Using ReturningColumnsType.AllColumns
Hello,  I am using the code below the line to draw an ellipse  when the user clicks a point. It seems that using "ReturningColumnsType.AllColumns" is what is needed to draw the ellipse.  The ellipse has a radius of 10 miles.  All I am doing is adding the "selectedFeatures in the selectedFeaturesCollection to the new Collection efc and using  GetFeaturesIntersecting(selectedExtent) to find itself.  It seems that I should be able to do the following, but this doesn't show the ellipse.
Thanks, sckeels...
highlightEllipseLayer.InternalFeatures.Clear();
foreach(Feature selectedFeatures in selectedFeaturesCollection)
  highlightEllipseLayer.InternalFeatures.Add(selectedFeatures.Id, selectedFeatures);
_____________________________________________
 selectedExtent = selectedFeatures.GetBoundingBox();
  ellipseLayer.Open();
Collection<Feature> efc = ellipseLayer.QueryTools.GetFeaturesIntersecting(selectedExtent, ReturningColumnsType.AllColumns);
  ellipseLayer.Close();
  foreach(Feature ellipseFeature in efc)
    string ellipseCellID = ellipseFeature.ColumnValues["CELLSITE_ID"];
    string selectionCellID = selectedFeatures.ColumnValues["CELLSITE_ID"];
    if(ellipseCellID == selectionCellID)
      highlightEllipseLayer.InternalFeatures.Add(ellipseFeature.Id, ellipseFeature);
      break;
Hi Steven,
 Could you check whether the count of the InternalFeatures at the end of the loop equals zero? If not, I guess that you missed refreshing the Overlay which contains the highlightEllipseLayer. If it doesn’t fix your issue, please send us a quick sample.
 Howard
