I’m basically trying to do the same thing that i did in thinkgeo.com/forums/MapSuite/tabid/143/aft/12365/Default.aspx , but for MVCEdition 9.0. I can’t find the same javascript files that i used before however. What javascript files should i download instead to copy locally so i can bundle them?
using IsDefaultJavascriptLibraryDisabled=true for MVCEdition 9.0
Hi Thomas,
We added a new JS library(binding) for it, please save the script to your folder, and modify your references follow this order as below:
<script src="…/…/Scripts/opl_GeoResource.js"></script>
<script src="…/…/Scripts/extension_GeoResource.js"></script>
<script src="…/…/Scripts/helper_GeoResource.js"></script>
<script src="…/…/Scripts/binding_GeoResource.js"></script>
<script src="…/…/Scripts/parser_GeoResource.js"></script>
<script src="…/…/Scripts/func_GeoResource.js"></script>
<script src="…/…/Scripts/cm_GeoResource.js"></script>
<script src="…/…/Scripts/MicrosoftAjax.js"></script>
I’m trying to find these files but they won’t load up on my browser anywhere. I’ve tried all these permutations:
servername/<servername>opl_GeoResource.js
servername<servername>/Scripts/opl_GeoResource.js
servername<servername>/appname<appname>/opl_GeoResource.js
servername<servername>/appname<appname>/Scripts/opl_GeoResource.js
and i get
The resource cannot be found
for all of them. The map shows on my page just fine. if i go to the debugger on that page and look at the sources, all i see is
servername<servername>/appname<appname>/thinkgeo.mvc.min_GeoResource.axd
which is not one of the files you mentioned</appname></servername></appname></servername></appname></servername></servername></servername>
Hi Thomas,
In the latest version, a major version is added as a suffix of URL, now it should look like as following:
servername/appname/helper_GeoResource.axd?v=9.0.0.0
The “v” means the version which should be the public versions, like 8.0.0.0, 9.0.0.0 etc.
thanks, that solved it. except you were wrong on one part. you stated that i would need
<scriptsrc="…/…/Scripts/MicrosoftAjax.js"></script>
but in fact it would be
<scriptsrc="…/…/Scripts/msajax_GeoResource.js"></script>
makes it difficult to find if it’s not the same name. Now i’m back to having the same problem as i have in thinkgeo.com/forums/MapSuite/tabid/143/aft/12878/Default.aspx w/out the default javascript library disabled
Hi Thomas,
Thanks for update this problem, so could you build a simple sample for reproduce that now? Just for mentioned in another post, it cannot be reproduced so it’s hard to be fixed.
