ScaleUp(pagePrinterLayer.GetPosition(), 10).GetBoundingBox();
    winformsMap1.Refresh();
private void AddMapLayer()
    // Create the MapPrinterLayer and set the position
    MapPrinterLayer mapPrinterLayer = new MapPrinterLayer();
    mapPrinterLayer.MapUnit = GeographyUnit.Meter;
    mapPrinterLayer.MapExtent = new RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962);
    mapPrinterLayer.BackgroundMask = new AreaStyle(new GeoPen(GeoColor.StandardColors.Black, 1));
    mapPrinterLayer.Open();
    RectangleShape pageBoundingbox = GetPageBoundingBox(PrintingUnit.Inch);
    mapPrinterLayer.SetPosition(8, 7, pageBoundingbox.GetCenterPoint().X, pageBoundingbox.GetCenterPoint().Y + 1, PrintingUnit.Inch);
    mapPrinterLayer.Layers.Add(new GoogleMapsLayer());
    // Add the MapPrinterLayer to the PrinterInteractiveOverlay
    PrinterInteractiveOverLay printerInteractiveOverLay = (PrinterInteractiveOverLay)winformsMap1.InteractiveOverlays[“PrintPreviewOverlay”];
    printerInteractiveOverLay.PrinterLayers.Add(“MapLayer”, mapPrinterLayer);
private RectangleShape GetPageBoundingBox(PrintingUnit unit)
    // This helper method gets the pages bounding box in the unit requested
    PagePrinterLayer pagePrinterLayer = (PagePrinterLayer)printerInteractiveOverLay.PrinterLayers[“PageLayer”];
    return pagePrinterLayer.GetPosition(unit); ;
The result should be look like this if everything goes well.
Hope it helps.
Your answer really helped me .
thanks a lot .
Hi Maryam,
 Good to hear it works for you.
 If any other queries, don’t hesitate to let us know.
