In the screen-capture below you will see I am having issues with Windows-10 and protected folders that the Product Center is attempting to access.
I was able to use V10 Product Center as recently as July 2019. The folder in the error message I have removed as a Protected Folder and still getting this error.
System.UnauthorizedAccessException: Access to the path ‘C:\Users\dberr\OneDrive\Documents\ThinkGeo\Map Suite 10.0\ProductCenter.log’ is denied.
I did recently have a large Windows-10 update on my machine. One odd thing I noticed is that there is now a Users\dberry.000 directory where the ThinkGeo fold is located. And there is a Product Center log from July 2019.
Why is Product Center attempting to access Users\dberry, should it not be User\dberry.000?
The ProductCenter.log isn’t introduced in this year, it saved there from the first version of product center.
Just like you mentioned, the problem is after upgrade your system, the administrator account dberr moved to dberr.000.
I did some research and found the reason of that is:
1, When upgrade system, it found old administrator account exsit, so create a new administrator.000
2, If your machine login domain before and the name is the same as your local administrator account, so it will get two folders: Administrator local machine)and Administrator.000(domain account)
The product center read path from system environment, for example here it read the path from: Environment.SpecialFolder.MyDocuments
You can did a quickly test to make sure what’s the return folder in your machine about this value, I think it should be “C:\Users\dberr\OneDrive\Documents”, but it looks your folder is “C:\Users\dberr.000\OneDrive\Documents” now.
You can try to modify it manual, or find a solution from search engines.
Please check the whether Environment.SpecialFolder.LocalApplicationData and Path.GetTempPath() also point to a valid folder now.
As an aside I’ve noticed that the images I’ve added to these posts do not appear. All that is visible is a small box with an x in the middle. When press the box it states “The image could not be loaded”. The image will appear for about 30 seconds and then disappears.
You know for suitable different system we won’t hard code related path in product center.
Our developer double check the logic and hadn’t found other behavior about local folders, and we test it in part of our win10 machines which install all lastest updates (But I think it still cannot simulator your environment 100%), the product center works well there.
So I think you can try some test here:
If you have another machine also can reproduce it please let us know what package you installed there, so we can try to reproduce it.
If it only appear in your currently machine, you can copy the same folder(\ThinkGeo…) and keep it both your dberr and dberr.000 folder, please let us know whether it make product center works without exception.
BTW, for the “The image could not be loaded” that’s because the image in AWS blocked by browser, right click in image to open it in new tab, then allow browser access it can make it works correct.
I finally got this working and not certain exactly how.
I had previously copied the ThinkGeo directory from dberr.ooo to dberr, but that initially did not work. Today I went in and saw that the properties on the ThinkGeo directory were set to read-only for all the files. So I changed that and it still did not work. Then I started Product Center in Supervisor Mode and that did the trick.
I’m sure other people will experience this when they upgrade to Windows-10 Version 1903 (OS Build 18362.356) so hopefully this will save other people time.
BTW…I attempted to open the image in Other Tab to no avail. This is what appears on the tab…
This site is not secure
This might mean that someone’s trying to fool you or steal any info you send to the server. You should close this site immediately.
Go to your Start page
Details
The hostname in the website’s security certificate differs from the website you are trying to visit.
Error Code: DLG_FLAGS_SEC_CERT_CN_INVALID
Go on to the webpage (Not recommended)
This is all due to Windows-10 Version 1903. You may want to consider doing these images in another way or finding a solution to the certificate error.
