Web Hover over feature Info
We need to get the Feature Info(Name,etc) when the mouse hovers over it
similar to the Map.Click event - where the feature info based on the clicked point coordinates. And as always the dead line sharpens it's edges :)
It would be a combination of the sample "Highlight a Feature While Hovering" and the Map.OnclientClick
Do you have a working example of such a fuctionality ?
Do you use the Page cache internally and if so, what are the cache key names to fetch features ?
Do I have to store features from different layers into the EditOverlay for Client-Server communication, currently they are in the InMemoryFeatureLayer using custom style via ValueStyle?
Hello Alex,
Here is a sample, in this sample, we show the areaname when mouse hover it, please have a look at it, I hope it can help.
Any more questions please feel free to tell me.
001_Post8789.zip (13 KB)
Hi Gary,
I really appreciate the quick response, but it is not entirely what I am trying to achive. Let me elaborate on that. Marker is a small area inside the feature( similar to the PointShape) and it triggers only when the user's cursor moves over it. I need to have an area hover, when the mouse moove enters the area from any direction just as you have in the sample "Highlight a Feature While Hovering". The information needs to be displayed in a  of a choice on the page not related to the marker's position.
I could create a transparent image with the bounding box for each feature but it is just like creating another image map - reinventing the weel.
What I want is to capture mouse coordinates on the client using jquery, then iside that method trigger the OnClientClick event on the Map control, which in turn should post back to the server as a normal Map1_Click, the Map control is wrapped inside My User control something like the below code:
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="MapHost.aspx.cs" Inherits="TestMapSuite_Web.MapHost" %>
<%@ Register Assembly="WebEdition" Namespace="ThinkGeo.MapSuite.WebEdition" TagPrefix="cc1" %>
<%@ Register src="~/Controls/Map/MapLoader.ascx" tagname="MapLoader" tagprefix="uc1" %>
    Display a Simple Map
    <script type="text/javascript" src="http://code.jquery.com/jquery-latest.js"></script>
    <script language="javascript" type="text/javascript">
        $(document).ready(function() {
            $("#map").mousemove(function(e) {
                var relativeX = e.pageX - this.offsetLeft;
                var relativeY = e.pageY - this.offsetTop;
                $('#mapTest').html('e.pageX = ' + e.pageX + ', e.pageY = ' + e.pageY + '
' + relativeX + ' ' + relativeY + '
' + screen.width + ',' + screen.height);
                OnClientClick(e);  //<-- passing event to the click function
            testMap(); // <-- or simulate the click event on the map element
        function OnClientClick(event) {
            //alert("OnClientClick: " + event.pageX);
            // If you return false, execute no more callbacks that means the server-side click event won't be triggered,
            // prevent the postback to happen
            //return false;
            var map2 = document.getElementById(Map2);
            alert("Testing Clik " + map2.clientId + " " + map2.tagName);
            return true;
        function testMap () {
            var OnMapCreated = function(map) {
            alert("Testing Clik " + map.clientId);
            //var map2 = document.getElementById('Map2');
            var el = document.getElementById(map.clientId);
            $(el).trigger("click");
 </script>
    <form> id="form1" runat="server">
      <asp:ScriptManager ID="ScriptManager1" runat="server">
    </asp:ScriptManager>
    <asp:UpdatePanel ID="UpdatePanel1" runat="server">
    <ContentTemplate>
        <uc1:MapLoader ID="MapLoader1" runat="server" OnMapClicked="MapLoader1_MapClicked"/>
    </ContentTemplate>
    </asp:UpdatePanel>
        <asp:BulletedList ID="BulletedList1" runat="server" DisplayMode="LinkButton" OnClick="BulletedList1_Click" >
            <asp:ListItem Value="#" Text="Henan"></asp:ListItem>
        </asp:BulletedList>
    </form>
------- The MapLoader Usaer Control ----
<%@ Control Language="C#" AutoEventWireup="true" CodeBehind="MapLoader.ascx.cs" Inherits="TestMapSuite_Web.Controls.Map.MapLoader" %>
    <cc1:Map ID="Map2" runat="server" Height="480px" Width="750px" OnClick="Map2_Click" OnClientClick="OnClientClick">
    </cc1:Map>
Does anybody know how to trigger the post back to the server on hover over the feature, perhaps using OpenLayers or any other technique?
Hi Alex,
 Sorry I think we don’t have an exsiting sample for show message when hover a feature.
 But I think you can get some useful information from our initHighlightOverlay function code of MapParser.js.
