Using osm map
 it is succeed,but I don’t need  GeographyUnit.Meter,I need use GeographyUnit.DecimalDegree. Can you help me.
private void WpfMap_Loaded(object sender, RoutedEventArgs e)
            wpfMap1.BackgroundOverlay.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean);
            wpfMap1.MapUnit = GeographyUnit.Meter;
            OpenStreetMapOverlay osmOverlay = null;
            osmOverlay = new OpenStreetMapOverlay();
            osmOverlay.IsVisible = true;
            wpfMap1.Overlays.Add(“Open Street Map”, osmOverlay);
            wpfMap1.CurrentExtent = new RectangleShape(-14136706, 6440000, -5649000, 952000);
            wpfMap1.CurrentExtent = new RectangleShape(103.58,1.50,104.11,1.17);
it don’t show osm map. Can you help me  to modify it?
Hi wang,
The OpenStreetMapOverlay supports projection, would you please try the below codes to do the projection conversion?
            proj4.InternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString();
            proj4.ExternalProjectionParametersString = Proj4Projection.GetDecimalDegreesParametersString();
            proj4.Open();
            OpenStreetMapOverlay osmOverlay = new OpenStreetMapOverlay();
            osmOverlay.ProjectionFromSphericalMercator = proj4;
Any other questions, don’t hesitate to let us know.
Hi Troy,
Can you help me?
I have a problem, I already init a osm map,and add a button in the map ,order to realize that :
if cilck button  can draw  a rectangle( only draw one rectangle) to set currentextent in the map, Like “Shift” + draw a rectangle function.
how to reallize,I know:
 this.wpfMap1.TrackOverlay.TrackMode = TrackMode.Rectangle; // it can draw a rectangle,but it can draw a lot of rectangle.Don’t i need.
1. how to get the rectangle?
2. how to set currentextent?  like “this.wpfMap1.CurrentExtent = rectangle.GetBoundingBox();”? this’s true?
Hi Burning,
Would you please try the below codes:
     wpfMap1.CurrentExtent = new RectangleShape(-133.2515625, 89.2484375, 126.9046875, -88.290625);
     WorldMapKitWmsWpfOverlay worldMapKitOverlay = new WorldMapKitWmsWpfOverlay();
     wpfMap1.Overlays.Add(worldMapKitOverlay);
     wpfMap1.TrackOverlay.TrackEnded += TrackOverlay_TrackEnded;
     wpfMap1.Refresh();
 void TrackOverlay_TrackEnded(object sender, TrackEndedTrackInteractiveOverlayEventArgs e)
     wpfMap1.TrackOverlay.TrackMode = TrackMode.None;
     wpfMap1.CurrentExtent = wpfMap1.TrackOverlay.TrackShapeLayer.InternalFeatures[0].GetBoundingBox();
Hope it helps and any questions, please let us know.
