There seems to be a problem with the resizing of Virtual Earth maps. I have the width of the map set to 100% which works fine for custom overlays, i.e. the maps change size as you'd expect.
The Virtual Earth overlay doesn't seem to change size though when the map container is resized. If the map is made larger you get blank areas that aren't populated with tiles, whilst if you make the map smaller the copyright information at the bottom right of the map disappears.
I'm also changing the height of the map via script, but again the same behaviour is seen.
Is there a workaround for this?
Thanks in advance,
