Hi ,
I see that there is a restriction with the Routing module that it supports LineShape data only.
How then would I use the routing module on a World Map and routing across oceans?
I would like to create routes between waypoints and ports.
Is there a world Map layer in the required format? as the sample data will not load into the Routing Explorer.
Any advice would be appreciated.
