I am trying to configure a web application and have set it up to use forms authentication. I have also added some controls and am now trying to add the map to my application. When I try to load the page with the web map on it I get the following exception. Anybody have any idea why I am getting this? It is like the map is trying to modify the web.config file or something. Machine is Vista 64-bit with IIS7
Curtis
body {font-family:"Verdana";font-weight:normal;font-size: .7em;color:black;}
p {font-family:"Verdana";font-weight:normal;color:black;margin-top: -5px}
b {font-family:"Verdana";font-weight:bold;color:black;margin-top: -5px}
H1 { font-family:"Verdana";font-weight:normal;font-size:18pt;color:red }
H2 { font-family:"Verdana";font-weight:normal;font-size:14pt;color:maroon }
pre {font-family:"Lucida Console";font-size: .9em}
.marker {font-weight: bold; color: black;text-decoration: none;}
.version {color: gray;}
.error {margin-bottom: 10px;}
.expandable { text-decoration:underline; font-weight:bold; color:navy; cursor:hand; }
Server Error in '/' Application.
Access to the path 'C:\inetpub\wwwroot\web.config' is denied.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.UnauthorizedAccessException: Access to the path 'C:\inetpub\wwwroot\web.config' is denied.
ASP.NET is not authorized to access the requested resource. Consider granting access rights to the resource to the ASP.NET request identity. ASP.NET has a base process identity (typically {MACHINE}\ASPNET on IIS 5 or Network Service on IIS 6) that is used if the application is not impersonating. If the application is impersonating via <identity impersonate="true"/>, the identity will be the anonymous user (typically IUSR_MACHINENAME) or the authenticated request user.
To grant ASP.NET access to a file, right-click the file in Explorer, choose "Properties" and select the Security tab. Click "Add" to add the appropriate user or group. Highlight the ASP.NET account, and check the boxes for the desired access.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.Stack Trace:
[UnauthorizedAccessException: Access to the path 'C:\inetpub\wwwroot\web.config' is denied.]
System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) +10547571
System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy) +2580
System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) +138
System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) +89
System.Xml.XmlDOMTextWriter..ctor(String filename, Encoding encoding) +63
System.Xml.XmlDocument.Save(String filename) +116
ThinkGeo.MapSuite.WebEdition.Map.x1811944f4031e215() +146
ThinkGeo.MapSuite.WebEdition.Map.OnLoad(EventArgs e) +59
System.Web.UI.Control.LoadRecursive() +66
System.Web.UI.Control.LoadRecursive() +191
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2428
