ThinkGeo Team,
After an upgrade to ThinkGeo.Core V13.0.0-beta160 I was zooming around faster than normal and received the below exception. Not sure if it is related or just a coincidence. I had not seen this previously and have not been able to repeat this.
In my application I only use MapView.GetSnappedZoomLevelIndex, I do not use ThinkGeo.Core.MapUtil.GetSnappedZoomLevelIndex.
Update – This exception occurs when the mouse-wheel is used to ZoomIn/ZoomOut.
Dennis
System.MissingMethodException
HResult=0x80131513
Message=Method not found: ‘Int32 ThinkGeo.Core.MapUtil.GetSnappedZoomLevelIndex(Double, System.Collections.Generic.IEnumerable`1, Double, Double)’.
Source=ThinkGeo.UI.Wpf
StackTrace:
at ThinkGeo.Core.MapArguments.GetSnappedZoomLevelIndex(Double scale)
at ThinkGeo.Core.ExtentInteractiveOverlay.MouseWheelCore(InteractionArguments interactionArguments)
at ThinkGeo.Core.InteractiveOverlay.MouseWheel(InteractionArguments interactionArguments)
at ThinkGeo.Core.MapViewBase.QUQ=(InteractionArguments interactionArguments)
at ThinkGeo.Core.MapViewBase.QEQ=(Object sender, MouseWheelEventArgs e)
at NxQ=.nUQ=.BUU=(Object sender, MouseWheelEventArgs e)
at System.Windows.Input.MouseWheelEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.Run()
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run()
at OriStarCoreReferenceCore.App.Main()
