WebEditition 5.0 Google layer using Key info does not work
Hi ThinkGeo,
I am using WebEditiion 5.0. When I run my page that uses Google overlay using the API Key setting then it gives JS error (See attached  image file).
However when I use following then it works ok.
add key="GoogleUriV3" value="maps.google.com/maps/api/js?sensor=false"/>
Anil
JSErrorUsingGoogleOverlay.zip (18.2 KB)
Anil,
In WebEdition 5.0, we have upgrade GoogleOverlay from v2 to v3, now it just supports v3 so you shouldn't use v2 library.
Ivan
I checked the samples and didn’t find anything with V5, could you please provide a quick sample of the few lines of code needed to add the google maps overlay with MapSuite Web V5 please ?
 Thank you very much.
Gautier,
Here is the code snippet, please check it. You don't need to set the v3 library uri because WebEdition 5.0 uses it internally.
Map1.CurrentExtent = new RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962);
GoogleOverlay google = new GoogleOverlay("Google Map");
google.GoogleMapType = GoogleMapType.Normal;
Ivan
OK just as simple as with V4.5 but simply remove the library uri !
 Thank you !
Gautier,
 You’re welcome.
 Ivan
