ThinkGeo Team,
In V12.1 code in regard to FileGeoDatabase worked just fine. However, under V14.3.0-beta071 I am encountering the exception below. The exception is occurring on the Open.
I then upgraded to V14.3.0-beta090, which introduced a compile error, namely that
TheDatabaseTableNames = TheFileGeoDatabaseFeatureLayer.LayerNames;
In V14.3.–beta090 LayerNames is no longer a property of–>>
My FileGeoDatabaseFeatureLayer contains multiple layers, hence the use of the LayerNames Collection.
And this worked just fine under V12.1 and no code changes were made for V14.3.0
Dennis
2025-03-11 21:47:31,182 ERROR OriStarFileDatabaseViewer - OriStarFileDatabaseViewer->GeneralMethods.PopulateDatabaseCollectionGdb:
Unable to get TheFileGeoDatabaseFeatureLayer.LayerNames Collection
Database=C:\OriStar\xxxx\OriStarVisionMapSuite\MapGeoDatabase\Airport.gdb
Source=Esri.FileGDBAPI
TargetSite=Esri.FileGDB.Table OpenTable(System.String)
StackTrace= at Esri.FileGDB.Geodatabase.OpenTable(String path)
at GRU=.R0I=.VUI=(String pathName, String tableName)
at GRU=.R0I=.VUI=()
at GRU=.R0I=.KB8=()
at ThinkGeo.Core.FileGeoDatabaseFeatureSource.OpenCore()
at ThinkGeo.Core.FeatureSource.Open()
at ThinkGeo.Core.FeatureLayer.OpenCore()
at ThinkGeo.Core.Layer.Open()
at OriStarFileDatabaseViewer.GeneralMethods.PopulateDatabaseCollectionGdb(String TheFile, String TheFilePath, String TheFileName, String TheFileTypeUpCase) in C:\OriStarMappingIncThinkGeoUI-V14.3.0Secondary\OriStarFileDatabaseViewer\TheGeneralMethods.cs:line 503
Message=The table was not found.
Esri.FileGDB.FileGDBException: The table was not found.
at GRU=.R0I=.VUI=()
at GRU=.R0I=.KB8=()
