ValidateXCaml task failed unexpectedly
I am working on Silverlight 3, Visual Studio 2008. I tried your sample code which is for c# (gis.thinkgeo.com/Support/Dis...fault.aspx) but it's giving below error
The "ValidateXaml" task failed unexpectedly.
System.TypeLoadException: Could not load type 'System.Runtime.Versioning.TargetFrameworkAttribute' from assembly 'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
Same error comes when I use new project and follow the instruction given on quick start guide. Please help.
File is attached. What error is this?
KC
Hi Kaustubh,
 Are you using our latest silverlight version 5.0?
 I haven’t see your attched file, could you upload again?
I am using Think Geo's Map Suite Silverlight Evaluation Edition 5.0.
File is attached.
Hi Kaustubh,
 I still haven’t see your file. And your link in post looks point to “Create New Topic”?
Hi Kaustubh,
 Here I found the same question with you forums.silverlight.net/p/172685/400987.aspx
 It looks you should forget reference some dlls, could you try our HowDoISample project first to make sure our map control works for your enviornment correct?
