I have started evaluating ThinkGeo using SQL Server 2012. I’m having issues displaying the features on the map. I can loop through all the features and then add them to an InMemoryFeatureLayer and then see the features on the map. Has anyone else had any success viewing SQL Server 2012 data. The data type in SQL Server is geometry.
Ken
Using SQL Server 2012
Hi Ken,
Which layer are you using to connect to SQL, are you using MsSql2008FeatureLayer?
Here I found a topic about access SQL with geometry data, wish that’s helpful.
thinkgeo.com/forums/MapSuite/tabid/143/aft/11639/Default.aspx
