Using images from the project resource?
Is there a way to use .ico,.bmp,& .png images that are part of the project resources when defining PointStyles w/ GeoImage ?  I noticed GeoImage takes a file path, but nothing that'll resolve down from an Icon or Bitmap, unless it's a TIFF(stream).
I can make a icon directory & use that easy enough, just wondered if there was a way to use the project images, such as "Properties.Resoures.MyDefaultIcon"
-Thanks
Wes,
With the event GeoImage.StreamLoading, you can set the GeoImage by stream, not need to be by path.Here is some sample code I think would be helpful.
// Here is how to set the GeoImage
InMemoryFeatureLayer bitmapLayer = new InMemoryFeatureLayer();
bitmapLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = PointType.Bitmap;
// we create a geoImage with no file path
GeoImage geoImage = new GeoImage();
geoImage.StreamLoading += new EventHandler<StreamLoadingEventArgs>(geoImage_StreamLoading);
bitmapLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.Image = geoImage;
bitmapLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
// Here we pass in a stream to e.AlternateStream which is the stream of the GeoImage.
// We don’t need to set  a file stream, any kind of stream is fine here
void geoImage_StreamLoading(object sender, StreamLoadingEventArgs e)
       e.AlternateStream = new System.IO.FileStream(@"..\..\SampleData\Data\United States.png", System.IO.FileMode.Open);
       e.FileAccess = System.IO.FileAccess.Read;
       e.FileMode = System.IO.FileMode.Open;
Hi Ben, thanks for the reply! I played around a bit and found the way to load the images from the project resource:
//for any .png,.bmp,jpg, or other images supported by System.Drawing.Bitmap
MemoryStream memStream = new MemoryStream();
Bitmap bm = Properties.Resources.MyImage;
bm.Save(memStream, System.Drawing.Imaging.ImageFormat.Tiff);
//GeoImage geo = new GeoImage(memStream);
//or
//e.AlternateStream = memStream
This will load an Icon/.ico from a resource:
Icon myIcon = Properties.Resources.MyDefaultIcon;
Bitmap bm = myIcon.ToBitmap();
//or
Thanks again
That’s great, Wes. Let us know if you have more issues.
