Using With Parameter on MsSql2008FeatureLayer
As you know if we use
WITH(INDEX(geom_index))
on our SQL queries, it will be much faster than not using it.
SELECT * FROM dbo.RoadNetworkFeature WITH(INDEX(geom_sidx)) WHERE (geometry::STGeomFromWKB(@Geometry,0).STIntersects(Location)=1)
is much faster than
SELECT * FROM dbo.RoadNetworkFeature WHERE (geometry::STGeomFromWKB(@Geometry,0).STIntersects(Location)=1)
but seems that MsSql2008FeatureLayer does not put it on the query you send to the SQL-Server.
is there a way to force MsSql2008FeatureLayer to use
With
on SQL-query.
Hi Behnam,
  1. You can modify the query string in MsSql2008FeatureSource.ExecutingSqlStatement event.
  2. You can remove the “where” from your sqlstatement, then set something like “WITH(INDEX(geom_sidx)) WHERE …” in the WhereClause.
  3. In fact some of our API will inner use “WITH(INDEX(geom_sidx))” in some special scenario.
