Web Edition 5.0 Daily dev Build
Hi ThinkGeo,
Web Edition 5.0 Daily build is indicated as 4.5.184 on Customer portal. (See attached picture)
Plus the size is 9.68MB.
Have a look at it and make corrections.
Anil
DailyProductionDownload.zip (13.2 KB)
Hi Anil,
 Thanks for your reporting, there are some sychronization problems in our daily build but we’ll fix it immidiately, you’ll get the right version in the end of this Friday.
 Ivan
Hi Ivan,
 Now For all builds it shows as 4.5.184 on Customer portal.
 I will check back later today or Monday.
 Regards.,
 Anil
Hi Anil,
 This will be fixed next Monday.
 Thanks for your quickly response about the problem and have a good weekend.
Hi Ivan, Don,
 The naming convention for Evaluation Daily Production Builds for May 23 has correct naming convention but not for  "My Product Download"=>Daily Dev Builds i.e licensed products
 Another problem
 - If I were to copy over Evaluation Daily Production Build  on top of my Full 5.0 licensed copy and then run my project  it gives Evaluation expire error even though I have  license. I am unable to use "Daily Development build" on my Full license copy.
 Anil
Anil,
 Thanks for your post, the Evaluation build is only desgined to run in the Evaluation environment where an expired date exsits. The full version of the map suite web edition daily build should be available on your "my product download" tab of helpdesk.thinkgeo.com.
 I just checked, and the 5.0 full version of the daily build of the web edition is available.
 Please let us know if you have any other questions.
 Thanks. I see the correct naming version on  "My Product Download"=>Daily Dev Builds i.e licensed products
Anil,
 You are welcome.
