Vehicle tracking application and best way to plot icons
I am spinning my wheels trying to upgrade from V2 and looking for the best way to plot multiple icons (all with different images) and then to be able to move them around as the new positions come in.
Any help available out there please
Ewan,
Thanks for your post and questions!
Hope following  project can satisfy with your requirement:
code.thinkgeo.com/projects/show/mapshapes
Let me know if any more questions.
Is there supposed to be some sample code along with the article ??
OK I found the code - but does this work with Desktop ??  I cannot seem to find reference to MapShapeLayer or MapShape in the documentation for Desktop V3
OK I am making progress ( I hope) but am stuck but am getting a null exception thrown from my iconLayer in the New_Raster_Position method ??
 I hope you can help
 Ewan
     Private Sub Load_Raster_Map()
         gisMAP.AdornmentOverlay.ShowLogo = False
         gisMAP.ZoomLevelSnapping = ZoomLevelSnappingMode.None
         If Not My.Settings.lastMAPmap = Nothing Then
             If System.IO.File.Exists(My.Settings.lastMAPmap) = True Then
                 gisMAP.Overlays.Clear()
                 gisMAP.MapUnit = GeographyUnit.DecimalDegree
                 Dim worldImageLayer As New GdiPlusRasterLayer(My.Settings.lastMAPmap)
                 worldImageLayer.UpperThreshold = Double.MaxValue
                 worldImageLayer.LowerThreshold = 0
                 Dim staticOverlay As New LayerOverlay()
                 staticOverlay.Layers.Add(“WorldImageLayer”, worldImageLayer)
                 gisMAP.Overlays.Add(staticOverlay)
                 worldImageLayer.Open()
                 gisMAP.CurrentExtent = GetFullExtent()
                 gisMAP.Refresh()
                 gMapLBL.Text = GetFileNameWithoutExtension(worldImageLayer.PathFilename)
                 ’ Setup the mapshape layer.
                 Dim iconLayer As New MapShapeLayer
                 iconLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = ThinkGeo.MapSuite.Core.PointType.Bitmap
                 iconLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.ContestedBorder2
                 iconLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
                 Dim iconOverlay As New LayerOverlay()
                 iconOverlay.Layers.Add(“iconLayer”, iconLayer)
                 gisMAP.Overlays.Add(“iconOverlay”, iconOverlay)
             End If
         End If
         Select Case My.Settings.mapBalloon
             Case Is = True
                 ToolBarBalloon.ImageIndex = 22
             Case Is = False
                 ToolBarBalloon.ImageIndex = 21
         End Select
     End Sub
     Private Sub New_Raster_Position(ByVal Unit_Name As String, ByVal Unit_Operator As String, ByVal Lat As Double, ByVal Lon As Double, ByVal Speed As Double, ByVal Direction As Integer, ByVal Status As String)
         Dim IconPath As String = Get_GIS_Icon(Unit_Name)
         If System.IO.File.Exists(IconPath) = False Then
             IconPath = AppPath & “\icons\gis\base.png”
         End If
         gisMAP.Overlays(“iconOverlay”).Lock.EnterWriteLock()
         Try
             Dim iconLayer As MapShapeLayer = DirectCast(gisMAP.FindFeatureLayer(“iconLayer”), MapShapeLayer)
             Dim myMapShape As New MapShape(New Feature(Lon, Lat, Unit_Name))
             myMapShape.ZoomLevels.ZoomLevel01.DefaultPointStyle = New PointStyle(New GeoImage(IconPath))
             myMapShape.ZoomLevels.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
             If Not iconLayer.MapShapes.ContainsKey(Unit_Name) Then
                 iconLayer.MapShapes.Add(Unit_Name, myMapShape)
             Else
                 iconLayer.Open()
                 iconLayer.EditTools.BeginTransaction()
                 iconLayer.EditTools.Delete(Unit_Name)
                 iconLayer.EditTools.CommitTransaction()
                 iconLayer.Close()
             End If
         Finally
             gisMAP.Overlays(“iconOverlay”).Lock.ExitWriteLock()
         End Try
         gisMAP.Refresh()
     End Sub
 Public Class MapShape
     Private m_feature As Feature
     Private zoomLevelSet As ZoomLevelSet
     Public Sub New()
         Me.New(New Feature())
     End Sub
     ’ Let’s use this as a handy constructor if you already have
     ’ a feature or want to create one inline.
     Public Sub New(ByVal feature As Feature)
         Me.m_feature = feature
         zoomLevelSet = New ZoomLevelSet()
     End Sub
     ’  This is the feature property, pretty simple.
     Public Property Feature() As Feature
         Get
             Return m_feature
         End Get
         Set(ByVal value As Feature)
             m_feature = value
         End Set
     End Property
     ’ This is the Zoom Level Set.  This high level object has all of
     ’ the logic in it for zoom levels, drawing and everything.
     Public Property ZoomLevels() As ZoomLevelSet
         Get
             Return zoomLevelSet
         End Get
         Set(ByVal value As ZoomLevelSet)
             zoomLevelSet = value
         End Set
     End Property
 End Class
 Class MapShapeLayer
     Inherits FeatureLayer
     Private m_mapShapes As Dictionary(Of String, MapShape)
     Public Sub New()
         m_mapShapes = New Dictionary(Of String, MapShape)()
     End Sub
     ’ Here is where you place all of your map shapes.
     Public ReadOnly Property MapShapes() As Dictionary(Of String, MapShape)
         Get
             Return m_mapShapes
         End Get
     End Property
     ’ This is a required overload of the Layer.  As you can see we simply
     ’ loop through all of our map shapes and then choose the correct zoom level.
     ’ After that, the zoom level class takes care of the heavy lifiting.  You
     ’ have to love how easy this framework is to re-use.
     Protected Overloads Overrides Sub DrawCore(ByVal canvas As GeoCanvas, ByVal labelsInAllLayers As Collection(Of SimpleCandidate))
         For Each mapShapeKey As String In m_mapShapes.Keys
             Dim mapShape As MapShape = m_mapShapes(mapShapeKey)
             Dim currentZoomLevel As ZoomLevel = mapShape.ZoomLevels.GetZoomLevelForDrawing(canvas.CurrentWorldExtent, canvas.Width, GeographyUnit.DecimalDegree)
             If currentZoomLevel IsNot Nothing Then
                 If canvas.CurrentWorldExtent.Intersects(mapShape.Feature.GetBoundingBox()) Then
                     currentZoomLevel.Draw(canvas, New Feature() {mapShape.Feature}, New Collection(Of SimpleCandidate)(), labelsInAllLayers)
                 End If
             End If
         Next
     End Sub
 End Class
Ewan,
I am really willing to help you, but with your code, I am very confused what you are trying to do and it absolutely cannot be compiled because it lakes many methods.
I made a sample using MapShape from our code project, in this sample, you can add MapShape when you MapClick on the MapControl.
Can you upload your sample project and paste out the exception stack trace to show your problem?
1033-MapShapesDemo.zip (29.5 KB)
