WFSFeatureLayer feature request
The WFSFeatureSource seems to be missing an important functionality that I find in SHPs and hope to see with ArcSDE as well: The ability to detect FeatureType.
It is probably one of the most important things to be able to tell what type of features my layer consists of. There is a URL that can return just the first feature of a layer so that it can then be consumed for analysis to determine it's type. Here is the URL for MassGIS to retrieve a single feature from a data source:
giswebservices.massgis.state...features=1
This would cut out a lot of the inherent slowness that is WFS in general.
Nelson,
Thanks for your post and ideas!
I think you can use following codes just get the type of first features as its type for WFSFeatureSource.
wfsFeatureLayer.Open();
Feature feature = wfsFeatureLayer.FeatureSource.GetFeatureById("0", ReturningColumnsType.NoColumns);
wfsFeatureLayer.Close();
WellKnownType wellKnowType = feature.GetWellKnownType();
Let me know if you still have more questions.
Yale, will this load the entire dataset from the WFS or will it grab only the first feature? The timing difference can be immense for a large or detailed set.
Nelson,
 I think it will only grab the first feature. The difference will be huge if the data set for the WFS is huge.
 Let me know if any more questions.
Great, Thanks Yale.
You are welcome! Nelson!
 Let me know if any more questions!
 Thanks again for your great suggestions.
This does not seem to work for either of the WFS I am trying to apply it to. It is likely the first ID is not 0 at all and can fluctuate altogether. We will not know the ID beforehand. Is there another way to return just the first feature? It's very important to detect the style type we need to apply to our feature source. Thanks.
Nelson,
Thanks for your post!
I have to admit this is a tough question if we have no idea about the Ids in WFS feature source.
I suggest one way to go around this problem by using the GetFeaturesInsideBoundingBox API which will query out some small portion of features, following is some code snippet you can take reference:
RectangleShape rectangle = wfsFeatureLayer.GetBoundingBox();
PointShape centerPointShape = rectangle.GetCenterPoint();
RectangleShape queryRectangle = new RectangleShape(centerPointShape.X - rectangle.Width * 0.01, centerPointShape.Y + rectangle.Height * 0.01, centerPointShape.X + rectangle.Width * 0.01, centerPointShape.Y - rectangle.Height * 0.01);
Collection<Feature> queryFeatures = wfsFeatureLayer.QueryTools.GetFeaturesInsideBoundingBox(queryRectangle, ReturningColumnsType.AllColumns);
if (queryFeatures.Count > 0)
    WellKnownType wellKnowType = queryFeatures[0].GetWellKnownType();
That is what I am saying; why not just incorporate the URL sample I provided as a means to automatically get the first feature regardless of ID? It seems like a good idea seeing as how it is a utility of WFS itself. I’d rather not hack it together…
Nelson,
I am also very strange why the Id in the WFS you provided seems random without any logic. I trying the logic with GetFeaturesInsideBoundingBox, it seems works:
WfsFeatureLayer wfsFeatureLayer = new WfsFeatureLayer(@"giswebservices.massgis.state.ma.us/geoserver/wfs", "GISDATA.COUNTIES_POLYM");
The ID is not without any logic… It is something the affect of F1__01 where F1 indicated the first layer to have been added or hosted by the WFS and two underscored followed by the index. This is the way ArcGIS Server handles hosting the WFS and there is no configurable control over this. And since the ArcSDE extension is way past deadline, this is the only way I can offer our customers the access to ArcSDE that we promised.
 So one layer may be F2__01 and another may be F9__01.
 Will your above example work if there happens to not be a feature located at the center point of the layer? I must be able to detect the type all the time and reliably, not just if there happens to be a feature located in the dead center of the layer…
Nelson,
Thanks for your post and explanation.
I am not very confident about the Id problem because I have no way to control the WFS server and I am not sure how it processes the request from client. It seems it is different with our other servers.
About the sample code provided above, it is possible return no features if there happens no features located in the dead center of the layer. If this case happened, we need to re-query with an enlarged bounding box unless one or more features returned.
Following is some code you can take reference:
private void btnGetAllFeatures_Click(object sender, EventArgs e)
            RectangleShape queryRectangle = new RectangleShape(centerPointShape.X - rectangle.Width * 0.001, centerPointShape.Y + rectangle.Height * 0.001, centerPointShape.X + rectangle.Width * 0.001, centerPointShape.Y - rectangle.Height * 0.001);
            Collection<Feature> queryFeatures = new Collection<Feature>();
            while (queryFeatures.Count == 0)
                queryRectangle.ScaleUp(50);
Let me know if you have any more questions.
You wouldn't need to have any control over the WFS.... You can use the URL parameter "maxresults=1" in the HTTP request and garuntee the return of one feature regardless of any ID issue... Did you click on the provided link in the first such post and look at it??????
Also, after re-reading your post, it seems like you are saying you are unsure about what the XML output will be from server to server? What is varying about the outputs from your servers versus the output from MassGIS? Any variance in output has always been resolved in-API so I am confused why this is different.
The proposed solution seems to be akin to throwing darts at the feature source until I hit a feature. Also, I don't feel too solid about integrating this process into my application with no garuntee of success. I feel like this should have been built into the API anyways and I don't understand why when a new FeatureSource is incorporated how this feature tends to get overlooked. Detecting the type of geometry in a featuresource is a mandatory requirement of every modern and any recollectable past GIS application and the aproach to do so just shouldn't fluctuate per programmer... It should be built in so there is no doubt it works........
Nelson,
 I agree we should add a build-in API to detect the type of the feature source, I will suggest to my direct to add a API like “FeatureType GetFeatureType” or similar in the FeatureSource.
Nelson,
I think the problem is that Yang is not familiar at all with the WMS stuff.  His knowledge is very broad but doesn’t cover that.  I think we can work through that though.  What we are going to do is to add some new methods on the abstract feature source and modify the WMS one specifically.
On FeatureSource…
public WellKnownType GetFirstFeaturesWellKnownType()
// Check if we are open etc..
//  Call the core method
protected virtual WellKnownType FeatureSource.GetFirstFeaturesWellKnownTypeCore
// Call Get All Records and then pick the first and return the type
As you can see from the name it is very specific to saying that this is the well known type of the first feature.  The reason for this is that many many features sources support tables that are no limited to on well known type.  For this reason it would be wrong and misleading to just add a FeatureType property to the feature source.
If you noticed the above in the core will get all records and then pick the first.  Of course for the WMS and other feature sources we will override this method and implement a faster version of it.
Yale,
I think you are missing Nelson’s point.  He provided a URL in the first post.  That URL has just one job which is to return one record.  That is the call we need to make in the overload on the WmsFeaturesSource for the method.  Then we use the same logic we use to parse the record that we use internally in the GetAllRecords etc.  I can discuss this with you when you get in.
Thanks for clearing that up. I likely wasn't being specific enough either...
When implementing Yang's provided code exactly, I am getting an exceptiong of: "The input double value is out of range. Parameter name: maxX"
I looked at the values and maxX did look larger than minX as I've often transposed them myself. It also took a substantial amount of time to get to that point while making the WFS call to the same machine the code was running on, but maybe that's just because of erroneous behavior.
I can't really move forward on my project at all at this point because I need to know what the feature type of the source is in order to show my users configuration that is relative to the feature source at hand. It isn't realistic for our-end users to know what the type is and select manually. They are not "in-the-know" so to speak GIS-wise. Time is really of the essence for me right now, so I'd appreciate a solution as soon as reasonably possible.
As far as getting the WellKnownType of the feature, that's completely fine; I actually have my own Enum type I need to filter down from whatever type I am being given so as long as I can discerne them I can provide myself with what I need. Thanks David and Yale.
Hi again, I noticed also it looks like you can not CloneDeep a WFSFeatureLayer. It is not marked as being serializable. I CloneDeep every layer added tomy map for use in my locus map. Can this be changed?
Thanks Nelson and David,
 We will move forward to add this new API and override it in WfsFeatureSource as soon as possible.
 I guess we can get it this week or at the beginning of next week.
 Thanks Nelson for your great ideas.
Posted By Nelson on 08-05-2009 02:24 PM
Nelson,
Thanks for your reporting!
It seems we missed to mark the WfsFeatureLayer serializable. Now we fix it.
Also, another thing I am noticing as I start utilizing this source more is that the WFSFeatureLayer.QueryTools.GetColumns is not returning to me all the available columns… I am getting 4 from a particular Zoning layer that has maybe 15?
 After doing a GetColumns, this is what my LastXMLResponse is:
 Debug.Print(layerToCheck_WFS.LastXmlResponse)
 <wfs:FeatureCollection xsi:schemaLocation=‘nelson-xp/ArcGIS/services/BrooklineWMS/MapServer/WFSServer nelson-xp/ArcGIS/services/BrooklineWMS/mapserver/WFSServer/?request=DescribeFeatureType%26version=1.0.0%26typename=Zoning opengis.net/wfs schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd’ xmlns:BrooklineWMS=‘nelson-xp/ArcGIS/services/BrooklineWMS/MapServer/WFSServer’ xmlns:gml=‘opengis.net/gml’ xmlns:wfs=‘opengis.net/wfs’ xmlns:xsi=‘w3.org/2001/XMLSchema-instance’><gml:boundedBy><gml:Box srsName=‘EPSG:2249’><gml:coordinates>743004.4375,2932567.5 762800.3125,2953433.75</gml:coordinates></gml:Box></gml:boundedBy><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__1’><BrooklineWMS:OBJECTID>1</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0(CA)</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>6</BrooklineWMS:CASE1><BrooklineWMS:CASE2>6</BrooklineW
 MS:CASE2><BrooklineWMS:ZONETYPE>G-2.0(CA)</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758349.238749996,2953253.545 758362.275625005,2953251.43187501 758414.603125006,2953242.95125 758472.986874998,2953233.48875 758501.920625001,2953229.27312499 758659.9375,2953206.25 758757.5,2953191.25 758803.5625,2953183.75 758871.367500007,2953173.30875 758926.388750002,2953164.83562499 758990.055000007,2953155.031875 759000,2953153.5 759055.654375002,2953144.89125 759119.931875005,2953134.94875 759186.310000002,2953124.68187501 759237.592500001,2953116.749375 759311.911874995,2953104.855 759332.688749999,2953102.546875 759341.526875004,2953241.90000001 758107.125,2953433.75 758088.9375,2953310.25 758087.421250001,2953310.48999999 758085.617500007,2953296.423125 758192.947500005,2953279.995 758213.796875
 ,2953275.608125 758258.075000003,2953268.31999999 758285.864374995,2953263.81625 758313.116874993,2953259.39937501 758349.238749996,2953253.545</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>175833.305797461</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2791.5231484663</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__2’><BrooklineWMS:OBJECTID>2</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>17</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gm
 l:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758349.238749996,2953253.545 758340.148750007,2953194.96312501 758332.006249994,2953142.488125 758327.678124994,2953114.59125 758323.683750004,2953088.84999999 758314.444999993,2953029.31 758301.613124996,2952949.316875 758481.991249993,2952933.51000001 758479.258125007,2952967.063125 758648.875,2952976.80562501 758632.569374993,2953046.56874999 758649.017499998,2953142.535625 758649.982500002,2953148.166875 758659.9375,2953206.25 758501.920625001,2953229.27312499 758472.986874998,2953233.48875 758414.603125006,2953242.95125 758362.275625005,2953251.43187501 758349.238749996,2953253.545</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>87946.3857273437</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1240.50460814878</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__3’><Brookline
 WMS:OBJECTID>3</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759332.688749999,2953102.546875 759325.201250002,2952984.489375 759321.776875004,2952934.02 759967.179374993,2952832.166875 760209.799374998,2952794.02562501 760513.155625001,2952747.64 760567.419375002,2952733.46187501 760921.441874996,2952679.183125 761254.303749993,2952624.42874999 761261.644374996,2952666.02625 761290.126249999,2952661.795 761538.654375002,2952627.57125001 761658.543750003,2952539.18000001 761670.253124997,2952530.486875
  761706.860624999,2952537.808125 761759.993750006,2952557.73375 761783.239999995,2952644.075625 761785.417500004,2952676.739375 761808.534999996,2952664.403125 761943.068749994,2952594.606875 762081.758750007,2952533.485 762203.916875005,2952487.895 762354.379374996,2952439.97375 762471.566249996,2952409.860625 762522.5,2952738 760881.875,2953002.5 759341.526875004,2953241.90000001 759332.688749999,2953102.546875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>955757.349821875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7258.97598789321</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__4’><BrooklineWMS:OBJECTID>4</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><
 BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757224.443124995,2952908.4175 757301.108750001,2952789.41374999 757321.405000001,2952847.44 757329.905625001,2952860.17125 757441.163124993,2952943.55500001 757460.292500004,2952959.7525 757518.820625007,2952884.61 757531.411249995,2952872.954375 757537.682500005,2952867.29125001 757541.331874996,2952863.99625 757550.906874999,2952858.035 757555.248750001,2952857.390625 757613.748125002,2952847.3775 757650.014375001,2953120.393125 757648.431250006,2953157.33812501 757639.251249999,2953204.28812499 757629.189374998,2953228.675 757609.0625,2953212.25 757544.0625,2953159.75 757451.1875,2953083.25 757355.9375,2953005 757322.125,2952977.25 757310.8125,2952968 757305.125,2952963.5 75
 7289.3125,2952952 757273.4375,2952940.5 757257.25,2952929.5 757247.6875,2952923 757224.443124995,2952908.4175</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>76938.0175</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1486.30998233724</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__5’><BrooklineWMS:OBJECTID>5</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRin
 g><gml:coordinates> 758659.9375,2953206.25 758649.982500002,2953148.166875 758649.017499998,2953142.535625 758632.569374993,2953046.56874999 758648.875,2952976.80562501 758650.093125001,2952971.5925 758659.004999995,2952933.46250001 758664.642499998,2952909.341875 758674.502499998,2952867.1575 758676.777500004,2952857.42375 758684.901250005,2952822.66625001 758690.895624995,2952797.01875 758698.155625001,2952765.9575 758706.836875007,2952733.21250001 758714.100624993,2952705.81874999 758721.329999998,2952678.55249999 758723.290625006,2952671.15625 758731.198750004,2952641.329375 758737.840000004,2952616.283125 758739.617500007,2952609.57875 758746.955624998,2952581.90125 758748.720624998,2952575.27 758752.690624997,2952560.35187501 758757.931875005,2952540.65875 758768.960624993,2952499.220625 758783.878124997,2952443.16875 758785.101249993,2952438.573125 758799.515000001,2952384.41500001 758803.646874994,2952368.890625 758814.290000007,2952328.89875001 758817.028750002,2952318.608125 758818.546250001,2952312.
 906875 758839.974374995,2952232.940625 758857.340625003,2952168.13187499 758860.925624996,2952154.755 758901.756874993,2952148.2325 758915.447500005,2952146.045625 758967.476875007,2952137.73375 758964.734999999,2952100.27375001 758960.701250002,2952045.166875 758957.870625004,2952006.486875 759014.760625005,2952003.66374999 759008.534374997,2951897.4725 759046.010000005,2951895.48999999 759350.096874997,2951881.715 759352.888750002,2951932.581875 759354.571250007,2952199.67125 759350.913124993,2952347.94875 759335.649375007,2952497.251875 759319.501874998,2952641.89375 759312.819999993,2952743.594375 759313.266874999,2952813.11812501 759321.776875004,2952934.02 759325.201250002,2952984.489375 759332.688749999,2953102.546875 759311.911874995,2953104.855 759237.592500001,2953116.749375 759186.310000002,2953124.68187501 759119.931875005,2953134.94875 759055.654375002,2953144.89125 759000,2953153.5 758990.055000007,2953155.031875 758926.388750002,2953164.83562499 758871.367500007,2953173.30875 758803.5625,2953183
 .75 758757.5,2953191.25 758659.9375,2953206.25</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>697772.438523437</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3731.6769096262</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__6’><BrooklineWMS:OBJECTID>6</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760513.155625001,2952747.64 7602
 09.799374998,2952794.02562501 759967.179374993,2952832.166875 759321.776875004,2952934.02 759313.266874999,2952813.11812501 759312.819999993,2952743.594375 759319.501874998,2952641.89375 759925.017499998,2952547.263125 760469.190624997,2952462.21125001 760473.436875001,2952489.778125 760513.155625001,2952747.64</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>342927.657453125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2950.95793194382</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__7’><BrooklineWMS:OBJECTID>7</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:D
 ATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757224.443124995,2952908.4175 757204.25,2952895.75 757190.75,2952887.75 757181.125,2952882.25 757173.75,2952878.25 757156.5,2952868.75 757153.25,2952867.25 757144.125,2952862.5 757139.125,2952859.75 757130.1875,2952855.25 757125.1875,2952852.75 757121.5625,2952851 757103.875,2952842.5 757086,2952834.5 757075.1875,2952829.75 757068,2952826.75 757049.9375,2952819 757031.75,2952812 757013.3125,2952805 757009.25,2952803.5 756994.8125,2952798.5 756976.3125,2952792.25 756957.625,2952786.5 756939.4375,2952781 756932.771874994,2952779.21125001 756989.934375003,2952645.833125 757134.709999993,2952700.28625 757169.978125006,2952719.176875 757301.108750001,2952789.41374999 757224.443124995,2952908.4175</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gm
 l:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>46610.476321875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>950.26964673429</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__8’><BrooklineWMS:OBJECTID>8</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757169.978125006,2952719.176875 757148.831874996,2952662.06937499 757137.073750004,2952627.750625 757125.535624996,2952594.075625 757114.098124996,2952560.6925 757096.0531249
 94,2952508.02312499 757134.957499996,2952498.99312501 757185.726875007,2952480.831875 757176.423749998,2952464.986875 757268.991249993,2952428.90625 757238.299374998,2952348.91 757233.979375005,2952337.19437499 757231.745000005,2952331.136875 757217.943124995,2952293.708125 757330.749375001,2952248.401875 757369.678124994,2952343.125 757383.737499997,2952384.18062501 757531.746250004,2952324.29125001 757534.996250004,2952351.76625 757558.510000005,2952434.61687499 757564.512500003,2952479.294375 757502.467500001,2952503.90000001 757492.040625006,2952507.88875 757433.196250007,2952530.30312499 757418.465625003,2952487.58437499 757370.121250004,2952507.0975 757336.706249997,2952518.17874999 757321.136250004,2952523.341875 757304.431250006,2952528.88187499 757272.578749999,2952539.44499999 757221.431875005,2952556.980625 757301.108750001,2952789.41374999 757169.978125006,2952719.176875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape
 ><BrooklineWMS:Shape.area>92020.8035296875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1955.24217349066</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__9’><BrooklineWMS:OBJECTID>9</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 761538.654375002,2952627.57125001 761290.126249999,2952661.795 761261.644374996,2952666.02625 761254.303749993,2952624.42874999 760921.441874996,2952679.183125 760567.419375002,2952733.46187501 760513.155625001,29
 52747.64 760473.436875001,2952489.778125 760469.190624997,2952462.21125001 760425.196875006,2952176.595 760355.59375,2951724.465625 760350.846249998,2951694.26000001 760348.031874999,2951621.315 760351.739374995,2951586.13437501 760358.873125002,2951555.05687501 760597.144374996,2950926.763125 760750.221249998,2950984.73 760832.547499999,2951016.139375 760889.116249993,2951037.7225 760973.0625,2951069.75 761003.170625001,2951081.03812499 761010.146249995,2951086.72499999 761051.28125,2951094.23875 761110.510000005,2951116.16249999 761189.541875005,2951145.41625001 761268.969999999,2951174.8175 761288.733750001,2951182.13312501 761346.569999993,2951203.541875 761367.209999993,2951211.18187501 761446.206874996,2951240.423125 761524.370000005,2951269.355625 761529.161874995,2951271.13 761572.430000007,2951287.145625 761602.890000001,2951298.420625 761746.065624997,2951351.190625 761747.147499993,2951351.46125001 761771.844999999,2951359.269375 761770.559375003,2951402.1275 761794.791875005,2951404.32375 761890.71
 8125001,2951424.08374999 761898.475624993,2951472.53937501 761962.198750004,2951495.783125 761939.010625005,2951557.5975 761942.531874999,2951556.91374999 761976.243750006,2951550.36937501 762005.1875,2951544.75 762008.763125002,2951580.701875 762011.335624993,2951606.561875 762013.096874997,2951624.2675 762041.210624993,2951620.02562501 762066.069999993,2951616.27437501 762091.079999998,2951612.500625 762116.358750001,2951608.686875 762123.481875002,2951607.611875 762143.940624997,2951604.52500001 762219.987499997,2951593.050625 762235.131874993,2951689.265625 762231.028125003,2951689.691875 762233.393749997,2951705.75687499 762237.851875007,2951705.231875 762242.858750001,2951734.0775 762244.575625002,2951754.2925 762227.781874999,2951756.9325 762232.646874994,2951775.951875 762245.928749993,2951858.62375 762253.101875007,2951903.310625 762230.014375001,2951906.93875 762210.816874996,2951909.95625 762190.975624993,2951913.074375 762150.705624998,2951919.403125 762113.001249999,2951925.328125 762074.440624997
 ,2951931.388125 762025.436250001,2951939.09 762045.483750001,2952067.340625 762047.888125002,2952105.94562501 762067.451875001,2952223.12 762089.415625006,2952219.61562499 762106.499375001,2952326.419375 762109.837500006,2952358.10625 761951.173124999,2952382.73875 761892.501249999,2952391.655 761852.546875,2952401.82125001 761759.993750006,2952557.73375 761706.860624999,2952537.808125 761670.253124997,2952530.486875 761658.543750003,2952539.18000001 761538.654375002,2952627.57125001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>2369039.02837656</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6626.61785206605</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__10’><BrooklineWMS:OBJECTID>10</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL B
 USINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756342.488124996,2952187.50749999 756597.945625007,2952313.659375 756598.246250004,2952316.22437499 756642.048749998,2952302.203125 756648.828125,2952324.49875 756702.830624998,2952316.581875 756705.058750004,2952332.83 756711.241249993,2952377.91249999 756717.594999999,2952424.24437501 756723.736874998,2952469.029375 756730.045000002,2952515.0275 756736.444999993,2952561.69625001 756742.543750003,2952606.16875 756761.65625,2952743.41312499 756752.75,2952742.25 756727.625,2952739.5 756706.6875,2952737.25 756681.0625,2952734.75 756654.25,2952732.5 756608.1875,2952729.25 756566.5625,2952726.5 756566,2952706.
 75 756564.25,2952695.5 756562.6875,2952687 756561.0625,2952679.5 756559.0625,2952671 756556.6875,2952662 756554.4375,2952654.5 756550.625,2952642.75 756546.5625,2952631.5 756540.8125,2952617.75 756534.375,2952603.75 756528.1875,2952591.75 756519.1875,2952576.25 756509.125,2952561 756500.5,2952549 756489.25,2952534.75 756475.0625,2952519 756462.75,2952506.75 756451.625,2952496.75 756436.375,2952484.5 756420.125,2952472.75 756396.8125,2952457.75 756378.9375,2952446.25 756350.4375,2952428 756328.0625,2952413.75 756304.9375,2952399 756291.4375,2952390.25 756259.322500005,2952369.53687499 756342.488124996,2952187.50749999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>140450.446285156</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1733.02398370811</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__11’><BrooklineWMS:OBJECTID>11</BrooklineWMS:OBJ
 ECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758768.960624993,2952499.220625 758757.931875005,2952540.65875 758752.690624997,2952560.35187501 758748.720624998,2952575.27 758746.955624998,2952581.90125 758739.617500007,2952609.57875 758737.840000004,2952616.283125 758731.198750004,2952641.329375 758723.290625006,2952671.15625 758721.329999998,2952678.55249999 758714.100624993,2952705.81874999 758518.266249999,2952675.395625 758547.448125005,2952467.466875 758768.960624993,2952499.220625</gml:coordinates></gml:LinearR
 ing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>44551.5578898438</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>845.684672806077</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__12’><BrooklineWMS:OBJECTID>12</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 762471.566249996,2952409.860625 762354.379374996,2952439.97375 762203.916875005,2952487.895 762081.7587500
 07,2952533.485 761943.068749994,2952594.606875 761808.534999996,2952664.403125 761785.417500004,2952676.739375 761783.239999995,2952644.075625 761759.993750006,2952557.73375 761852.546875,2952401.82125001 761892.501249999,2952391.655 761951.173124999,2952382.73875 762109.837500006,2952358.10625 762106.499375001,2952326.419375 762089.415625006,2952219.61562499 762067.451875001,2952223.12 762047.888125002,2952105.94562501 762045.483750001,2952067.340625 762025.436250001,2951939.09 762074.440624997,2951931.388125 762113.001249999,2951925.328125 762150.705624998,2951919.403125 762190.975624993,2951913.074375 762210.816874996,2951909.95625 762230.014375001,2951906.93875 762253.101875007,2951903.310625 762245.928749993,2951858.62375 762232.646874994,2951775.951875 762227.781874999,2951756.9325 762244.575625002,2951754.2925 762242.858750001,2951734.0775 762237.851875007,2951705.231875 762233.393749997,2951705.75687499 762231.028125003,2951689.691875 762235.131874993,2951689.265625 762219.987499997,2951593.050625 7622
 50.551249996,2951588.43875 762401.957499996,2951644.95125 762367.125,2951737 762471.566249996,2952409.860625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>309930.21074375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3292.52729624449</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__13’><BrooklineWMS:OBJECTID>13</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs> ml:LinearRing><gml:coordinates> 760469.190624997,2952462.21125001 759925.017499998,2952547.263125 759319.501874998,2952641.89375 759335.649375007,2952497.251875 759350.913124993,2952347.94875 759445.263125002,2952329.801875 759878.623125002,2952262.74375001 759807.135000005,2951811.67625 760063.069999993,2951771.36 760355.59375,2951724.465625 760425.196875006,2952176.595 760469.190624997,2952462.21125001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>577828.50739375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3752.35090338448</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__14’><BrooklineWMS:OBJECTID>14</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><Brooklin
 eWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756342.488124996,2952187.50749999 756259.322500005,2952369.53687499 756032.683125004,2952223.359375 756128.380624995,2952098.864375 756197.533124998,2952150.4975 756244.247500002,2952087.55 756265.566249996,2952059.51375 756365.871875003,2952136.326875 756342.488124996,2952187.50749999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>53146.83251875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1009.36353474579</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__15’><BrooklineWMS:OBJECTID>15</BrooklineWMS:OBJECTID>
 ooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759350.096874997,2951881.715 759342.940624997,2951773.486875 759339.433750004,2951720.44687501 759337.403125003,2951691.12625 759328.036249995,2951556.95375 759605.903125003,2951514.669375 759655.650000006,2951834.56812499 759807.135000005,2951811.67625 759878.623125002,2952262.74375001 759445.263125002,2952329.801875 759350.913124993,2952347.94875 759354.571250007,2952199.67125 759352.888750002,2951932.581875 759350.096874997,2951881.715</gml:coordinates></gml:LinearRing></gml:ou
 terBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>322279.527939063</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2541.17947220844</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__16’><BrooklineWMS:OBJECTID>16</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757751.259375006,2952058.121875 757735.851875007,2952197.96187501 757726.368125007,2952244.38062499 757695.653125003,2
 952261.57187501 757531.746250004,2952324.29125001 757538.578125,2952207.08625001 757537.708749995,2952180.68062501 757421.580624998,2952181.22375 757414.430000007,2952149.79062501 757410.635000005,2952133.17 757406.819999993,2952116.465625 757399.064374998,2952082.50375 757398.194374993,2952078.69499999 757391.333124995,2952048.64812499 757385.647499993,2952023.99312501 757381.828125,2952014.424375 757371.462500006,2951988.451875 757492.046875,2951942.21125001 757488.553749993,2951931.38249999 757482.653125003,2951918.925625 757602.739999995,2951872.340625 757616.547499999,2951900.90375 757618.701250002,2951917.78 757620.227500007,2951929.739375 757623.697500005,2951956.93125001 757757.011250004,2951921.611875 757760.584374994,2951973.48999999 757751.259375006,2952058.121875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>109546.543284375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1504.64458491268</
 BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__17’><BrooklineWMS:OBJECTID>17</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757751.259375006,2952058.121875 757836.146249995,2951995.89937501 757963.458749995,2951903.675625 757977.880624995,2951922.42 757988.199375004,2951935.831875 758021.259375006,2951978.8 758075.589375004,2952042.311875 758090.446875006,2952059.68000001 758125.421875,2952107.03687499 758161.832499996,2952156.33687501
  758149.913124993,2952160.72375 758092.747500002,2952181.765 758086.103750005,2952184.21062499 758050.104375005,2952197.46125001 758036.989374995,2952202.28874999 758012.679374993,2952211.236875 757975.574375004,2952224.89375 757971.403125003,2952226.42937499 757941.012500003,2952237.61562499 757906.134375006,2952250.453125 757897.968125001,2952253.45874999 757855.955624998,2952130.21375 757834.521874994,2952143.268125 757789.21875,2952178.56999999 757726.368125007,2952244.38062499 757735.851875007,2952197.96187501 757751.259375006,2952058.121875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>80021.6661671875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1356.81249524698</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__18’><BrooklineWMS:OBJECTID>18</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:
 SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758889.239999995,2951902.77500001 759000,2951897.924375 759008.534374997,2951897.4725 759014.760625005,2952003.66374999 758957.870625004,2952006.486875 758960.701250002,2952045.166875 758964.734999999,2952100.27375001 758967.476875007,2952137.73375 758915.447500005,2952146.045625 758901.756874993,2952148.2325 758860.925624996,2952154.755 758857.340625003,2952168.13187499 758799.939374998,2952161.8725 758737.769374996,2952155.093125 758682.128749996,2952149.02562501 758597.461250007,2952139.136875 758602.374375001,2952088.94875 758604.48062500
 4,2952058.765625 758605.358125001,2952033.52249999 758601.046250001,2952004.406875 758593.763125002,2951974.955625 758376.563124999,2952006.651875 758367.976875007,2951973.52187499 758360.571875006,2951944.95375 758357.998125002,2951935.02375001 758350.243750006,2951905.10312501 758342.323125005,2951874.54375 758332.575625002,2951836.935625 758319.973749995,2951788.311875 758317.672499999,2951779.434375 758308.808750004,2951745.234375 758297.016874999,2951699.739375 758284.65625,2951652.046875 758498.969374999,2951597.344375 758562.666250005,2951849.205625 758743.310625002,2951902.958125 758775.200000003,2951907.76875 758889.239999995,2951902.77500001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>183793.192066406</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2364.97241243962</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__19’><Brookli
 neWMS:OBJECTID>19</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>THREE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>F-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED>10/03/07</BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>PK/OK Planning4/12/07Amendmant</BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758889.239999995,2951902.77500001 758890.871875003,2951822.91437501 758892.992500007,2951769.6275 758894.578749999,2951729.783125 758894.901250005,2951719.059375 758896.700000003,2951659.25624999 758896.835624993,2951654.75624999 758897.958124995,2951617.46125001 758898.566874996,2951597.22 758899.091875002,2951579.7625 758899.980000004,2951550.25375 758900.203749999,2951542.814375 758901.284999996,295150
 6.871875 758901.413124993,2951502.60375001 758902.483125001,2951467.049375 758902.912499994,2951452.765 758903.633750007,2951428.785625 758904.468125001,2951401.06 758904.845624998,2951388.520625 758905.456874996,2951368.19 758894.073125005,2951351.0325 758891.235624999,2951346.75624999 758868.309375003,2951312.204375 758845.303749993,2951277.53375 758841.300624996,2951271.5 758877.808125004,2951250.63875 758909.125624999,2951232.74250001 759024.236874998,2951294.70999999 759028.370000005,2951286.79000001 759044.858125001,2951277.55312499 759149.521874994,2951269.96625 759157.411874995,2951379.52437501 759159.646249995,2951413.14687499 759160.079999998,2951419.670625 759161.731875002,2951444.534375 759162.740624994,2951459.715625 759164.094374999,2951480.09125 759165.418125004,2951500.010625 759166.442499995,2951515.42375 759168.105625004,2951540.4575 759168.508125007,2951546.510625 759170.485624999,2951576.278125 759170.696875006,2951579.455625 759173.366874993,2951619.63375001 759175.868750006,2951657.289375
 01 759178.495625004,2951696.81812499 759178.655625001,2951699.22437499 759181.298124999,2951738.98875 759184.036249995,2951780.200625 759229.913749993,2951778.21062499 759342.940624997,2951773.486875 759350.096874997,2951881.715 759046.010000005,2951895.48999999 759008.534374997,2951897.4725 759000,2951897.924375 758889.239999995,2951902.77500001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>192126.9247</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2232.74902541003</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__20’><BrooklineWMS:OBJECTID>20</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0<
 /BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759605.903125003,2951514.669375 759328.036249995,2951556.95375 759307.203125,2951258.535625 759523.181250006,2951228.666875 759560.986874998,2951225.831875 759759.046875,2951195.78 759817.438124999,2951568.66625001 759807.135000005,2951811.67625 759655.650000006,2951834.56812499 759605.903125003,2951514.669375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>197466.0844625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2134.08988476124</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__21’><BrooklineWMS:OBJECTID>21</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>SC-7</BrooklineWMS
 :ZTYPEOLD><BrooklineWMS:SYMBOL>17</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>TWO-FAMILY & ATTACHED SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>27</BrooklineWMS:CASE1><BrooklineWMS:CASE2>26</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>SC-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759807.135000005,2951811.67625 759817.438124999,2951568.66625001 759759.046875,2951195.78 759916.709999993,2951170.40625 760185.753124997,2951127.1075 760271.661249995,2950973.69625001 760314.587500006,2950894.35187501 760346.973124996,2950840.02500001 760350.051874995,2950832.12625 760413.900000006,2950857.718125 760431.523750007,2950864.33687501 760441.391249999,2950868.0425 760460.941874996,2950875.38437501 760479.646874994,2950882.40875 760571.962500006,2950917.22750001 760597.144374996,295092
 6.763125 760358.873125002,2951555.05687501 760351.739374995,2951586.13437501 760348.031874999,2951621.315 760350.846249998,2951694.26000001 760355.59375,2951724.465625 760063.069999993,2951771.36 759807.135000005,2951811.67625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>459134.763546875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3053.37012062292</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__22’><BrooklineWMS:OBJECTID>22</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:
 NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759328.036249995,2951556.95375 759337.403125003,2951691.12625 759339.433750004,2951720.44687501 759342.940624997,2951773.486875 759229.913749993,2951778.21062499 759184.036249995,2951780.200625 759181.298124999,2951738.98875 759178.655625001,2951699.22437499 759178.495625004,2951696.81812499 759175.868750006,2951657.28937501 759173.366874993,2951619.63375001 759170.696875006,2951579.455625 759170.485624999,2951576.278125 759168.508125007,2951546.510625 759168.105625004,2951540.4575 759166.442499995,2951515.42375 759165.418125004,2951500.010625 759164.094374999,2951480.09125 759162.740624994,2951459.715625 759161.731875002,2951444.534375 759160.079999998,2951419.670625 759159.646249995,2951413.14687499 759157.411874995,2951379.52437501 759149.521874994,2951269.96625 759044.858125001,2951277.55312499 759028.370000005,2951286.79000001 759024.236874998,2951294.70999
 999 758909.125624999,2951232.74250001 758877.808125004,2951250.63875 758841.300624996,2951271.5 758845.303749993,2951277.53375 758812.452500001,2951298.32062501 758802.041250005,2951283.2775 758759.012500003,2951298.020625 758688.083749995,2951320.26000001 758674.581874996,2951266.13437501 758663.058750004,2951251.78 758647.885625005,2951241.955 758874.200000003,2951082.46312501 758895.735624999,2951068.925 758978.960624993,2951192.72812501 759009.881249994,2951172.62625 759041.879374996,2951151.824375 759053.366874993,2951144.35625 759079.979375005,2951127.05500001 759111.375,2951106.64812499 759158.778750002,2951079.878125 759264.803749993,2951017.638125 759228.795625001,2950897.3475 759355.374375001,2950882.861875 759340.756249994,2950756.173125 759195.568124995,2950823.465625 759152.695625007,2950733.316875 759041.211250007,2950816.503125 759013.626874998,2950836.784375 758988.447500005,2950793.08750001 758958.903750002,2950741.816875 758928.045625001,2950688.26375 758899.949375004,2950639.504375 758876.40
 2500004,2950598.64 759045.833124995,2950515.76375 759000,2950424.613125 758984.329374999,2950393.44750001 759099.836250007,2950341.264375 759175.699375004,2950370.21187501 759253.565624997,2950399.923125 759257.524375007,2950401.43375 759364.126874998,2950441.716875 759440.060000002,2950244.439375 759615.486249998,2950310.143125 759659.297499999,2950326.22750001 759668.084374994,2950397.45999999 759691.083749995,2950593.78625 759856.633125007,2950655.635625 760346.973124996,2950840.02500001 760316.498125002,2950890.8775 760271.661249995,2950973.69625001 759880.763750002,2950828.40375 759876.243125007,2950865.76125 759901.149375007,2951058.370625 759916.709999993,2951170.40625 759759.046875,2951195.78 759560.986874998,2951225.831875 759523.181250006,2951228.666875 759307.203125,2951258.535625 759328.036249995,2951556.95375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>853342.945359375</BrooklineWMS:Shape
 .area><BrooklineWMS:Shape.len>7361.9187737815</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__23’><BrooklineWMS:OBJECTID>23</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 762401.957499996,2951644.95125 762250.551249996,2951588.43875 762136.676249996,2951543.10625 762104.002499998,2951530.09937499 762078.155625001,2951533.574375 762053.968125001,2951537.27875 762028.001249999,2951541.25624999 762005.1875,2951544.75 761976.243750006,2951550.3
 6937501 761942.531874999,2951556.91374999 761939.010625005,2951557.5975 761962.198750004,2951495.783125 761898.475624993,2951472.53937501 761890.718125001,2951424.08374999 761794.791875005,2951404.32375 761770.559375003,2951402.1275 761771.844999999,2951359.269375 761776.204999998,2951330.076875 761822.471874997,2951207.535 761838.571250007,2951167.394375 762336.993750006,2951351.995 762395.965000004,2951184.20874999 762391.658749998,2951182.249375 762392.743750006,2951176.673125 762398.967500001,2951178.92749999 762423.912499994,2951187.964375 762470.713750005,2951204.918125 762556.856250003,2951235.613125 762401.957499996,2951644.95125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>208763.69169375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2370.28817182704</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__24’><BrooklineWMS:OBJECTID>
 24</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 762250.551249996,2951588.43875 762219.987499997,2951593.050625 762143.940624997,2951604.52500001 762123.481875002,2951607.611875 762116.358750001,2951608.686875 762091.079999998,2951612.500625 762066.069999993,2951616.27437501 762041.210624993,2951620.02562501 762013.096874997,2951624.2675 762011.335624993,2951606.561875 762008.763125002,2951580.701875 762005.1875,2951544.75 762028.001249999,2951541.25624999 762053.968125001,2951537.27875 762078.155625
 001,2951533.574375 762104.002499998,2951530.09937499 762136.676249996,2951543.10625 762250.551249996,2951588.43875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>13556.17919375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>577.684521363072</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__25’><BrooklineWMS:OBJECTID>25</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>31</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Po
 lygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754683.671250001,2951213.3075 754732.861874998,2951162.730625 754748.090000004,2951178.19312499 754792.950000003,2951132.39937501 754783.557500005,2951123.11375 754828.588125005,2951103.2075 754873.156874999,2951083.504375 754918.676874995,2951063.38124999 754936.364999995,2951055.561875 754942.963750005,2951053.075625 754954.935000002,2951048.565 754993.360624999,2951034.08687501 755039.418125004,2951016.7325 755047.692499995,2951013.614375 755079.171250001,2951001.75375 755096.668750003,2950995.160625 755143.799374998,2950977.4025 755197.123125002,2950958.7925 755204.528750002,2950956.1825 755240.979375005,2950943.33374999 755255.464375004,2950938.22812501 755284.855000004,2950927.86812501 755307.636250004,2950919.83875 755348.603125006,2950905.39812499 755359.253124997,2950901.644375 755411.366249993,2950883.27562501 755413.518124998,2950882.516875 755475.853125006,2950860.545 755525.364374995,2950843.093125 755540.014375001,2950837.92874999 75557
 3.631874993,2950826.079375 755605.403125003,2950814.88062499 755621.878749996,2950809.073125 755670.033749998,2950792.09937499 755733.309375003,2950769.795625 755735.564374998,2950769.000625 755796.644999996,2950747.470625 755798.972499996,2950746.65000001 755861.583124995,2950724.58125 755870.655625001,2950720.203125 755920.398750007,2950698.38 755927.546875,2950695.24437501 755971.656874999,2950675.8925 755991.915625006,2950667.005 756023.348124996,2950653.215 756050.299999997,2950636.77 756061.983125001,2950629.61125 756103.058750004,2950604.44125 756106.636250004,2950602.24875 756143.25,2950579.81375 756162.025625005,2950568.30875 756184.321250007,2950554.64687499 756215.083749995,2950535.796875 756221.6875,2950531.75 756266.100624993,2950500.013125 756307.705624998,2950470.2825 756318.459999993,2950462.598125 756356.870000005,2950412.13187499 756366.584999993,2950399.69125 756398.361249998,2950359.003125 756402.243750006,2950354.764375 756433.796250001,2950322.11875001 756446.243125007,2950309.24062499 75
 6473.343125001,2950281.20125 756486.448125005,2950267.6425 756514.630624995,2950238.48375 756581.030000001,2950288.2025 756597.035624996,2950299.035625 756589.826875001,2950308.298125 756528.448125005,2950396.67812499 756509.478125006,2950438.14624999 756506.078125,2950462.81125 756509.918750003,2950493.52187499 756529.369375005,2950525.85312501 756430.045000002,2950595.74124999 756444.828125,2950614.78687499 756463.729375005,2950642.41187499 756485.341250002,2950673.9975 756507.314999998,2950706.1125 756508.860624999,2950708.371875 756463.150625005,2950740.513125 756423.717500001,2950698.51000001 756401.528750002,2950718.861875 756416.019999996,2950734.55374999 756375.314999998,2950772.0775 756347.732500002,2950802.904375 756318.405000001,2950831.02375001 756313.625,2950826.4875 756280.540000007,2950857.28749999 756296.903750002,2950874.58562499 756232.405625001,2950933.683125 756218.361249998,2950947.35187501 756176.691249996,2950901.596875 756163.890000001,2950916.690625 756101.143749997,2950975.54000001 75
 6089.558125004,2950962.99625 756051.653750002,2950997.15625 756041.748125002,2951000.80500001 755997.760625005,2951017.00875001 755942.766874999,2951037.266875 755886.282499999,2951058.07375 755834.974374995,2951076.97437499 755829.981875002,2951078.813125 755773.598749995,2951098.699375 755767.760000005,2951100.75875001 755720.139375001,2951117.55374999 755711.866874993,2951120.47125 755677.381249994,2951132.63437501 755661.659999996,2951138.27562501 755656.971874997,2951139.958125 755606.370625004,2951158.11624999 755596.483125001,2951161.66437501 755549.789375007,2951178.420625 755545.476875007,2951179.968125 755506.086250007,2951194.10375001 755492.659999996,2951198.96375 755483.334999993,2951202.339375 755434.549999997,2951219.999375 755385.314999998,2951237.82187501 755378.206249997,2951240.395 755354,2951249.1575 755337.454374999,2951255.13249999 755318.019374996,2951262.15062501 755287.012500003,2951273.348125 755265.126249999,2951281.251875 755241.349999994,2951289.83812501 755209.766874999,2951301.24
 375001 755194.511875004,2951306.7525 755155.771874994,2951320.74250001 755147.496875003,2951323.730625 755100.794375002,2951340.72875001 755052.378124997,2951363.371875 755002.060000002,2951386.90375 754996.254999995,2951389.61875001 754950.469999999,2951411.03125 754916.867500007,2951430.730625 754763,2951300.5 754683.671250001,2951213.3075</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>619746.800578125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5021.90046578571</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__26’><BrooklineWMS:OBJECTID>26</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0<
 /BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 761771.844999999,2951359.269375 761747.147499993,2951351.46125001 761746.065624997,2951351.190625 761602.890000001,2951298.420625 761572.430000007,2951287.145625 761529.161874995,2951271.13 761524.370000005,2951269.355625 761446.206874996,2951240.423125 761367.209999993,2951211.18187501 761346.569999993,2951203.541875 761288.733750001,2951182.13312501 761268.969999999,2951174.8175 761189.541875005,2951145.41625001 761110.510000005,2951116.16249999 761051.28125,2951094.23875 761010.146249995,2951086.72499999 760985.893749997,2950868.45625 761071.999375001,2950642.03125 761074.788124993,2950643.064375 761099.983750001,2950576.58374999 761273.041250005,2950641.9175 761448.161874995,2950705.98 761415.317499995,2950791.44625001 761471.800624996,2950814
 .60375001 761492.958124995,2950822.6075 761514.780000001,2950830.8625 761536.608750001,2950839.120625 761552.298124999,2950845.05625001 761558.693749994,2950847.47562499 761579.269374996,2950855.25937501 761601.306875005,2950863.59625 761623.594999999,2950872.028125 761640.739999995,2950893.56 761652.793750003,2950908.69750001 761653.6875,2950915.25 761657.069999993,2950916.53 761679.167500004,2950924.894375 761700.380624995,2950932.92375 761722.426249996,2950941.268125 761743.061250001,2950949.07875 761764.895624995,2950957.343125 761769.747500002,2950959.18000001 761798.034999996,2950881.21187501 761834.308125004,2950786.44125 761963.946875006,2950835.24875 762102.101249993,2950887.424375 762083.411249995,2950941.72437499 762075.020624995,2950963.74875 762066.800624996,2950985.32375 762058.689999998,2951006.61375 762045.875,2951040.25 762043.569999993,2951050.1825 762078.745000005,2951062.925 762112.671875,2951075.215625 762143.932500005,2951086.53937501 762168.765000001,2951095.535625 762174.063124999,29510
 97.455 762200.711250007,2951107.108125 762221.943749994,2951114.8 762243.814374998,2951122.7225 762265.696875006,2951130.65000001 762281.271249995,2951136.29125001 762286.713750005,2951138.263125 762309.601249993,2951146.55437499 762331.796875,2951154.594375 762351.139375001,2951161.60187501 762353.550624996,2951162.47499999 762375.518749997,2951170.433125 762392.743750006,2951176.673125 762391.658749998,2951182.249375 762395.965000004,2951184.20874999 762336.993750006,2951351.995 761838.571250007,2951167.394375 761822.471874997,2951207.535 761776.204999998,2951330.076875 761771.844999999,2951359.269375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>533120.811828125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4148.03950248567</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__27’><BrooklineWMS:OBJECTID>27</BrooklineWMS:OBJECTID><Brookli
 neWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758794.622500002,2950405.873125 758760.803749993,2950422.425 758581.558750004,2950508.784375 758519.993750006,2950537.36499999 758403.338125005,2950584.268125 758235.043750003,2950697.653125 758270.600624993,2950754.761875 758289.109999999,2950791.32625 758316.423749998,2950859.75125 758390.146874994,2951164.72125 758404.197500005,2951222.608125 758411.537499994,2951251.63249999 758386.083749995,2951258.74437501 758309.746250004,2951277.479375 758285.545625001,2951283.419375 758263.974
 374995,2951288.71375 758195.199375004,2951305.593125 758180.775625005,2951309.06 758164.191874996,2951240.989375 758154.651250005,2951201.829375 758118.407499999,2951053.064375 758100.086875007,2950977.86875001 758083.727500007,2950910.72 758073.278125003,2950867.83 758057.018124998,2950801.09 758044.022499993,2950747.745625 757932.230000004,2950627.91500001 758100.931250006,2950512.33687501 758114.191874996,2950531.00125 758199.698750004,2950471.27124999 758261.441249996,2950426.84125 758265.385000005,2950432.48375 758312.443749994,2950399.33875 758350.419375002,2950372.590625 758360.946875006,2950365.175625 758442.669375002,2950305.35250001 758431.361249998,2950288.9375 758534.866249993,2950218.705 758551.118125007,2950243.394375 758569.873125002,2950271.88625 758589.219374999,2950301.2775 758608.666875005,2950330.82125001 758684.696875006,2950279.109375 758689,2950288 758726.375,2950269.5 758794.622500002,2950405.873125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMembe
 r></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>310944.456748437</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3405.84609230497</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__28’><BrooklineWMS:OBJECTID>28</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 762556.856250003,2951235.613125 762470.713750005,2951204.918125 762423.912499994,2951187.964375 762398.967500001,2951178.92749999 762392.743
 750006,2951176.673125 762375.518749997,2951170.433125 762353.550624996,2951162.47499999 762351.139375001,2951161.60187501 762331.796875,2951154.594375 762309.601249993,2951146.55437499 762286.713750005,2951138.263125 762281.271249995,2951136.29125001 762265.696875006,2951130.65000001 762243.814374998,2951122.7225 762221.943749994,2951114.8 762200.711250007,2951107.108125 762174.063124999,2951097.455 762168.765000001,2951095.535625 762143.932500005,2951086.53937501 762112.671875,2951075.215625 762078.745000005,2951062.925 762043.569999993,2951050.1825 762045.875,2951040.25 762058.689999998,2951006.61375 762066.800624996,2950985.32375 762075.020624995,2950963.74875 762083.411249995,2950941.72437499 762102.101249993,2950887.424375 761963.946875006,2950835.24875 762108.856250003,2950453.903125 762174.192499995,2950333.97125 762274.920000002,2950167.140625 762509.4375,2950311.25 762629.755624995,2950427.483125 762536.156874999,2950674.643125 762534.233750001,2950680.21875 762503.400000006,2950769.638125 762464.0912
 50002,2950872.82250001 762431.334374994,2950959.62875 762411.883125007,2951004.515625 762594.785624996,2951073.74437501 762615.064374998,2951081.79125001 762556.856250003,2951235.613125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>416282.6451125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3047.18546294015</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__29’><BrooklineWMS:OBJECTID>29</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsNa
 me=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754683.671250001,2951213.3075 753862.129374996,2950310.33374999 753869.595624998,2950304.61624999 753915.126874998,2950259.32375 753949.673749998,2950293.845 753958.459374994,2950302.62375 753983.742500007,2950327.88875 754031.659999996,2950282.61499999 754060.814999998,2950255.06937499 754076.644374996,2950226.263125 754080.991249993,2950223.61125 754160.778125003,2950135.925 754206.768124998,2950091.33499999 754246.116874993,2950060.97 754458.280625001,2949914.266875 754462.273124993,2949922.65875 754522.831874996,2950043.641875 754530.889375001,2950063.498125 754585.908124998,2950023.28375 754632.033749998,2949998.71625 754680.900000006,2949980.185 754775.481250003,2949954.10062499 754764.338750005,2949936.36937501 754735.089375004,2949899.469375 754807.206249997,2949860.36499999 754808.705624998,2949862.285 754881.549374998,2949806.513125 754906.159999996,2949790.770625 754917.960624993,2949769.75687499 75
 5009.125,2949689.64 755103.203125,2949601.31 755124.206874996,2949585.69374999 755170.206874996,2949563.486875 755298.291875005,2949522.04875 755308.061250001,2949514.433125 755309.751874998,2949507.58687501 755342.465000004,2949682.7825 755300.034374997,2949687.99312501 755273.235624999,2949694.6925 755278.789375007,2949712.9675 755318.533124998,2949873.42874999 755280.830624998,2949882.388125 755289.717500001,2949914.276875 755317.917500004,2950015.47499999 755322.876874998,2950035.03937501 755515.123125002,2949984.343125 755576.394999996,2949973.99187499 756001.916875005,2949922.964375 755996.048124999,2949905.358125 755987.859999999,2949879.30374999 755966.272499993,2949848.03937501 755988.215625003,2949840.17375 756064.464375004,2949795.9425 756074.856875002,2949789.91374999 756071.826875001,2949759.013125 756065.553124994,2949695.03937501 756116.180625007,2949694 756135.597499996,2949693.60124999 756194.325625002,2949692.395 756215.373750001,2949691.96312501 756217.780000001,2949684.52187499 756260.59687
 4997,2949689.205625 756316.156874999,2949695.28375 756322.3125,2949676 756363.159999996,2949676.26000001 756412.290625006,2949676.57187501 756417.559375003,2949698.408125 756442.969999999,2949698.27312499 756465.152500004,2949708.09937499 756483.673749998,2949712.95 756490.304374993,2949709.268125 756510.120625004,2949691.923125 756536.742500007,2949659.46375 756543.834999993,2949650.92 756554.573125005,2949633.96375 756611.109999999,2949667.82875 756638.216875002,2949687.79625 756667.571875006,2949721.688125 756669.225624993,2949725.14624999 756687.758125007,2949763.908125 756575.388125002,2949791.14812499 756579.727500007,2949811.42 756588.853750005,2949853.9375 756568.043125004,2949895.93062501 756531.791250005,2949931.25875001 756535.019999996,2949948.38187499 756530.711875007,2949973.613125 756513.938124999,2949977.90000001 756516.258125007,2949994.8275 756484.998125002,2950003.783125 756473.273124993,2949990.218125 756403.386250004,2950013.5475 756379.155625001,2950021.635625 756458.877499998,2950116.815
  756474.406874999,2950130.855625 756448.260625005,2950152.91625001 756459.986874998,2950169.64937501 756514.630624995,2950238.48375 756486.448125005,2950267.6425 756473.343125001,2950281.20125 756446.243125007,2950309.24062499 756433.796250001,2950322.11875001 756402.243750006,2950354.764375 756398.361249998,2950359.003125 756366.584999993,2950399.69125 756356.870000005,2950412.13187499 756318.459999993,2950462.598125 756307.705624998,2950470.2825 756266.100624993,2950500.013125 756221.6875,2950531.75 756215.083749995,2950535.796875 756184.321250007,2950554.64687499 756162.025625005,2950568.30875 756143.25,2950579.81375 756106.636250004,2950602.24875 756103.058750004,2950604.44125 756061.983125001,2950629.61125 756050.299999997,2950636.77 756023.348124996,2950653.215 755991.915625006,2950667.005 755971.656874999,2950675.8925 755927.546875,2950695.24437501 755920.398750007,2950698.38 755870.655625001,2950720.203125 755861.583124995,2950724.58125 755798.972499996,2950746.65000001 755796.644999996,2950747.470625
 755735.564374998,2950769.000625 755733.309375003,2950769.795625 755670.033749998,2950792.09937499 755621.878749996,2950809.073125 755605.403125003,2950814.88062499 755573.631874993,2950826.079375 755540.014375001,2950837.92874999 755525.364374995,2950843.093125 755475.853125006,2950860.545 755413.518124998,2950882.516875 755411.366249993,2950883.27562501 755359.253124997,2950901.644375 755348.603125006,2950905.39812499 755307.636250004,2950919.83875 755284.855000004,2950927.86812501 755255.464375004,2950938.22812501 755240.979375005,2950943.33374999 755204.528750002,2950956.1825 755197.123125002,2950958.7925 755143.799374998,2950977.4025 755096.668750003,2950995.160625 755079.171250001,2951001.75375 755047.692499995,2951013.614375 755039.418125004,2951016.7325 754993.360624999,2951034.08687501 754954.935000002,2951048.565 754942.963750005,2951053.075625 754936.364999995,2951055.561875 754918.676874995,2951063.38124999 754873.156874999,2951083.504375 754828.588125005,2951103.2075 754783.557500005,2951123.11375
 754792.950000003,2951132.39937501 754748.090000004,2951178.19312499 754732.861874998,2951162.730625 754683.671250001,2951213.3075</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>2353302.86980625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>8558.43561269342</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__30’><BrooklineWMS:OBJECTID>30</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><
 gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760271.661249995,2950973.69625001 760185.753124997,2951127.1075 759916.709999993,2951170.40625 759901.149375007,2951058.370625 759876.243125007,2950865.76125 759880.763750002,2950828.40375 760271.661249995,2950973.69625001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>84557.695725</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1210.31245857729</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__31’><BrooklineWMS:OBJECTID>31</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE
 _MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759111.375,2951106.64812499 759093.999375001,2951070.9675 759092.903750002,2951048.999375 759092.690624997,2951026.558125 759068.144999996,2950985.94374999 759069.733125001,2950934.154375 759013.626874998,2950836.784375 759041.211250007,2950816.503125 759152.695625007,2950733.316875 759195.568124995,2950823.465625 759340.756249994,2950756.173125 759355.374375001,2950882.861875 759228.795625001,2950897.3475 759264.803749993,2951017.638125 759158.778750002,2951079.878125 759111.375,2951106.64812499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>65149.562984375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1286.84006408887</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><Bro
 oklineWMS:Zoning fid=‘F1__32’><BrooklineWMS:OBJECTID>32</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 761003.170625001,2951081.03812499 760973.0625,2951069.75 760889.116249993,2951037.7225 760832.547499999,2951016.139375 760750.221249998,2950984.73 760597.144374996,2950926.763125 760571.962500006,2950917.22750001 760479.646874994,2950882.40875 760460.941874996,2950875.38437501 760441.391249999,2950868.0425 760431.523750007,2950864.33687501 760413.900000006,2950857.718125 760350.051874995,2950832.1262
 5 760351.601249993,2950828.15062501 760409.53125,2950677.04625 760433.271249995,2950616.96312501 760436.826250002,2950607.96625 760161.441249996,2950514.15375 760225.640000001,2950350.705 760238.301874995,2950317.026875 760375.370000005,2950369.74312501 760508.981250003,2950417.925625 760503.78125,2950431.66875 760646.265000001,2950483.82875 760791.615624994,2950537.923125 760938.530625001,2950592.59999999 761071.999375001,2950642.03125 760985.893749997,2950868.45625 761010.146249995,2951086.72499999 761003.170625001,2951081.03812499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>331612.960807813</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2822.18667667292</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__33’><BrooklineWMS:OBJECTID>33</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134 rooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 762594.785624996,2951073.74437501 762411.883125007,2951004.515625 762431.334374994,2950959.62875 762464.091250002,2950872.82250001 762503.400000006,2950769.638125 762534.233750001,2950680.21875 762536.156874999,2950674.643125 762629.755624995,2950427.483125 762800.3125,2950592.25 762615.064374998,2951081.79125001 762594.785624996,2951073.74437501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>123379.88945</BrooklineWMS:Shape.area><BrooklineWMS:Shape
 .len>1594.83968134707</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__34’><BrooklineWMS:OBJECTID>34</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>21</BrooklineWMS:CASE1><BrooklineWMS:CASE2>20</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 761834.308125004,2950786.44125 761798.034999996,2950881.21187501 761769.747500002,2950959.18000001 761764.895624995,2950957.343125 761743.061250001,2950949.07875 761722.426249996,2950941.268125 761700.380624995,2950932.92375 761679.167500004,2950924.894375 761657.069999993,2950916.53 761653.6875
 ,2950915.25 761652.793750003,2950908.69750001 761640.739999995,2950893.56 761623.594999999,2950872.028125 761601.306875005,2950863.59625 761579.269374996,2950855.25937501 761558.693749994,2950847.47562499 761552.298124999,2950845.05625001 761536.608750001,2950839.120625 761514.780000001,2950830.8625 761492.958124995,2950822.6075 761471.800624996,2950814.60375001 761415.317499995,2950791.44625001 761448.161874995,2950705.98 761273.041250005,2950641.9175 761099.983750001,2950576.58374999 761074.788124993,2950643.064375 761071.999375001,2950642.03125 760938.530625001,2950592.59999999 760791.615624994,2950537.923125 760646.265000001,2950483.82875 760503.78125,2950431.66875 760508.981250003,2950417.925625 760375.370000005,2950369.74312501 760238.301874995,2950317.026875 760245.673124999,2950297.420625 760254.723124996,2950258.62625 760267.343125001,2950147.543125 760275.313749999,2950123.098125 760281.621250004,2950094.063125 760302.819999993,2950049.19687501 760422.288749993,2949843.75562499 760381.719999999,29495
 12.9425 760400.162499994,2949511.3625 760471.009375006,2949502.23875 760540.800624996,2949493.250625 760579.759375006,2949488.23375 760612.981250003,2949500.6725 760679.159374997,2949525.4525 760806.894999996,2949573.280625 760824.796250001,2949581.06375 760760.769374996,2949753.18625 760793.236874998,2949762.63500001 760967.369375005,2949828.583125 761379.061875001,2949984.501875 761384.806875005,2949964.659375 761470.871250004,2949744.4325 761480.745625004,2949719.966875 761469.443124995,2949702.77124999 761409.793125004,2949595.613125 761343.245000005,2949458.70375 761302.441874996,2949364.55562501 761290.891874999,2949329.933125 761340.248750001,2949327.33 761452.617500007,2949307.720625 761461.375,2949342.75 761702.5,2949687.25 761984,2949818.25 762043.0625,2949869.25 762077.375,2950045.75 762274.920000002,2950167.140625 762174.192499995,2950333.97125 762108.856250003,2950453.903125 761963.946875006,2950835.24875 761834.308125004,2950786.44125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:
 Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1709509.82586875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7202.27495635284</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__35’><BrooklineWMS:OBJECTID>35</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760350.051874995,2950832.12625 760346.973124996,2950840.02500001 759856.633125007,2950655.635625 759691.083749995,2950593.78625 759668.084
 374994,2950397.45999999 759659.297499999,2950326.22750001 759748.583124995,2950359.00687499 759821.600624993,2950387.01375 759894.686875001,2950195.36125 759894.959374994,2950195.46250001 759898.993125007,2950184.03749999 760008.536249995,2950223.723125 760076.938749999,2950249.12 760078.829999998,2950253.68187501 760098.936250001,2950302.183125 760134.228125006,2950315.4025 760225.640000001,2950350.705 760161.441249996,2950514.15375 760436.826250002,2950607.96625 760433.271249995,2950616.96312501 760409.53125,2950677.04625 760351.601249993,2950828.15062501 760350.051874995,2950832.12625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>257099.903758789</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2458.84493356053</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__36’><BrooklineWMS:OBJECTID>36</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M
 -2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759364.126874998,2950441.716875 759257.524375007,2950401.43375 759253.565624997,2950399.923125 759175.699375004,2950370.21187501 759099.836250007,2950341.264375 759085,2950335.60312501 759150.683125004,2950156.96875 759159.118750006,2950136.78687499 759168.958749995,2950113.245625 759236.591250002,2950138.80625001 759292.668125004,2949983.18187501 759355.703749999,2950008.58625001 759424.836875007,2950036.44875 759428.533124998,2950063.80312499 759509.590000004,2950054.989375 759495.452500001,2950090.
 56937499 759562.844374999,2950104.06125 759632.798124999,2950095.658125 759655.718125001,2950297.20937499 759658.686250001,2950321.270625 759659.297499999,2950326.22750001 759615.486249998,2950310.143125 759440.060000002,2950244.439375 759364.126874998,2950441.716875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>142134.951096875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1880.63450412375</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__37’><BrooklineWMS:OBJECTID>37</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODI
 FIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759659.297499999,2950326.22750001 759658.686250001,2950321.270625 759655.718125001,2950297.20937499 759632.798124999,2950095.658125 759562.844374999,2950104.06125 759495.452500001,2950090.56937499 759509.590000004,2950054.989375 759428.533124998,2950063.80312499 759424.836875007,2950036.44875 759355.703749999,2950008.58625001 759292.668125004,2949983.18187501 759236.591250002,2950138.80625001 759168.958749995,2950113.245625 759150.670625001,2950106.33374999 759190.144374996,2949995.83562499 759233.09375,2949875.608125 759266.943124995,2949876.74062499 759456.465625003,2949853.00125 759604.135000005,2949843.59999999 759583.893749997,2949667.793125 759703.235624999,2949647.016875 759706.146874994,2949672.11375 759807.173749998,2949662.50687499 759892.333749995,2949654.40875 759871.206874996,2949474.906875 759866.026250005,2
 949452.655 759904.308125004,2949445.50562499 759919.099999994,2949443.565 759914.230625004,2949419.66125 759885.463125005,2949244.38312501 759911.75,2949239 759957.315624997,2949230.16312499 760002.798124999,2949221.341875 760005.181250006,2949287.17749999 760084.235624999,2949277.45 760154.641249999,2949268.78687499 760213.788749993,2949261.50937501 760325.526250005,2949247.76000001 760421.339375004,2949204.19750001 760499.346249998,2949193.653125 760582.806250006,2949182.371875 760586.581249997,2949222.471875 760590.831249997,2949267.61375 760596.758750007,2949330.57250001 760599.762500003,2949355.47437499 760366.020624995,2949384.91875 760196.424374998,2949407.17375 760198.794375002,2949429.749375 760214,2949551.110625 760224.616249993,2949635.83750001 760133.954374999,2949645.01875 760047.905000001,2949653.733125 760026.084374994,2949655.9425 759975.851875007,2949661.03 759959.438124999,2949864.751875 760010.870000005,2949867.814375 760020.120625004,2949867.9575 760027.471874997,2949992.7225 760068.1868750
 01,2949991.328125 760107.303124994,2949989.98875 760145.413749993,2949988.68375 760184.858750001,2949987.245 760181.879374996,2949995.156875 760165.170000002,2950039.529375 760150.946250007,2950077.300625 760275.313749999,2950123.098125 760267.343125001,2950147.543125 760254.723124996,2950258.62625 760245.673124999,2950297.420625 760238.301874995,2950317.026875 760225.640000001,2950350.705 760134.228125006,2950315.4025 760098.936250001,2950302.183125 760078.829999998,2950253.68187501 760076.938749999,2950249.12 760008.536249995,2950223.723125 759898.993125007,2950184.03749999 759894.959374994,2950195.46250001 759894.686875001,2950195.36125 759821.600624993,2950387.01375 759748.583124995,2950359.00687499 759659.297499999,2950326.22750001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>579294.500354687</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6127.68375954737</BrooklineWMS:Shape.len></BrooklineWMS:Z
 oning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__38’><BrooklineWMS:OBJECTID>38</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754076.644374996,2950226.263125 754060.814999998,2950255.06937499 754031.659999996,2950282.61499999 753983.742500007,2950327.88875 753958.459374994,2950302.62375 753949.673749998,2950293.845 753915.126874998,2950259.32375 753869.595624998,2950304.61624999 753862.129374996,2950310.33374999 753584.910624996,2950005.63625 753612.24
 4375005,2949967.92 753623.829999998,2949948.671875 753636.763125002,2949952.408125 753671.515625,2949948.936875 753697.789375007,2949936.291875 753833.558125004,2949843.564375 753839.344374999,2949840.66500001 753828.172499999,2949823.68000001 753797.730625004,2949781.66625001 753766.777500004,2949738.94562501 753748.876874998,2949713.66500001 753765.734999999,2949701.36125 753788.136875004,2949687.67125 753828.607500002,2949662.94 754033.866249993,2949546.159375 754092.640625,2949512.720625 754132.853125006,2949487.655 754183.030625001,2949448.09625 754343.632499993,2949285.97624999 754454.838750005,2949173.058125 754545.632499993,2949080.86687499 754608.701250002,2949022.78 754629.028750002,2949042.5775 754719.9375,2949116.5 754734.079999998,2949131.11687499 754818.883125007,2949167.229375 754883.837500006,2949198.5325 754850.034999996,2949224.19625001 754805.408749998,2949263.51625 754766.120000005,2949308.168125 754680.183125004,2949433.56812499 754696.046875,2949445.81125 754798.148124993,2949539.76625 75
 4793.933125004,2949544.3925 754787.706249997,2949550.279375 754763.452500001,2949573.21062499 754724.185625002,2949610.33437499 754685.753124997,2949646.670625 754651.882499993,2949678.69312499 754643.465625003,2949686.65125 754618.134375006,2949710.60062499 754604.724999994,2949723.278125 754578.070625007,2949748.47875001 754572.254999995,2949753.97687501 754541.934375003,2949782.64375 754532.033124998,2949792.004375 754455.852500007,2949864.029375 754480.25,2949888.5 754488.178749993,2949897.16500001 754478.185625002,2949900.503125 754458.280625001,2949914.266875 754246.116874993,2950060.97 754206.768124998,2950091.33499999 754160.778125003,2950135.925 754080.991249993,2950223.61125 754076.644374996,2950226.263125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>691770.114694531</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4156.58605682721</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMe
 mber><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__39’><BrooklineWMS:OBJECTID>39</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760275.313749999,2950123.098125 760150.946250007,2950077.300625 760165.170000002,2950039.529375 760181.879374996,2949995.156875 760184.858750001,2949987.245 760145.413749993,2949988.68375 760107.303124994,2949989.98875 760068.186875001,2949991.328125 760027.471874997,2949992.7225 760020.120625004,2949867.9575 760010.870000005,2949867.814375 759959.438124999,2949864.751875
 759975.851875007,2949661.03 760026.084374994,2949655.9425 760047.905000001,2949653.733125 760133.954374999,2949645.01875 760224.616249993,2949635.83750001 760214,2949551.110625 760198.794375002,2949429.749375 760196.424374998,2949407.17375 760366.020624995,2949384.91875 760381.719999999,2949512.9425 760422.288749993,2949843.75562499 760302.819999993,2950049.19687501 760281.621250004,2950094.063125 760275.313749999,2950123.098125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>199028.622358594</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2207.1290818054</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__40’><BrooklineWMS:OBJECTID>40</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>SC-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>17</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>TWO-FAMILY & ATTACHED SINGLE-FAMILY</BrooklineWMS:ZONEDESC><Broo
 klineWMS:CASE1>27</BrooklineWMS:CASE1><BrooklineWMS:CASE2>26</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>SC-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754530.889375001,2950063.498125 754522.831874996,2950043.641875 754462.273124993,2949922.65875 754458.280625001,2949914.266875 754478.185625002,2949900.503125 754488.178749993,2949897.16500001 754480.25,2949888.5 754455.852500007,2949864.029375 754532.033124998,2949792.004375 754541.934375003,2949782.64375 754572.254999995,2949753.97687501 754578.070625007,2949748.47875001 754604.724999994,2949723.278125 754618.134375006,2949710.60062499 754643.465625003,2949686.65125 754651.882499993,2949678.69312499 754685.753124997,2949646.670625 754724.185625002,2949610.33437499 754763.452500001,2949573.21062499 754787.706249997,2949550.279375 754793.93
 3125004,2949544.3925 754798.148124993,2949539.76625 754835.346874997,2949498.9375 754842.451250002,2949491.139375 754874.449375004,2949456.01875 754879.333749995,2949450.656875 754898.909374997,2949429.171875 754923.184375003,2949402.526875 754953.773124993,2949368.95375 754957.586875007,2949364.7675 754970.886875004,2949354.11875001 755003.809375003,2949327.75937501 755022.797499999,2949312.55625001 755101.808750004,2949407.7375 755115.795000002,2949424.47562499 755176.836250007,2949376.83374999 755214.056250006,2949354.501875 755283.564374998,2949318.746875 755359.340000004,2949291.67375 755436.263125002,2949274.94499999 755448.541875005,2949274.1875 755449.851875007,2949293.59125 755456.242500007,2949345.24875 755522.290000007,2949350.38062499 755522.575625002,2949353.14624999 755624.831874996,2949365.30312499 755659.108125001,2949369.378125 755693.110624999,2949373.420625 755703.75,2949465.75 755703.038749993,2949486.04875 755707.731875002,2949485.871875 755794.198125005,2949462.439375 755843.031874999,294
 9449.205 755903.851875007,2949443.03874999 755964.956874996,2949447.405 756042.480000004,2949459.49625 756199.096249998,2949491.68187501 756282.634375006,2949516.324375 756292.921875,2949519.359375 756383.465625003,2949552.45375 756452.998125002,2949585.07062501 756463.366249993,2949565.51125 756505.609375,2949471.1575 756532.095624998,2949412 756553.859999999,2949410.66249999 756564.441874996,2949498.924375 756567.185625002,2949521.808125 756621.575625002,2949514.793125 756666.213125005,2949509.03625 756666.628749996,2949513.393125 756674.600624993,2949596.923125 756685.633750007,2949712.53687499 756669.225624993,2949725.14624999 756667.571875006,2949721.688125 756638.216875002,2949687.79625 756611.109999999,2949667.82875 756554.573125005,2949633.96375 756543.834999993,2949650.92 756536.742500007,2949659.46375 756510.120625004,2949691.923125 756490.304374993,2949709.268125 756483.673749998,2949712.95 756465.152500004,2949708.09937499 756442.969999999,2949698.27312499 756417.559375003,2949698.408125 756412.290
 625006,2949676.57187501 756363.159999996,2949676.26000001 756322.3125,2949676 756316.156874999,2949695.28375 756260.596874997,2949689.205625 756217.780000001,2949684.52187499 756215.373750001,2949691.96312501 756194.325625002,2949692.395 756135.597499996,2949693.60124999 756116.180625007,2949694 756065.553124994,2949695.03937501 756071.826875001,2949759.013125 756074.856875002,2949789.91374999 756064.464375004,2949795.9425 755988.215625003,2949840.17375 755966.272499993,2949848.03937501 755987.859999999,2949879.30374999 755996.048124999,2949905.358125 756001.916875005,2949922.964375 755576.394999996,2949973.99187499 755515.123125002,2949984.343125 755322.876874998,2950035.03937501 755317.917500004,2950015.47499999 755289.717500001,2949914.276875 755280.830624998,2949882.388125 755318.533124998,2949873.42874999 755278.789375007,2949712.9675 755273.235624999,2949694.6925 755300.034374997,2949687.99312501 755342.465000004,2949682.7825 755309.751874998,2949507.58687501 755308.061250001,2949514.433125 755298.291875
 005,2949522.04875 755170.206874996,2949563.486875 755124.206874996,2949585.69374999 755103.203125,2949601.31 755009.125,2949689.64 754917.960624993,2949769.75687499 754906.159999996,2949790.770625 754881.549374998,2949806.513125 754808.705624998,2949862.285 754807.206249997,2949860.36499999 754735.089375004,2949899.469375 754764.338750005,2949936.36937501 754775.481250003,2949954.10062499 754680.900000006,2949980.185 754632.033749998,2949998.71625 754585.908124998,2950023.28375 754530.889375001,2950063.498125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>771479.531043555</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6791.87581583806</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__41’><BrooklineWMS:OBJECTID>41</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><Brook
 lineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753623.829999998,2949948.671875 753612.244375005,2949967.92 753584.910624996,2950005.63625 753517.6875,2949931.75 753494.818749994,2949910.76000001 753534.803749993,2949879.63875 753730.146874994,2949727.33625001 753748.876874998,2949713.66500001 753766.777500004,2949738.94562501 753797.730625004,2949781.66625001 753828.172499999,2949823.68000001 753839.344374999,2949840.66500001 753833.558125004,2949843.564375 753697.789375007,2949936.291875 753671.515625,2949948.936875 753636.763125002,2949952.408125 753623.829999998,2949948.671875</gml:coordinates></gml:LinearRing></gml:outerB
 oundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>43543.9129089844</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>925.909641729703</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__42’><BrooklineWMS:OBJECTID>42</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759583.893749997,2949667.793125 759604.135000005,2949843.59999999 759456.465625003,2949853.00125 759266.943124995,2949876.
 74062499 759233.09375,2949875.608125 759190.144374996,2949995.83562499 759025.732500002,2949932.33499999 759028.484375,2949925.22562499 759038.060000002,2949929.404375 759071.473749995,2949841.280625 759000,2949776.90062501 758954.751249999,2949736.20625 758936.748125002,2949711.08812501 758896.348749995,2949634.34625 759000,2949614.895625 759005.019374996,2949613.95375 758965.220624998,2949468.190625 758946.446250007,2949472.02 758831.885625005,2949496.32125001 758751.054374993,2949323.24875 758732.251249999,2949300.96250001 758711.988749996,2949276.94562501 758684.920625001,2949168.208125 758822.682500005,2949132.218125 758839.371250004,2949127.858125 758880.549374998,2949273.60312501 758886.105625004,2949292.344375 759000,2949263.55437499 759215.266249999,2949198.77437501 759322.403750002,2949164.63500001 759328.506874993,2949184.739375 759357.591875002,2949278.500625 759365.936875001,2949305.40125 759360.171250001,2949307.46375 759372.125624999,2949360.60312501 759351.858125001,2949360.330625 759348.735624
 999,2949360.28874999 759316.021249995,2949366.85124999 759348.25,2949549.545 759565.584374994,2949508.760625 759543.091250002,2949304.640625 759567.167500004,2949301.66312499 759664.789375007,2949287.29375 759707.806250006,2949278.950625 759765.451250002,2949267.770625 759885.463125005,2949244.38312501 759914.230625004,2949419.66125 759919.099999994,2949443.565 759904.308125004,2949445.50562499 759866.026250005,2949452.655 759871.206874996,2949474.906875 759892.333749995,2949654.40875 759807.173749998,2949662.50687499 759706.146874994,2949672.11375 759703.235624999,2949647.016875 759583.893749997,2949667.793125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>522940.789170313</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4805.00021486436</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__43’><BrooklineWMS:OBJECTID>43</BrooklineWMS:OBJECTID>
 <BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 761379.061875001,2949984.501875 760967.369375005,2949828.583125 760975.375,2949810.11687499 761017.553749993,2949700.51125 761055.026250005,2949603.13437501 761115.202500001,2949446.75937501 761115.829999998,2949351.830625 761115.643749997,2949331.63124999 761202.681875005,2949332.763125 761290.891874999,2949329.933125 761302.441874996,2949364.55562501 761343.245000005,2949458.70375 761409.793125004,2949595.613125 761469.443124995,2949702.77124999 761480.745625004,2949719.96687
 5 761470.871250004,2949744.4325 761384.806875005,2949964.659375 761379.061875001,2949984.501875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>204177.946396875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1858.16147103014</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__44’><BrooklineWMS:OBJECTID>44</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>SC-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>17</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>TWO-FAMILY & ATTACHED SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>27</BrooklineWMS:CASE1><BrooklineWMS:CASE2>26</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>SC-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoun
 daryIs><gml:LinearRing><gml:coordinates> 753534.803749993,2949879.63875 753494.818749994,2949910.76000001 753473.5625,2949891.25 753391.140625,2949803.63249999 753401.238124996,2949795.25375 753406.398124993,2949791.08562499 753432.744375005,2949769.80562501 753469.447500005,2949740.16 753485.603125006,2949727.11125 753476.922499999,2949715.22375 753496.584374994,2949699.3725 753547.212500006,2949658.55687501 753556.537499994,2949670.85875 753649.068749994,2949599.405625 753656.323125005,2949603.198125 753771.120625004,2949663.21125001 753788.136875004,2949687.67125 753765.734999999,2949701.36125 753748.876874998,2949713.66500001 753730.146874994,2949727.33625001 753534.803749993,2949879.63875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>54906.090503125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1044.26697350997</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember>
 <BrooklineWMS:Zoning fid=‘F1__45’><BrooklineWMS:OBJECTID>45</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>SC-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>17</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>TWO-FAMILY & ATTACHED SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>27</BrooklineWMS:CASE1><BrooklineWMS:CASE2>26</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>SC-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760967.369375005,2949828.583125 760793.236874998,2949762.63500001 760760.769374996,2949753.18625 760824.796250001,2949581.06375 760906.219999999,2949362.173125 760912.621250004,2949328.99062499 760960.501874998,2948945.34 760958.505624995,2948919.33875 760937.901875004,2948825.295 760890.106250003,2948685.684375 760889.0625,2948682.6375 760905.159999996,2948663.435625 761120.
 680000007,2948552.11624999 761135.493125007,2948547.81812499 761107.693749994,2948464.7525 761098.349374995,2948436.83125 761039.788749993,2948290.768125 761197.160624996,2948112.02500001 761220.634375006,2948142.50749999 761204.5,2948171.75 761250.5,2948416.25 761338.4375,2948650.75 761378.5625,2949011.5 761452.617500007,2949307.720625 761340.248750001,2949327.33 761290.891874999,2949329.933125 761202.681875005,2949332.763125 761115.643749997,2949331.63124999 761115.829999998,2949351.830625 761115.202500001,2949446.75937501 761055.026250005,2949603.13437501 761017.553749993,2949700.51125 760975.375,2949810.11687499 760967.369375005,2949828.583125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>504502.173085156</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4229.17312908793</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__46’><BrooklineWM
 S:OBJECTID>46</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753788.136875004,2949687.67125 753771.120625004,2949663.21125001 753656.323125005,2949603.198125 753649.068749994,2949599.405625 753556.537499994,2949670.85875 753547.212500006,2949658.55687501 753496.584374994,2949699.3725 753476.922499999,2949715.22375 753485.603125006,2949727.11125 753469.447500005,2949740.16 753432.744375005,2949769.80562501 753406.398124993,2949791.08562499 753401.238124996,2949795.25375 753391.140625,2949803.63249999 753281.
 1875,2949686.75 753108.8125,2949474.75 753092.1875,2949451.5 753077.0625,2949428.5 753065.0625,2949408.5 753053.125,2949387.25 753041.5625,2949364.75 753032.3125,2949345.25 753024.8125,2949328.25 753015.625,2949305.5 753007.6875,2949283.75 753001.5625,2949261.5 752993.75,2949237 752989.875,2949221.25 752987.25,2949211.5 752982,2949185.5 752979.5,2949173 752976.8125,2949157.5 752972.625,2949136.75 752971.25,2949130.25 752961.4375,2949132.25 752848.5,2949149.5 752357,2949133.5 752244.5,2949037.5 752226.189999998,2949021.175 752235.736874998,2948996.839375 752338.323125005,2948977.323125 752367.620000005,2948973.876875 752368.690624997,2948955.56125 752377.049999997,2948903.17375 752383.321875006,2948864.1125 752397.977500007,2948807.80875 752403.180625007,2948787.221875 752410.368750006,2948739.96250001 752419.621250004,2948679.12375 752428.533124998,2948619.47499999 752431.879999995,2948600.201875 752437.610624999,2948602.88500001 752565.053749993,2948649.000625 752645.836875007,2948669.80500001 752706.20187500
 1,2948676.248125 752853.275625005,2948691.94499999 752899.253124997,2948536.535 752994.615624994,2948562.644375 753173.948750004,2948611.74437501 753685.319999993,2948762.38187499 753680.061250001,2948778.16 754077.786874995,2948908.98999999 754383.237499997,2949021.20625 754338.316249996,2949067.859375 754433.756249994,2949152.770625 754454.838750005,2949173.058125 754343.632499993,2949285.97624999 754183.030625001,2949448.09625 754132.853125006,2949487.655 754092.640625,2949512.720625 754033.866249993,2949546.159375 753828.607500002,2949662.94 753788.136875004,2949687.67125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1418411.28674336</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5908.66397541739</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__47’><BrooklineWMS:OBJECTID>47</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</Brookl
 ineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756669.225624993,2949725.14624999 756685.633750007,2949712.53687499 756674.600624993,2949596.923125 756666.628749996,2949513.393125 756666.213125005,2949509.03625 756621.575625002,2949514.793125 756567.185625002,2949521.808125 756564.441874996,2949498.924375 756553.859999999,2949410.66249999 756550.944999993,2949386.3475 756584.482500002,2949388.220625 756613.731875002,2949389.855 756654.051874995,2949392.1075 756654.856875002,2949400.450625 756781.84375,2949418.940625 756801.765000001,2949422.94562501 756809.473
 124996,2949493.71875 756830.795000002,2949499.815 756898.864999995,2949530.26875 757017.448125005,2949583.32062501 757071.233125001,2949607.38375001 757099.03125,2949543.425 757154.173749998,2949568.5425 757152.125624999,2949571.49875 757162.636250004,2949628.958125 757165.314999998,2949646.815625 756833.543750003,2949727.610625 756687.758125007,2949763.908125 756669.225624993,2949725.14624999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>107401.499667578</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1823.53082492082</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__48’><BrooklineWMS:OBJECTID>48</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-1.75(LSH</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>0</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LIMITED SERVICE HOTEL</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>0</BrooklineWMS:CASE1><BrooklineW
 MS:CASE2>0</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-1.75(LSH)</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758455.170625001,2949325.0425 758465.091250002,2949361.54062501 758522.776250005,2949347.32375 758555.407499999,2949483.8625 758555.379999995,2949483.86750001 758562.579374999,2949519.85625 758110.081249997,2949625.78874999 758096.808750004,2949634.30500001 758088.484999999,2949647.69875 758080.078749999,2949678.656875 758078.711250007,2949708.38 757929.018749997,2949663.5 757876.114999995,2949464.809375 757895.356875002,2949461.31625 757989.862499997,2949438.31125 758013.913124993,2949432.45625 758087.237499997,2949414.6075 758164.616874993,2949395.77124999 758180.482500002,2949391.909375 758289.584999993,2949365.35062499 758311.188124999,2949360.091875 758455.170625001,2949325.042
 5</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>141918.461247266</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1790.05902334335</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__49’><BrooklineWMS:OBJECTID>49</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>15</BrooklineWMS:CASE1><BrooklineWMS:CASE2>15</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757099.03125,2949543.425 757071.233125001,2949607.38375001 757017.44812500
 5,2949583.32062501 756898.864999995,2949530.26875 756830.795000002,2949499.815 756809.473124996,2949493.71875 756801.765000001,2949422.94562501 756783.047499999,2949249.10312501 756781.098124996,2949248.19562501 756740.096249998,2949230.30562501 756717.223749995,2949220.578125 756657.781874999,2949196.21125001 756603.403125003,2949175.72562499 756554.716250002,2949157.96187501 756506.454999998,2949141.670625 756456.613749996,2949125.38500001 756412.046250001,2949112.136875 756359.683125004,2949097.436875 756297.211250007,2949081.501875 756250.408749998,2949070.67625 756262.668125004,2949016.55374999 756299.390000001,2948853.92749999 756310.034374997,2948855.955625 756442.769999996,2948892.77437501 756476.336875007,2948902.08562499 756503.519999996,2948909.625625 756514.091250002,2948912.558125 756526.199375004,2948915.916875 756550.205624998,2948922.575625 756573.550624996,2948929.05125 756576.275625005,2948929.80687501 756598.182500005,2948935.88375001 756649.306250006,2948934.1525 756673.169375002,2948935.86
 25 756691.264375001,2948937.15875 756696.879374996,2948961.36125 756708.029375002,2948964.53 756725.464375004,2948969.485 756748.452500001,2948976.018125 756760.199375004,2948979.35625 756769.508125007,2948982.001875 756778.653125003,2948984.60062499 756788.232500002,2948987.323125 756798.165000007,2948990.145625 756803.104375005,2948991.55 756808.523750007,2948993.09 756820.803749993,2948996.58 756852.668750003,2949005.635625 756866.931250006,2949009.689375 756895.908749998,2949017.924375 756899.822500005,2949019.504375 756939.741874993,2949042.71375 756946.383750007,2949046.575625 756988.207499996,2949070.8925 757001.000624999,2949078.330625 757018.247500002,2949088.35875 757021.538124993,2949081.89375 757021.203749999,2949070.51375 757073.371250004,2949055.39749999 757084.590000004,2949069.55562501 757161.803124994,2949052.019375 757176.714375004,2949107.32250001 757189.510625005,2949104.73 757193.240624994,2949119.3775 757285.711250007,2949097.3175 757289.916875005,2949096.379375 757323.614999995,2949216.7
 31875 757329.498750001,2949238.845625 757312.902500004,2949242.979375 757157.626874998,2949279.25937501 757141.084374994,2949295.81 757132.635625005,2949317.18875 757133.351249993,2949336.923125 757145.105625004,2949369.610625 757158.458124995,2949405.67874999 757159.583124995,2949421.35375001 757154.115624994,2949435.47437499 757130.269374996,2949470.361875 757118.836250007,2949497.855625 757099.03125,2949543.425</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>326604.757776562</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3133.65722465328</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__50’><BrooklineWMS:OBJECTID>50</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE
 1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756463.366249993,2949565.51125 756452.998125002,2949585.07062501 756383.465625003,2949552.45375 756292.921875,2949519.359375 756282.634375006,2949516.324375 756289.210624993,2949497.31999999 756327.538749993,2949367.355 756370.546250001,2949379.4975 756420.541875005,2949393.6125 756455.5625,2949403.5 756461.4375,2949405 756464.3125,2949405.5 756467.25,2949406.25 756470.25,2949406.75 756476.125,2949407.75 756479.0625,2949408.5 756485,2949409.25 756488,2949409.75 756490.9375,2949410 756493.9375,2949410.5 756505.9375,2949411.5 756508.875,2949411.75 756511.875,2949411.75 756514.875,2949412 756532.095624998,2949412 756505.609375,2949471.1575 756463.366249993,2949565.51125</gml:co
 ordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>32365.55451875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>740.18231843075</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__51’><BrooklineWMS:OBJECTID>51</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760381.719999999,2949512.9425 760366.020624995,2949384.91875 760599.762500003,2949355.474374
 99 760692.891874999,2949343.74312501 760739.151250005,2949337.91562501 760735.905000001,2949312.99124999 760717.765625,2949174.57125001 760711.304374993,2949125.26625 760706.943749994,2949125.83687501 760704.826250002,2949126.11375 760642.305000007,2949134.25375 760637.073125005,2949134.934375 760621.909999996,2949002.55125 760619.838125005,2948982.43062501 760960.501874998,2948945.34 760912.621250004,2949328.99062499 760906.219999999,2949362.173125 760824.796250001,2949581.06375 760806.894999996,2949573.280625 760679.159374997,2949525.4525 760612.981250003,2949500.6725 760579.759375006,2949488.23375 760540.800624996,2949493.250625 760471.009375006,2949502.23875 760400.162499994,2949511.3625 760381.719999999,2949512.9425</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>178900.8843375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2406.14931275433</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featur
 eMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__52’><BrooklineWMS:OBJECTID>52</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759543.091250002,2949304.640625 759565.584374994,2949508.760625 759348.25,2949549.545 759316.021249995,2949366.85124999 759348.735624999,2949360.28874999 759351.858125001,2949360.330625 759372.125624999,2949360.60312501 759360.171250001,2949307.46375 759365.936875001,2949305.40125 759357.591875002,2949278.500625 759328.506874993,2949184.739375 759322.403750002,2949164.6
 3500001 759356.155000001,2949153.879375 759481.284999996,2949114.00687499 759515.253749996,2949106.83499999 759534.290625006,2949224.77875 759543.091250002,2949304.640625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>81390.658959375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1277.97753722928</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__53’><BrooklineWMS:OBJECTID>53</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG
 :2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754680.183125004,2949433.56812499 754766.120000005,2949308.168125 754805.408749998,2949263.51625 754850.034999996,2949224.19625001 754883.837500006,2949198.5325 754910.996875003,2949177.91249999 754923.848749995,2949193.356875 754963.439999998,2949241.05 755022.797499999,2949312.55625001 755003.809375003,2949327.75937501 754970.886875004,2949354.11875001 754957.586875007,2949364.7675 754953.773124993,2949368.95375 754923.184375003,2949402.526875 754898.909374997,2949429.171875 754879.333749995,2949450.656875 754874.449375004,2949456.01875 754842.451250002,2949491.139375 754835.346874997,2949498.9375 754798.148124993,2949539.76625 754696.046875,2949445.81125 754680.183125004,2949433.56812499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>57826.5747828125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1001.59175
 130109</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__54’><BrooklineWMS:OBJECTID>54</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756289.210624993,2949497.31999999 756282.634375006,2949516.324375 756199.096249998,2949491.68187501 756042.480000004,2949459.49625 755964.956874996,2949447.405 755903.851875007,2949443.03874999 755843.031874999,2949449.205 755794.198125005,2949462.439375 755792.558125004,2949442.355
 625 755782.465625003,2949354.906875 755772.123125002,2949265.28812499 755810.594999999,2949255.21062499 755814.449375004,2949256.96250001 755825.310625002,2949257.66312499 755864.550624996,2949264.67 755874.010625005,2949268.17375 755897.834999993,2949274.830625 755918.856250003,2949280.08625001 755960.900000006,2949287.61937501 756076.151250005,2949303.9525 756089.156874999,2949306.441875 756150.021874994,2949320.343125 756207.625,2949333.5 756210.575000003,2949334.333125 756270.386875004,2949351.219375 756327.538749993,2949367.355 756289.210624993,2949497.31999999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>87431.1309</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1422.15604704718</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__55’><BrooklineWMS:OBJECTID>55</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD>
 <BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757876.114999995,2949464.809375 757854.477500007,2949468.736875 757785.690624997,2949485.374375 757772.092500001,2949488.66312499 757762.113749996,2949450.004375 757757.676874995,2949432.815 757726.459999993,2949440.74187499 757708.726249993,2949445.24437501 757713.400000006,2949431.386875 757666.568749994,2949417.04625 757661.684375003,2949402.79875 757646.300624996,2949406.78874999 757572.724374995,2949425.873125 757564.688749999,2949395.300625 757551.295625001,2949344.341875 757542.215625003,2949345.971875 757503.169375002,29
 49352.98125 757499.409374997,2949353.0825 757462.156874999,2949349.32125001 757421.493125007,2949344.00749999 757386.233750001,2949349.61125 757341.4375,2949356.73 757336.661874995,2949337.534375 757319.128749996,2949267.060625 757312.902500004,2949242.979375 757329.498750001,2949238.845625 757323.614999995,2949216.731875 757289.916875005,2949096.379375 757267.297499999,2949010.21625 757273.275625005,2949009.22375 757352.898124993,2948991.49625 757372.642499998,2948974.16249999 757436.166875005,2948918.39624999 757329.025000006,2948829.159375 757334.476875007,2948820.958125 757350.924999997,2948777.85625 757359.634375006,2948719.25125 757359.233750001,2948707.778125 757652.518749997,2948631.370625 757628.040625006,2948540.9075 757752.408749998,2948510.484375 757809.561250001,2948495.4075 757845.226249993,2948485.999375 757821.266249999,2948395.925 757874.334999993,2948380.97624999 757883.650000006,2948378.35250001 757912.132499993,2948485.670625 757929.953749999,2948552.81625 757865.473749995,2948568.436875 75
 7869.28125,2948583.13875 757874.847499996,2948604.63312501 757883.313124999,2948635.16875 757896.668750003,2948683.341875 757901.988124996,2948702.53 757915.349374995,2948744.16500001 757937.182500005,2948829.07250001 757941.111874998,2948848.904375 757750.396874994,2948993.0975 757811.036249995,2949220.393125 757944.954999998,2949210.83625001 758040.658124998,2949197.25624999 758302.526250005,2949137.393125 758397.214375004,2949114.40375 758455.170625001,2949325.0425 758311.188124999,2949360.091875 758289.584999993,2949365.35062499 758180.482500002,2949391.909375 758164.616874993,2949395.77124999 758087.237499997,2949414.6075 758013.913124993,2949432.45625 757989.862499997,2949438.31125 757895.356875002,2949461.31625 757876.114999995,2949464.809375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>551236.464213867</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4719.66063371508</BrooklineWMS:Shape.len> rooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__56’><BrooklineWMS:OBJECTID>56</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755703.75,2949465.75 755693.110624999,2949373.420625 755659.108125001,2949369.378125 755624.831874996,2949365.30312499 755522.575625002,2949353.14624999 755522.290000007,2949350.38062499 755456.242500007,2949345.24875 755449.851875007,2949293.59125 755448.541875005,2949274.1875 755436.263125002,2949274.94499999 755359.340000004,2949291.673
 75 755283.564374998,2949318.746875 755214.056250006,2949354.501875 755176.836250007,2949376.83374999 755115.795000002,2949424.47562499 755101.808750004,2949407.7375 755022.797499999,2949312.55625001 754963.439999998,2949241.05 754923.848749995,2949193.356875 754910.996875003,2949177.91249999 754919.728125006,2949171.28375 754944.010000005,2949147.98 754968.716875002,2949110.583125 754996.842500001,2949039.471875 755060.310625002,2948982.93187501 755156.424999997,2948897.30875 755158.144374996,2948795.19625001 755180.459999993,2948791.168125 755230.813124999,2948782.078125 755273.407499999,2948774.38875 755312.164375007,2948767.391875 755337.709374994,2948762.780625 755346.981250003,2948762.72499999 755393.505624995,2948762.44875 755415.236249998,2948762.31937499 755432.046250001,2948762.219375 755458.803124994,2948762.06 755478.659999996,2948787.3625 755534.228125006,2948778.754375 755573.627499998,2948772.65062501 755607.935000002,2948767.33625001 755651.379374996,2948760.605625 755702.604375005,2948752.67062
 5 755712.669375002,2948751.624375 755718.246250004,2948794.21625 755810.559375003,2948784.110625 755830.513125002,2948780.47562499 755833.489999995,2948807.64687499 755853.9375,2948805.89812499 755925.626249999,2948797.955625 755964.056875005,2948795.049375 755994.198125005,2948798.655625 755996.871250004,2948798.92375 756009.310000002,2948800.17 756065.920000002,2948805.841875 756105.770624995,2948809.83437499 756142.847499996,2948813.60124999 756175.342500001,2948819.70874999 756179.128749996,2948820.420625 756219.065624997,2948827.92749999 756230.413124993,2948830.06 756244.390625,2948832.6875 756292.591250002,2948841.7475 756301.864999995,2948842.965 756299.390000001,2948853.92749999 756262.668125004,2949016.55374999 756250.408749998,2949070.67625 756228.843125001,2949065.688125 756170.694999993,2949053.11 756130.280625001,2949045.44125 756105.073750004,2949040.658125 756025.028125003,2949027.82375 756000,2949024.205625 755991.416250005,2949022.96625 755818.351875007,2949004.62125 755644.473124996,2948997.
 28874999 755609.818749994,2948997.489375 755608.267499998,2949092.21312501 755613.640625,2949243.36 755613.620000005,2949264.00375 755685.771249995,2949259.55312499 755737.409999996,2949250.50687499 755772.123125002,2949265.28812499 755782.465625003,2949354.906875 755792.558125004,2949442.355625 755794.198125005,2949462.439375 755707.731875002,2949485.871875 755703.038749993,2949486.04875 755703.75,2949465.75</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>503721.783328125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4428.21644921798</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__57’><BrooklineWMS:OBJECTID>57</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1>
 ooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756781.84375,2949418.940625 756654.856875002,2949400.450625 756654.051874995,2949392.1075 756613.731875002,2949389.855 756584.482500002,2949388.220625 756550.944999993,2949386.3475 756553.859999999,2949410.66249999 756532.095624998,2949412 756514.875,2949412 756511.875,2949411.75 756508.875,2949411.75 756505.9375,2949411.5 756493.9375,2949410.5 756490.9375,2949410 756488,2949409.75 756485,2949409.25 756479.0625,2949408.5 756476.125,2949407.75 756470.25,2949406.75 756467.25,2949406.25 756464.3125,2949405.5 756461.4375,2949405 756455.5625,2949403.5 756420.541875005,2949393.6125 756370.546250001,2949379.4975 756327.538749993,2949367.355 756270.386875004,2949351.219375 756210.5750000
 03,2949334.333125 756207.625,2949333.5 756150.021874994,2949320.343125 756089.156874999,2949306.441875 756076.151250005,2949303.9525 756114.794375002,2949139.109375 756130.280625001,2949045.44125 756170.694999993,2949053.11 756228.843125001,2949065.688125 756250.408749998,2949070.67625 756297.211250007,2949081.501875 756359.683125004,2949097.436875 756412.046250001,2949112.136875 756456.613749996,2949125.38500001 756506.454999998,2949141.670625 756554.716250002,2949157.96187501 756603.403125003,2949175.72562499 756657.781874999,2949196.21125001 756717.223749995,2949220.578125 756740.096249998,2949230.30562501 756781.098124996,2949248.19562501 756783.047499999,2949249.10312501 756801.765000001,2949422.94562501 756781.84375,2949418.940625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>170150.302125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1900.80679877441</BrooklineWMS:Shape.len></BrooklineWMS:Zoni
 ng></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__58’><BrooklineWMS:OBJECTID>58</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758455.170625001,2949325.0425 758397.214375004,2949114.40375 758518.722499996,2949086.34125 758500.868750006,2949032.74062499 758494.668125004,2949003.541875 758473.007499993,2948942.70125 758503.906874999,2948934.17749999 758613.508125007,2948903.645 758600.355000004,2948857.73 758710.350624993,2948831.65625 758736.938749999,2948824.50125 758822.682500005,294
 9132.218125 758684.920625001,2949168.208125 758711.988749996,2949276.94562501 758732.251249999,2949300.96250001 758660.926874995,2949313.27625 758526.132499993,2949346.496875 758522.776250005,2949347.32375 758465.091250002,2949361.54062501 758455.170625001,2949325.0425</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>134062.836615625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1745.46879349338</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__59’><BrooklineWMS:OBJECTID>59</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED
 > </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760599.762500003,2949355.47437499 760596.758750007,2949330.57250001 760590.831249997,2949267.61375 760586.581249997,2949222.471875 760582.806250006,2949182.371875 760499.346249998,2949193.653125 760421.339375004,2949204.19750001 760325.526250005,2949247.76000001 760213.788749993,2949261.50937501 760154.641249999,2949268.78687499 760084.235624999,2949277.45 760005.181250006,2949287.17749999 760002.798124999,2949221.341875 759957.315624997,2949230.16312499 759911.75,2949239 759885.463125005,2949244.38312501 759765.451250002,2949267.770625 759707.806250006,2949278.950625 759664.789375007,2949287.29375 759567.167500004,2949301.66312499 759543.091250002,2949304.640625 759534.290625006,2949224.77875 759515.253749996,2949106.83499999 759449.616874993,2948841.668125 759414.924374998,2948708.72624999 7594
 38.179374993,2948703.58499999 759517.705624998,2948683.69 759573.633125007,2948669.69875 759583.889375001,2948667.13312501 759562.674999997,2948581.31812499 759575.768124998,2948578.09 759572.580624998,2948565.5 759557.301874995,2948505.141875 759550.8125,2948478.25 759540.725624993,2948438.404375 759531.540625006,2948402.11937501 759512.735624999,2948327.83562499 759521.267499998,2948325.77249999 759502.681250006,2948252.863125 759493.256249994,2948255.13875 759498.239374995,2948275.07062501 759431.033124998,2948291.86812501 759433.6875,2948302.58374999 759338.141874999,2948325.969375 759315.537499994,2948331.950625 759279.656874999,2948197.31812499 759266.186875001,2948163.75 759244.691874996,2948134.595 759126.871250004,2948029.68000001 759077.566249996,2947979.82187501 759105.361249998,2947946.28687499 759134.566249996,2947909.39125 759159.375,2947878.048125 759172.037499994,2947889.38249999 759194.590000004,2947893.125625 759214.488124996,2947896.42812499 759233.955624998,2947899.65875 759259.746875003,29
 47903.93875 759276.143124998,2947906.66 759310.781874999,2947912.40875 759317.303749993,2947913.49062499 759360.410624996,2947920.645 759458.381249994,2947941.156875 759454.941874996,2947976.29625 759517.615624994,2947977.89937501 759564.628749996,2947979.10187501 759603.072500005,2947968.57125001 759651.954999998,2947953.54062501 759672.274375007,2947947.2925 759676.579374999,2947960.504375 759696.158124998,2947955.331875 759710.178749993,2947951.6275 759743.576250002,2947942.80437499 759747.644999996,2947958.311875 759797.790625006,2947945.81874999 759775.643124998,2947856.91562501 759758.627499998,2947817.526875 759755.051249996,2947766.168125 759743.515625,2947743.985 759730.052499995,2947718.0925 759722.650000006,2947703.85625 759716.734375,2947692.479375 759702.730625004,2947665.548125 759689.444999993,2947639.996875 759724.288124993,2947643.04000001 759726.803124994,2947613.938125 759731.181250006,2947563.27375001 759764.930000007,2947521.84375 759775.743125007,2947507.566875 759780.963125005,2947491.70
 1875 759786.415000007,2947370.566875 759746.476875007,2947367.68375 759746.998750001,2947347.99124999 759736.885000005,2947283.83562499 759785.424374998,2947278.46250001 759821.936250001,2947274.42125 759816.351249993,2947192.425625 759813.9375,2947177.27187499 759604.719999999,2947211.03125 759601.875624999,2947194.65625 759582.806250006,2947078.831875 759573.246875003,2947020.769375 759590.721249998,2947017.86499999 759672.625,2947004.25 759683.5,2947002.25 759690.405000001,2947001.261875 759780.458749995,2946986.27875 759794.806250006,2946983.89125 759868.848124996,2946971.57187501 759938.392499998,2946960.00125 759965.352500007,2946955.515625 759982.614999995,2946952.643125 760017.545000002,2946946.83125 760036.524375007,2946943.67375 760047.337500006,2946941.875 760058.244375005,2946940.06 760090.080624998,2946989.35625 760148.262500003,2947079.44750001 760159.597499996,2947097.40125 760264.138750002,2947031.26375 760364.406874999,2947182.685625 760473.833124995,2947349.94125 760606.946875006,2947605.8337
 4999 760708.469999999,2947807.003125 760732.923749998,2947866.08374999 760753.581874996,2947926.595625 760836.946875006,2948261.916875 760844.279375002,2948302.013125 760859.364374995,2948444.89687499 760889.0625,2948682.6375 760890.106250003,2948685.684375 760937.901875004,2948825.295 760958.505624995,2948919.33875 760960.501874998,2948945.34 760619.838125005,2948982.43062501 760621.909999996,2949002.55125 760637.073125005,2949134.934375 760642.305000007,2949134.25375 760704.826250002,2949126.11375 760706.943749994,2949125.83687501 760711.304374993,2949125.26625 760717.765625,2949174.57125001 760735.905000001,2949312.99124999 760739.151250005,2949337.91562501 760692.891874999,2949343.74312501 760599.762500003,2949355.47437499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>2594175.87813359</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>9204.64333131522</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gm
 l:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__60’><BrooklineWMS:OBJECTID>60</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>15</BrooklineWMS:CASE1><BrooklineWMS:CASE2>15</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756076.151250005,2949303.9525 755960.900000006,2949287.61937501 755918.856250003,2949280.08625001 755897.834999993,2949274.830625 755874.010625005,2949268.17375 755864.550624996,2949264.67 755825.310625002,2949257.66312499 755814.449375004,2949256.96250001 755810.594999999,2949255.21062499 755772.123125002,2949265.28812499 755737.409999996,2949250.50687499 75568
 5.771249995,2949259.55312499 755613.620000005,2949264.00375 755613.640625,2949243.36 755608.267499998,2949092.21312501 755609.818749994,2948997.489375 755644.473124996,2948997.28874999 755818.351875007,2949004.62125 755991.416250005,2949022.96625 756000,2949024.205625 756025.028125003,2949027.82375 756105.073750004,2949040.658125 756130.280625001,2949045.44125 756114.794375002,2949139.109375 756076.151250005,2949303.9525</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>129570.985834375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1527.08231741091</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__61’><BrooklineWMS:OBJECTID>61</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineW
 MS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758880.549374998,2949273.60312501 758839.371250004,2949127.858125 758822.682500005,2949132.218125 758736.938749999,2948824.50125 758710.350624993,2948831.65625 758687.728125006,2948730.23 758697.635625005,2948715.2825 758691.949375004,2948690.46375 758688.0625,2948673.5 758683.333124995,2948654.405625 758674.743125007,2948619.72750001 758684.375,2948616.75 758904.489374995,2948563.00125 758912.471874997,2948586.94875 758916.3125,2948586 758960.151875004,2948770.19625001 758983.278750002,2948764.56999999 759003.073125005,2948841.925 759014.553749993,2948890.579375 759025.627499998,2948937.51125 759036.871250004,2948985.16125 759047.297499999,2949029.34937499 759057.588
 750005,2949072.96187501 759147.238749996,2949051.51625 759167.442499995,2949047.65000001 759215.266249999,2949198.77437501 759000,2949263.55437499 758886.105625004,2949292.344375 758880.549374998,2949273.60312501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>189323.56825</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2165.10806632343</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__62’><BrooklineWMS:OBJECTID>62</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWM
 S:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758397.214375004,2949114.40375 758302.526250005,2949137.393125 758040.658124998,2949197.25624999 757944.954999998,2949210.83625001 757811.036249995,2949220.393125 757750.396874994,2948993.0975 757941.111874998,2948848.904375 757970.243125007,2948826.87875 758010.363124996,2948802.95625 758046.464375004,2948789.30374999 758301.582499996,2948720.9225 758322.239374995,2948788.78812499 758336.708749995,2948839.28812499 758341.476875007,2948855.93125001 758346.342500001,2948872.91312499 758350.094374999,2948883.546875 758373.058750004,2948970.27249999 758388.005624995,2948966.14937501 758473.007499993,2948942.70125 758494.668125004,2949003.541875 758500.868750006,2949032.74062499 758518.722499996,2949086.34125 758397.214375004,2949114.40375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Sh
 ape.area>234891.195404687</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2096.0261271661</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__63’><BrooklineWMS:OBJECTID>63</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759322.403750002,2949164.63500001 759215.266249999,2949198.77437501 759167.442499995,2949047.65000001 759147.238749996,2949051.51625 759057.588750005,2949072.96187501 759047.297499999,2949029.3493749
 9 759036.871250004,2948985.16125 759025.627499998,2948937.51125 759014.553749993,2948890.579375 759003.073125005,2948841.925 758983.278750002,2948764.56999999 759182.705624998,2948715.85875 759187.823750004,2948735.86375 759203.144374996,2948794.1925 759212.997500002,2948831.704375 759216.566249996,2948842.44 759232.200000003,2948889.47 759245.226249993,2948928.654375 759250.223749995,2948936.48875 759275.588750005,2948976.255 759301.488124996,2949016.85875 759321.305000007,2949048.250625 759350.948125005,2949134.80312499 759356.155000001,2949153.879375 759322.403750002,2949164.63500001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>91040.7721640625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1416.56149161631</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__64’><BrooklineWMS:OBJECTID>64</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-
 1.75(WS)</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>4</BrooklineWMS:CASE1><BrooklineWMS:CASE2>4</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-1.75(WS)</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754910.996875003,2949177.91249999 754883.837500006,2949198.5325 754818.883125007,2949167.229375 754734.079999998,2949131.11687499 754719.9375,2949116.5 754629.028750002,2949042.5775 754608.701250002,2949022.78 754545.632499993,2949080.86687499 754383.237499997,2949021.20625 754077.786874995,2948908.98999999 753680.061250001,2948778.16 753685.319999993,2948762.38187499 753740.557500005,2948596.645625 753584.430625007,2948479.655625 753591.386250004,2948454.33625001 753676.103125006,2948119.7931
 25 753807.180000007,2948150.92375 753747.045625001,2948386.48999999 753846.379999995,2948412.32375 753865.614374995,2948417.05125 753885.748750001,2948339.576875 753904.555625007,2948345.45125 753961.323750004,2948364.925 753990.708124995,2948375.005 754008.886875004,2948381.24124999 754019.198125005,2948384.69750001 754031.144999996,2948388.70125 754048.178749993,2948394.436875 754073.121250004,2948402.83625001 754078.038749993,2948404.49250001 754097.685000002,2948411.108125 754109.272499993,2948415.01000001 754120.983750001,2948418.954375 754146.219374999,2948427.451875 754168.158124998,2948434.84 754185.556250006,2948440.69875 754202.832499996,2948446.14624999 754206.614999995,2948446.94374999 754217.731875002,2948449.28749999 754223.879374996,2948448.861875 754238.146874994,2948550.07187501 754247.178124994,2948614.139375 754255.066249996,2948646.739375 754268.197500005,2948624.85375001 754315.554374993,2948593.83437499 754339.262500003,2948598.280625 754407.263750002,2948619.01125 754411.699375004,294860
 3.99312501 754445.724374995,2948614.86 754487.615624994,2948628.239375 754498.063749999,2948625.561875 754522.468125001,2948619.30875 754536.132499993,2948612.74437501 754553.620000005,2948604.343125 754640.906874999,2948690.60250001 754658.03125,2948702.18375 754674.408124998,2948713.26000001 754691.843125001,2948726.155 754747.067499995,2948744.705 754767.426874995,2948751.54375 754774.097499996,2948752.16374999 754777.069374993,2948752.191875 754780.035624996,2948752.011875 754782.981875002,2948751.62625 754785.894374996,2948751.035 754788.758750007,2948750.24312501 754793.197500005,2948748.56937499 754795.691874996,2948747.36812501 754798.276250005,2948745.90125 754800.102500007,2948744.6075 754819.818124995,2948729.129375 754841.443749994,2948712.151875 754844.808750004,2948709.5925 754874.751249999,2948686.81125 754899.041875005,2948668.33 754929.507499993,2948645.15062501 754972.820625007,2948701.10062499 754999.535624996,2948752.93875 755021.192499995,2948807.214375 755029.700000003,2948806.49625 75506
 4.993750006,2948803.518125 755126.229375005,2948798.35062499 755148.386250004,2948796.480625 755153.353750005,2948796.06125 755158.144374996,2948795.19625001 755156.424999997,2948897.30875 755060.310625002,2948982.93187501 754996.842500001,2949039.471875 754968.716875002,2949110.583125 754944.010000005,2949147.98 754919.728125006,2949171.28375 754910.996875003,2949177.91249999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>647003.343504297</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4873.68219098244</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__65’><BrooklineWMS:OBJECTID>65</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS
 :CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754545.632499993,2949080.86687499 754454.838750005,2949173.058125 754433.756249994,2949152.770625 754338.316249996,2949067.859375 754383.237499997,2949021.20625 754545.632499993,2949080.86687499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>15201.955225</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>524.16857977127</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__66’><BrooklineWMS:OBJECTID>66</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APAR
 TMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759350.948125005,2949134.80312499 759321.305000007,2949048.250625 759301.488124996,2949016.85875 759275.588750005,2948976.255 759250.223749995,2948936.48875 759245.226249993,2948928.654375 759232.200000003,2948889.47 759216.566249996,2948842.44 759212.997500002,2948831.704375 759203.144374996,2948794.1925 759187.823750004,2948735.86375 759182.705624998,2948715.85875 758983.278750002,2948764.56999999 758960.151875004,2948770.19625001 758916.3125,2948586 758912.471874997,2948586.94875 758904.489374995,2948563.00125 758943.811875001,2948553.39937501 758932.476249993,2948492.53812499 758895.8125,2948401.
 25 758879.625,2948402.25 758807.75,2948238.25 758788.114374995,2948171.576875 758835.549999997,2948113.826875 758860.800624996,2948108.67 758906.453125,2948058.311875 758943.982500002,2948016.91500001 758947.510625005,2948013.02312499 759010.933750004,2947943.063125 759025.426874995,2947927.096875 759015.938749999,2947917.503125 759000,2947899.74250001 758960.504999995,2947855.733125 758841.282499999,2947744.671875 758859.530625001,2947728.91125 758905.351249993,2947682.0975 758950.707499996,2947635.75937501 758963.588125005,2947622.043125 758889.879374996,2947552.78625 759000,2947420.24250001 759034.081249997,2947379.221875 759077.868125007,2947308.27375001 759096.739999995,2947269.80562501 759144.731875002,2947283.3 759247.633125007,2947267.46875 759257.156874999,2947245.19125 759265.041875005,2947224.56 759274.206874996,2947200.5775 759290.560000002,2947157.78937501 759293.746250004,2947149.45125 759310.645624995,2947146.77875 759312.491249993,2947118.579375 759303.103125006,2947120.473125 759305.400000006,
 2947105.79875 759309.020624995,2947082.66500001 759315.484999999,2947041.355 759378.900000006,2947053.090625 759393.641874999,2947050.638125 759424.915000007,2947045.434375 759476.696875006,2947036.81937499 759573.246875003,2947020.769375 759582.806250006,2947078.831875 759601.875624999,2947194.65625 759604.719999999,2947211.03125 759813.9375,2947177.27187499 759816.351249993,2947192.425625 759821.936250001,2947274.42125 759785.424374998,2947278.46250001 759736.885000005,2947283.83562499 759746.998750001,2947347.99124999 759746.476875007,2947367.68375 759786.415000007,2947370.566875 759780.963125005,2947491.701875 759775.743125007,2947507.566875 759764.930000007,2947521.84375 759731.181250006,2947563.27375001 759726.803124994,2947613.938125 759724.288124993,2947643.04000001 759689.444999993,2947639.996875 759702.730625004,2947665.548125 759716.734375,2947692.479375 759722.650000006,2947703.85625 759730.052499995,2947718.0925 759743.515625,2947743.985 759755.051249996,2947766.168125 759758.627499998,2947817.526
 875 759775.643124998,2947856.91562501 759797.790625006,2947945.81874999 759747.644999996,2947958.311875 759743.576250002,2947942.80437499 759710.178749993,2947951.6275 759696.158124998,2947955.331875 759676.579374999,2947960.504375 759672.274375007,2947947.2925 759651.954999998,2947953.54062501 759603.072500005,2947968.57125001 759564.628749996,2947979.10187501 759517.615624994,2947977.89937501 759454.941874996,2947976.29625 759458.381249994,2947941.156875 759360.410624996,2947920.645 759317.303749993,2947913.49062499 759310.781874999,2947912.40875 759276.143124998,2947906.66 759259.746875003,2947903.93875 759233.955624998,2947899.65875 759214.488124996,2947896.42812499 759194.590000004,2947893.125625 759172.037499994,2947889.38249999 759159.375,2947878.048125 759134.566249996,2947909.39125 759105.361249998,2947946.28687499 759077.566249996,2947979.82187501 759126.871250004,2948029.68000001 759244.691874996,2948134.595 759266.186875001,2948163.75 759279.656874999,2948197.31812499 759315.537499994,2948331.95062
 5 759338.141874999,2948325.969375 759433.6875,2948302.58374999 759431.033124998,2948291.86812501 759498.239374995,2948275.07062501 759493.256249994,2948255.13875 759502.681250006,2948252.863125 759521.267499998,2948325.77249999 759512.735624999,2948327.83562499 759531.540625006,2948402.11937501 759540.725624993,2948438.404375 759550.8125,2948478.25 759557.301874995,2948505.141875 759572.580624998,2948565.5 759575.768124998,2948578.09 759562.674999997,2948581.31812499 759583.889375001,2948667.13312501 759573.633125007,2948669.69875 759517.705624998,2948683.69 759438.179374993,2948703.58499999 759414.924374998,2948708.72624999 759449.616874993,2948841.668125 759515.253749996,2949106.83499999 759481.284999996,2949114.00687499 759356.155000001,2949153.879375 759350.948125005,2949134.80312499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1096468.7478625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7375.0
 7553369752</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__67’><BrooklineWMS:OBJECTID>67</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757289.916875005,2949096.379375 757285.711250007,2949097.3175 757193.240624994,2949119.3775 757189.510625005,2949104.73 757176.714375004,2949107.32250001 757161.803124994,2949052.019375 757084.590000004,2949069.55562501 757073.371250004,2949055.39749999 757021.203749999,2949070.
 51375 757021.538124993,2949081.89375 757018.247500002,2949088.35875 757001.000624999,2949078.330625 756988.207499996,2949070.8925 756946.383750007,2949046.575625 756939.741874993,2949042.71375 756899.822500005,2949019.504375 756895.908749998,2949017.924375 756866.931250006,2949009.689375 756852.668750003,2949005.635625 756820.803749993,2948996.58 756808.523750007,2948993.09 756803.104375005,2948991.55 756798.165000007,2948990.145625 756788.232500002,2948987.323125 756778.653125003,2948984.60062499 756769.508125007,2948982.001875 756760.199375004,2948979.35625 756748.452500001,2948976.018125 756725.464375004,2948969.485 756708.029375002,2948964.53 756696.879374996,2948961.36125 756691.264375001,2948937.15875 756673.169375002,2948935.8625 756649.306250006,2948934.1525 756598.182500005,2948935.88375001 756576.275625005,2948929.80687501 756573.550624996,2948929.05125 756550.205624998,2948922.575625 756526.199375004,2948915.916875 756514.091250002,2948912.558125 756503.519999996,2948909.625625 756476.336875007,2948
 902.08562499 756442.769999996,2948892.77437501 756470.775625005,2948787.203125 756474.698125005,2948766.425625 756530.528125003,2948778.33625001 756601.990624994,2948786.52437501 756646.654375002,2948787.26875 756674.097499996,2948790.300625 756651.665000007,2948710.50687499 756731.609999999,2948664.203125 756677.461250007,2948571.21625 756663.290625006,2948542.93062501 756599.778125003,2948570.41 756549.890000001,2948583.13124999 756484.849999994,2948590.02124999 756485.686875001,2948491.110625 756459.661249995,2948490.154375 756401.373125002,2948493.685 756378.591250002,2948461.24437501 756367.941874996,2948456.858125 756361.966250002,2948454.39687499 756318.302499995,2948436.41312499 756311.141874999,2948433.46375 756355.471874997,2948360.25937501 756366.116249993,2948343.69625001 756360.578125,2948340.091875 756278.441874996,2948305.81812499 756191.305000007,2948287.708125 756102.314999998,2948286.416875 755873.418750003,2948324.263125 755803.575000003,2948330.99625 755787.669375002,2948331.551875 755767.4
 22499999,2948113.60062499 755735.988749996,2948095.6925 755701.683125004,2948022.404375 755666.568124995,2947946.674375 755654.974999994,2947929.19437499 755678.403125003,2947906.925 755707.930000007,2947865.85187501 755723.054374993,2947835.67812499 755728.956874996,2947818.86937501 755748.291875005,2947824.8275 755853.758125007,2947872.07062501 755959.696250007,2947919.52500001 755976.900625005,2947925.86750001 755988.626874998,2947895.46187501 756000.783749998,2947845.583125 756006.963750005,2947768.886875 755998.519374996,2947692.408125 755972.643124998,2947602.44687501 755944.185000002,2947533.191875 755913.439999998,2947479.25624999 756135.295000002,2947471.55312499 756192.673749998,2947519.99124999 756287.593125001,2947611.066875 756379.158124998,2947704.895 756409.248750001,2947727.00624999 756442.973124996,2947745.77375001 756497.325625002,2947765.56375 756535.221874997,2947772.871875 756646.930625007,2947781.280625 756745.367500007,2947803.985625 756775.838750005,2947812.253125 756889.355625004,29477
 95.435625 757182.256874993,2948049.096875 757161.234999999,2948071.169375 757188.910624996,2948087.5 757254.9375,2948123 757269.1875,2948128.75 757297.471249998,2948148.639375 757288.140000001,2948211.98999999 757281.851875007,2948254.68000001 757273.385625005,2948256.7775 757286.90625,2948316.964375 757294.665625006,2948351.50562499 757305.740624994,2948400.80312499 757393.043125004,2948377.04062501 757431.197500005,2948459.564375 757462.571250007,2948527.4225 757321.456249997,2948564.51625 757327.226249993,2948577.12 757353.253749996,2948654.596875 757358.498750001,2948686.72125 757359.233750001,2948707.778125 757359.634375006,2948719.25125 757350.924999997,2948777.85625 757334.476875007,2948820.958125 757329.025000006,2948829.159375 757436.166875005,2948918.39624999 757372.642499998,2948974.16249999 757352.898124993,2948991.49625 757273.275625005,2949009.22375 757267.297499999,2949010.21625 757289.916875005,2949096.379375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMem
 ber></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1424312.38953359</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7156.09913191962</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__68’><BrooklineWMS:OBJECTID>68</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752226.189999998,2949021.175 752070.375,2948882.25 751831.75,2948648.5 751809.375,2948610.75 751711.9375,2948589.5 751743.9375,2948452.75 751783.9375,2948407.25 7
 51824.630624995,2948235.33437499 751874.178124994,2948249.955625 751959.263125002,2948275.065625 752032.133125007,2948295.68875 751991.686875001,2948348.55687501 751985.590625003,2948354.81999999 752008.034999996,2948365.27562501 752179.016874999,2948449.59625 752187.429374993,2948397.45999999 752327.282499999,2948434.29625 752306.891874999,2948536.393125 752255.908124998,2948909.171875 752235.736874998,2948996.839375 752226.189999998,2949021.175</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>252692.713185937</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2364.80409450846</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__69’><BrooklineWMS:OBJECTID>69</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</Broo
 klineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752235.736874998,2948996.839375 752255.908124998,2948909.171875 752306.891874999,2948536.393125 752327.282499999,2948434.29625 752345.961250007,2948340.77 752493.826875001,2948382.464375 752484.627499998,2948412.91875 752482.086875007,2948421.328125 752477.814999998,2948435.47125 752472.588750005,2948452.77249999 752471.344374999,2948456.8925 752465.083749995,2948477.61624999 752462.708749995,2948485.47812501 752489.677499995,2948493.0025 752509.225624993,2948498.456875 752528.053749993,2948503.70999999 752547.909374997,2948509.25 752581.704374999,2948518.67937499 752599.403125003,2948522.566875 752565.053749993,294864
 9.000625 752437.610624999,2948602.88500001 752431.879999995,2948600.201875 752428.533124998,2948619.47499999 752419.621250004,2948679.12375 752410.368750006,2948739.96250001 752403.180625007,2948787.221875 752397.977500007,2948807.80875 752383.321875006,2948864.1125 752377.049999997,2948903.17375 752368.690624997,2948955.56125 752367.620000005,2948973.876875 752338.323125005,2948977.323125 752235.736874998,2948996.839375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>101675.488354688</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1854.98350576115</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__70’><BrooklineWMS:OBJECTID>70</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineW
 MS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758473.007499993,2948942.70125 758388.005624995,2948966.14937501 758373.058750004,2948970.27249999 758350.094374999,2948883.546875 758346.342500001,2948872.91312499 758341.476875007,2948855.93125001 758336.708749995,2948839.28812499 758322.239374995,2948788.78812499 758301.582499996,2948720.9225 758429.459999993,2948687.52562501 758398.034374997,2948560.6275 758404.619375005,2948558.84125 758391.893124998,2948511.361875 758395.249375001,2948510.51000001 758379.345624998,2948450.083125 758513.186875001,2948414.13062499 758517.133125007,2948475.93625 758526.996250004,2948556.698125 758545.302499995,2948649.18125001 758674.743125007,2948619.72750001 758683.333124995,2948
 654.405625 758688.0625,2948673.5 758691.949375004,2948690.46375 758697.635625005,2948715.2825 758687.728125006,2948730.23 758710.350624993,2948831.65625 758600.355000004,2948857.73 758613.508125007,2948903.645 758503.906874999,2948934.17749999 758473.007499993,2948942.70125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>121834.315065234</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1783.59984011008</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__71’><BrooklineWMS:OBJECTID>71</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DA
 TE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756299.390000001,2948853.92749999 756301.864999995,2948842.965 756316.421875,2948778.5 756362.439999998,2948571.298125 756412.654375002,2948584.94312499 756445.518749997,2948589.328125 756484.849999994,2948590.02124999 756549.890000001,2948583.13124999 756599.778125003,2948570.41 756663.290625006,2948542.93062501 756677.461250007,2948571.21625 756731.609999999,2948664.203125 756651.665000007,2948710.50687499 756674.097499996,2948790.300625 756646.654375002,2948787.26875 756601.990624994,2948786.52437501 756530.528125003,2948778.33625001 756474.698125005,2948766.425625 756470.775625005,2948787.203125 756442.769999996,2948892.77437501 756310.034374997,2948855.955625 756299.390000001,2948853.92749999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></Brooklin
 eWMS:Shape><BrooklineWMS:Shape.area>85576.8399804688</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1394.95731372492</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__72’><BrooklineWMS:OBJECTID>72</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755964.056875005,2948795.049375 755959.596874997,2948753.96125001 755955.182500005,2948713.29000001 755953.989999995,2948699.801875 755947.995000005,2948649.420625 755936.
 671250001,2948549.344375 755933.912499994,2948519.37375 755972.462500006,2948512.623125 756027.028750002,2948508.418125 756091.181250006,2948508.863125 756169.276875004,2948518.80875 756362.439999998,2948571.298125 756316.421875,2948778.5 756301.864999995,2948842.965 756292.591250002,2948841.7475 756244.390625,2948832.6875 756230.413124993,2948830.06 756219.065624997,2948827.92749999 756179.128749996,2948820.420625 756175.342500001,2948819.70874999 756142.847499996,2948813.60124999 756105.770624995,2948809.83437499 756065.920000002,2948805.841875 756009.310000002,2948800.17 755996.871250004,2948798.92375 755994.198125005,2948798.655625 755964.056875005,2948795.049375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>112504.907858594</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1334.05503762535</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=’
 F1__73’><BrooklineWMS:OBJECTID>73</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755158.144374996,2948795.19625001 755153.353750005,2948796.06125 755148.386250004,2948796.480625 755126.229375005,2948798.35062499 755064.993750006,2948803.518125 755029.700000003,2948806.49625 755021.192499995,2948807.214375 754999.535624996,2948752.93875 754972.820625007,2948701.10062499 754929.507499993,2948645.15062501 754922.116249993,2948635.46625 754868.393124998,2948564.916875 754832.166875005,2948540.269375 75479
 2.199375004,2948477.47687501 754777.928749993,2948456.528125 754720.430625007,2948381.528125 754736.019374996,2948330.30687501 754703.573125005,2948266.10062499 754681.638750002,2948222.69437499 754664.398124993,2948188.578125 754647.479375005,2948155.096875 754645.784999996,2948151.745 754626.340000004,2948113.265 754602.283124998,2948065.31874999 754599.480000004,2948060.5575 754595.958749995,2947983.66312499 754595.745000005,2947978.996875 754594.309375003,2947947.645625 754591.997500002,2947897.16562501 754589.903750002,2947851.44687501 754587.576875001,2947800.644375 754584.229375005,2947768.9175 754593.174999997,2947753.92625 754605.780625001,2947732.799375 754612.055625007,2947722.72437499 754635.799999997,2947688.36624999 754637.473124996,2947685.660625 754641.179374993,2947682.75687499 754647.851875007,2947677.529375 754682.728125006,2947650.204375 754717.278750002,2947622.66187499 754724.824375004,2947616.645 754746.257499993,2947599.55437499 754757.993125007,2947590.19687501 754761.324375004,2947587
 .715625 754764.698125005,2947585.2925 754769.675624996,2947581.878125 754773.150000006,2947579.60187501 754777.571250007,2947576.82875 754781.132499993,2947574.690625 754784.730625004,2947572.61562499 754788.364999995,2947570.60375001 754792.033124998,2947568.655625 754795.734999999,2947566.77124999 754799.469374999,2947564.9525 754803.234999999,2947563.19875 754807.030625001,2947561.51125 754810.854375005,2947559.89 754814.706249997,2947558.33562499 754819.213750005,2947556.61562499 754822.276250005,2947555.50562499 754825.353750005,2947554.438125 754861.710624993,2947663.925625 754877.750624999,2947700.35187501 754920.038124993,2947801.951875 754929.420000002,2947824.49375001 754948.144374996,2947832.645 754950.202500001,2947833.54125001 754964.634375006,2947839.82375 754971.482500002,2947842.80500001 754983.171250001,2947847.893125 755043.890000001,2947874.32625 755109.598749995,2947908.33625001 755167.839375004,2947922.07375 755215.642499998,2947925.31874999 755243.529375002,2947927.21250001 755269.7987499
 98,2947928.995625 755320.246875003,2947932.420625 755334.96875,2947929.176875 755356.218125001,2947925.158125 755361.683750004,2947924.1375 755367.765625,2947922.876875 755372.837500006,2947921.72437499 755377.888125002,2947920.483125 755382.916250005,2947919.15375 755387.920625001,2947917.736875 755392.899375007,2947916.233125 755397.851249993,2947914.6425 755402.774375007,2947912.96625 755412.307500005,2947909.4425 755417.138125002,2947907.514375 755421.933750004,2947905.501875 755426.694374993,2947903.406875 755434.569999993,2947899.7175 755439.227500007,2947897.4025 755447.383750007,2947893.098125 755451.923749998,2947890.56 755456.418750003,2947887.94374999 755460.866874993,2947885.24875 755465.268124998,2947882.47687501 755469.619375005,2947879.62875 755473.920625001,2947876.704375 755478.170625001,2947873.705625 755482.635625005,2947870.433125 755486.775000006,2947867.28375 755490.857500002,2947864.0625 755494.884375006,2947860.77 755498.852500007,2947857.408125 755501.838750005,2947854.79875 755504.790
 000007,2947852.14937501 755511.808750004,2947845.55312499 755515.508750007,2947841.89812499 755519.144374996,2947838.17874999 755522.715000004,2947834.39687499 755526.21875,2947830.55312499 755529.655000001,2947826.64937501 755621.403125003,2947933.97499999 755632.248750001,2947950.796875 755654.974999994,2947929.19437499 755666.568124995,2947946.674375 755701.683125004,2948022.404375 755735.988749996,2948095.6925 755767.422499999,2948113.60062499 755787.669375002,2948331.551875 755822.152500004,2948538.94374999 755933.912499994,2948519.37375 755936.671250001,2948549.344375 755947.995000005,2948649.420625 755953.989999995,2948699.801875 755955.182500005,2948713.29000001 755959.596874997,2948753.96125001 755964.056875005,2948795.049375 755925.626249999,2948797.955625 755853.9375,2948805.89812499 755833.489999995,2948807.64687499 755830.513125002,2948780.47562499 755810.559375003,2948784.110625 755718.246250004,2948794.21625 755712.669375002,2948751.624375 755702.604375005,2948752.670625 755651.379374996,2948760
 .605625 755607.935000002,2948767.33625001 755573.627499998,2948772.65062501 755534.228125006,2948778.754375 755478.659999996,2948787.3625 755458.803124994,2948762.06 755432.046250001,2948762.219375 755415.236249998,2948762.31937499 755393.505624995,2948762.44875 755346.981250003,2948762.72499999 755337.709374994,2948762.780625 755312.164375007,2948767.391875 755273.407499999,2948774.38875 755230.813124999,2948782.078125 755180.459999993,2948791.168125 755158.144374996,2948795.19625001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1021576.79489336</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4703.4301084928</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__74’><BrooklineWMS:OBJECTID>74</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT
  HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>15</BrooklineWMS:CASE1><BrooklineWMS:CASE2>15</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752994.615624994,2948562.644375 753009.694999993,2948512.59937499 753037.141249999,2948421.61 753064.974999994,2948320.68125001 753243.297499999,2948374.41500001 753252.425624996,2948349.99625 753329.019999996,2948218.168125 753402.380624995,2948137.046875 753488.118125007,2948100.760625 753501.439999998,2948092.23625 753602.822500005,2948000 753653.696875006,2947953.715 753680.015625,2947913.583125 753723.105625004,2947883.82875 753705.831249997,2948000 753704.968125001,2948005.80625001 753676.103125006,2948119.793125 753591.386250004,2948454.33625001 753584.430625007,2948479.655625 753740.557500005,2948
 596.645625 753685.319999993,2948762.38187499 753173.948750004,2948611.74437501 752994.615624994,2948562.644375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>298346.616403125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2842.35265662565</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__75’><BrooklineWMS:OBJECTID>75</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs
 ><gml:LinearRing><gml:coordinates> 754929.507499993,2948645.15062501 754899.041875005,2948668.33 754874.751249999,2948686.81125 754844.808750004,2948709.5925 754841.443749994,2948712.151875 754819.818124995,2948729.129375 754800.102500007,2948744.6075 754798.276250005,2948745.90125 754795.691874996,2948747.36812501 754793.197500005,2948748.56937499 754788.758750007,2948750.24312501 754785.894374996,2948751.035 754782.981875002,2948751.62625 754780.035624996,2948752.011875 754777.069374993,2948752.191875 754774.097499996,2948752.16374999 754767.426874995,2948751.54375 754747.067499995,2948744.705 754691.843125001,2948726.155 754674.408124998,2948713.26000001 754658.03125,2948702.18375 754640.906874999,2948690.60250001 754553.620000005,2948604.343125 754536.132499993,2948612.74437501 754522.468125001,2948619.30875 754498.063749999,2948625.561875 754487.615624994,2948628.239375 754445.724374995,2948614.86 754411.699375004,2948603.99312501 754407.263750002,2948619.01125 754339.262500003,2948598.280625 754315.55437
 4993,2948593.83437499 754468.668750003,2948493.54125001 754434.526875004,2948475.1575 754435.523750007,2948469.77625 754467.441874996,2948364.69875 754472.607500002,2948344.72 754556.718125001,2948370.5175 754556.153125003,2948365.141875 754549.478750005,2948301.645 754531.195625007,2948200.94374999 754518.878749996,2948147.91625001 754496.331249997,2948072.81625 754469.325625002,2948000 754437.190624997,2947927.655625 754379.195625007,2947816.27500001 754416.638125002,2947724.496875 754439.019999996,2947679.916875 754461.183125004,2947643.22437499 754502.671875,2947594.16875 754506.282499999,2947591.065 754535.178749993,2947566.223125 754541.619375005,2947561.920625 754637.473124996,2947685.660625 754635.799999997,2947688.36624999 754612.055625007,2947722.72437499 754605.780625001,2947732.799375 754593.174999997,2947753.92625 754584.229375005,2947768.9175 754587.576875001,2947800.644375 754589.903750002,2947851.44687501 754591.997500002,2947897.16562501 754594.309375003,2947947.645625 754595.745000005,2947978
 .996875 754595.958749995,2947983.66312499 754599.480000004,2948060.5575 754602.283124998,2948065.31874999 754626.340000004,2948113.265 754645.784999996,2948151.745 754647.479375005,2948155.096875 754664.398124993,2948188.578125 754681.638750002,2948222.69437499 754703.573125005,2948266.10062499 754736.019374996,2948330.30687501 754720.430625007,2948381.528125 754777.928749993,2948456.528125 754792.199375004,2948477.47687501 754832.166875005,2948540.269375 754868.393124998,2948564.916875 754922.116249993,2948635.46625 754929.507499993,2948645.15062501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>249133.073592969</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3304.81458483519</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__76’><BrooklineWMS:OBJECTID>76</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><Brookline
 WMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757359.233750001,2948707.778125 757358.498750001,2948686.72125 757353.253749996,2948654.596875 757327.226249993,2948577.12 757321.456249997,2948564.51625 757462.571250007,2948527.4225 757431.197500005,2948459.564375 757393.043125004,2948377.04062501 757550.615624994,2948334.15125 757570.251249999,2948329.551875 757526.137500003,2948169.81625 757513.021249995,2948147.191875 757442.123750001,2948058.46625 757460.393124998,2948045.763125 757477.877499998,2948032.1225 757491.311250001,2948021.6425 757506.668125004,2948009.66249999 757520.8206
 25007,2947998.621875 757534.639375001,2947987.84125 757537.503124997,2947985.6075 757549.203749999,2947976.479375 757563.730000004,2947965.14687499 757576.043750003,2947955.54062501 757584.878749996,2947948.64812499 757591.344999999,2947943.60312501 757605.610624999,2947932.47499999 757620.297499999,2947921.016875 757632.151250005,2947911.769375 757644.966250002,2947901.77124999 757716.234999999,2947990.11499999 757727.860624999,2948008.06812499 757721.248750001,2948013.578125 757732.514375001,2948031.903125 757808.968125001,2948158.246875 757811.594999999,2948162.58812501 757827.106250003,2948216.91374999 757831.443124995,2948232.10375001 757844.729375005,2948278.636875 757863.051874995,2948342.80687501 757874.334999993,2948380.97624999 757821.266249999,2948395.925 757845.226249993,2948485.999375 757809.561250001,2948495.4075 757752.408749998,2948510.484375 757628.040625006,2948540.9075 757652.518749997,2948631.370625 757359.233750001,2948707.778125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gm
 l:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>222081.550133984</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2520.20278342127</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__77’><BrooklineWMS:OBJECTID>77</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752706.201875001,2948676.248125 752734.166875005,2948572.3775 752767.573750004,2948460.593125 752909.592500001,2
 948501.589375 752899.253124997,2948536.535 752853.275625005,2948691.94499999 752706.201875001,2948676.248125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>31183.59898125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>718.476881458756</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__78’><BrooklineWMS:OBJECTID>78</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gm
 l:LinearRing><gml:coordinates> 761039.788749993,2948290.768125 761098.349374995,2948436.83125 761107.693749994,2948464.7525 761135.493125007,2948547.81812499 761120.680000007,2948552.11624999 760905.159999996,2948663.435625 760889.0625,2948682.6375 760859.364374995,2948444.89687499 760844.279375002,2948302.013125 760836.946875006,2948261.916875 760753.581874996,2947926.595625 760732.923749998,2947866.08374999 760708.469999999,2947807.003125 760606.946875006,2947605.83374999 760473.833124995,2947349.94125 760579.838750005,2947253.66500001 760568,2947228.75 760545.5,2947190.5 760479.549999997,2947107.3075 760556.122500002,2947030.735 760654.169375002,2946955.565625 760735.875,2946886.933125 760821.857500002,2946817.591875 760866.09375,2946874.703125 761155.003124997,2947244.34375 761235.677499995,2947349.2675 761235.776875004,2947428.298125 761228.398124993,2947476.89375 761213.873125002,2947541.223125 761195.298124999,2947604.501875 761172.746875003,2947666.47375 761108.391874999,2947807.25687499 761102.3981249
 93,2947842.315625 761103.220624998,2947906.23875 761131.271249995,2947991.659375 761150.901875004,2948039.84875 761176.475624993,2948085.16625001 761197.160624996,2948112.02500001 761039.788749993,2948290.768125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>748701.447259375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4459.08926596855</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__79’><BrooklineWMS:OBJECTID>79</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><Brooklin
 eWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752565.053749993,2948649.000625 752599.403125003,2948522.566875 752581.704374999,2948518.67937499 752547.909374997,2948509.25 752528.053749993,2948503.70999999 752509.225624993,2948498.456875 752489.677499995,2948493.0025 752462.708749995,2948485.47812501 752465.083749995,2948477.61624999 752471.344374999,2948456.8925 752472.588750005,2948452.77249999 752477.814999998,2948435.47125 752482.086875007,2948421.328125 752484.627499998,2948412.91875 752493.826875001,2948382.464375 752627.245000005,2948420.08499999 752666.433750004,2948275.83625001 752681.422499999,2948213.456875 752970.858125001,2948294.01625 753044.563749999,2948314.53125 753064.974999994,2948320.68125001 753037.141249999,2948421.61 753009.694999993,2948512.59937499 752994.615624994,2948562.644375 752899.253124997,2948536.535 752909.592500001,2948501.589375 752767.573750004,2948460.593125 752734.166875005,2948572.3
 775 752706.201875001,2948676.248125 752645.836875007,2948669.80500001 752565.053749993,2948649.000625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>137377.640615625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2034.3058257395</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__80’><BrooklineWMS:OBJECTID>80</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRin
 g><gml:coordinates> 758545.302499995,2948649.18125001 758526.996250004,2948556.698125 758517.133125007,2948475.93625 758513.186875001,2948414.13062499 758379.345624998,2948450.083125 758375.820625007,2948451.26625 758360.519999996,2948392.769375 758370.394999996,2948362.671875 758365.758125007,2948347.61687499 758380.361249998,2948343.74375001 758355.546250001,2948248.439375 758357.714375004,2948206.87 758323.553749993,2948072.06999999 758311.162499994,2948024.433125 758311.123125002,2948024.281875 758316.198125005,2948022.9875 758332.030625001,2948026.92812499 758353.407499999,2948032.24875 758397.700625002,2947934.546875 758410.625624999,2947838.144375 758475.344374999,2947818.05875 758541.229375005,2947690.13312501 758582.477500007,2947690.74375001 758608.975624993,2947648.564375 758655.034999996,2947602.86937501 758657.572500005,2947599.88875 758672.825000003,2947583.49250001 758772.521874994,2947680.61750001 758841.282499999,2947744.671875 758960.504999995,2947855.733125 759000,2947899.74250001 759015.938
 749999,2947917.503125 759025.426874995,2947927.096875 759010.933750004,2947943.063125 758947.510625005,2948013.02312499 758943.982500002,2948016.91500001 758906.453125,2948058.311875 758860.800624996,2948108.67 758835.549999997,2948113.826875 758788.114374995,2948171.576875 758807.75,2948238.25 758879.625,2948402.25 758895.8125,2948401.25 758932.476249993,2948492.53812499 758943.811875001,2948553.39937501 758904.489374995,2948563.00125 758684.375,2948616.75 758674.743125007,2948619.72750001 758545.302499995,2948649.18125001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>447051.997041406</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3146.59819326592</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__81’><BrooklineWMS:OBJECTID>81</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWM
 S:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754315.554374993,2948593.83437499 754268.197500005,2948624.85375001 754255.066249996,2948646.739375 754247.178124994,2948614.139375 754238.146874994,2948550.07187501 754223.879374996,2948448.861875 754217.731875002,2948449.28749999 754206.614999995,2948446.94374999 754202.832499996,2948446.14624999 754185.556250006,2948440.69875 754168.158124998,2948434.84 754146.219374999,2948427.451875 754120.983750001,2948418.954375 754109.272499993,2948415.01000001 754097.685000002,2948411.108125 754078.038749993,2948404.49250001 754073.121250004,2948402.83625001 754048.1787499
 93,2948394.436875 754031.144999996,2948388.70125 754019.198125005,2948384.69750001 754008.886875004,2948381.24124999 753990.708124995,2948375.005 753961.323750004,2948364.925 753904.555625007,2948345.45125 753885.748750001,2948339.576875 753865.614374995,2948417.05125 753846.379999995,2948412.32375 753747.045625001,2948386.48999999 753807.180000007,2948150.92375 753911.290000007,2947624.41 753960.903125003,2947634.200625 753975.137500003,2947609.26000001 754051.757499993,2947667.94374999 754070.721874997,2947677.8475 754044.155625001,2947734.41 754038.662499994,2947749.75 754029.474999994,2947775.405625 754000,2947889.874375 753971.643124998,2948000 753924.498750001,2948183.08812501 754305.046875,2948295.46875 754302.669375002,2948224.121875 754304.821250007,2948152.76875 754311.493750006,2948081.69625001 754322.661874995,2948011.18875 754325.170625001,2948000 754338.278125003,2947941.531875 754353.908124998,2947885.598125 754359.007499993,2947871.61937501 754379.195625007,2947816.27500001 754437.190624997,294
 7927.655625 754469.325625002,2948000 754496.331249997,2948072.81625 754518.878749996,2948147.91625001 754531.195625007,2948200.94374999 754549.478750005,2948301.645 754556.153125003,2948365.141875 754556.718125001,2948370.5175 754472.607500002,2948344.72 754467.441874996,2948364.69875 754435.523750007,2948469.77625 754434.526875004,2948475.1575 754468.668750003,2948493.54125001 754315.554374993,2948593.83437499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>305191.278432812</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4263.18995099538</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__82’><BrooklineWMS:OBJECTID>82</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE
 1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756362.439999998,2948571.298125 756169.276875004,2948518.80875 756091.181250006,2948508.863125 756027.028750002,2948508.418125 755972.462500006,2948512.623125 755933.912499994,2948519.37375 755822.152500004,2948538.94374999 755787.669375002,2948331.551875 755803.575000003,2948330.99625 755873.418750003,2948324.263125 756102.314999998,2948286.416875 756191.305000007,2948287.708125 756278.441874996,2948305.81812499 756360.578125,2948340.091875 756366.116249993,2948343.69625001 756355.471874997,2948360.25937501 756311.141874999,2948433.46375 756318.302499995,2948436.41312499 756361.966250002,2948454.39687499 756367.941874996,2948456.858125 756378.591250002,
 2948461.24437501 756401.373125002,2948493.685 756459.661249995,2948490.154375 756485.686875001,2948491.110625 756484.849999994,2948590.02124999 756445.518749997,2948589.328125 756412.654375002,2948584.94312499 756362.439999998,2948571.298125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>132888.808914063</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1878.04262362074</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__83’><BrooklineWMS:OBJECTID>83</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>
 </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752345.961250007,2948340.77 752327.282499999,2948434.29625 752187.429374993,2948397.45999999 752179.016874999,2948449.59625 752008.034999996,2948365.27562501 751985.590625003,2948354.81999999 751991.686875001,2948348.55687501 752032.133125007,2948295.68875 752035.446875006,2948291.356875 752059.419375002,2948254.47499999 752083.549999997,2948259.88625 752203.995625004,2948292.49062499 752200.543125004,2948306.3725 752245.556250006,2948317.63625 752325.723749995,2948337.69687501 752345.961250007,2948340.77</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>38405.2813007813</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>946.282778378884</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=
 ‘F1__84’><BrooklineWMS:OBJECTID>84</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752493.826875001,2948382.464375 752345.961250007,2948340.77 752376.818124995,2948195.69562501 752393.267499998,2948132.70125 752107.795625001,2948052.41374999 752000,2948020.76000001 751892.145624995,2947989.09 751863.028125003,2948091.41125 751843.236249998,2948159.754375 751834.262500003,2948190.74187499 751520.1875,2948096.75 751136.875,2947977.75 751253.007499993,2947612.52625 751296.045625001,2947626.22562499 751333
 .022499993,2947637.845 751363.626874998,2947647.46125001 751369.895624995,2947649.43062501 751405.881874993,2947660.73875 751443.340000004,2947672.50875001 751481.731875002,2947684.57187501 751519.893124998,2947696.563125 751630.491874993,2947730.1675 751712.795000002,2947432.1675 751856.323125005,2947468.2075 752311.456874996,2947586.205625 752293.523124993,2947648.58562499 752197.495000005,2947760.364375 752207.413124993,2947779.45 752242.618125007,2947788.281875 752214.129999995,2947888.894375 752252.001874998,2947899.42125 752293.265625,2947910.89125 752332.245000005,2947921.72624999 752370.309375003,2947932.30687501 752410.432500005,2947943.45999999 752447.947500005,2947953.888125 752486.037499994,2947964.47562499 752522.207499996,2947974.529375 752608.620625004,2947997.020625 752648.508125007,2948007.878125 752687.637500003,2948018.528125 752726.317499995,2948029.05625001 752766.158749998,2948039.90000001 752809.218125001,2948051.62 752828.689374998,2947981.063125 753025.726249993,2948033.05125 753048.23
 3750001,2948040.144375 753060.560000002,2948000 753099.961875007,2947869.03625 753106.219999999,2947837.7075 753107.739999995,2947780.24437501 753098.896249995,2947732.870625 753068.896874994,2947659.733125 753191.753749996,2947631.06812499 753256.409999996,2947616.39 753301.766874999,2947603.82062501 753315.793125004,2947599.84375 753390.041875005,2947575.73999999 753462.611874998,2947546.97562499 753533.211875007,2947513.66562501 753587.963750005,2947485.676875 753605.215000004,2947475.92812499 753636.098749995,2947458.136875 753751.796875,2947385.171875 753862.633750007,2947305.016875 753868.645624995,2947300.371875 753900.721249998,2947275.591875 753918.388750002,2947305.095 753888.196250007,2947332.564375 753861.345624998,2947352.333125 753841.717500001,2947378.60875 753785.334999993,2947454.08499999 753802.757499993,2947468.81812499 753880.129374996,2947534.24375001 753882.03125,2947539.27 753884.114999995,2947555.830625 753886.747500002,2947575.13312501 753911.290000007,2947624.41 753807.180000007,29481
 50.92375 753676.103125006,2948119.793125 753704.968125001,2948005.80625001 753705.831249997,2948000 753723.105625004,2947883.82875 753680.015625,2947913.583125 753653.696875006,2947953.715 753602.822500005,2948000 753501.439999998,2948092.23625 753488.118125007,2948100.760625 753402.380624995,2948137.046875 753329.019999996,2948218.168125 753252.425624996,2948349.99625 753243.297499999,2948374.41500001 753064.974999994,2948320.68125001 753044.563749999,2948314.53125 752970.858125001,2948294.01625 752681.422499999,2948213.456875 752666.433750004,2948275.83625001 752627.245000005,2948420.08499999 752493.826875001,2948382.464375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1274630.81174062</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>9156.25232554424</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__85’><BrooklineWMS:OBJECTID>85</Brookli
 neWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757550.615624994,2948334.15125 757393.043125004,2948377.04062501 757305.740624994,2948400.80312499 757294.665625006,2948351.50562499 757286.90625,2948316.964375 757273.385625005,2948256.7775 757281.851875007,2948254.68000001 757288.140000001,2948211.98999999 757297.471249998,2948148.639375 757269.1875,2948128.75 757254.9375,2948123 757188.910624996,2948087.5 757161.234999999,2948071.169375 757182.256874993,2948049.096875 757214.834374994,2948000 757301.412499994,
 2947882.37 757383.045000002,2947777.596875 757411.493750006,2947738.41625001 757481.148750007,2947630.84125 757510.096874997,2947648.10375001 757581.256874993,2947693.613125 757612.272499993,2947695.04375 757655.491249993,2947723.839375 757617.323125005,2947748.73625 757601.372500002,2947759.151875 757591,2947767.75 757613.8125,2947794.5 757680.260000005,2947874.05875 757644.966250002,2947901.77124999 757632.151250005,2947911.769375 757620.297499999,2947921.016875 757605.610624999,2947932.47499999 757591.344999999,2947943.60312501 757584.878749996,2947948.64812499 757576.043750003,2947955.54062501 757563.730000004,2947965.14687499 757549.203749999,2947976.479375 757537.503124997,2947985.6075 757534.639375001,2947987.84125 757520.820625007,2947998.621875 757506.668125004,2948009.66249999 757491.311250001,2948021.6425 757477.877499998,2948032.1225 757460.393124998,2948045.763125 757442.123750001,2948058.46625 757513.021249995,2948147.191875 757526.137500003,2948169.81625 757570.251249999,2948329.551875 757550.61
 5624994,2948334.15125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>189673.612915234</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2264.09465112497</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__86’><BrooklineWMS:OBJECTID>86</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752032.133125007,2948295.68875 751959.263125002,294827
 5.065625 751874.178124994,2948249.955625 751824.630624995,2948235.33437499 751835.125,2948191 751834.262500003,2948190.74187499 751843.236249998,2948159.754375 751863.028125003,2948091.41125 751892.145624995,2947989.09 752000,2948020.76000001 752107.795625001,2948052.41374999 752393.267499998,2948132.70125 752376.818124995,2948195.69562501 752345.961250007,2948340.77 752325.723749995,2948337.69687501 752245.556250006,2948317.63625 752200.543125004,2948306.3725 752203.995625004,2948292.49062499 752083.549999997,2948259.88625 752059.419375002,2948254.47499999 752035.446875006,2948291.356875 752032.133125007,2948295.68875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>121061.869475</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1569.85585466912</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__87’><BrooklineWMS:OBJECTID>87</BrooklineWMS:OBJE
 CTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754038.662499994,2947749.75 754057.610624999,2947756.434375 754200.831874996,2947810.50875001 754340.168125004,2947862.53687499 754359.007499993,2947871.61937501 754353.908124998,2947885.598125 754338.278125003,2947941.531875 754325.170625001,2948000 754322.661874995,2948011.18875 754311.493750006,2948081.69625001 754304.821250007,2948152.76875 754302.669375002,2948224.121875 754305.046875,2948295.46875 753924.498750001,2948183.08812501 753971.643124998,2948000 754000,2947
 889.874375 754029.474999994,2947775.405625 754038.662499994,2947749.75</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>155138.81943125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1617.74242515846</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__88’><BrooklineWMS:OBJECTID>88</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757613
 .8125,2947794.5 757591,2947767.75 757601.372500002,2947759.151875 757617.323125005,2947748.73625 757655.491249993,2947723.839375 757612.272499993,2947695.04375 757581.256874993,2947693.613125 757510.096874997,2947648.10375001 757481.148750007,2947630.84125 757573.901250005,2947487.595625 757597.524375007,2947451.61 757615.430625007,2947430.470625 757655.081249997,2947391.80875 757686.164375007,2947367.645625 757743.368750006,2947335.67812499 757827.832499996,2947303.49437501 757921.118750006,2947267.948125 758015.683125004,2947230.37625 758027.439374998,2947258.214375 758101.071875006,2947443.763125 758184.112499997,2947418.739375 758176.502499998,2947383.3275 758212.653125003,2947389.745625 758246.603125006,2947395.77312499 758283.049999997,2947402.24375001 758332.768124998,2947436.03749999 758346.635000005,2947445.46250001 758366.451875001,2947458.9325 758434.693124995,2947389.251875 758452.867500007,2947373.07187501 758554.905000001,2947468.61499999 758672.825000003,2947583.49250001 758657.572500005,2947599
 .88875 758655.034999996,2947602.86937501 758608.975624993,2947648.564375 758582.477500007,2947690.74375001 758541.229375005,2947690.13312501 758475.344374999,2947818.05875 758410.625624999,2947838.144375 758397.700625002,2947934.546875 758353.407499999,2948032.24875 758332.030625001,2948026.92812499 758316.198125005,2948022.9875 758311.123125002,2948024.281875 758311.162499994,2948024.433125 757808.968125001,2948158.246875 757732.514375001,2948031.903125 757721.248750001,2948013.578125 757727.860624999,2948008.06812499 757716.234999999,2947990.11499999 757716.197500005,2947990.06812499 757752.060000002,2947960.25 757878.929374993,2947854.765 757901.167500004,2947837.88625 757914.5,2947829.5 757932,2947820.25 757947.784999996,2947813.61875001 757957.741874993,2947809.43625 757849.310000002,2947602.5 757733.25,2947674 757758.060000002,2947704.75 757717.560000002,2947730 757763.560000002,2947788 757715.140000001,2947826.401875 757724.873750001,2947838.675 757680.260000005,2947874.05875 757613.8125,2947794.5</gml:
 coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757679.671250001,2947874.52562501 757644.966250002,2947901.77124999 757680.260000005,2947874.05875 757679.671250001,2947874.52562501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>584233.110837891</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4519.36624408155</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__89’><BrooklineWMS:OBJECTID>89</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MOD
 IFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 761197.160624996,2948112.02500001 761176.475624993,2948085.16625001 761150.901875004,2948039.84875 761131.271249995,2947991.659375 761103.220624998,2947906.23875 761102.398124993,2947842.315625 761108.391874999,2947807.25687499 761172.746875003,2947666.47375 761195.298124999,2947604.501875 761213.873125002,2947541.223125 761228.398124993,2947476.89375 761235.776875004,2947428.298125 761235.677499995,2947349.2675 761155.003124997,2947244.34375 760866.09375,2946874.703125 760874.459999993,2946738.973125 760869.719374999,2946698.2925 760859.844999999,2946667.863125 760806.666250005,2946578.419375 760754.108125001,2946508.07187501 760649.018124998,2946381.35312501 760631.603125006,2946352.36812501 760619.988749996,2946320.61 760614.21875,2946275.948125 760617.381874993,2946242.28125 760631.31937
 4993,2946199.595625 760637.549374998,2946158.120625 760663.283124998,2946161.47875001 760669.606250003,2946162.30374999 760676.213125005,2946164.49875 760726.679374993,2946173.33 760741.75,2946274.25 760789.3125,2946492.75 760904,2946688.25 760966.6875,2946821.25 761063.875,2946960 761218.125,2947153 761340,2947271.75 761438.6875,2947412 761441.125,2947524 761282.625,2947637.25 761406.625,2947815.75 761279.8125,2948035.25 761220.634375006,2948142.50749999 761197.160624996,2948112.02500001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>269678.926348047</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4695.0917654068</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__90’><BrooklineWMS:OBJECTID>90</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-
 FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753025.726249993,2948033.05125 752828.689374998,2947981.063125 752809.218125001,2948051.62 752766.158749998,2948039.90000001 752726.317499995,2948029.05625001 752687.637500003,2948018.528125 752648.508125007,2948007.878125 752608.620625004,2947997.020625 752522.207499996,2947974.529375 752486.037499994,2947964.47562499 752447.947500005,2947953.888125 752410.432500005,2947943.45999999 752370.309375003,2947932.30687501 752332.245000005,2947921.72624999 752293.265625,2947910.89125 752252.001874998,2947899.42125 752214.129999995,2947888.894375 752242.618125007,2947788.281875 752207.413124993,2947779.45 752197.4
 95000005,2947760.364375 752293.523124993,2947648.58562499 752311.456874996,2947586.205625 752363.742500007,2947404.33625001 752207.720624998,2947368.7225 752397.188124999,2947278.644375 752458.188749999,2947244.910625 752632.290000007,2947127.200625 752662.334999993,2947103.809375 752689.180000007,2947076.796875 752864.503749996,2946865.53 752911.678124994,2946802.95625 752935.634375006,2946754.23375 752956.827500001,2946726.455625 752977.03125,2946722.74312501 753012.608750001,2946717.20874999 753038.476249993,2946712.1925 753367.073750004,2947035.52375001 753395.272499993,2947018.4375 753409.056250006,2947043.126875 753482.275625005,2947178.73875 753531.739999995,2947145.80437499 753564.255624995,2947194.80374999 753665.585624993,2947124.376875 753705.657499999,2947094.77187499 753806.658749998,2947044.26000001 753789.325000003,2947004.33687501 753857.841250002,2946957.3275 753880.390000001,2946941.8575 753877.299374998,2946936.30625001 753888.383125007,2946927.609375 753919.706249997,2946903.033125 753955.5
 60000002,2946874.901875 753966.499375001,2946866.31874999 754009.211875007,2946832.80562501 754063.252499998,2946790.405 754073.998750001,2946781.973125 754108.406874999,2946754.97624999 754139.375,2946730.67812499 754153.996250004,2946719.205625 754159.467500001,2946715.698125 754213.936875001,2946680.77375001 754226.398750007,2946672.783125 754263.023124993,2946649.36624999 754299.486249998,2946626.05312499 754318.194999993,2946614.09125 754357.214375004,2946589.143125 754377.475624993,2946576.28812499 754397.279375002,2946563.723125 754412.253124997,2946553.44625001 754435.511250004,2946537.4825 754479.043750003,2946507.604375 754486.011250004,2946517.715 754494.801249996,2946511.654375 754527.669375002,2946488.99062499 754569.223124996,2946460.33812501 754576.071875006,2946455.61499999 754539.267499998,2946382.29625 754535.751249999,2946372.49437501 754661.460624993,2946311.61624999 754829.073125005,2946234.925625 754944.504999995,2946144.794375 754985.617500007,2946083.125625 755006.964375004,2946053.8725
  755026.616249993,2946061.57062501 755093.825000003,2946089.216875 755124.541875005,2946115.14812499 755147.893749997,2946149.02562501 755223.093125001,2946297.98 755147.078749999,2946337.418125 755056.450000003,2946391.996875 754969.504374996,2946452.185 754908.291250005,2946497.12375 754752.453125,2946616.313125 754630.143124998,2946711.33 754525.815624997,2946791.89125 754463.401875004,2946840.08687501 754358.418750003,2946921.05125 754165.294375002,2947070.433125 754057.449375004,2947155.03812499 753991.896874994,2947205.406875 753900.721249998,2947275.591875 753868.645624995,2947300.371875 753862.633750007,2947305.016875 753751.796875,2947385.171875 753636.098749995,2947458.136875 753605.215000004,2947475.92812499 753587.963750005,2947485.676875 753533.211875007,2947513.66562501 753462.611874998,2947546.97562499 753390.041875005,2947575.73999999 753315.793125004,2947599.84375 753301.766874999,2947603.82062501 753256.409999996,2947616.39 753191.753749996,2947631.06812499 753068.896874994,2947659.733125 753
 098.896249995,2947732.870625 753107.739999995,2947780.24437501 753106.219999999,2947837.7075 753099.961875007,2947869.03625 753060.560000002,2948000 753048.233750001,2948040.144375 753025.726249993,2948033.05125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1598346.51107344</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>8818.58469086834</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__91’><BrooklineWMS:OBJECTID>91</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:S
 hape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757182.256874993,2948049.096875 756889.355625004,2947795.435625 756775.838750005,2947812.253125 756745.367500007,2947803.985625 756646.930625007,2947781.280625 756535.221874997,2947772.871875 756497.325625002,2947765.56375 756442.973124996,2947745.77375001 756409.248750001,2947727.00624999 756379.158124998,2947704.895 756287.593125001,2947611.066875 756192.673749998,2947519.99124999 756135.295000002,2947471.55312499 755913.439999998,2947479.25624999 755869.373125002,2947420.12875 755797.511250004,2947349.105625 755713.246875003,2947283.313125 755668.155625001,2947254.55562501 755621.331874996,2947228.716875 755509.483125001,2947181.583125 755414.019999996,2947151.76875 755392.139375001,2947147.890625 755436.791875005,2947031.573125 755400.269999996,2946999.38437501 755335.323750004,2946942.14375 755324.794375002,2946932.06 755485.651875004,2946817.503125 755576.325625002,2946747.852
 50001 755631.654375002,2946705.35124999 755644.129999995,2946695.768125 755659.679374993,2946712.5125 755704.968125001,2946692.688125 755746.888125002,2946526.591875 755753.263125002,2946506.659375 755831.024375007,2946538.901875 755865.019999996,2946574.69499999 755953.448125005,2946561.825 756099.685000002,2946498.38 756119.765625,2946592.29000001 756142.408124998,2946663.875 756173.930000007,2946732.01375 756213.825000003,2946795.61687499 756261.484375,2946853.69437499 756393.053749993,2946996.875625 756479.036249995,2946916.11 756542.125,2946833.5 756562.765625,2946856.15875 756650.525625005,2946761.28375 756660.46875,2946776.684375 756700.626249999,2946817.3925 756726.394999996,2946843.515625 756740.661874995,2946857.97750001 756770.147499993,2946887.86812501 756786.798124999,2946904.7475 756812.784374997,2946931.09 756828.453749999,2946946.97499999 756847.620000005,2946966.40375 756868.281874999,2946987.34999999 756890.915000007,2947010.29375 756902.034374997,2947021.565625 756939.275625005,2947000.19875
  756982.318124995,2946988.5475 757001.206249997,2947025.635625 757005.416250005,2947033.901875 757027.273124993,2947076.81937499 757043.292500004,2947068.62375 757102.589375004,2947038.28749999 757123.319999993,2947033.4575 757204.935000002,2947115.7 757348.385000005,2947254.576875 757573.901250005,2947487.595625 757481.148750007,2947630.84125 757411.493750006,2947738.41625001 757383.045000002,2947777.596875 757301.412499994,2947882.37 757214.834374994,2948000 757182.256874993,2948049.096875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1597926.30425313</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6382.0456417982</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__92’><BrooklineWMS:OBJECTID>92</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>SC-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>17</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>TWO
 -FAMILY & ATTACHED SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>26</BrooklineWMS:CASE1><BrooklineWMS:CASE2>25</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>SC-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755632.248750001,2947950.796875 755621.403125003,2947933.97499999 755529.655000001,2947826.64937501 755536.236249998,2947818.7675 755539.465625003,2947814.690625 755542.622500002,2947810.5575 755545.707499996,2947806.37 755548.71875,2947802.129375 755551.655625001,2947797.83687501 755554.516874999,2947793.49375001 755556.443124995,2947789.754375 755558.332499996,2947786.298125 755559.939374998,2947783.22437499 755561.492500007,2947780.1225 755562.991249993,2947776.99437501 755564.434375003,2947773.84 755565.823750004,2947770.66125 755567.15625,2947767.45874999 755568.43312500
 4,2947764.233125 755569.653750002,2947760.98625 755570.816874996,2947757.718125 755571.923124999,2947754.43062501 755573.237499997,2947750.454375 755573.942499995,2947748.139375 755574.606875002,2947745.813125 755575.230000004,2947743.47499999 755575.8125,2947741.126875 755576.353750005,2947738.76875 755576.854375005,2947736.40125 755577.313124999,2947734.02562501 755577.730000004,2947731.6425 755578.105625004,2947729.2525 755578.439374998,2947726.85625 755578.731250003,2947724.454375 755578.981250003,2947722.0475 755579.189374998,2947719.636875 755579.355625004,2947717.223125 755579.479375005,2947714.80687501 755579.561250001,2947712.38875 755579.599999994,2947709.969375 755579.597499996,2947707.55 755579.551874995,2947705.13062499 755579.465000004,2947702.71250001 755579.334999993,2947700.296875 755579.163749993,2947697.88312501 755578.950000003,2947695.473125 755578.700625002,2947689.52562501 755578.472499996,2947686.05374999 755578.184375003,2947682.58687501 755577.835624993,2947679.125625 755577.426249996
 ,2947675.67125 755576.595624998,2947669.83374999 755576.024375007,2947666.401875 755575.393124998,2947662.980625 755574.702500001,2947659.57125001 755573.952500001,2947656.17375 755573.143749997,2947652.79062501 755572.275625005,2947649.42125 755571.348749995,2947646.06874999 755570.363749996,2947642.731875 755569.320625007,2947639.41312499 755568.219999999,2947636.113125 755567.061250001,2947632.8325 755565.845624998,2947629.573125 755564.573750004,2947626.33499999 755563.245000005,2947623.12 755561.860624999,2947619.92812499 755560.420625001,2947616.76125 755558.204999998,2947611.99250001 755556.403750002,2947608.42874999 755554.479375005,2947604.93000001 755552.433750004,2947601.500625 755550.269999996,2947598.144375 755547.989999995,2947594.86562499 755623.410624996,2947511.760625 755637.15625,2947497.541875 755634.136250004,2947494.80500001 755604.728750005,2947474.285 755541.773124993,2947443.27 755446.758750007,2947410.61562499 755329.071250007,2947384.96125001 755252.686875001,2947377.86624999 755245.6
 37500003,2947256.121875 755237.842500001,2947149.7625 755213.818749994,2947154.766875 755166.021874994,2947171.261875 755025.246250004,2947232.231875 754973.439374998,2947260.064375 754912.944999993,2947298.16625001 754853.754999995,2947341.39 754705.826250002,2947452.23125 754657.686250001,2947484.388125 754580.537499994,2947372.89 754627.543125004,2947339.31874999 754528.139375001,2947219.89875001 754767.383125007,2947019.145 754737.348749995,2946990.33687501 754711.026875004,2946975.13375001 754669.480000004,2946961.20999999 754623.748125002,2946953.88500001 754576.040625006,2946955.620625 754545.849374995,2946824.58374999 754525.815624997,2946791.89125 754630.143124998,2946711.33 754752.453125,2946616.313125 754908.291250005,2946497.12375 754969.504374996,2946452.185 755056.450000003,2946391.996875 755147.078749999,2946337.418125 755223.093125001,2946297.98 755240.986874998,2946288.69562501 755337.796250001,2946246.02875 755422.634375006,2946214.45999999 755450.454999998,2946205.746875 755512.838125005,294
 6188.11125 755553.008750007,2946178.11875001 755562.238124996,2946176.201875 755601.023124993,2946168.436875 755637.417500004,2946313.715 755641.336875007,2946329.533125 755673.625,2946463.25 755679.041875005,2946481.75937501 755719.108125001,2946492.496875 755753.263125002,2946506.659375 755746.888125002,2946526.591875 755704.968125001,2946692.688125 755659.679374993,2946712.5125 755644.129999995,2946695.768125 755631.654375002,2946705.35124999 755576.325625002,2946747.85250001 755485.651875004,2946817.503125 755324.794375002,2946932.06 755335.323750004,2946942.14375 755400.269999996,2946999.38437501 755436.791875005,2947031.573125 755392.139375001,2947147.890625 755414.019999996,2947151.76875 755509.483125001,2947181.583125 755621.331874996,2947228.716875 755668.155625001,2947254.55562501 755713.246875003,2947283.313125 755797.511250004,2947349.105625 755869.373125002,2947420.12875 755913.439999998,2947479.25624999 755944.185000002,2947533.191875 755972.643124998,2947602.44687501 755998.519374996,2947692.408
 125 756006.963750005,2947768.886875 756000.783749998,2947845.583125 755988.626874998,2947895.46187501 755976.900625005,2947925.86750001 755959.696250007,2947919.52500001 755853.758125007,2947872.07062501 755748.291875005,2947824.8275 755728.956874996,2947818.86937501 755723.054374993,2947835.67812499 755707.930000007,2947865.85187501 755678.403125003,2947906.925 755654.974999994,2947929.19437499 755632.248750001,2947950.796875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1116476.74648633</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7030.07922762229</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__93’><BrooklineWMS:OBJECTID>93</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>SC-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>17</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>TWO-FAMILY & ATTACHED SINGLE-FAMILY</BrooklineWMS:ZONEDESC><Brook
 lineWMS:CASE1>27</BrooklineWMS:CASE1><BrooklineWMS:CASE2>26</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>SC-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754637.473124996,2947685.660625 754541.619375005,2947561.920625 754657.686250001,2947484.388125 754705.826250002,2947452.23125 754853.754999995,2947341.39 754912.944999993,2947298.16625001 754973.439374998,2947260.064375 755025.246250004,2947232.231875 755166.021874994,2947171.261875 755213.818749994,2947154.766875 755237.842500001,2947149.7625 755245.637500003,2947256.121875 755252.686875001,2947377.86624999 755329.071250007,2947384.96125001 755446.758750007,2947410.61562499 755541.773124993,2947443.27 755604.728750005,2947474.285 755634.136250004,2947494.80500001 755637.15625,2947497.541875 755623.410624996,2947511.760625 755547.989999995,
 2947594.86562499 755550.269999996,2947598.144375 755552.433750004,2947601.500625 755554.479375005,2947604.93000001 755556.403750002,2947608.42874999 755558.204999998,2947611.99250001 755560.420625001,2947616.76125 755561.860624999,2947619.92812499 755563.245000005,2947623.12 755564.573750004,2947626.33499999 755565.845624998,2947629.573125 755567.061250001,2947632.8325 755568.219999999,2947636.113125 755569.320625007,2947639.41312499 755570.363749996,2947642.731875 755571.348749995,2947646.06874999 755572.275625005,2947649.42125 755573.143749997,2947652.79062501 755573.952500001,2947656.17375 755574.702500001,2947659.57125001 755575.393124998,2947662.980625 755576.024375007,2947666.401875 755576.595624998,2947669.83374999 755577.426249996,2947675.67125 755577.835624993,2947679.125625 755578.184375003,2947682.58687501 755578.472499996,2947686.05374999 755578.700625002,2947689.52562501 755578.950000003,2947695.473125 755579.163749993,2947697.88312501 755579.334999993,2947700.296875 755579.465000004,2947702.71250
 001 755579.551874995,2947705.13062499 755579.597499996,2947707.55 755579.599999994,2947709.969375 755579.561250001,2947712.38875 755579.479375005,2947714.80687501 755579.355625004,2947717.223125 755579.189374998,2947719.636875 755578.981250003,2947722.0475 755578.731250003,2947724.454375 755578.439374998,2947726.85625 755578.105625004,2947729.2525 755577.730000004,2947731.6425 755577.313124999,2947734.02562501 755576.854375005,2947736.40125 755576.353750005,2947738.76875 755575.8125,2947741.126875 755575.230000004,2947743.47499999 755574.606875002,2947745.813125 755573.942499995,2947748.139375 755573.237499997,2947750.454375 755571.923124999,2947754.43062501 755570.816874996,2947757.718125 755569.653750002,2947760.98625 755568.433125004,2947764.233125 755567.15625,2947767.45874999 755565.823750004,2947770.66125 755564.434375003,2947773.84 755562.991249993,2947776.99437501 755561.492500007,2947780.1225 755559.939374998,2947783.22437499 755558.332499996,2947786.298125 755556.443124995,2947789.754375 755554.51687
 4999,2947793.49375001 755551.655625001,2947797.83687501 755548.71875,2947802.129375 755545.707499996,2947806.37 755542.622500002,2947810.5575 755539.465625003,2947814.690625 755536.236249998,2947818.7675 755529.655000001,2947826.64937501 755526.21875,2947830.55312499 755522.715000004,2947834.39687499 755519.144374996,2947838.17874999 755515.508750007,2947841.89812499 755511.808750004,2947845.55312499 755504.790000007,2947852.14937501 755501.838750005,2947854.79875 755498.852500007,2947857.408125 755494.884375006,2947860.77 755490.857500002,2947864.0625 755486.775000006,2947867.28375 755482.635625005,2947870.433125 755478.170625001,2947873.705625 755473.920625001,2947876.704375 755469.619375005,2947879.62875 755465.268124998,2947882.47687501 755460.866874993,2947885.24875 755456.418750003,2947887.94374999 755451.923749998,2947890.56 755447.383750007,2947893.098125 755439.227500007,2947897.4025 755434.569999993,2947899.7175 755426.694374993,2947903.406875 755421.933750004,2947905.501875 755417.138125002,2947907.
 514375 755412.307500005,2947909.4425 755402.774375007,2947912.96625 755397.851249993,2947914.6425 755392.899375007,2947916.233125 755387.920625001,2947917.736875 755382.916250005,2947919.15375 755377.888125002,2947920.483125 755372.837500006,2947921.72437499 755367.765625,2947922.876875 755361.683750004,2947924.1375 755356.218125001,2947925.158125 755334.96875,2947929.176875 755320.246875003,2947932.420625 755269.798749998,2947928.995625 755243.529375002,2947927.21250001 755215.642499998,2947925.31874999 755167.839375004,2947922.07375 755109.598749995,2947908.33625001 755043.890000001,2947874.32625 754983.171250001,2947847.893125 754971.482500002,2947842.80500001 754964.634375006,2947839.82375 754950.202500001,2947833.54125001 754948.144374996,2947832.645 754929.420000002,2947824.49375001 754920.038124993,2947801.951875 754877.750624999,2947700.35187501 754861.710624993,2947663.925625 754825.353750005,2947554.438125 754822.276250005,2947555.50562499 754819.213750005,2947556.61562499 754814.706249997,2947558.33
 562499 754810.854375005,2947559.89 754807.030625001,2947561.51125 754803.234999999,2947563.19875 754799.469374999,2947564.9525 754795.734999999,2947566.77124999 754792.033124998,2947568.655625 754788.364999995,2947570.60375001 754784.730625004,2947572.61562499 754781.132499993,2947574.690625 754777.571250007,2947576.82875 754773.150000006,2947579.60187501 754769.675624996,2947581.878125 754764.698125005,2947585.2925 754761.324375004,2947587.715625 754757.993125007,2947590.19687501 754746.257499993,2947599.55437499 754724.824375004,2947616.645 754717.278750002,2947622.66187499 754682.728125006,2947650.204375 754647.851875007,2947677.529375 754641.179374993,2947682.75687499 754637.473124996,2947685.660625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>458369.35698125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3161.58400073981</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:feat
 ureMember><BrooklineWMS:Zoning fid=‘F1__94’><BrooklineWMS:OBJECTID>94</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 754359.007499993,2947871.61937501 754340.168125004,2947862.53687499 754200.831874996,2947810.50875001 754057.610624999,2947756.434375 754038.662499994,2947749.75 754044.155625001,2947734.41 754070.721874997,2947677.8475 754081.161249995,2947655.62 754127.841875002,2947582.14812499 754183.448750004,2947515.17625 754239.723749995,2947461.91374999 754298.554374993,2947412.548125 754506.282
 499999,2947591.065 754502.671875,2947594.16875 754461.183125004,2947643.22437499 754439.019999996,2947679.916875 754416.638125002,2947724.496875 754379.195625007,2947816.27500001 754359.007499993,2947871.61937501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>116793.478364844</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1368.2370636317</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__95’><BrooklineWMS:OBJECTID>95</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><Brookline
 WMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758963.588125005,2947622.043125 758950.707499996,2947635.75937501 758905.351249993,2947682.0975 758859.530625001,2947728.91125 758841.282499999,2947744.671875 758772.521874994,2947680.61750001 758672.825000003,2947583.49250001 758554.905000001,2947468.61499999 758452.867500007,2947373.07187501 758383.486874998,2947308.108125 758337.639375001,2947280.22 758217.119375005,2947234.93875 758133.180625007,2947204.93375 758116.939999998,2947195.535625 758085.313124999,2947183.208125 758105.821250007,2947183.31125 758137.908124998,2947175.43375 758205.251249999,2947149.57875 758400.236874998,2947057.715625 758389.070625007,2947031.060625 758356.299999997,2946947.550625 758317.683125004,2946965.495 758299.46875,2946919.25624999 758336.961875007,2946901.63187499 758331.521874994,2946887.301875 758303.466875002,2946831.438125 758322.9375,2946817.5 758330.9375,2946824.25 758367.4375,294679
 8.75 758365.328125,2946793.00125 758512.965000004,2946689.59875 758573.276875004,2946752.41312499 758585.630624995,2946737.594375 758633.454999998,2946687.7525 758658.129999995,2946675.99875 758682.883125007,2946664.208125 758679.920625001,2946657.925625 758710.683125004,2946649.39375 758708.647499993,2946640.7375 758748.138750002,2946630.93187501 758727.5,2946539.75 758726.760000005,2946536.480625 758733.521249995,2946535.0275 758807.266874999,2946519.17375 758810.105625004,2946518.563125 758828.088125005,2946599.75624999 758844.386250004,2946599.07125001 758907.233125001,2946596.42937499 758952.793750003,2946605.416875 758977.665000007,2946610.323125 758996.553124994,2946614.04875 759033.083749995,2946500.14624999 759041.775000006,2946481.00562499 759091.584374994,2946499.98125 759098.075000003,2946481.875 759121.397499993,2946421.125625 759127.4375,2946423.5 759135.875,2946400 759163.130624995,2946319.59625 759217.618750006,2946332.42749999 759222.860624999,2946333.6375 759232.500624999,2946336.375625 75925
 3.377499998,2946314.27500001 759289.303749993,2946255.37 759338.457499996,2946247.17812499 759384.791875005,2946232.59 759345.518124998,2946209.33374999 759326.979375005,2946200.94687501 759329.127499998,2946194.986875 759337.071875006,2946161.02187499 759354.664375007,2946085.81125 759365.141249999,2946042.60312501 759333.516249999,2946032.720625 759344.334374994,2946002.145625 759356.529375002,2945964.160625 759372.019999996,2945915.90875 759378.474999994,2945897.31812499 759520.438124999,2945945.639375 759534.070625007,2946069.516875 759592.75,2946079.593125 759682.842500001,2946087.89125 759788.346249998,2946099.745625 759938.896249995,2946119.89812499 759950.977500007,2946123.004375 759941.221874997,2946182.316875 759895.456874996,2946425.90875 759897.698125005,2946446.85875 759904.598124996,2946464.34375 759915.669375002,2946479.535 759930.198750004,2946491.45999999 760200.051249996,2946648.54062501 760227.163749993,2946664.051875 760247.328749999,2946670.78625 760264.911249995,2946671.99124999 760177.00
 7499993,2946723.52124999 760142.732500002,2946757.79625 760134.646874994,2946750.81874999 760118.556875005,2946737.41562501 760102.236249998,2946724.29625 760085.688749999,2946711.46312501 760068.920000002,2946698.920625 760051.934375003,2946686.673125 760034.737499997,2946674.72375 760017.335624993,2946663.07625 759999.732500002,2946651.734375 759965.6875,2946631 759972.969999999,2946667.19 759999.231250003,2946686.55312499 760002.704999998,2946689.125625 760035.296250001,2946719.625625 760065.351875007,2946752.71187501 760131.309375003,2946835.641875 760264.138750002,2947031.26375 760159.597499996,2947097.40125 760148.262500003,2947079.44750001 760090.080624998,2946989.35625 760058.244375005,2946940.06 760047.337500006,2946941.875 760036.524375007,2946943.67375 760017.545000002,2946946.83125 759982.614999995,2946952.643125 759965.352500007,2946955.515625 759938.392499998,2946960.00125 759868.848124996,2946971.57187501 759794.806250006,2946983.89125 759780.458749995,2946986.27875 759690.405000001,2947001.2618
 75 759683.5,2947002.25 759672.625,2947004.25 759590.721249998,2947017.86499999 759573.246875003,2947020.769375 759476.696875006,2947036.81937499 759424.915000007,2947045.434375 759393.641874999,2947050.638125 759378.900000006,2947053.090625 759315.484999999,2947041.355 759309.020624995,2947082.66500001 759305.400000006,2947105.79875 759303.103125006,2947120.473125 759312.491249993,2947118.579375 759310.645624995,2947146.77875 759293.746250004,2947149.45125 759290.560000002,2947157.78937501 759274.206874996,2947200.5775 759265.041875005,2947224.56 759257.156874999,2947245.19125 759247.633125007,2947267.46875 759144.731875002,2947283.3 759096.739999995,2947269.80562501 759077.868125007,2947308.27375001 759034.081249997,2947379.221875 759000,2947420.24250001 758889.879374996,2947552.78625 758963.588125005,2947622.043125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1560052.01227812</BrooklineWMS:Shape.area
 ><BrooklineWMS:Shape.len>8159.25940797111</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__96’><BrooklineWMS:OBJECTID>96</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-0.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>0</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>0</BrooklineWMS:CASE1><BrooklineWMS:CASE2>0</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-0.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 751253.007499993,2947612.52625 751259.375,2947592.5 750783.0625,2947439.75 750763.0625,2947373 750674.8125,2947284.5 750831.123125002,2947170.10875 751073.922499999,2947271.74625 751712.795000002,2947432.1675 751630.491874993,2947730.1675 751519.893124998,2947696.563125 751481
 .731875002,2947684.57187501 751443.340000004,2947672.50875001 751405.881874993,2947660.73875 751369.895624995,2947649.43062501 751363.626874998,2947647.46125001 751333.022499993,2947637.845 751296.045625001,2947626.22562499 751253.007499993,2947612.52625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>266550.754459766</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2536.05165048879</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__97’><BrooklineWMS:OBJECTID>97</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWM
 S:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753911.290000007,2947624.41 753886.747500002,2947575.13312501 753884.114999995,2947555.830625 753882.03125,2947539.27 753880.129374996,2947534.24375001 753802.757499993,2947468.81812499 753785.334999993,2947454.08499999 753841.717500001,2947378.60875 753861.345624998,2947352.333125 753888.196250007,2947332.564375 753918.388750002,2947305.095 753900.721249998,2947275.591875 753991.896874994,2947205.406875 754057.449375004,2947155.03812499 754165.294375002,2947070.433125 754358.418750003,2946921.05125 754463.401875004,2946840.08687501 754525.815624997,2946791.89125 754545.849374995,2946824.58374999 754576.040625006,2946955.620625 754623.748125002,2946953.88500001 754669.480000004,2946961.20999999 754711.026875004,2946975.13375001 754737.348749995,2946990.33687501 754767.383125007,2947019.145 754528.139375001,2947
 219.89875001 754627.543125004,2947339.31874999 754580.537499994,2947372.89 754657.686250001,2947484.388125 754541.619375005,2947561.920625 754535.178749993,2947566.223125 754506.282499999,2947591.065 754298.554374993,2947412.548125 754239.723749995,2947461.91374999 754183.448750004,2947515.17625 754127.841875002,2947582.14812499 754081.161249995,2947655.62 754070.721874997,2947677.8475 754051.757499993,2947667.94374999 753975.137500003,2947609.26000001 753960.903125003,2947634.200625 753911.290000007,2947624.41</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>403836.336988281</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3299.88285610432</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__98’><BrooklineWMS:OBJECTID>98</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><Broo
 klineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>21</BrooklineWMS:CASE1><BrooklineWMS:CASE2>20</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752311.456874996,2947586.205625 751856.323125005,2947468.2075 751712.795000002,2947432.1675 751073.922499999,2947271.74625 750831.123125002,2947170.10875 750839.8125,2947163.75 750797.6875,2947141.5 750770.4375,2947123.75 750743.1875,2947104.75 750696.4375,2947070.5 748903.6875,2945609.25 748944.5,2945554.75 748481.1875,2945131.75 747993.4375,2944629.75 747739.8125,2944376.75 747435.25,2944070.75 747230.569374993,2943865.13249999 747465.146874994,2943499.67375 747505.536874995,2943458.370625 747580.276875004,2943406.295 747635.599999994,2943363.3 747647.820625007,2943351.17874999 7
 47672.194999993,2943294.09625 747734.286874995,2943287.63187499 747765.055625007,2943231.856875 747803.566874996,2943172.83499999 747809.463750005,2943154.595625 747848.576250002,2942965.4425 747857.856875002,2942920.563125 747867.965625003,2942884.94687501 747876.576250002,2942854.613125 747886.010625005,2942830.85187501 748191.755624995,2942994.030625 748349.923124999,2942872.956875 748391.579999998,2942834.081875 748451.581249997,2942769.82187501 748479.244375005,2942749.763125 748514.165000007,2942736.88437501 748593.939374998,2942720.11624999 749053.411874995,2942657.394375 749177.584999993,2942640.72562499 749228.106875002,2942635.07125001 749209.080624998,2942732.92125 749241.0625,2942966.53125 749215.649375007,2943062.89749999 749199.626874998,2943123.651875 749105.893749997,2943060.04125001 749056.861249998,2943103.735625 749040.501874998,2943148.8475 749014.529375002,2943220.470625 748979.481250003,2943317.12 748919.998750001,2943285.91187499 748917.256874993,2943288.761875 748915.515625,2943290.6537
 5 748913.808125004,2943292.57625 748912.133750007,2943294.5275 748910.493750006,2943296.50875001 748908.889375001,2943298.5175 748907.319374993,2943300.55437499 748905.785624996,2943302.61812501 748904.288124993,2943304.70874999 748902.827500001,2943306.824375 748901.403125003,2943308.965625 748900.017499998,2943311.13187499 748898.669375002,2943313.32125001 748897.359375,2943315.534375 748896.088125005,2943317.769375 748894.856875002,2943320.026875 748893.664375007,2943322.30500001 748892.512500003,2943324.60375001 748891.400625005,2943326.9225 748890.329374999,2943329.26000001 748889.299374998,2943331.61562499 748888.310000002,2943333.989375 748887.362499997,2943336.38 748886.456874996,2943338.78687499 748885.59375,2943341.20874999 748884.772499993,2943343.645625 748883.994375005,2943346.09625 748883.258750007,2943348.560625 748882.566249996,2943351.03687499 748881.917500004,2943353.52500001 748881.311875001,2943356.02375001 748880.75,2943358.533125 748880.231875002,2943361.051875 748879.758125007,2943363.57
 9375 748879.328125,2943366.114375 748878.943124995,2943368.656875 748878.601875007,2943371.205625 748878.305625007,2943373.76000001 748878.053749993,2943376.31874999 748877.846874997,2943378.88187499 748877.684375003,2943381.448125 748877.566874996,2943384.016875 748877.493750006,2943386.58750001 748877.466250002,2943389.158125 748877.483125001,2943391.73 748877.545000002,2943394.300625 748877.651875004,2943396.87 748877.803124994,2943399.436875 748878,2943402.000625 748878.241249993,2943404.560625 748878.526875004,2943407.11624999 748878.856875002,2943409.66625001 748879.231875002,2943412.20999999 748879.650625005,2943414.746875 748880.113749996,2943417.27625 748880.621875003,2943419.796875 748881.172499999,2943422.30875 748881.768124998,2943424.810625 748882.40625,2943427.30125 748883.088750005,2943429.780625 748883.813749999,2943432.2475 748884.581249997,2943434.701875 748885.392499998,2943437.141875 748886.245625004,2943439.5675 748887.141249999,2943441.97812501 748888.078749999,2943444.3725 748889.0575000
 05,2943446.75 748890.078125,2943449.110625 748891.139375001,2943451.4525 748892.241874993,2943453.77562501 748893.383750007,2943456.079375 748811.586875007,2943632.14937501 748972.388125002,2943689.546875 749075.872500002,2943728.08499999 749003.890625,2943905.99250001 749023.367500007,2944029.284375 748963.494375005,2944048.765625 748919.753124997,2944072.12 748893.628124997,2944091.735 748730.645624995,2944223.156875 748713.663124993,2944249.82875 748615.028750002,2944332.10375001 748735.884375006,2944470.285625 748672.128124997,2944519.90375 748646.236249998,2944540.05312499 748760.356875002,2944640.69 748780.427499995,2944624.59 748813.153750002,2944624.59875 748878.959999993,2944699.84625 748871.341250002,2944706.405 748867.005624995,2944701.895 748836.258125007,2944731.88 748893.616249993,2944791.844375 748964.504374996,2944865.95375 748992.493125007,2944838.995625 749121.989999995,2944971.89375 749194.428124994,2945046.234375 749170.008125007,2945070.54062501 749235.997500002,2945116.83374999 749251.756
 874993,2945127.889375 749353.028750002,2945171.035625 749338.203749999,2945197.10375001 749423.409999996,2945265.92749999 749611.101875007,2945321.2825 749640.461250007,2945339.20937499 749645.208124995,2945341.979375 749703.614999995,2945316.97812501 749783.262500003,2945290.020625 750091.008750007,2945347.058125 750138.310000002,2945348.860625 750185.629999995,2945347.66125 750279.566874996,2945336.280625 750325.805000007,2945326.14687499 750415.890000001,2945297.19625001 750531.894374996,2945244.44687501 750644.090000004,2945191.343125 750671.799999997,2945185.22624999 750694.483125001,2945186.77875 750714.001249999,2945193.02500001 750759.519999996,2945216.65875 750776.214375004,2945231.439375 750817.973124996,2945309.56812499 750827.173749998,2945330.4375 750964.034999996,2945293.29875 750924.869375005,2945136.528125 751006.918125004,2945084.143125 751103.271874994,2945033.51125 751174.468125001,2945129.949375 751219.980625004,2945189.826875 751243.501874998,2945220.77312499 751259.483750001,2945241.79937
 5 751308.005624995,2945305.63625 751352.9375,2945364.75 751356.347499996,2945369.333125 751358.706874996,2945372.479375 751362.821250007,2945379.74375001 751579.037499994,2945232.89125 751636.986874998,2945311.44 751677.413124993,2945349.62625 751728.466875002,2945382.625 751760.992500007,2945395.44 751909.199375004,2945453.831875 751889.033749998,2945517.441875 751875.258750007,2945586.689375 751860.393749997,2945720.83625001 751829.521249995,2945713.96625 751599.873125002,2945655.68125001 751572.645624995,2945753.156875 751524.106875002,2945926.9225 751467.739374995,2946128.719375 751536.364999995,2946186.60062499 751670.593125001,2946299.090625 751700.980000004,2946308.38 751621.306875005,2946450.98875 751539.164375007,2946607.81812499 751774.965000004,2946720.11812501 751918.488124996,2946782.79125001 752074.101249993,2946863.22624999 752221.998125002,2946940.95375 752295.856250003,2946798.23 752282.869375005,2946792.74375001 752343.374375001,2946674.1575 752352.573750004,2946653.845625 752402.129374996,29
 46674.2975 752413.141874999,2946649.91249999 752478.181875005,2946500.089375 752563.260000005,2946533.6075 752571.461875007,2946535.503125 752655.576250002,2946556.248125 752688.418125004,2946427.80562501 752696.120000005,2946404.10062499 752732.303749993,2946411.966875 752759.834374994,2946414.326875 752762.341875002,2946396.923125 752762.551249996,2946392.2825 752782.886250004,2946275.808125 752769.423749998,2946272.450625 752808.376874998,2946125.9575 752812.585624993,2946114.33812501 752816.314374998,2946100.99062499 752834.328749999,2946106.685 752912.059375003,2946123.13187499 752978.841875002,2946127.79375 753012.321250007,2946126.94125 753078.780000001,2946118.88 753143.683750004,2946102.470625 753206.120000005,2946077.91500001 753265.065624997,2946049 753300.947500005,2946023.8725 753364.378749996,2945962.839375 753366.585624993,2945960.47499999 753372.856250003,2946004.049375 753386.576250002,2946025.21250001 753398.928124994,2946031.71375 753453.578749999,2946175.49124999 753476.642499998,2946236.16
 6875 753535.840625003,2946391.908125 753540.748125002,2946422.89749999 753476.639375001,2946483.74187499 753483.145624995,2946596.66500001 753492.381874993,2946660.55125 753499.791875005,2946695.82875 753522.200000003,2946688.63625 753638.070625007,2946642.5 753655.546875,2946635.54062501 753641.201875001,2946598.4975 753689.135000005,2946572.435625 753734.426874995,2946547.81 753757.551874995,2946535.23625 753814.758750007,2946504.13249999 753833.471874997,2946493.958125 753890.996250004,2946462.68125001 753921.504999995,2946446.093125 753971.986874998,2946418.64624999 754010.978750005,2946397.44562501 754059.34375,2946371.14937501 754050.378124997,2946348.95937499 754083.118125007,2946329.406875 754135.694374993,2946298.00875001 754153.351875007,2946287.46312501 754222.318749994,2946246.27562501 754233.133125007,2946270.668125 754317.586875007,2946223.4025 754333.477500007,2946214.50875001 754369.146249995,2946189.89875001 754303.306250006,2946023.828125 754326.660624996,2946017.49312501 754375.704374999,294
 5996.155 754431.084999993,2945965.061875 754525.041875005,2945901.293125 754601.372500002,2945857.40125 754610.859999999,2945852.6575 754646.042500004,2945836.449375 754665.808750004,2945826.96187501 754689.922499999,2945817.47437499 754733.011875004,2945800.87125 754785.193124995,2945778.33812501 754806.935625002,2945769.24625 754783.338125005,2945719.76125 754882.942499995,2945582.86937501 754932.979375005,2945514.10124999 754985.546875,2945441.855625 755028.215625003,2945383.21375 755055.883125007,2945345.18875 755073.862499997,2945313.265 755086.3125,2945273.63625 755103.821875006,2945217.9025 755094.602500007,2945168.9825 755141.829999998,2945022.746875 755432.724374995,2945090.31375 755428.145624995,2945108.973125 755428.145624995,2945154.300625 755463.156874999,2945288.81874999 755474.292500004,2945369.370625 755479.678124994,2945391.3425 755505.087500006,2945384.291875 755518.383750007,2945382.0575 755610.477500007,2945366.583125 755694.775625005,2945432.70999999 755707.815624997,2945452.16374999 75573
 0.318124995,2945422.95 755767.313124999,2945353.05500001 755786.038749993,2945307.7475 755819.798124999,2945192.846875 755889.611874998,2945211.70874999 755914.152500004,2945217.41125 755917.424374998,2945180.33812501 755921.379374996,2945035.505 755930.591250002,2945003.465 755946.966250002,2944980.95874999 755964.633750007,2944967.354375 756006.474374995,2944950.55562501 756033.735624999,2944944.34999999 756061.650000006,2944945.18625 756187.436250001,2944964.0325 756188.101249993,2944947.83499999 756191.491874993,2944855.69687501 756309.026875004,2944839.2025 756328.495000005,2944815.940625 756332.066249996,2944733.326875 756386.800624996,2944735.659375 756408.321250007,2944627.950625 756413.186875001,2944604.83 756387.316874996,2944602.11499999 756402.711875007,2944493.19687501 756411.069374993,2944461.36375 756446.636250004,2944382.49875 756481.423124999,2944305.36375 756516.761875004,2944213.948125 756544.466875002,2944127.42812499 756568.741249993,2944135.2925 756703.343125001,2944180.528125 756763.4993
 75001,2944200.745 756704.622500002,2944270.09 756778.770624995,2944308.85312501 756753.889375001,2944389.1675 756846.421875,2944401.425625 756901.535624996,2944408.72687501 756979.963750005,2944536.04875 756991.129999995,2944554.019375 756915.915000007,2944644.11125 756862.811875001,2944693.489375 756874.140000001,2944724.595 756845.370000005,2944806.96375 756815.258750007,2944893.173125 756803.998750001,2944925.41 756802.759375006,2944931.906875 756792.628124997,2944985.030625 756786.913124993,2945010.79062501 756773.720624998,2945070.254375 756764.221249998,2945113.073125 756756.996875003,2945145.636875 756744.201875001,2945203.3075 756730.406874999,2945265.48875 756686.650625005,2945252.2525 756665.028125003,2945246.235 756679.253749996,2945374.26125 756523.369375005,2945339.29125001 756511.844374999,2945376.9325 756477.969374999,2945504.46312501 756474.433125004,2945503.168125 756461.853125006,2945500.410625 756458.623125002,2945513.04125001 756417.379374996,2945579.26000001 756424.467500001,2945585.071875
 01 756421.234375,2945590.49625 756387.525625005,2945656.45125 756355.974999994,2945683.511875 756324.396249995,2945710.59625 756292.257499993,2945738.16125 756200.717500001,2945777.64375 756097.546250001,2945822.1425 756012.545625001,2945847.52875 755957.705624998,2945872.606875 755920.351249993,2945889.689375 755902.597499996,2945897.80875 755935.178749993,2946015.92 755941.616874993,2946034.84375 755849.745625004,2946055.58875 755858.636250004,2946102.41374999 755861.021874994,2946126.27187499 755808.431875005,2946132.49312501 755607.891874999,2946167.061875 755601.023124993,2946168.436875 755562.238124996,2946176.201875 755553.008750007,2946178.11875001 755512.838125005,2946188.11125 755450.454999998,2946205.746875 755422.634375006,2946214.45999999 755337.796250001,2946246.02875 755240.986874998,2946288.69562501 755223.093125001,2946297.98 755147.893749997,2946149.02562501 755124.541875005,2946115.14812499 755093.825000003,2946089.216875 755026.616249993,2946061.57062501 755006.964375004,2946053.8725 754985
 .617500007,2946083.125625 754944.504999995,2946144.794375 754829.073125005,2946234.925625 754661.460624993,2946311.61624999 754535.751249999,2946372.49437501 754539.267499998,2946382.29625 754576.071875006,2946455.61499999 754569.223124996,2946460.33812501 754527.669375002,2946488.99062499 754494.801249996,2946511.654375 754486.011250004,2946517.715 754479.043750003,2946507.604375 754435.511250004,2946537.4825 754412.253124997,2946553.44625001 754397.279375002,2946563.723125 754377.475624993,2946576.28812499 754357.214375004,2946589.143125 754318.194999993,2946614.09125 754299.486249998,2946626.05312499 754263.023124993,2946649.36624999 754226.398750007,2946672.783125 754213.936875001,2946680.77375001 754159.467500001,2946715.698125 754153.996250004,2946719.205625 754139.375,2946730.67812499 754108.406874999,2946754.97624999 754073.998750001,2946781.973125 754063.252499998,2946790.405 754009.211875007,2946832.80562501 753966.499375001,2946866.31874999 753955.560000002,2946874.901875 753919.706249997,2946903.03
 3125 753888.383125007,2946927.609375 753877.299374998,2946936.30625001 753880.390000001,2946941.8575 753857.841250002,2946957.3275 753789.325000003,2947004.33687501 753806.658749998,2947044.26000001 753705.657499999,2947094.77187499 753665.585624993,2947124.376875 753564.255624995,2947194.80374999 753531.739999995,2947145.80437499 753482.275625005,2947178.73875 753409.056250006,2947043.126875 753395.272499993,2947018.4375 753367.073750004,2947035.52375001 753038.476249993,2946712.1925 753012.608750001,2946717.20874999 752977.03125,2946722.74312501 752956.827500001,2946726.455625 752935.634375006,2946754.23375 752911.678124994,2946802.95625 752864.503749996,2946865.53 752689.180000007,2947076.796875 752662.334999993,2947103.809375 752632.290000007,2947127.200625 752458.188749999,2947244.910625 752397.188124999,2947278.644375 752207.720624998,2947368.7225 752363.742500007,2947404.33625001 752311.456874996,2947586.205625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember> ml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>10661255.8899953</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>35489.8020443836</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__99’><BrooklineWMS:OBJECTID>99</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757573.901250005,2947487.595625 757348.385000005,2947254.576875 757204.935000002,2947115.7 757123.319999993,2947033.4575 757102.589375004,2947038
 .28749999 757043.292500004,2947068.62375 757027.273124993,2947076.81937499 757005.416250005,2947033.901875 757001.206249997,2947025.635625 756982.318124995,2946988.5475 756939.275625005,2947000.19875 756902.034374997,2947021.565625 756890.915000007,2947010.29375 756868.281874999,2946987.34999999 756847.620000005,2946966.40375 756828.453749999,2946946.97499999 756812.784374997,2946931.09 756786.798124999,2946904.7475 756770.147499993,2946887.86812501 756740.661874995,2946857.97750001 756726.394999996,2946843.515625 756700.626249999,2946817.3925 756660.46875,2946776.684375 756650.525625005,2946761.28375 756562.765625,2946856.15875 756542.125,2946833.5 756479.036249995,2946916.11 756393.053749993,2946996.875625 756261.484375,2946853.69437499 756213.825000003,2946795.61687499 756173.930000007,2946732.01375 756142.408124998,2946663.875 756119.765625,2946592.29000001 756099.685000002,2946498.38 755953.448125005,2946561.825 755865.019999996,2946574.69499999 755831.024375007,2946538.901875 755753.263125002,2946506.659
 375 755719.108125001,2946492.496875 755679.041875005,2946481.75937501 755673.625,2946463.25 755641.336875007,2946329.533125 755637.417500004,2946313.715 755601.023124993,2946168.436875 755607.891874999,2946167.061875 755808.431875005,2946132.49312501 755861.021874994,2946126.27187499 755858.636250004,2946102.41374999 755849.745625004,2946055.58875 755941.616874993,2946034.84375 755935.178749993,2946015.92 755902.597499996,2945897.80875 755920.351249993,2945889.689375 755957.705624998,2945872.606875 756012.545625001,2945847.52875 756097.546250001,2945822.1425 756200.717500001,2945777.64375 756292.257499993,2945738.16125 756324.396249995,2945710.59625 756355.974999994,2945683.511875 756387.525625005,2945656.45125 756421.234375,2945590.49625 756424.467500001,2945585.07187501 756417.379374996,2945579.26000001 756458.623125002,2945513.04125001 756461.853125006,2945500.410625 756474.433125004,2945503.168125 756477.969374999,2945504.46312501 756511.844374999,2945376.9325 756523.369375005,2945339.29125001 756679.25374
 9996,2945374.26125 756665.028125003,2945246.235 756686.650625005,2945252.2525 756730.406874999,2945265.48875 756744.201875001,2945203.3075 756847.508750007,2945228.13249999 756871.293750003,2945233.78749999 756878.998750001,2945198.22499999 757018.417500004,2945234.27187499 757014.063749999,2945254.30249999 756999.658749998,2945307.35312501 756992.845624998,2945332.4425 756972.417500004,2945407.67625 756958.704374999,2945461.625625 757015.526875004,2945475.799375 757010.538124993,2945496.749375 756984.556250006,2945593.61375 757015.510000005,2945600.935 757029.109375,2945627.421875 757108.271874994,2945697.2225 757107.254999995,2945752.36812501 757116.108750001,2945816.136875 757134.464375004,2945839.293125 757154.168125004,2945965.655 757166.243125007,2945964.155 757340.033124998,2945943.04000001 757342.673124999,2945942.77375001 757369.999375001,2946013.715 757471.164375007,2946215.52312499 757627.340625003,2946516.628125 757655.933125004,2946572.62125 757785.041875005,2946820.825625 757878.465000004,2946996
 .04375 757853.601875007,2947019.85250001 757814.682500005,2947042.77187499 757772.899375007,2947067.3775 757726.246875003,2947094.85124999 757719.454374999,2947098.85124999 757725.438749999,2947110.139375 757768.568749994,2947191.5 757814.454999998,2947278.05875 757827.832499996,2947303.49437501 757743.368750006,2947335.67812499 757686.164375007,2947367.645625 757655.081249997,2947391.80875 757615.430625007,2947430.470625 757597.524375007,2947451.61 757573.901250005,2947487.595625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>2384191.19076094</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>8244.69170169744</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__100’><BrooklineWMS:OBJECTID>100</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-0.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINE
 SS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>8</BrooklineWMS:CASE1><BrooklineWMS:CASE2>8</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-0.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758434.693124995,2947389.251875 758366.451875001,2947458.9325 758346.635000005,2947445.46250001 758332.768124998,2947436.03749999 758283.049999997,2947402.24375001 758246.603125006,2947395.77312499 758212.653125003,2947389.745625 758176.502499998,2947383.3275 758184.112499997,2947418.739375 758101.071875006,2947443.763125 758027.439374998,2947258.214375 758015.683125004,2947230.37625 757921.118750006,2947267.948125 757827.832499996,2947303.49437501 757814.454999998,2947278.05875 757768.568749994,2947191.5 757725.438749999,2947110.139375 757719.454374999,2947098.85124999 757726.246875003,2947094.85124999 757772.
 899375007,2947067.3775 757814.682500005,2947042.77187499 757853.601875007,2947019.85250001 757878.465000004,2946996.04375 757939.451875001,2947072.95625 757995.804374993,2947144.02375001 758018.989374995,2947163.239375 758048.701875001,2947177.565625 758072.833749995,2947183.145 758085.313124999,2947183.208125 758116.939999998,2947195.535625 758133.180625007,2947204.93375 758217.119375005,2947234.93875 758337.639375001,2947280.22 758383.486874998,2947308.108125 758452.867500007,2947373.07187501 758434.693124995,2947389.251875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>119611.395074219</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2015.48087214287</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__101’><BrooklineWMS:OBJECTID>101</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</Brookli
 neWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760479.549999997,2947107.3075 760545.5,2947190.5 760568,2947228.75 760579.838750005,2947253.66500001 760473.833124995,2947349.94125 760364.406874999,2947182.685625 760264.138750002,2947031.26375 760131.309375003,2946835.641875 760065.351875007,2946752.71187501 760035.296250001,2946719.625625 760002.704999998,2946689.125625 759999.231250003,2946686.55312499 759972.969999999,2946667.19 759965.6875,2946631 759999.732500002,2946651.734375 760017.335624993,2946663.07625 760034.737499997,2946674.72375 760051.934375003,2946686.673125 760068.920000002,2946698.920625 76
 0085.688749999,2946711.46312501 760102.236249998,2946724.29625 760118.556875005,2946737.41562501 760134.646874994,2946750.81874999 760142.732500002,2946757.79625 760150.5,2946764.5 760290.8125,2946892 760445.8125,2947064.75 760479.549999997,2947107.3075</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>83586.222296875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1912.74249042622</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__102’><BrooklineWMS:OBJECTID>102</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>2</BrooklineWMS:CASE1><BrooklineWMS:CASE2>2</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><Brooklin
 eWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757939.451875001,2947072.95625 757957.726249993,2947065.72437499 758053.489374995,2947025.55687501 758068.789375007,2947019.13875 758121.564374998,2946997.0025 758130.515625,2946993.248125 758148.773124993,2946985.59 758167.055625007,2946977.92125 758180.403125003,2946972.32250001 758203.890625,2946962.470625 758237.769374996,2946948.26000001 758241.471874997,2946946.52 758280.785624996,2946928.03937501 758287.548124999,2946924.86 758299.46875,2946919.25624999 758317.683125004,2946965.495 758356.299999997,2946947.550625 758389.070625007,2947031.060625 758400.236874998,2947057.715625 758205.251249999,2947149.57875 758137.908124998,2947175.43375 758105.821250007,2947183.31125 758085.313124999,2947183.208125 758072.833749995,2947183.145 758048.701875001,2947177.565625 758018.989374995,2947163.239375 757995.804374993,2947144.02375001 75793
 9.451875001,2947072.95625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>65489.259878125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1134.66988192661</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__103’><BrooklineWMS:OBJECTID>103</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760479.549999997,2947107.3075 760445.8125,2947064
 .75 760290.8125,2946892 760150.5,2946764.5 760142.732500002,2946757.79625 760177.007499993,2946723.52124999 760264.911249995,2946671.99124999 760268.539375007,2946672.23999999 760289.434375003,2946668.31999999 760495.613124996,2946557.140625 760582.740624994,2946508.886875 760821.857500002,2946817.591875 760735.875,2946886.933125 760654.169375002,2946955.565625 760556.122500002,2947030.735 760479.549999997,2947107.3075</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>203668.554859375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1834.83773060065</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__104’><BrooklineWMS:OBJECTID>104</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><Brookli
 neWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757878.465000004,2946996.04375 757785.041875005,2946820.825625 757655.933125004,2946572.62125 757627.340625003,2946516.628125 757471.164375007,2946215.52312499 757369.999375001,2946013.715 757342.673124999,2945942.77375001 757394.840000004,2945937.515 757449.886250004,2945935.47687501 757504.951250002,2945936.935 757559.811875001,2945941.88187499 757564.268124998,2945942.566875 757612.708124995,2945950.011875 757717.983125001,2945970.19687501 757855.231250003,2945996.699375 757874.861874998,2946000 757892.481875002,2946002.96250001 757955.383125007,2946013.53874999 758056.685000002,2946024.05125 758244.921875,2946034.00624999 758440.689999998,2
 946044.36 758544.666875005,2946050.23375 758674.143124998,2946057.548125 758865.658749998,2946069.903125 758931.656874999,2946075.26375 758997.181250006,2946084.79875 759061.96875,2946098.470625 759125.758750007,2946116.22375 759185.888125002,2946137.11562499 759326.979375005,2946200.94687501 759345.518124998,2946209.33374999 759384.791875005,2946232.59 759338.457499996,2946247.17812499 759289.303749993,2946255.37 759253.377499998,2946314.27500001 759232.500624999,2946336.375625 759222.860624999,2946333.6375 759217.618750006,2946332.42749999 759163.130624995,2946319.59625 759135.875,2946400 759127.4375,2946423.5 759121.397499993,2946421.125625 759098.075000003,2946481.875 759091.584374994,2946499.98125 759041.775000006,2946481.00562499 759033.083749995,2946500.14624999 758996.553124994,2946614.04875 758977.665000007,2946610.323125 758952.793750003,2946605.416875 758907.233125001,2946596.42937499 758844.386250004,2946599.07125001 758828.088125005,2946599.75624999 758810.105625004,2946518.563125 758807.266874999
 ,2946519.17375 758733.521249995,2946535.0275 758726.760000005,2946536.480625 758727.5,2946539.75 758748.138750002,2946630.93187501 758708.647499993,2946640.7375 758710.683125004,2946649.39375 758679.920625001,2946657.925625 758682.883125007,2946664.208125 758658.129999995,2946675.99875 758633.454999998,2946687.7525 758585.630624995,2946737.594375 758573.276875004,2946752.41312499 758512.965000004,2946689.59875 758365.328125,2946793.00125 758367.4375,2946798.75 758330.9375,2946824.25 758322.9375,2946817.5 758303.466875002,2946831.438125 758331.521874994,2946887.301875 758336.961875007,2946901.63187499 758299.46875,2946919.25624999 758287.548124999,2946924.86 758280.785624996,2946928.03937501 758241.471874997,2946946.52 758237.769374996,2946948.26000001 758203.890625,2946962.470625 758180.403125003,2946972.32250001 758167.055625007,2946977.92125 758148.773124993,2946985.59 758130.515625,2946993.248125 758121.564374998,2946997.0025 758068.789375007,2947019.13875 758053.489374995,2947025.55687501 757957.726249993,
 2947065.72437499 757939.451875001,2947072.95625 757878.465000004,2946996.04375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1209239.63211875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5555.59713196604</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__105’><BrooklineWMS:OBJECTID>105</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>
  752343.374375001,2946674.1575 752282.869375005,2946792.74375001 752295.856250003,2946798.23 752221.998125002,2946940.95375 752074.101249993,2946863.22624999 751918.488124996,2946782.79125001 751774.965000004,2946720.11812501 751539.164375007,2946607.81812499 751621.306875005,2946450.98875 751700.980000004,2946308.38 751670.593125001,2946299.090625 751536.364999995,2946186.60062499 751467.739374995,2946128.719375 751524.106875002,2945926.9225 751572.645624995,2945753.156875 751599.873125002,2945655.68125001 751829.521249995,2945713.96625 751860.393749997,2945720.83625001 751849.165000007,2945822.16312499 751892.803749993,2945803.723125 751904.790000007,2945796.333125 751917.676874995,2945782.455 751931.194999993,2945762.358125 752000,2945619.765 752048.038124993,2945545.423125 752119.623750001,2945454.69499999 752232.106250003,2945309.765625 752256.367500007,2945337.295 752369.693124995,2945474.41500001 752388.985624999,2945497.75875001 752504.661874995,2945637.723125 752536.170000002,2945675.846875 752587.233
 125001,2945737.63187499 752663.856250003,2945774.875 752688.049374998,2945783.18062501 752737.727500007,2945682.90125 752764.691874996,2945696.33812501 752938.661249995,2945791.91500001 752816.314374998,2946100.99062499 752812.585624993,2946114.33812501 752808.376874998,2946125.9575 752769.423749998,2946272.450625 752782.886250004,2946275.808125 752762.551249996,2946392.2825 752762.341875002,2946396.923125 752759.834374994,2946414.326875 752732.303749993,2946411.966875 752696.120000005,2946404.10062499 752688.418125004,2946427.80562501 752655.576250002,2946556.248125 752571.461875007,2946535.503125 752563.260000005,2946533.6075 752478.181875005,2946500.089375 752413.141874999,2946649.91249999 752402.129374996,2946674.2975 752352.573750004,2946653.845625 752343.374375001,2946674.1575</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1348217.06806719</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5563.74198
 341717</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__106’><BrooklineWMS:OBJECTID>106</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>I-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>477</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>INDUSTRIAL SERVICES</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>7</BrooklineWMS:CASE1><BrooklineWMS:CASE2>7</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>I-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760821.857500002,2946817.591875 760582.740624994,2946508.886875 760445.191874996,2946330.63375001 760403.909999996,2946303.816875 760320.663124993,2946200.6425 760317.191874996,2946189.481875 760317.310625002,2946154.17937499 760369.208124995,2946150.719375 760555.321250007,2946150.719375 760637.549374
 998,2946158.120625 760631.319374993,2946199.595625 760617.381874993,2946242.28125 760614.21875,2946275.948125 760619.988749996,2946320.61 760631.603125006,2946352.36812501 760649.018124998,2946381.35312501 760754.108125001,2946508.07187501 760806.666250005,2946578.419375 760859.844999999,2946667.863125 760869.719374999,2946698.2925 760874.459999993,2946738.973125 760866.09375,2946874.703125 760821.857500002,2946817.591875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>121018.019759375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2036.10233364951</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__107’><BrooklineWMS:OBJECTID>107</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-15</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>22</BrooklineW
 MS:CASE1><BrooklineWMS:CASE2>21</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-15</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753364.378749996,2945962.839375 753300.947500005,2946023.8725 753265.065624997,2946049 753206.120000005,2946077.91500001 753143.683750004,2946102.470625 753078.780000001,2946118.88 753012.321250007,2946126.94125 752978.841875002,2946127.79375 752912.059375003,2946123.13187499 752834.328749999,2946106.685 752816.314374998,2946100.99062499 752938.661249995,2945791.91500001 752764.691874996,2945696.33812501 752737.727500007,2945682.90125 752688.049374998,2945783.18062501 752663.856250003,2945774.875 752587.233125001,2945737.63187499 752536.170000002,2945675.846875 752504.661874995,2945637.723125 752388.985624999,2945497.75875001 752369.693124995,2945474.41500001 752256.36
 7500007,2945337.295 752232.106250003,2945309.765625 752119.623750001,2945454.69499999 752048.038124993,2945545.423125 752000,2945619.765 751931.194999993,2945762.358125 751917.676874995,2945782.455 751904.790000007,2945796.333125 751892.803749993,2945803.723125 751849.165000007,2945822.16312499 751860.393749997,2945720.83625001 751875.258750007,2945586.689375 751889.033749998,2945517.441875 751909.199375004,2945453.831875 751760.992500007,2945395.44 751797.958124995,2945297.565 751807.793750003,2945271.86499999 751821.405625001,2945236.30125 751828.449375004,2945217.89624999 751846.848124996,2945169.824375 751852.971874997,2945153.82375 751855.088125005,2945132.433125 751856.188124999,2945121.31375 751851.927499995,2945099.60187501 751855.683750004,2945097.01375 751882.361874998,2945078.48 751906.121875003,2945046.813125 751929.846249998,2945015.21312501 751954.228750005,2944982.738125 751986.537499994,2944945.904375 752015.113749996,2944913.34999999 752033.250624999,2944930.18000001 752088.861874998,2944981.7
 84375 752110.478125006,2945002.24062499 752122.786874995,2944983.468125 752281.831249997,2944781.5 752496.886875004,2944524.33 752643.196250007,2944362.50125 752681.091250002,2944324.41625001 752721.391874999,2944283.91437501 752808.498125002,2944196.3725 752838.949375004,2944147.09999999 752446.466250002,2943741.485 752452.835624993,2943715.138125 752665.519374996,2943558.755 752726.530000001,2943513.894375 752848.023124993,2943424.5625 752941.191249996,2943356.05625001 753057.090625003,2943270.83687501 753074.361249998,2943258.138125 753144.292500004,2943351.110625 753210.250624999,2943301.52312499 753379.767499998,2943475.470625 753450.916875005,2943413.938125 753609.739999995,2943256.90000001 753691.801249996,2943157.89687499 753793.995000005,2943016.24187499 753921.269999996,2942817.46187501 753942.239999995,2942793.609375 753976.168125004,2942767.9725 754000,2942760.83875 754023.049999997,2942753.939375 754065.215000004,2942748.07625 754140.089375004,2942749.885625 754202.997500002,2942760.96625 754254.3
 85000005,2942765.08 754319.432500005,2942751.4975 754382.986874998,2942752.685 754413.495000005,2942745.065625 754451.346249998,2942724.88062499 754511.819999993,2942681.855 754543.018749997,2942664.046875 754559.481875002,2942723.91187499 754561.073125005,2942827.333125 754534.079374999,2942940.283125 754569.782499999,2942929.02312499 754746.064999998,2942883.00812501 754760.855000004,2942879.14749999 754756.728125006,2942868.235 754981.646874994,2942735.3175 754974.274375007,2943050.995 754948.848749995,2943050.77124999 754947.90625,2943093.205 754933.4375,2943094.14875001 754932.808125004,2943162.356875 754970.511250004,2943162.44125 754965.453749999,2943299.845 754961.015000001,2943420.455 755256.814999998,2943414.63187499 755301.592500001,2943444.48375 755402.623750001,2943511.83750001 755410.335624993,2943529.791875 755373.732500002,2943607.63875 755397.808125004,2943713.535 755401.195625007,2943742.175 755400.915625006,2943767.85250001 755427.464375004,2943902.905 755418.806875005,2943905.145 755385.556
 250006,2943922.06812499 755301.228125006,2943990.385625 755277.253124997,2944001.60062499 755290.228750005,2944048.30500001 755326.546875,2944230.55687501 755344.198750004,2944265.72812501 755371.943749994,2944293.63625 755403.474999994,2944310.938125 755435.051249996,2944320.64624999 755489.469374999,2944323.51375 755489.623750001,2944345.114375 755487.830624998,2944449.858125 755614.845624998,2944445.979375 755734.058125004,2944480.294375 755751.613124996,2944485.595 755765.368750006,2944460.591875 755776.826875001,2944411.40000001 755788.590000004,2944431.74187499 755806.233750001,2944452.495 755867.894999996,2944504.175 755894.696875006,2944520.50875001 755939.475624993,2944541.323125 755974.193124995,2944549.531875 755997.931875005,2944551.28 756078.460624993,2944554.31937499 756294.640625,2944591.058125 756387.316874996,2944602.11499999 756413.186875001,2944604.83 756408.321250007,2944627.950625 756386.800624996,2944735.659375 756332.066249996,2944733.326875 756328.495000005,2944815.940625 756309.0268750
 04,2944839.2025 756191.491874993,2944855.69687501 756188.101249993,2944947.83499999 756187.436250001,2944964.0325 756061.650000006,2944945.18625 756033.735624999,2944944.34999999 756006.474374995,2944950.55562501 755964.633750007,2944967.354375 755946.966250002,2944980.95874999 755930.591250002,2945003.465 755921.379374996,2945035.505 755917.424374998,2945180.33812501 755914.152500004,2945217.41125 755889.611874998,2945211.70874999 755819.798124999,2945192.846875 755588.773750007,2945126.354375 755432.724374995,2945090.31375 755141.829999998,2945022.746875 755094.602500007,2945168.9825 755103.821875006,2945217.9025 755086.3125,2945273.63625 755073.862499997,2945313.265 755055.883125007,2945345.18875 755028.215625003,2945383.21375 754985.546875,2945441.855625 754932.979375005,2945514.10124999 754882.942499995,2945582.86937501 754783.338125005,2945719.76125 754806.935625002,2945769.24625 754785.193124995,2945778.33812501 754733.011875004,2945800.87125 754689.922499999,2945817.47437499 754665.808750004,2945826.96
 187501 754646.042500004,2945836.449375 754610.859999999,2945852.6575 754601.372500002,2945857.40125 754525.041875005,2945901.293125 754431.084999993,2945965.061875 754375.704374999,2945996.155 754326.660624996,2946017.49312501 754303.306250006,2946023.828125 754369.146249995,2946189.89875001 754333.477500007,2946214.50875001 754317.586875007,2946223.4025 754233.133125007,2946270.668125 754222.318749994,2946246.27562501 754153.351875007,2946287.46312501 754135.694374993,2946298.00875001 754083.118125007,2946329.406875 754050.378124997,2946348.95937499 754059.34375,2946371.14937501 754010.978750005,2946397.44562501 753971.986874998,2946418.64624999 753921.504999995,2946446.093125 753890.996250004,2946462.68125001 753833.471874997,2946493.958125 753814.758750007,2946504.13249999 753757.551874995,2946535.23625 753734.426874995,2946547.81 753689.135000005,2946572.435625 753641.201875001,2946598.4975 753655.546875,2946635.54062501 753638.070625007,2946642.5 753522.200000003,2946688.63625 753499.791875005,2946695.828
 75 753492.381874993,2946660.55125 753483.145624995,2946596.66500001 753476.639375001,2946483.74187499 753540.748125002,2946422.89749999 753535.840625003,2946391.908125 753476.642499998,2946236.166875 753453.578749999,2946175.49124999 753398.928124994,2946031.71375 753386.576250002,2946025.21250001 753372.856250003,2946004.049375 753366.585624993,2945960.47499999 753387.256874993,2945938.3275 753576.814374998,2945828.02500001 753686.299999997,2945736.514375 753768.005624995,2945646.638125 753867.686875001,2945599.24875 753960.831249997,2945573.10250001 754107.901875004,2945512.640625 754207.583124995,2945448.093125 754145.486874998,2945438.28812499 754034.366249993,2945395.80125 753916.709999993,2945330.436875 753835.004374996,2945258.535625 753759.834999993,2945212.78 753638.910624996,2945153.951875 753540.863749996,2945155.58625001 753413.402500004,2945170.293125 753336.599374995,2945212.78 753302.282499999,2945276.510625 753295.114374995,2945325.09875 753287.575625002,2945376.191875 753289.209999993,2945498.
 750625 753300.648750007,2945723.44125 753367.647499993,2945921.169375 753364.330624998,2945944.80312499 753366.585624993,2945960.47499999 753364.378749996,2945962.839375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>8517614.85963906</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>20532.5075835717</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__108’><BrooklineWMS:OBJECTID>108</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0(VS)</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS AND MEDICAL RESEARCH</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>GMR-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gm
 l:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760582.740624994,2946508.886875 760495.613124996,2946557.140625 760289.434375003,2946668.31999999 760268.539375007,2946672.23999999 760264.911249995,2946671.99124999 760247.328749999,2946670.78625 760227.163749993,2946664.051875 760200.051249996,2946648.54062501 759930.198750004,2946491.45999999 759915.669375002,2946479.535 759904.598124996,2946464.34375 759897.698125005,2946446.85875 759895.456874996,2946425.90875 759941.221874997,2946182.316875 759950.977500007,2946123.004375 759980.386250004,2946130.566875 760031.359999999,2946149.53375 760089.446250007,2946154.27562501 760171.240624994,2946155.46125001 760266.075625002,2946155.46125001 760317.310625002,2946154.17937499 760317.191874996,2946189.481875 760320.663124993,2946200.6425 760403.909999996,2946303.816875 760445.191874996,2946330.63375001 760582.740624994,2946508.886875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml
 :Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>239561.766692187</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1951.38673316319</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__109’><BrooklineWMS:OBJECTID>109</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>2</BrooklineWMS:CASE1><BrooklineWMS:CASE2>2</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759354.664375007,2946085.81125 759337.071875006,2946161.02187499 759329.127499998,2946194.986875 759326.979375005,2946200.94687501 75918
 5.888125002,2946137.11562499 759125.758750007,2946116.22375 759061.96875,2946098.470625 758997.181250006,2946084.79875 758931.656874999,2946075.26375 758865.658749998,2946069.903125 758903.119375005,2945917.564375 758590.525625005,2945839.7 758549.051249996,2945829.36937501 758088.998750001,2945700.355 758029.805000007,2945685.811875 758035.808750004,2945661.16875 758053.620625004,2945586.171875 758131.933750004,2945603.00875001 758142.134375006,2945555.721875 758213.875,2945577.79625 758290.635000005,2945601.941875 758359.511250004,2945623.608125 758490.788124993,2945664.9025 758544.334999993,2945681.74625 758545.400625005,2945685.80374999 758550.733750001,2945706.1075 758578.890000001,2945712.47875001 758624.515000001,2945722.80374999 758631.578125,2945724.401875 758664.870625004,2945731.935625 758704.569374993,2945740.919375 758701.484375,2945756.230625 758756.930625007,2945770.471875 758776.493750006,2945775.49625 758844.472499996,2945792.95625 758837.21875,2945820.061875 758899.847499996,2945836.36375 758
 900.394374996,2945834.245 758938.186875001,2945844.48999999 758971.977500007,2945853.65000001 758991.481250003,2945858.936875 758998.127499998,2945859.541875 759014.588125005,2945863.86812501 759011.425624996,2945872.514375 759036.150625005,2945878.58125 759074.925624996,2945888.095 759089.192499995,2945880.42874999 759150.171875,2945903.16562501 759210.279375002,2945920.6375 759240.799999997,2945928.956875 759241.498750001,2945926.70625 759271.200000003,2945933.684375 759298.576250002,2945945.06375 759321.760625005,2945952.70375 759356.529375002,2945964.160625 759344.334374994,2946002.145625 759333.516249999,2946032.720625 759365.141249999,2946042.60312501 759354.664375007,2946085.81125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>216994.666179688</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3397.49699145377</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><Broo
 klineWMS:Zoning fid=‘F1__110’><BrooklineWMS:OBJECTID>110</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760676.213125005,2946164.49875 760669.606250003,2946162.30374999 760663.283124998,2946161.47875001 760643.633125007,2946141.198125 760607.553749993,2946089.51000001 760585.128749996,2946057.11812501 760568.016874999,2946017.81 760412.333124995,2945699.32625 760209.156874999,2945280.145 760197.779375002,2945262.300625 760133.650000006,2945201.04375 760104.291250005,2945164.135625 760085.206874996,2945133.7
 0937499 760066.892499998,2945085.28375 759978.721874997,2945123.79125001 759889.965625003,2945162.35124999 759896.926874995,2945177.98 759943.581249997,2945289.06874999 759888.715000004,2945315.323125 759818.605000004,2945348.871875 759752.489374995,2945375.92874999 759703.927499995,2945395.33374999 759659.991249993,2945412.89 759645.458749995,2945418.68875 759625.870625004,2945426.504375 759570.989374995,2945452.184375 759542.224374995,2945467.184375 759577.064374998,2945515.40000001 759596.035624996,2945541.655 759537.837500006,2945587.796875 759461.340625003,2945606.43625 759443.035624996,2945609.98 759425.900000006,2945531.330625 759406.625624999,2945535.8475 759396.064999998,2945538.21375 759384.631874993,2945524.456875 759375.140000001,2945513.035 759346.189999998,2945478.19875 759317.540625006,2945443.72437499 759241.397499993,2945512.090625 759199.481875002,2945516.5125 759179.471249998,2945521.99375001 759072.653125003,2945686.71312501 759057.406874999,2945677.1275 759011.315624997,2945649.13625 75897
 9.081249997,2945629.56 758937.063124999,2945604.041875 758903.619375005,2945587.30312499 758859.980625004,2945582.093125 758798.863124996,2945540.76875 758766.010625005,2945518.55625001 758804.434375003,2945465.78874999 758847.359375,2945406.840625 758858.076875001,2945391.44875 758967.136250004,2945464.94625001 759000,2945419.13625 759095.228750005,2945280.20874999 759109.588125005,2945279.985 759369.803749993,2945272.778125 759525.668750003,2945298.14875001 759562.326875001,2945297.89 759607.586875007,2945284.48875 759797.542500004,2945202.505 759536.243750006,2944608.723125 759709.064374998,2944532.793125 759968.280625001,2944420.44687501 759946.658124998,2944342.735 759930.186875001,2944265.448125 759887.299999997,2944004.811875 760021.822500005,2944040.5475 760014.798749998,2944062.215625 760000.6875,2944105.75 760002.75,2944146.25 760016.0625,2944194.75 760123.5625,2944350.75 760149.625,2944362 760160.875,2944511.75 760668.875,2945786.25 760726.679374993,2946173.33 760676.213125005,2946164.49875</gml:coo
 rdinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>935894.795712109</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>8496.15437401974</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__111’><BrooklineWMS:OBJECTID>111</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 760637.549374998,2946158.120625 760555.321250007,2946150.719375 760369.208124995,2
 946150.719375 760317.310625002,2946154.17937499 760266.075625002,2946155.46125001 760171.240624994,2946155.46125001 760089.446250007,2946154.27562501 760031.359999999,2946149.53375 759980.386250004,2946130.566875 759950.977500007,2946123.004375 759938.896249995,2946119.89812499 759788.346249998,2946099.745625 759682.842500001,2946087.89125 759592.75,2946079.593125 759534.070625007,2946069.516875 759520.438124999,2945945.639375 759378.474999994,2945897.31812499 759342.623125002,2945883.996875 759349.783749998,2945866.875 759406.857500002,2945792.998125 759430.725624993,2945762.104375 759428.344374999,2945751.261875 759452.736874998,2945745.9225 759472.131874993,2945743.52249999 759443.035624996,2945609.98 759461.340625003,2945606.43625 759537.837500006,2945587.796875 759596.035624996,2945541.655 759577.064374998,2945515.40000001 759542.224374995,2945467.184375 759570.989374995,2945452.184375 759625.870625004,2945426.504375 759645.458749995,2945418.68875 759659.991249993,2945412.89 759703.927499995,2945395.33374
 999 759752.489374995,2945375.92874999 759818.605000004,2945348.871875 759888.715000004,2945315.323125 759943.581249997,2945289.06874999 759896.926874995,2945177.98 759889.965625003,2945162.35124999 759978.721874997,2945123.79125001 760066.892499998,2945085.28375 760085.206874996,2945133.70937499 760104.291250005,2945164.135625 760133.650000006,2945201.04375 760197.779375002,2945262.300625 760209.156874999,2945280.145 760412.333124995,2945699.32625 760568.016874999,2946017.81 760585.128749996,2946057.11812501 760607.553749993,2946089.51000001 760643.633125007,2946141.198125 760663.283124998,2946161.47875001 760637.549374998,2946158.120625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>779578.538614648</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4066.22089821071</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__112’><BrooklineWMS:OBJECTI
 D>112</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758865.658749998,2946069.903125 758674.143124998,2946057.548125 758544.666875005,2946050.23375 758590.525625005,2945839.7 758903.119375005,2945917.564375 758865.658749998,2946069.903125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>59409.8817140625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1016.08928510219</BrooklineWMS:Shape.len></Broo
 klineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__113’><BrooklineWMS:OBJECTID>113</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0(CAM)</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>12</BrooklineWMS:CASE1><BrooklineWMS:CASE2>12</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0(CAM)</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758544.666875005,2946050.23375 758440.689999998,2946044.36 758244.921875,2946034.00624999 758056.685000002,2946024.05125 757955.383125007,2946013.53874999 757892.481875002,2946002.96250001 757914.894999996,2945918.231875 757910.418125004,2945917.53 757698.021249995,2945864.78687499 757690.138125002,2945858.88437501 757686.04999999
 7,2945843.84 757687.886875004,2945835.510625 757729,2945649.061875 757735.868125007,2945613.595 758029.805000007,2945685.811875 758088.998750001,2945700.355 758549.051249996,2945829.36937501 758590.525625005,2945839.7 758544.666875005,2946050.23375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>243246.065528125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2326.00403075373</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__114’><BrooklineWMS:OBJECTID>114</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>I-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>477</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>INDUSTRIAL SERVICES</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>7</BrooklineWMS:CASE1><BrooklineWMS:CASE2>7</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>I-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><Brookline
 WMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757892.481875002,2946002.96250001 757874.861874998,2946000 757855.231250003,2945996.699375 757717.983125001,2945970.19687501 757612.708124995,2945950.011875 757564.268124998,2945942.566875 757595.497500002,2945815.11687499 757673.311875001,2945832.0425 757687.886875004,2945835.510625 757686.049999997,2945843.84 757690.138125002,2945858.88437501 757698.021249995,2945864.78687499 757910.418125004,2945917.53 757914.894999996,2945918.231875 757892.481875002,2946002.96250001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>34859.094975</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>904.58605633351</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__115’><BrooklineWMS:OBJECT
 ID>115</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-0.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>8</BrooklineWMS:CASE1><BrooklineWMS:CASE2>8</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-0.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757342.673124999,2945942.77375001 757340.033124998,2945943.04000001 757166.243125007,2945964.155 757154.168125004,2945965.655 757134.464375004,2945839.293125 757116.108750001,2945816.136875 757107.254999995,2945752.36812501 757108.271874994,2945697.2225 757029.109375,2945627.421875 757015.510000005,2945600.935 756984.556250006,2945593.61375 757010.538124993,2945496.749375 757015.526875004,2945475.799375 756958.704374999,2945461.625625 756972.417500004,2
 945407.67625 756992.845624998,2945332.4425 757050.305625007,2945347.064375 757120.085624993,2945364.82187501 757148.367500007,2945372.01875 757161.688749999,2945375.40875 757159.339375004,2945351.35625 757250.203125,2945353.003125 757276.512500003,2945353.343125 757307.916875005,2945353.74875 757365.578749999,2945356.25687499 757365.539375007,2945374.686875 757394.168125004,2945375.591875 757394.496250004,2945409.69499999 757307.892499998,2945411.3725 757276.138125002,2945411.55562501 757275.566249996,2945500.505 757275.331249997,2945536.956875 757279.859999999,2945645.563125 757285.381249994,2945728.27 757298.318124995,2945808.954375 757303.208124995,2945825.60187501 757321.425624996,2945887.61624999 757342.673124999,2945942.77375001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>145759.732458984</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2092.05760133334</BrooklineWMS:Shape.len></BrooklineWMS:Zon
 ing></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__116’><BrooklineWMS:OBJECTID>116</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759372.019999996,2945915.90875 759356.529375002,2945964.160625 759321.760625005,2945952.70375 759298.576250002,2945945.06375 759271.200000003,2945933.684375 759241.498750001,2945926.70625 759240.799999997,2945928.956875 759210.279375002,2945920.6375 759150.171875,2945903.16562501 759089.192499995,2945880.42874999 759074.92562499
 6,2945888.095 759036.150625005,2945878.58125 759011.425624996,2945872.514375 759014.588125005,2945863.86812501 758998.127499998,2945859.541875 758991.481250003,2945858.936875 758971.977500007,2945853.65000001 758938.186875001,2945844.48999999 758900.394374996,2945834.245 758899.847499996,2945836.36375 758837.21875,2945820.061875 758844.472499996,2945792.95625 758776.493750006,2945775.49625 758756.930625007,2945770.471875 758701.484375,2945756.230625 758704.569374993,2945740.919375 758664.870625004,2945731.935625 758631.578125,2945724.401875 758624.515000001,2945722.80374999 758578.890000001,2945712.47875001 758550.733750001,2945706.1075 758545.400625005,2945685.80374999 758579.5,2945560.96625 758696.265625,2945616.68125001 758707.221249998,2945599.29125001 758766.010625005,2945518.55625001 758798.863124996,2945540.76875 758859.980625004,2945582.093125 758903.619375005,2945587.30312499 758937.063124999,2945604.041875 758979.081249997,2945629.56 759011.315624997,2945649.13625 759057.406874999,2945677.1275 759072
 .653125003,2945686.71312501 759179.471249998,2945521.99375001 759199.481875002,2945516.5125 759241.397499993,2945512.090625 759317.540625006,2945443.72437499 759346.189999998,2945478.19875 759375.140000001,2945513.035 759384.631874993,2945524.456875 759396.064999998,2945538.21375 759406.625624999,2945535.8475 759425.900000006,2945531.330625 759443.035624996,2945609.98 759472.131874993,2945743.52249999 759452.736874998,2945745.9225 759428.344374999,2945751.261875 759430.725624993,2945762.104375 759406.857500002,2945792.998125 759349.783749998,2945866.875 759342.623125002,2945883.996875 759378.474999994,2945897.31812499 759372.019999996,2945915.90875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>239988.930225</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2708.79593080725</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__117’><BrooklineWMS
 :OBJECTID>117</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-0.5P</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>16</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SPECIAL DISTRICT</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>0</BrooklineWMS:CASE1><BrooklineWMS:CASE2>0</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-0.5P</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753364.330624998,2945944.80312499 753367.647499993,2945921.169375 753300.648750007,2945723.44125 753289.209999993,2945498.750625 753287.575625002,2945376.191875 753295.114374995,2945325.09875 753302.282499999,2945276.510625 753336.599374995,2945212.78 753413.402500004,2945170.293125 753540.863749996,2945155.58625001 753638.910624996,2945153.951875 753759.834999993,2945212.78 753835.004374996,2945258.535625 753916.709999993,2945330.436875 754
 034.366249993,2945395.80125 754145.486874998,2945438.28812499 754207.583124995,2945448.093125 754107.901875004,2945512.640625 753960.831249997,2945573.10250001 753867.686875001,2945599.24875 753768.005624995,2945646.638125 753686.299999997,2945736.514375 753576.814374998,2945828.02500001 753387.256874993,2945938.3275 753366.585624993,2945960.47499999 753364.330624998,2945944.80312499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>391078.281767188</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2729.69300835239</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__118’><BrooklineWMS:OBJECTID>118</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</Broo
 klineWMS:CASE2><BrooklineWMS:ZONETYPE>G-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757564.268124998,2945942.566875 757559.811875001,2945941.88187499 757504.951250002,2945936.935 757449.886250004,2945935.47687501 757394.840000004,2945937.515 757342.673124999,2945942.77375001 757321.425624996,2945887.61624999 757303.208124995,2945825.60187501 757298.318124995,2945808.954375 757285.381249994,2945728.27 757279.859999999,2945645.563125 757275.331249997,2945536.956875 757275.566249996,2945500.505 757276.138125002,2945411.55562501 757307.892499998,2945411.3725 757394.496250004,2945409.69499999 757417.625,2945409.246875 757430.866874993,2945408.99062499 757466,2945408.309375 757501.394999996,2945407.62375 757537.942499995,2945406.91562501 757546.875,2945340.5 757559.9375,2945296.25 757570.0362
 49995,2945234.22687501 757574.453749999,2945207.095 757594.361249998,2945217.609375 757628.576875001,2945235.68125001 757663.71875,2945254.24250001 757719.172499999,2945283.53125 757738.194999993,2945293.578125 757693.844999999,2945377.5975 757685.381874993,2945434.09625 757792.361249998,2945455.425625 757797.326250002,2945421.42937499 757976.258125007,2945490.22562499 758015.640625,2945505.36687499 758068.028125003,2945525.50937501 758053.620625004,2945586.171875 758035.808750004,2945661.16875 758029.805000007,2945685.811875 757735.868125007,2945613.595 757729,2945649.061875 757687.886875004,2945835.510625 757673.311875001,2945832.0425 757595.497500002,2945815.11687499 757564.268124998,2945942.566875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>296693.090851563</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2918.4642955892</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featur
 eMember><BrooklineWMS:Zoning fid=‘F1__119’><BrooklineWMS:OBJECTID>119</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>21</BrooklineWMS:CASE1><BrooklineWMS:CASE2>20</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758707.221249998,2945599.29125001 758696.265625,2945616.68125001 758579.5,2945560.96625 758545.400625005,2945685.80374999 758544.334999993,2945681.74625 758490.788124993,2945664.9025 758359.511250004,2945623.608125 758290.635000005,2945601.941875 758213.875,2945577.79625 758142.134375006,2945555.721875 758131.933750004,2945603.00875001 758053.620625004,2945586.171875 758068.028125003,294552
 5.50937501 758102.816249996,2945379.03687499 758110.792500004,2945357.52625 758149.150000006,2945376.71375 758159.362499997,2945358.38500001 758211.239374995,2945246.63187499 758148.191874996,2945215.988125 758102.943749994,2945193.995625 758027.951250002,2945157.54625 758076.348749995,2945039.36 758087.571875006,2945011.953125 758108.737499997,2944960.26625 758125.626249999,2944919.02437501 758146.019999996,2944869.22375 758183.080624998,2944778.721875 758185.957499996,2944774.229375 758175,2944761.08499999 758162.590000004,2944746.07375 758181.715625003,2944733.718125 758205.933750004,2944707.41312499 758261.055000007,2944626.285 758273.831874996,2944607.46625 758433.706249997,2944371.999375 758625.286874995,2944236.735 758638.375,2944256.25 758693.884375006,2944344.675 758704.659374997,2944361.84 758748.026875004,2944342.52187499 758789.170625001,2944324.19374999 758814.668125004,2944312.83562499 758829.803124994,2944306.09375 758919.098124996,2944266.31625 758937.611249998,2944257.6225 758953.416875005,294
 4294.503125 758971.176874995,2944286.83562499 759067.718125001,2944244.29375 759098.614999995,2944230.67874999 759109.21875,2944254.3725 759113.801249996,2944264.610625 759146.776250005,2944249.9025 759208.532499999,2944222.356875 759210.331249997,2944163.03625 759212.071875006,2944105.61750001 759213.144374996,2944070.246875 759226.511250004,2944063.908125 759268.017499998,2944044.22437499 759282.704999998,2944037.25937501 759291.569999993,2944049.41 759318.490624994,2944036.079375 759355.559375003,2944017.72375 759379.100624993,2944006.066875 759396.900625005,2943997.2525 759400.768124998,2943995.33750001 759434.753124997,2943978.50875001 759464.056250006,2943963.99875 759494.335624993,2943948.971875 759496.258750007,2943947.983125 759498.245625004,2943947.13187499 759500.287499994,2943946.42125 759502.373750001,2943945.854375 759504.494375005,2943945.434375 759506.638750002,2943945.16374999 759508.797499999,2943945.043125 759510.959374994,2943945.073125 759513.113749996,2943945.254375 759515.25,2943945.5849
 9999 759517.358125001,2943946.064375 759519.427499995,2943946.689375 759521.448125005,2943947.456875 759523.410624996,2943948.36375 759525.305000007,2943949.405625 759527.753749996,2943951.026875 759535.655625001,2943959.50749999 759540.613749996,2943974.608125 759558.574375004,2944029.31 759536.063124999,2944165.77625 759515.574375004,2944164.06125 759504.579374999,2944260.67749999 759592.855625004,2944269.72875001 759551.070625007,2944427.249375 759474.284374997,2944402.8875 759457.521249995,2944449.230625 759518.342500001,2944589.85187501 759536.243750006,2944608.723125 759797.542500004,2945202.505 759607.586875007,2945284.48875 759562.326875001,2945297.89 759525.668750003,2945298.14875001 759369.803749993,2945272.778125 759109.588125005,2945279.985 759095.228750005,2945280.20874999 759000,2945419.13625 758967.136250004,2945464.94625001 758858.076875001,2945391.44875 758847.359375,2945406.840625 758804.434375003,2945465.78874999 758766.010625005,2945518.55625001 758707.221249998,2945599.29125001</gml:coordi
 nates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1749161.30985625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6745.99694628389</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__120’><BrooklineWMS:OBJECTID>120</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757797.326250002,2945421.42937499 757814.890625,2945301.17312
 5 757824.245625004,2945237.120625 757830.620000005,2945217.375 757769.183750004,2945186.643125 757319.814374998,2944951.25375 757385.944374993,2944857.20125 757469.542500004,2944741.92 757511.581874996,2944696.340625 757579.120000005,2944641.7475 757670.995625004,2944584.25562499 757687.605000004,2944606.94687501 757702.717500001,2944617.4825 757688.778750002,2944709.185 757711.4375,2944694.5 757716.125,2944691.75 757754.5625,2944702.75 757823.338125005,2944614.62125 757825.150625005,2944616.245 757848.652500004,2944626.066875 757877.081874996,2944637.94875 757899.346874997,2944647.25375 757892.658124998,2944661.17874999 757898.381249994,2944664.405 757878.396874994,2944708.9425 757872.982500002,2944706.4975 757848.457499996,2944759.27437501 757881.939374998,2944778.06874999 757972.159999996,2944828.71125001 757988.576250002,2944837.859375 758003.829999998,2944802.785 758067.673124999,2944657.519375 758091.328749999,2944615.79062501 758157.385000005,2944522.44374999 758171.328125,2944533.77437501 758260.515000
 001,2944595.656875 758273.831874996,2944607.46625 758261.055000007,2944626.285 758205.933750004,2944707.41312499 758181.715625003,2944733.718125 758162.590000004,2944746.07375 758175,2944761.08499999 758185.957499996,2944774.229375 758183.080624998,2944778.721875 758146.019999996,2944869.22375 758125.626249999,2944919.02437501 758108.737499997,2944960.26625 758087.571875006,2945011.953125 758076.348749995,2945039.36 758027.951250002,2945157.54625 758102.943749994,2945193.995625 758148.191874996,2945215.988125 758211.239374995,2945246.63187499 758159.362499997,2945358.38500001 758149.150000006,2945376.71375 758110.792500004,2945357.52625 758102.816249996,2945379.03687499 758068.028125003,2945525.50937501 758015.640625,2945505.36687499 757976.258125007,2945490.22562499 757797.326250002,2945421.42937499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>434617.522223438</BrooklineWMS:Shape.area><BrooklineWMS:Sh
 ape.len>3988.15589000975</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__121’><BrooklineWMS:OBJECTID>121</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757276.512500003,2945353.343125 757276.981875002,2945280.30562501 757279.299999997,2945059.698125 757286.459999993,2945022.21375 757299.956874996,2944980.71125001 757319.814374998,2944951.25375 757769.183750004,2945186.643125 757830.620000005,2945217.375 757824.245625004,2945237.120625
 757814.890625,2945301.173125 757797.326250002,2945421.42937499 757792.361249998,2945455.425625 757685.381874993,2945434.09625 757693.844999999,2945377.5975 757738.194999993,2945293.578125 757719.172499999,2945283.53125 757663.71875,2945254.24250001 757628.576875001,2945235.68125001 757594.361249998,2945217.609375 757574.453749999,2945207.095 757570.036249995,2945234.22687501 757559.9375,2945296.25 757546.875,2945340.5 757537.942499995,2945406.91562501 757501.394999996,2945407.62375 757466,2945408.309375 757430.866874993,2945408.99062499 757417.625,2945409.246875 757394.496250004,2945409.69499999 757394.168125004,2945375.591875 757365.539375007,2945374.686875 757365.578749999,2945356.25687499 757307.916875005,2945353.74875 757276.512500003,2945353.343125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>151314.992983594</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2191.99234938887</BrooklineWMS:Shape.len
 ></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__122’><BrooklineWMS:OBJECTID>122</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755474.292500004,2945369.370625 755463.156874999,2945288.81874999 755428.145624995,2945154.300625 755428.145624995,2945108.973125 755432.724374995,2945090.31375 755588.773750007,2945126.354375 755819.798124999,2945192.846875 755786.038749993,2945307.7475 755767.313124999,2945353.05500001 755730.318124995,29454
 22.95 755707.815624997,2945452.16374999 755694.775625005,2945432.70999999 755610.477500007,2945366.583125 755518.383750007,2945382.0575 755505.087500006,2945384.291875 755479.678124994,2945391.3425 755474.292500004,2945369.370625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>86954.370065625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1256.57649939246</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__123’><BrooklineWMS:OBJECTID>123</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><Brookli
 neWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 751760.992500007,2945395.44 751728.466875002,2945382.625 751677.413124993,2945349.62625 751636.986874998,2945311.44 751579.037499994,2945232.89125 751362.821250007,2945379.74375001 751358.706874996,2945372.479375 751356.347499996,2945369.333125 751352.9375,2945364.75 751308.005624995,2945305.63625 751259.483750001,2945241.799375 751243.501874998,2945220.77312499 751219.980625004,2945189.826875 751174.468125001,2945129.949375 751103.271874994,2945033.51125 751079.75,2944998 751013.484999999,2944907.10875 750872.759375006,2944712.561875 750960.839375004,2944655.166875 751002.645624995,2944625.263125 751119.511250004,2944521.42812499 751170.069999993,2944461.55625001 751198.469999999,2944427.925 751326.158124998,2944417.08 751535.086875007,2944403.37125 751602.383125007,2944355.53937501 751581.3125,2944327.25 751639.25,2944314.25 751639.
 575000003,2944319.346875 751667.659999996,2944313.529375 751670.758750007,2944359.01875 751704.926874995,2944346.53 751713.961875007,2944340.82875 751732.364374995,2944329.216875 751752.137500003,2944328.08 751806.493125007,2944324.955 751803.988124996,2944290.16500001 751823.691874996,2944285.029375 751861.301249996,2944281.46125001 751895.870000005,2944278.18187501 751933.090625003,2944274.91437501 751973.235624999,2944271.83374999 751973.235624999,2944157.246875 752390.555000007,2944148.31375 752750.383125007,2944144.07375 752838.949375004,2944147.09999999 752808.498125002,2944196.3725 752721.391874999,2944283.91437501 752681.091250002,2944324.41625001 752643.196250007,2944362.50125 752496.886875004,2944524.33 752281.831249997,2944781.5 752122.786874995,2944983.468125 752110.478125006,2945002.24062499 752088.861874998,2944981.784375 752033.250624999,2944930.18000001 752015.113749996,2944913.34999999 751986.537499994,2944945.904375 751954.228750005,2944982.738125 751929.846249998,2945015.21312501 751906.1218
 75003,2945046.813125 751882.361874998,2945078.48 751855.683750004,2945097.01375 751851.927499995,2945099.60187501 751856.188124999,2945121.31375 751855.088125005,2945132.433125 751852.971874997,2945153.82375 751846.848124996,2945169.824375 751828.449375004,2945217.89624999 751821.405625001,2945236.30125 751807.793750003,2945271.86499999 751797.958124995,2945297.565 751760.992500007,2945395.44</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1221304.13052344</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5514.57777163032</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__124’><BrooklineWMS:OBJECTID>124</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWM
 S:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757276.512500003,2945353.343125 757250.203125,2945353.003125 757159.339375004,2945351.35625 757161.688749999,2945375.40875 757148.367500007,2945372.01875 757120.085624993,2945364.82187501 757050.305625007,2945347.064375 756992.845624998,2945332.4425 756999.658749998,2945307.35312501 757014.063749999,2945254.30249999 757018.417500004,2945234.27187499 757023.079999998,2945212.81999999 757041.538749993,2945144.583125 757046.773124993,2945125.233125 757060.918750003,2945084.828125 757070.164375007,2945058.419375 757082.479375005,2945023.24187499 757085.703125,2945014.034375 757106.605000004,2944954.33 757137.123750001,2944867.1575 757142.418750003,2944849.323125 757179.55875
 0004,2944870.66312499 757319.814374998,2944951.25375 757299.956874996,2944980.71125001 757286.459999993,2945022.21375 757279.299999997,2945059.698125 757276.981875002,2945280.30562501 757276.512500003,2945353.343125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>106823.957165625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1437.35818359653</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__125’><BrooklineWMS:OBJECTID>125</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><Brooklin
 eWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 749783.262500003,2945290.020625 750008.105000004,2945233.81 750120.800624996,2945205.16875 750240.069374993,2945141.88437501 750810.329999998,2944753.24187499 750872.759375006,2944712.561875 751013.484999999,2944907.10875 751079.75,2944998 751103.271874994,2945033.51125 751006.918125004,2945084.143125 750924.869375005,2945136.528125 750964.034999996,2945293.29875 750827.173749998,2945330.4375 750817.973124996,2945309.56812499 750776.214375004,2945231.439375 750759.519999996,2945216.65875 750714.001249999,2945193.02500001 750694.483125001,2945186.77875 750671.799999997,2945185.22624999 750644.090000004,2945191.343125 750531.894374996,2945244.44687501 750415.890000001,2945297.19625001 750325.805000007,2945326.14687499 750279.566874996,2945336.280625 750185.629999995,2945347.66125 750138.310000002,2945348.860625 750091.008750007,2945347.058125 749783.262500003,2945290.020625</gml
 :coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>323571.193796094</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3304.84324126925</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__126’><BrooklineWMS:OBJECTID>126</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-15</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>22</BrooklineWMS:CASE1><BrooklineWMS:CASE2>21</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-15</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 749783.262500003,2945290.020625 749703.614999995,2945316.97812501 749645.208124995
 ,2945341.979375 749640.461250007,2945339.20937499 749611.101875007,2945321.2825 749423.409999996,2945265.92749999 749338.203749999,2945197.10375001 749353.028750002,2945171.035625 749251.756874993,2945127.889375 749235.997500002,2945116.83374999 749170.008125007,2945070.54062501 749194.428124994,2945046.234375 749121.989999995,2944971.89375 748992.493125007,2944838.995625 748964.504374996,2944865.95375 748893.616249993,2944791.844375 748836.258125007,2944731.88 748867.005624995,2944701.895 748871.341250002,2944706.405 748878.959999993,2944699.84625 748813.153750002,2944624.59875 748780.427499995,2944624.59 748760.356875002,2944640.69 748646.236249998,2944540.05312499 748672.128124997,2944519.90375 748735.884375006,2944470.285625 748615.028750002,2944332.10375001 748713.663124993,2944249.82875 748730.645624995,2944223.156875 748893.628124997,2944091.735 748919.753124997,2944072.12 748963.494375005,2944048.765625 749023.367500007,2944029.284375 749003.890625,2943905.99250001 749075.872500002,2943728.08499999 749
 258.426874995,2943796.06937499 749356.088125005,2943845.043125 749606.151875004,2943996.71625 749720.363749996,2944058.296875 749881.491874993,2944134.08437499 750047.103125006,2944199.5 750140.108750001,2944232.235 750205.258125007,2944251.11624999 750249.124375001,2944260.111875 750338.125,2944269.67874999 750584.079374999,2944264.18000001 750725.299374998,2944253.108125 750846.046250001,2944243.64125 751017.091250002,2944217.26375 751083.429374993,2944209.864375 751086.014375001,2944209.7775 751095.436250001,2944274.4875 751170.069999993,2944461.55625001 751119.511250004,2944521.42812499 751002.645624995,2944625.263125 750960.839375004,2944655.166875 750872.759375006,2944712.561875 750810.329999998,2944753.24187499 750240.069374993,2945141.88437501 750120.800624996,2945205.16875 750008.105000004,2945233.81 749783.262500003,2945290.020625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>2191953.67337891<
 /BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6819.26238744819</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__127’><BrooklineWMS:OBJECTID>127</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756744.201875001,2945203.3075 756756.996875003,2945145.636875 756764.221249998,2945113.073125 756773.720624998,2945070.254375 756786.913124993,2945010.79062501 756792.628124997,2944985.030625 756802.759375006,2944931.906875 756803.998750001,2944925.41
 756815.258750007,2944893.173125 756845.370000005,2944806.96375 756874.140000001,2944724.595 756862.811875001,2944693.489375 756915.915000007,2944644.11125 756991.129999995,2944554.019375 756996.533124998,2944547.548125 757028.590000004,2944488.613125 757078.366249993,2944357.625 757081.979375005,2944350.895 757100.301874995,2944358.343125 757203.490624994,2944402.49062499 757205.551874995,2944397.828125 757244.096249998,2944414.01625 757288.739374995,2944432.76625 757223.480000004,2944534.126875 757209.500624999,2944528.27437501 757157.5,2944595.5 757170.1875,2944606.5 757258.543750003,2944668.090625 757243.102500007,2944689.65375 757274.661874995,2944712.43062501 757286.078125,2944720.67 757189.850624993,2944855.93125001 757179.558750004,2944870.66312499 757142.418750003,2944849.323125 757137.123750001,2944867.1575 757106.605000004,2944954.33 757085.703125,2945014.034375 757082.479375005,2945023.24187499 757070.164375007,2945058.419375 757060.918750003,2945084.828125 757046.773124993,2945125.233125 757041.538
 749993,2945144.583125 757023.079999998,2945212.81999999 757018.417500004,2945234.27187499 756878.998750001,2945198.22499999 756871.293750003,2945233.78749999 756847.508750007,2945228.13249999 756744.201875001,2945203.3075</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>245573.871971094</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2537.92488592122</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__128’><BrooklineWMS:OBJECTID>128</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOT
 ES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757179.558750004,2944870.66312499 757189.850624993,2944855.93125001 757286.078125,2944720.67 757274.661874995,2944712.43062501 757243.102500007,2944689.65375 757258.543750003,2944668.090625 757170.1875,2944606.5 757157.5,2944595.5 757209.500624999,2944528.27437501 757223.480000004,2944534.126875 757288.739374995,2944432.76625 757244.096249998,2944414.01625 757205.551874995,2944397.828125 757203.490624994,2944402.49062499 757100.301874995,2944358.343125 757081.979375005,2944350.895 757090.795000002,2944334.47624999 757110.053749993,2944308.481875 757102.048749998,2944266.189375 757101.681875005,2944239.35187501 757139.483750001,2943995.2525 757532.876874998,2943956.71312501 757665.623750001,2943816.91125 757709.853750005,2943770.330625 757720.578749999,2943755.921875 757813.209999993,2943810.845 757837.953125,2943824.83437499 757862.019999996,2943786.671875 757892.8
 90000001,2943744.549375 757962.325000003,2943666.593125 758000.609999999,2943631.07375 758095.718125001,2943557.67874999 758146.276875004,2943524.513125 758263.668125004,2943455.6525 758501.423749998,2943316.57375 758530.313124999,2943263.62875 758911.625,2942887.25 759083.0625,2942862.75 759165.986249998,2942887.139375 759137.393124998,2943067.0625 759110.040000007,2943246.376875 759093.596874997,2943388.31874999 759090.386875004,2943466.19499999 759089.046250001,2943903.66500001 759089.726875007,2943949.07625 759097.365624994,2944006.735 759039.129999995,2944042.141875 759000,2944059.99312501 758877.252499998,2944115.99062499 758861.478125006,2944080.59375 758850.413749993,2944060.57250001 758831.9375,2944071.03625 758747.586250007,2944109.36937501 758709.473749995,2944126.689375 758672.482500002,2944143.5 758644.336250007,2944156.29062501 758627.954999998,2944163.735 758610.579374999,2944171.63187499 758591.991874993,2944180.605625 758552.954999998,2944128.88625 758390.813749999,2944186.66562501 758386.2699
 99996,2944198.28687499 758324.628124997,2944286.79625 758218.215000004,2944436.481875 758157.385000005,2944522.44374999 758091.328749999,2944615.79062501 758067.673124999,2944657.519375 758003.829999998,2944802.785 757988.576250002,2944837.859375 757972.159999996,2944828.71125001 757881.939374998,2944778.06874999 757848.457499996,2944759.27437501 757872.982500002,2944706.4975 757878.396874994,2944708.9425 757898.381249994,2944664.405 757892.658124998,2944661.17874999 757899.346874997,2944647.25375 757877.081874996,2944637.94875 757848.652500004,2944626.066875 757825.150625005,2944616.245 757823.338125005,2944614.62125 757819.463750005,2944611.14875001 757853.165000007,2944534.6575 757860.143749997,2944518.09375 757778.903750002,2944483.7625 757928.686875001,2944232.03125 757994.676874995,2944123.32187501 758009.109999999,2944104.28375 758034.083124995,2944080.281875 758278.852500007,2943933.55249999 758199.386875004,2943770.45375 758114.048749998,2943820.405 758090.864374995,2943786.279375 758069.960624993,294
 3755.510625 758059.840000004,2943740.6125 758039.427499995,2943756.09875 758019.736874998,2943771.03749999 758011.674999997,2943777.153125 758023.855000004,2943789.343125 757994.626249999,2943811.5175 757968.398124993,2943831.41500001 757933.399375007,2943857.965625 757993.081874996,2943902.8875 757977.169375002,2943913.870625 757971.620000005,2943920.19562501 757962.148750007,2943930.99062499 757934.493750006,2943962.511875 757908.459999993,2943992.184375 757866.751249999,2944039.72375 757844.852500007,2944064.68375 757809.825000003,2944104.6075 757777.118750006,2944141.88500001 757706.242500007,2944222.551875 757725.557500005,2944291.11125 757755.178124994,2944398.08125 757729.797499999,2944405.10187501 757688.467500001,2944416.37625 757639.633750007,2944430.08625001 757633,2944439.389375 757626.659374997,2944448.281875 757616.456249997,2944462.590625 757707.064374998,2944525.214375 757730.634375006,2944540.91374999 757713.083749995,2944557.918125 757670.995625004,2944584.25562499 757579.120000005,2944641.74
 75 757511.581874996,2944696.340625 757469.542500004,2944741.92 757385.944374993,2944857.20125 757319.814374998,2944951.25375 757179.558750004,2944870.66312499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1679756.67630703</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>10076.8840519289</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__129’><BrooklineWMS:OBJECTID>129</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>0</BrooklineWMS:CASE1><BrooklineWMS:CASE2>0</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:po
 lygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757823.338125005,2944614.62125 757754.5625,2944702.75 757716.125,2944691.75 757711.4375,2944694.5 757688.778750002,2944709.185 757702.717500001,2944617.4825 757687.605000004,2944606.94687501 757670.995625004,2944584.25562499 757713.083749995,2944557.918125 757730.634375006,2944540.91374999 757707.064374998,2944525.214375 757616.456249997,2944462.590625 757626.659374997,2944448.281875 757633,2944439.389375 757639.633750007,2944430.08625001 757688.467500001,2944416.37625 757729.797499999,2944405.10187501 757755.178124994,2944398.08125 757725.557500005,2944291.11125 757706.242500007,2944222.551875 757777.118750006,2944141.88500001 757809.825000003,2944104.6075 757844.852500007,2944064.68375 757866.751249999,2944039.72375 757908.459999993,2943992.184375 757934.493750006,2943962.511875 757962.148750007,2943930.99062499 757971.620000005,2943920.19562501 757977.169375002,2943913.870625 757993.081874996,2943902.8875 757933.399375007,294385
 7.965625 757968.398124993,2943831.41500001 757994.626249999,2943811.5175 758023.855000004,2943789.343125 758011.674999997,2943777.153125 758019.736874998,2943771.03749999 758039.427499995,2943756.09875 758059.840000004,2943740.6125 758069.960624993,2943755.510625 758090.864374995,2943786.279375 758114.048749998,2943820.405 758199.386875004,2943770.45375 758278.852500007,2943933.55249999 758034.083124995,2944080.281875 758009.109999999,2944104.28375 757994.676874995,2944123.32187501 757928.686875001,2944232.03125 757778.903750002,2944483.7625 757860.143749997,2944518.09375 757853.165000007,2944534.6575 757819.463750005,2944611.14875001 757823.338125005,2944614.62125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>174530.300689844</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2909.80649789653</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1
 __130’><BrooklineWMS:OBJECTID>130</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-0.75P</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SPECIAL DISTRICT</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>20</BrooklineWMS:CASE1><BrooklineWMS:CASE2>19</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-0.75P</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759536.243750006,2944608.723125 759518.342500001,2944589.85187501 759457.521249995,2944449.230625 759474.284374997,2944402.8875 759551.070625007,2944427.249375 759592.855625004,2944269.72875001 759504.579374999,2944260.67749999 759515.574375004,2944164.06125 759536.063124999,2944165.77625 759558.574375004,2944029.31 759540.613749996,2943974.608125 759558.973749995,2943959.660625 759590.838125005,2943933.72 759660.125
 ,2943871.5 759678.918125004,2943841.921875 759847.516249999,2943976.8 759861.215000004,2943988.39125 759874.386875004,2943997.875 759887.299999997,2944004.811875 759930.186875001,2944265.448125 759946.658124998,2944342.735 759968.280625001,2944420.44687501 759709.064374998,2944532.793125 759536.243750006,2944608.723125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>234755.713283594</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2227.23851500219</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__131’><BrooklineWMS:OBJECTID>131</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><Bro
 oklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758157.385000005,2944522.44374999 758218.215000004,2944436.481875 758324.628124997,2944286.79625 758386.269999996,2944198.28687499 758390.813749999,2944186.66562501 758552.954999998,2944128.88625 758591.991874993,2944180.605625 758613.470624998,2944219.11687499 758625.286874995,2944236.735 758433.706249997,2944371.999375 758273.831874996,2944607.46625 758260.515000001,2944595.656875 758171.328125,2944533.77437501 758157.385000005,2944522.44374999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>80263.2844671875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1374.98829563859</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><Brookline
 WMS:Zoning fid=‘F1__132’><BrooklineWMS:OBJECTID>132</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755776.826875001,2944411.40000001 755768.866249993,2944390.986875 755763.53125,2944364.21375 755751.546875,2944262.933125 755740.489999995,2944202.7225 755725.685000002,2944201.485 755607.445625007,2944200.86 755569.173124999,2944187.61 755494.048124999,2944190.219375 755483.243125007,2944096.88187499 755461.329999998,2944019.514375 755449.481875002,2943917.03874999 755448.044375002,2943897.58125 755427.4643
 75004,2943902.905 755400.915625006,2943767.85250001 755401.195625007,2943742.175 755397.808125004,2943713.535 755373.732500002,2943607.63875 755410.335624993,2943529.791875 755402.623750001,2943511.83750001 755301.592500001,2943444.48375 755256.814999998,2943414.63187499 754961.015000001,2943420.455 754965.453749999,2943299.845 754970.511250004,2943162.44125 754932.808125004,2943162.356875 754933.4375,2943094.14875001 754947.90625,2943093.205 754948.848749995,2943050.77124999 754974.274375007,2943050.995 754981.646874994,2942735.3175 755371.515000001,2942629.44437499 755493.085624993,2942693.520625 755605.592500001,2942752.81937499 755728.356875002,2942930.38437501 755742.946875006,2942996.73375 755731.648124993,2943129.27187499 755729.268749997,2943157.185625 755746.216875002,2943267.06625 755684.310625002,2943463.93062501 755634.723749995,2943587.624375 755619.366874993,2943624.58125 755753.631874993,2943685.46625 755767.440624997,2943691.72687501 755811.301874995,2943571.405625 755824.606875002,2943574.9231
 25 755956.871875003,2943619.05374999 756051.174374998,2943638.020625 756080.989374995,2943637.60124999 756073.033749998,2943713.50562499 756041.616874993,2943716.798125 756020.299374998,2943876.6225 756006.157499999,2943982.64875001 755990.863749996,2944097.310625 755988.459999993,2944115.33562499 755968.151875004,2944267.58750001 756242.768749997,2944359.371875 756420.875,2944380.25 756446.636250004,2944382.49875 756411.069374993,2944461.36375 756402.711875007,2944493.19687501 756387.316874996,2944602.11499999 756294.640625,2944591.058125 756078.460624993,2944554.31937499 755997.931875005,2944551.28 755974.193124995,2944549.531875 755939.475624993,2944541.323125 755894.696875006,2944520.50875001 755867.894999996,2944504.175 755806.233750001,2944452.495 755788.590000004,2944431.74187499 755776.826875001,2944411.40000001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1100123.63438906</BrooklineWMS:Shape.a
 rea><BrooklineWMS:Shape.len>6645.62445777569</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__133’><BrooklineWMS:OBJECTID>133</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756991.129999995,2944554.019375 756979.963750005,2944536.04875 756901.535624996,2944408.72687501 756846.421875,2944401.425625 756753.889375001,2944389.1675 756778.770624995,2944308.85312501 756704.622500002,2944270.09 756763.499375001,2944200.745 756703.343125001,2944180
 .528125 756568.741249993,2944135.2925 756544.466875002,2944127.42812499 756579.40625,2944018.31812499 756610.100624993,2943905.21375 756635.665000007,2943911.216875 756756.313749999,2943929.216875 756867.968125001,2943946.136875 756887.572500005,2943827.405625 756904.628749996,2943724.36375 757151.758750007,2943762.355625 757168.099374995,2943765.185 757164.586250007,2943816.06125 757159.218125001,2943867.82625 757139.483750001,2943995.2525 757101.681875005,2944239.35187501 757102.048749998,2944266.189375 757110.053749993,2944308.481875 757090.795000002,2944334.47624999 757081.979375005,2944350.895 757078.366249993,2944357.625 757028.590000004,2944488.613125 756996.533124998,2944547.548125 756991.129999995,2944554.019375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>277996.63708125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2616.81435825026</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featu
 reMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__134’><BrooklineWMS:OBJECTID>134</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>21</BrooklineWMS:CASE1><BrooklineWMS:CASE2>20</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 755776.826875001,2944411.40000001 755765.368750006,2944460.591875 755751.613124996,2944485.595 755734.058125004,2944480.294375 755614.845624998,2944445.979375 755487.830624998,2944449.858125 755489.623750001,2944345.114375 755489.469374999,2944323.51375 755435.051249996,2944320.64624999 755403.474999994,2944310.938125 755371.943749994,2944293.63625 755344.198750004,29442
 65.72812501 755326.546875,2944230.55687501 755290.228750005,2944048.30500001 755277.253124997,2944001.60062499 755301.228125006,2943990.385625 755385.556250006,2943922.06812499 755418.806875005,2943905.145 755427.464375004,2943902.905 755448.044375002,2943897.58125 755449.481875002,2943917.03874999 755461.329999998,2944019.514375 755483.243125007,2944096.88187499 755494.048124999,2944190.219375 755569.173124999,2944187.61 755607.445625007,2944200.86 755725.685000002,2944201.485 755740.489999995,2944202.7225 755751.546875,2944262.933125 755763.53125,2944364.21375 755768.866249993,2944390.986875 755776.826875001,2944411.40000001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>133263.419252344</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1872.11091171754</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__135’><BrooklineWMS:OBJECTID>135</Broo
 klineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-0.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>8</BrooklineWMS:CASE1><BrooklineWMS:CASE2>8</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-0.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 751198.469999999,2944427.925 751170.069999993,2944461.55625001 751095.436250001,2944274.4875 751086.014375001,2944209.7775 751303.301249996,2944203.69374999 751343.53125,2944199.563125 751390.006249994,2944194.79125001 751529.791875005,2944125.815 751569.829999998,2944102.58625001 751615.583749995,2944082.64125 751742.075625002,2944056.83125 751781.963750005,2944043.5 751823.715000004,2944022.0425 751848.322500005,2944085.79062501 751884.530000001,2944084.858125 75
 1885.508125007,2944159.125 751973.235624999,2944157.246875 751973.235624999,2944271.83374999 751933.090625003,2944274.91437501 751895.870000005,2944278.18187501 751861.301249996,2944281.46125001 751823.691874996,2944285.029375 751803.988124996,2944290.16500001 751806.493125007,2944324.955 751752.137500003,2944328.08 751732.364374995,2944329.216875 751713.961875007,2944340.82875 751704.926874995,2944346.53 751670.758750007,2944359.01875 751667.659999996,2944313.529375 751639.575000003,2944319.346875 751639.25,2944314.25 751581.3125,2944327.25 751602.383125007,2944355.53937501 751535.086875007,2944403.37125 751326.158124998,2944417.08 751198.469999999,2944427.925</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>197036.731197266</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2409.25510349822</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__13
 6’><BrooklineWMS:OBJECTID>136</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-40</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>24</BrooklineWMS:CASE1><BrooklineWMS:CASE2>23</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-40</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756420.875,2944380.25 756242.768749997,2944359.371875 755968.151875004,2944267.58750001 755988.459999993,2944115.33562499 755990.863749996,2944097.310625 756006.157499999,2943982.64875001 756020.299374998,2943876.6225 756041.616874993,2943716.798125 756073.033749998,2943713.50562499 756080.989374995,2943637.60124999 756051.174374998,2943638.020625 755956.871875003,2943619.05374999 755824.606875002,2943574.923125 755811.301874995,
 2943571.405625 755767.440624997,2943691.72687501 755753.631874993,2943685.46625 755619.366874993,2943624.58125 755634.723749995,2943587.624375 755684.310625002,2943463.93062501 755746.216875002,2943267.06625 755729.268749997,2943157.185625 755731.648124993,2943129.27187499 755742.946875006,2942996.73375 755728.356875002,2942930.38437501 755605.592500001,2942752.81937499 755493.085624993,2942693.520625 755371.515000001,2942629.44437499 754981.646874994,2942735.3175 754756.728125006,2942868.235 754760.855000004,2942879.14749999 754746.064999998,2942883.00812501 754569.782499999,2942929.02312499 754534.079374999,2942940.283125 754561.073125005,2942827.333125 754559.481875002,2942723.91187499 754543.018749997,2942664.046875 754511.819999993,2942681.855 754451.346249998,2942724.88062499 754413.495000005,2942745.065625 754382.986874998,2942752.685 754319.432500005,2942751.4975 754254.385000005,2942765.08 754202.997500002,2942760.96625 754140.089375004,2942749.885625 754065.215000004,2942748.07625 754023.049999997,29
 42753.939375 754000,2942760.83875 753976.168125004,2942767.9725 753942.239999995,2942793.609375 753921.269999996,2942817.46187501 753793.995000005,2943016.24187499 753691.801249996,2943157.89687499 753609.739999995,2943256.90000001 753450.916875005,2943413.938125 753379.767499998,2943475.470625 753210.250624999,2943301.52312499 753144.292500004,2943351.110625 753074.361249998,2943258.138125 753057.090625003,2943270.83687501 752941.191249996,2943356.05625001 752848.023124993,2943424.5625 752726.530000001,2943513.894375 752665.519374996,2943558.755 752452.835624993,2943715.138125 752446.466250002,2943741.485 752421.184375003,2943723.22 752399.768124998,2943713.85625 752369.200000003,2943707.97624999 752345.838125005,2943708.72499999 752257.383750007,2943726.66875 752251.704999998,2943728.645625 752205.901875004,2943632.38625 752163.114999995,2943579.11937501 752056.451250002,2943446.33125 752001.395624995,2943488.708125 751928.381249994,2943499.85312501 751903,2943501.05500001 751902.573750004,2943495.97812501 7
 51892.454374999,2943459.361875 751839.508750007,2943339.49312501 751805.381249994,2943280.859375 751839.59375,2943248.86687499 751686.045000002,2943119.918125 751638.033749998,2943095.854375 751561.371250004,2943057.42937499 751447.020624995,2943027.47437499 751410.513750002,2943017.910625 751247.069999993,2942975.095 751186.212500006,2942959.153125 751090.288124993,2942869.83625001 750919.568749994,2942750.55374999 750874.165000007,2942725.88 750800.480000004,2942695.986875 750733.450625002,2942677.825 750664.661874995,2942668.295 750595.206874996,2942667.55 750513.121875003,2942680.26000001 750462.791250005,2942694.31375 750390.659999996,2942723.831875 750142.795000002,2942859.720625 750131.75,2942839.75 750119.905000001,2942815.19 749894.356875002,2942887.36687499 749905.284374997,2942923.51375 749726.319374993,2942961.24437501 749522.834999993,2942936.77625 749520.288124993,2942938.40062501 749348.953749999,2942900.348125 749254.323125005,2942879.33125 749264.234375,2942743.64 749228.106875002,2942635.0712
 5001 749177.584999993,2942640.72562499 749053.411874995,2942657.394375 748593.939374998,2942720.11624999 748514.165000007,2942736.88437501 748479.244375005,2942749.763125 748465.550624996,2942730.408125 748457.173124999,2942708.29000001 748453.941249996,2942645.375 748458.599999994,2942561.57062501 748480.670000002,2942399.136875 748493.453749999,2942302.94875 748496.051874995,2942236.176875 748475.020624995,2942000 748472.435000002,2941970.96875 748462.456249997,2941929.97125 748437.980000004,2941871.66 748415.705624998,2941835.823125 748383.939999998,2941797.125625 748351.360624999,2941759.496875 748273.178124994,2941656.291875 748251.071250007,2941622.904375 748243.746875003,2941611.841875 748220.178749993,2941564.02312499 748156.581249997,2941384.76625 748135.575625002,2941348.581875 748083.055625007,2941297.08374999 748063.188124999,2941283.230625 748029.061875001,2941268.84 747986.298749998,2941260.215625 747732.713125005,2941209.753125 747625.871875003,2941176.77312499 747556.511250004,2941150.291875 74
 7508.551874995,2941126.70874999 747449.519374996,2941089.923125 747407.453749999,2941048.111875 747377.234999999,2941004.72562499 747329.521874994,2940915.828125 747287.010000005,2940895.17937499 747256.611874998,2940892.74312501 747273.296250001,2940809.71187501 747292.829374999,2940712.65000001 747297.153750002,2940642.089375 747270.250624999,2940312.23999999 747252.538124993,2940104.081875 747236.718125001,2939990.481875 747219.526875004,2939918.55 747213.516249999,2939899.761875 747599.335624993,2939723.7675 747814.255624995,2939932.48625 747943.406874999,2939767.55500001 747962.586250007,2939743.061875 748191.133125007,2939959.83750001 748293.139375001,2939857.2625 748476.5,2939769.78812499 748687.807500005,2939573.68187501 748705.398124993,2939557.356875 748835.214375004,2939409.83 748899.706874996,2939361.49187499 748957.641874999,2939301.59875 749047.404375002,2939266.10312501 749515.165000007,2939222.105 749763.935000002,2938853.276875 749737.731875002,2938775.87375 749823.766249999,2938659.354375 749
 849.090000004,2938588.66249999 749867.526250005,2938539.455625 749879.163124993,2938485.62375 749925.430625007,2938432.72 750033.848124996,2938397.669375 750070.723124996,2938231.81 750180.128749996,2938179.901875 750698.104375005,2937983.82625 750954.027500004,2937702.35875 751157.536249995,2937904.093125 751396.760625005,2938081.985625 751633.393124998,2937940.85625 751647.294375002,2937926.810625 751807.434375003,2937765.00875001 751826.616249993,2937745.6275 751837.246250004,2937710.488125 751992.401875004,2937555.7625 751966.911249995,2937482.685625 752037.136250004,2937427.3175 752011.870000005,2937396.46375 751983.805000007,2937367.97 751860.305000007,2937259.845 751825.234375,2937223.870625 751772.905000001,2937158.906875 751771.569999993,2937156.64812499 751733.898750007,2937092.901875 751706.436250001,2937030.355 751569.253749996,2936674.420625 751566.461875007,2936653.31812499 751569.058125004,2936632.19 751576.878124997,2936612.39125 751592.737499997,2936590.729375 752445.219374999,2936024.41312499
  752898.109375,2935731.298125 752989.209999993,2935672.33687501 753371.383125007,2935427.71875 753414.861874998,2935395.99187499 753440.219999999,2935377.488125 753511.824375004,2935329.65062501 753527.75,2935345.25 754493.875,2936818 755043.875,2937878.25 755487.5,2938852.75 755663.875,2939212.75 755694.375,2939275 755737.75,2939365 756075.1875,2939871.5 756579.5,2940692.5 757006.3125,2941365.5 757775.875,2942534.25 757927,2942850.5 757927.256874993,2942850.35625 757954.843125001,2942900.66125 757981.440624997,2942944.104375 757949.523124993,2942962.7225 757925.585624993,2942979.5675 757904.307500005,2942993.753125 757827.549999997,2943045.83374999 757768.659374997,2943087.73125 757715.463750005,2943124.081875 757689.613124996,2943131.18062501 757742.726875007,2943361.40062501 757747.204999998,2943424.54625 757743.498125002,2943466.620625 757728.049374998,2943528.01000001 757701.261250004,2943585.36687499 757677.563749999,2943620.331875 757635.943749994,2943666.73625 757594.881874993,2943701.548125 757549.743
 750006,2943730.88187499 757501.254999995,2943754.26625 757423.959374994,2943777.39 757262.611874998,2943804.104375 757164.586250007,2943816.06125 757168.099374995,2943765.185 757151.758750007,2943762.355625 756904.628749996,2943724.36375 756887.572500005,2943827.405625 756867.968125001,2943946.136875 756756.313749999,2943929.216875 756635.665000007,2943911.216875 756610.100624993,2943905.21375 756579.40625,2944018.31812499 756544.466875002,2944127.42812499 756516.761875004,2944213.948125 756481.423124999,2944305.36375 756446.636250004,2944382.49875 756420.875,2944380.25</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs><gml:innerBoundaryIs><gml:LinearRing><gml:coordinates> 753295.690624997,2940855.24250001 753318.635625005,2940852.75624999 753513.260625005,2940815.095625 753501.404375002,2940760.72437499 753493.337500006,2940727.41374999 753484.690624997,2940694.249375 753475.466250002,2940661.24062499 753465.667500004,2940628.39812499 753462.893124998,2940619.46312501 753455.822500005,2940597.341875 753
 448.491249993,2940575.30562501 753411.995000005,2940466.708125 753363.744375005,2940323.13249999 753320.825625002,2940195.42375 753397.4375,2940171.5 753438.871875003,2940156.52375001 753457.457499996,2940149.80625001 753460.273124993,2940148.78874999 753476.008750007,2940143.81937499 753599.773124993,2940104.7375 753601.403125003,2940088.07375 753742.573750004,2939955.004375 753800.060625002,2939900.81625 753852.268749997,2939851.605 753902.511250004,2939804.24625 754072.313749999,2939984.625 754202.140000001,2939865.471875 754218.203125,2939852.858125 754206.045000002,2939833.18375 754100.094999999,2939614.96375 754052.103125006,2939529.55562501 754000,2939434.640625 753994.888125002,2939425.328125 753951.065624997,2939355.44499999 753893.661249995,2939238.823125 753863.178124994,2939158.41187499 753843.504374996,2939081.105625 753815.723124996,2938926.971875 753794.756874993,2938840.52 753771.088750005,2938765.93000001 753744.681875005,2938698.505 753714.050624996,2938632.891875 753711.717500001,2938628.447
 50001 753671.588750005,2938552.015 753648.613124996,2938519.85875 753619.576250002,2938490.35312501 753584.926249996,2938461.32062501 753557.990624994,2938443.36937501 753521.056875005,2938424.376875 753453.017499998,2938396.36375 753346.168750003,2938366.64875001 753418.961250007,2938376.27625 753498.480000004,2938378.956875 753537.201875001,2938374.018125 753614.176874995,2938353.391875 753715.448750004,2938326.36 753961.763750002,2938244.921875 754000,2938230.953125 754366.659999996,2938097 754471.868125007,2938065.901875 754643.186875001,2938021.44499999 754634.676249996,2937997.5975 754536.433125004,2937696.75687499 754406.225624993,2937748.794375 754291.53125,2937794.63249999 754071.789375007,2937882.4525 753946.714375004,2937932.13375001 753827.537499994,2937976.935 753752.855000004,2938005.01000001 753717.536249995,2938018.28687499 753712.278125003,2938004.27375001 753618.698750004,2937754.88625 753536.433125004,2937535.64812499 753361.666250005,2937771.7075 753304.341875002,2937849.135625 753228.18062
 5007,2937952.00749999 753134.709374994,2938078.26000001 753001.602500007,2938258.049375 752995.416250005,2938296.31999999 752956.258125007,2938430.155 752903.236874998,2938601.3175 752899.678124994,2938612.8075 752864.479375005,2938713.279375 752778.121875003,2938941.58562499 752752.811875001,2939016.795625 752741.161874995,2939079.64937501 752738.370625004,2939111.25812501 752738.457499996,2939124.08125 752738.804374993,2939175.42625 752747.348124996,2939238.7775 752763.841875002,2939300.53749999 752838.863749996,2939522.078125 752841.390000001,2939529.53625 752932.126249999,2939797.4825 752954.073125005,2939862.21187501 752926.791875005,2939963.40625 752907.186250001,2940013.78375 752887.212500006,2940051.666875 752857.183125004,2940106.40062501 752816.189999998,2940157.644375 752833.211250007,2940170.08812501 752905.049374998,2940238.655 752966.991874993,2940297.7775 753042.052499995,2940369.42 753113.317499995,2940437.44 753198.413124993,2940519.58875 753256.078125,2940688.83812501 753286.666875005,2940807
 .84625 753295.690624997,2940855.24250001</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>45060500.8382742</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>47620.3340833932</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__137’><BrooklineWMS:OBJECTID>137</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758971.1
 76874995,2944286.83562499 758953.416875005,2944294.503125 758937.611249998,2944257.6225 758919.098124996,2944266.31625 758829.803124994,2944306.09375 758814.668125004,2944312.83562499 758789.170625001,2944324.19374999 758748.026875004,2944342.52187499 758704.659374997,2944361.84 758693.884375006,2944344.675 758638.375,2944256.25 758625.286874995,2944236.735 758613.470624998,2944219.11687499 758591.991874993,2944180.605625 758610.579374999,2944171.63187499 758627.954999998,2944163.735 758644.336250007,2944156.29062501 758672.482500002,2944143.5 758709.473749995,2944126.689375 758747.586250007,2944109.36937501 758831.9375,2944071.03625 758850.413749993,2944060.57250001 758861.478125006,2944080.59375 758877.252499998,2944115.99062499 759000,2944059.99312501 759039.129999995,2944042.141875 759097.365624994,2944006.735 759089.726875007,2943949.07625 759089.046250001,2943903.66500001 759090.386875004,2943466.19499999 759093.596874997,2943388.31874999 759110.040000007,2943246.376875 759137.393124998,2943067.0625 7591
 65.986249998,2942887.139375 759236.0625,2942907.75 759333.3125,2943002.5 759352.0625,2943043.5 759354.5,2943070 759428.5,2943124.25 759809.8125,2943261.25 759932.3125,2943648 760021.625,2943960 760022,2944040 760021.822500005,2944040.5475 759887.299999997,2944004.811875 759874.386875004,2943997.875 759861.215000004,2943988.39125 759847.516249999,2943976.8 759678.918125004,2943841.921875 759660.125,2943871.5 759590.838125005,2943933.72 759558.973749995,2943959.660625 759540.613749996,2943974.608125 759535.655625001,2943959.50749999 759527.753749996,2943951.026875 759525.305000007,2943949.405625 759523.410624996,2943948.36375 759521.448125005,2943947.456875 759519.427499995,2943946.689375 759517.358125001,2943946.064375 759515.25,2943945.58499999 759513.113749996,2943945.254375 759510.959374994,2943945.073125 759508.797499999,2943945.043125 759506.638750002,2943945.16374999 759504.494375005,2943945.434375 759502.373750001,2943945.854375 759500.287499994,2943946.42125 759498.245625004,2943947.13187499 759496.2587
 50007,2943947.983125 759494.335624993,2943948.971875 759464.056250006,2943963.99875 759434.753124997,2943978.50875001 759400.768124998,2943995.33750001 759396.900625005,2943997.2525 759379.100624993,2944006.066875 759355.559375003,2944017.72375 759318.490624994,2944036.079375 759291.569999993,2944049.41 759282.704999998,2944037.25937501 759268.017499998,2944044.22437499 759226.511250004,2944063.908125 759213.144374996,2944070.246875 759212.071875006,2944105.61750001 759210.331249997,2944163.03625 759208.532499999,2944222.356875 759146.776250005,2944249.9025 759113.801249996,2944264.610625 759109.21875,2944254.3725 759098.614999995,2944230.67874999 759067.718125001,2944244.29375 758971.176874995,2944286.83562499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>826400.762521094</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5244.94029271558</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember>
 <gml:featureMember><BrooklineWMS:Zoning fid=‘F1__138’><BrooklineWMS:OBJECTID>138</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 750725.299374998,2944253.108125 750584.079374999,2944264.18000001 750338.125,2944269.67874999 750249.124375001,2944260.111875 750205.258125007,2944251.11624999 750140.108750001,2944232.235 750047.103125006,2944199.5 749881.491874993,2944134.08437499 749720.363749996,2944058.296875 749606.151875004,2943996.71625 749356.088125005,2943845.043125 749258.426874995,2943796.06937499 749
 075.872500002,2943728.08499999 748972.388125002,2943689.546875 748811.586875007,2943632.14937501 748893.383750007,2943456.079375 748892.241874993,2943453.77562501 748891.139375001,2943451.4525 748890.078125,2943449.110625 748889.057500005,2943446.75 748888.078749999,2943444.3725 748887.141249999,2943441.97812501 748886.245625004,2943439.5675 748885.392499998,2943437.141875 748884.581249997,2943434.701875 748883.813749999,2943432.2475 748883.088750005,2943429.780625 748882.40625,2943427.30125 748881.768124998,2943424.810625 748881.172499999,2943422.30875 748880.621875003,2943419.796875 748880.113749996,2943417.27625 748879.650625005,2943414.746875 748879.231875002,2943412.20999999 748878.856875002,2943409.66625001 748878.526875004,2943407.11624999 748878.241249993,2943404.560625 748878,2943402.000625 748877.803124994,2943399.436875 748877.651875004,2943396.87 748877.545000002,2943394.300625 748877.483125001,2943391.73 748877.466250002,2943389.158125 748877.493750006,2943386.58750001 748877.566874996,2943384.016
 875 748877.684375003,2943381.448125 748877.846874997,2943378.88187499 748878.053749993,2943376.31874999 748878.305625007,2943373.76000001 748878.601875007,2943371.205625 748878.943124995,2943368.656875 748879.328125,2943366.114375 748879.758125007,2943363.579375 748880.231875002,2943361.051875 748880.75,2943358.533125 748881.311875001,2943356.02375001 748881.917500004,2943353.52500001 748882.566249996,2943351.03687499 748883.258750007,2943348.560625 748883.994375005,2943346.09625 748884.772499993,2943343.645625 748885.59375,2943341.20874999 748886.456874996,2943338.78687499 748887.362499997,2943336.38 748888.310000002,2943333.989375 748889.299374998,2943331.61562499 748890.329374999,2943329.26000001 748891.400625005,2943326.9225 748892.512500003,2943324.60375001 748893.664375007,2943322.30500001 748894.856875002,2943320.026875 748896.088125005,2943317.769375 748897.359375,2943315.534375 748898.669375002,2943313.32125001 748900.017499998,2943311.13187499 748901.403125003,2943308.965625 748902.827500001,2943306.
 824375 748904.288124993,2943304.70874999 748905.785624996,2943302.61812501 748907.319374993,2943300.55437499 748908.889375001,2943298.5175 748910.493750006,2943296.50875001 748912.133750007,2943294.5275 748913.808125004,2943292.57625 748915.515625,2943290.65375 748917.256874993,2943288.761875 748919.998750001,2943285.91187499 748979.481250003,2943317.12 749014.529375002,2943220.470625 749040.501874998,2943148.8475 749056.861249998,2943103.735625 749105.893749997,2943060.04125001 749199.626874998,2943123.651875 749215.649375007,2943062.89749999 749241.0625,2942966.53125 749209.080624998,2942732.92125 749228.106875002,2942635.07125001 749264.234375,2942743.64 749254.323125005,2942879.33125 749348.953749999,2942900.348125 749520.288124993,2942938.40062501 749522.834999993,2942936.77625 749726.319374993,2942961.24437501 749905.284374997,2942923.51375 749894.356875002,2942887.36687499 750119.905000001,2942815.19 750131.75,2942839.75 750142.795000002,2942859.720625 750390.659999996,2942723.831875 750462.791250005,29
 42694.31375 750513.121875003,2942680.26000001 750595.206874996,2942667.55 750664.661874995,2942668.295 750733.450625002,2942677.825 750800.480000004,2942695.986875 750874.165000007,2942725.88 750919.568749994,2942750.55374999 751090.288124993,2942869.83625001 751186.212500006,2942959.153125 751247.069999993,2942975.095 751410.513750002,2943017.910625 751447.020624995,2943027.47437499 751561.371250004,2943057.42937499 751638.033749998,2943095.854375 751686.045000002,2943119.918125 751839.59375,2943248.86687499 751805.381249994,2943280.859375 751839.508750007,2943339.49312501 751892.454374999,2943459.361875 751902.573750004,2943495.97812501 751903,2943501.05500001 751928.381249994,2943499.85312501 752001.395624995,2943488.708125 752056.451250002,2943446.33125 752163.114999995,2943579.11937501 752205.901875004,2943632.38625 752251.704999998,2943728.645625 752221.366874993,2943739.206875 752187.226875007,2943756.203125 751883.713125005,2943978.16500001 751809.15625,2943876.66437501 751750.819374993,2943873.2625 75
 1593.539375007,2943864.090625 751392.119375005,2943852.345 751174.668750003,2943839.66437501 751059.773750007,2943832.964375 751021.941874996,2943830.75812501 750889.484999999,2943823.034375 750764.201250002,2943815.72812501 750725.299374998,2944253.108125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>3262922.885225</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>9403.02555807784</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__139’><BrooklineWMS:OBJECTID>139</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>O-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>349</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>BUSINESS AND PROFESSIONAL OFFICE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>18</BrooklineWMS:CASE1><BrooklineWMS:CASE2>17</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>O-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DAT
 E_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 751083.429374993,2944209.864375 751017.091250002,2944217.26375 750846.046250001,2944243.64125 750725.299374998,2944253.108125 750764.201250002,2943815.72812501 750889.484999999,2943823.034375 751021.941874996,2943830.75812501 751059.773750007,2943832.964375 751174.668750003,2943839.66437501 751392.119375005,2943852.345 751593.539375007,2943864.090625 751750.819374993,2943873.2625 751809.15625,2943876.66437501 751883.713125005,2943978.16500001 751823.715000004,2944022.0425 751781.963750005,2944043.5 751742.075625002,2944056.83125 751615.583749995,2944082.64125 751569.829999998,2944102.58625001 751529.791875005,2944125.815 751390.006249994,2944194.79125001 751343.53125,2944199.563125 751303.301249996,2944203.69374999 751086.014375001,2944209.7775 751083.429374993,2944209.864375</gml:coordinates></gml:LinearRing></gml:
 outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>354519.508861523</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2824.33675452601</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__140’><BrooklineWMS:OBJECTID>140</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 751973.235624999,2944157.246875 751885.508125007,2944159.125 751884.530000001,2944084.8581
 25 751848.322500005,2944085.79062501 751823.715000004,2944022.0425 751883.713125005,2943978.16500001 752187.226875007,2943756.203125 752221.366874993,2943739.206875 752251.704999998,2943728.645625 752257.383750007,2943726.66875 752345.838125005,2943708.72499999 752369.200000003,2943707.97624999 752399.768124998,2943713.85625 752421.184375003,2943723.22 752446.466250002,2943741.485 752838.949375004,2944147.09999999 752750.383125007,2944144.07375 752390.555000007,2944148.31375 751973.235624999,2944157.246875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>281486.853298437</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2422.81736603364</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__141’><BrooklineWMS:OBJECTID>141</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><Brookli
 neWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757532.876874998,2943956.71312501 757139.483750001,2943995.2525 757159.218125001,2943867.82625 757164.586250007,2943816.06125 757262.611874998,2943804.104375 757423.959374994,2943777.39 757501.254999995,2943754.26625 757549.743750006,2943730.88187499 757594.881874993,2943701.548125 757635.943749994,2943666.73625 757677.563749999,2943620.331875 757701.261250004,2943585.36687499 757728.049374998,2943528.01000001 757743.498125002,2943466.620625 757747.204999998,2943424.54625 757742.726875007,2943361.40062501 757689.613124996,2943131.18062501 757715.463750005,2943124.081875 757768.6593749
 97,2943087.73125 757827.549999997,2943045.83374999 757904.307500005,2942993.753125 757925.585624993,2942979.5675 757949.523124993,2942962.7225 757981.440624997,2942944.104375 757954.843125001,2942900.66125 757927.256874993,2942850.35625 758020.375,2942798.25 758515.5,2943278.25 758530.313124999,2943263.62875 758501.423749998,2943316.57375 758263.668125004,2943455.6525 758254.369375005,2943427.83374999 758193.53125,2943320.073125 758139.322500005,2943355.208125 758086.701250002,2943389.31375 758033.629999995,2943423.71187501 758011.306875005,2943438.18000001 757978.924999997,2943467.9575 757946.144374996,2943498.10312501 757934.106250003,2943509.173125 757886.826250002,2943552.65125 757839.451250002,2943596.2175 757811.987499997,2943633.114375 757799.946875006,2943649.291875 757760.765625,2943701.93125001 757720.578749999,2943755.921875 757709.853750005,2943770.330625 757665.623750001,2943816.91125 757532.876874998,2943956.71312501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:poly
 gonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>450319.012640625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4340.75943930257</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__142’><BrooklineWMS:OBJECTID>142</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747230.569374993,2943865.13249999 747216.75,2943851.25 746849.375,2943484.5 746676.595624998,2943314.69312499 746695.063749999,294
 3244.26375 746928.377499998,2943304.0925 746934.558750004,2943284.145 746975.403125003,2943175.22624999 747008.586875007,2943114.72 747025.282499999,2943090.46250001 747040.034999996,2943072.91187499 747293.613124996,2943163.85625 747448.212500006,2943216.58687501 747451.771249995,2943217.81812499 747672.194999993,2943294.09625 747647.820625007,2943351.17874999 747635.599999994,2943363.3 747580.276875004,2943406.295 747505.536874995,2943458.370625 747465.146874994,2943499.67375 747230.569374993,2943865.13249999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>366838.16524375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2755.43993527508</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__143’><BrooklineWMS:OBJECTID>143</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><Brook
 lineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757720.578749999,2943755.921875 757760.765625,2943701.93125001 757799.946875006,2943649.291875 757811.987499997,2943633.114375 757839.451250002,2943596.2175 757886.826250002,2943552.65125 757934.106250003,2943509.173125 757946.144374996,2943498.10312501 757978.924999997,2943467.9575 758011.306875005,2943438.18000001 758033.629999995,2943423.71187501 758086.701250002,2943389.31375 758139.322500005,2943355.208125 758193.53125,2943320.073125 758254.369375005,2943427.83374999 758263.668125004,2943455.6525 758146.276875004,2943524.513125 758095.718125001,294
 3557.67874999 758000.609999999,2943631.07375 757962.325000003,2943666.593125 757892.890000001,2943744.549375 757862.019999996,2943786.671875 757837.953125,2943824.83437499 757813.209999993,2943810.845 757720.578749999,2943755.921875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>85884.5922960937</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1509.56684158226</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__144’><BrooklineWMS:OBJECTID>144</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>2</BrooklineWMS:CASE1><BrooklineWMS:CASE2>2</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </Brookl
 ineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 746676.595624998,2943314.69312499 746130.597499996,2942778.08875 746165.461875007,2942790.65000001 746175.987499997,2942800.9075 746491.655625001,2942903.09999999 746563.760000005,2942930.644375 746616.694999993,2942760.35625 746673.168125004,2942787.034375 746683.739374995,2942791.785 746707.887500003,2942802.545625 746740.980625004,2942817.29125001 746748.412499994,2942820.60250001 746793.661249995,2942840.765 746841.518749997,2942862.089375 746888.618125007,2942883.07625 746920.594999999,2942824.35312501 746946.924999997,2942798.1675 746982.024375007,2942738.18125001 747028.84375,2942670.91249999 747009.165000007,2942656.86125 747084.366874993,2942571.06999999 747092.185000002,2942562.14125 747028.528125003,2942506.825 746994.844999999,2942477.55500001 746973.348749995,2942491.995625 746964.611874998,2942495.28125 746878.537499994,2942476.004375 746900
 .540625006,2942405.965625 746927.856250003,2942319.01625 747013.160624996,2942308.315 747029.900625005,2942306.215 747058.262500003,2942379.3725 747079.96875,2942435.364375 747228.273124993,2942564.25749999 747284.871875003,2942548.22437499 747302.737499997,2942553.140625 747317.806875005,2942557.28687499 747315.338125005,2942599.940625 747296.609999999,2942696.14812499 747268.194999993,2942766.589375 747226.904375002,2942824.0325 747252.496875003,2942846.965 747319.233125001,2942898.598125 747311.584999993,2942915.205625 747254.741249993,2942986.91625001 747290.409374997,2943014.52562501 747325.223124996,2943041.473125 747333.558125004,2943031.00937501 747358.286249995,2943050.78125 747382.549374998,2943070.18187501 747464.291875005,2943116.40625 747503.920625001,2943133.769375 747451.771249995,2943217.81812499 747448.212500006,2943216.58687501 747293.613124996,2943163.85625 747040.034999996,2943072.91187499 747025.282499999,2943090.46250001 747008.586875007,2943114.72 746975.403125003,2943175.22624999 746934
 .558750004,2943284.145 746928.377499998,2943304.0925 746695.063749999,2943244.26375 746676.595624998,2943314.69312499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs><gml:innerBoundaryIs><gml:LinearRing><gml:coordinates> 747159.915000007,2942869.151875 747081.499375001,2942815.13249999 747059.845624998,2942800.215625 747108.170000002,2942734.91312499 747089.088125005,2942720.201875 747161.794375002,2942638.245625 747126.214375004,2942607.37625 747050.901875004,2942689.08625001 747082.533124998,2942715.14812499 747038.002499998,2942772.733125 747032.548124999,2942781.85187501 747003.051249996,2942830.499375 746995.714375004,2942845.580625 747038.512500003,2942871.666875 747085.386250004,2942898.160625 747145.083124995,2942938.405 747182.802499995,2942885.52500001 747159.915000007,2942869.151875</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>446687.598799219</BrooklineWMS:Shape.area><BrooklineWMS:S
 hape.len>5944.14330919118</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__145’><BrooklineWMS:OBJECTID>145</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747451.771249995,2943217.81812499 747503.920625001,2943133.769375 747464.291875005,2943116.40625 747382.549374998,2943070.18187501 747358.286249995,2943050.78125 747333.558125004,2943031.00937501 747325.223124996,2943041.473125 747290.409374997,2943014.52562501
 747254.741249993,2942986.91625001 747311.584999993,2942915.205625 747319.233125001,2942898.598125 747392.980625004,2942955.656875 747433.814999998,2942982.979375 747532.385000005,2943034.795 747779.004999995,2943163.00875001 747803.566874996,2943172.83499999 747765.055625007,2943231.856875 747734.286874995,2943287.63187499 747672.194999993,2943294.09625 747451.771249995,2943217.81812499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>78190.1360890625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1499.10815271247</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__146’><BrooklineWMS:OBJECTID>146</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE
 1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747532.385000005,2943034.795 747585.840000004,2942940.53812499 747649.003124997,2942854.676875 747653.872500002,2942842.68125001 747658.786249995,2942823.026875 747652.746250004,2942821.389375 747648.1875,2942820 747548.202500001,2942785.79062501 747582.481250003,2942690.98999999 747465.361249998,2942645.88062499 747474.869375005,2942548.18062501 747359.719999999,2942553.28125 747318.480000004,2942553.560625 747317.806875005,2942557.28687499 747302.737499997,2942553.140625 747284.871875003,2942548.22437499 747228.273124993,2942564.25749999 747079.96875,2942435.364375 747058.262500003,2942379.3725 747029.900625005,2942306.215 747013.160624996,2942308.315 746927.856250003,294231
 9.01625 746955.907499999,2942229.72750001 746978.229375005,2942158.67375 746998.983125001,2942088.9875 747012.306250006,2942044.24875 747026.680625007,2941995.983125 747059.841875002,2941884.63375001 747074.388125002,2941835.78937501 747090.715000004,2941780.966875 747140.483750001,2941595.591875 747252.221249998,2941578.92125 747262.528750002,2941710.106875 747273.364999995,2941848.01000001 747272.971874997,2941884.875 747265.073750004,2941963.371875 747260.480000004,2942000 747243.658749998,2942134.11499999 747244.958124995,2942197.045 747256.738124996,2942269.49875 747277.496875003,2942333.624375 747359.395624995,2942302.151875 747589.711250007,2942326.005 747645.648750007,2942625.58687501 747924.474374995,2942733.985625 747886.010625005,2942830.85187501 747876.576250002,2942854.613125 747867.965625003,2942884.94687501 747857.856875002,2942920.563125 747848.576250002,2942965.4425 747809.463750005,2943154.595625 747803.566874996,2943172.83499999 747779.004999995,2943163.00875001 747532.385000005,2943034.795<
 /gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>426585.346948438</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4693.15603962638</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__147’><BrooklineWMS:OBJECTID>147</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>0</BrooklineWMS:CASE1><BrooklineWMS:CASE2>0</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747319.233125001,2942898.598125 747252.496875003,2942846.965 747226.90437500
 2,2942824.0325 747268.194999993,2942766.589375 747296.609999999,2942696.14812499 747315.338125005,2942599.940625 747317.806875005,2942557.28687499 747318.480000004,2942553.560625 747359.719999999,2942553.28125 747474.869375005,2942548.18062501 747465.361249998,2942645.88062499 747582.481250003,2942690.98999999 747548.202500001,2942785.79062501 747648.1875,2942820 747652.746250004,2942821.389375 747658.786249995,2942823.026875 747653.872500002,2942842.68125001 747649.003124997,2942854.676875 747585.840000004,2942940.53812499 747532.385000005,2943034.795 747433.814999998,2942982.979375 747392.980625004,2942955.656875 747319.233125001,2942898.598125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>114662.417932813</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1509.53737772224</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__148’><BrooklineWM
 S:OBJECTID>148</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747886.010625005,2942830.85187501 747924.474374995,2942733.985625 747645.648750007,2942625.58687501 747589.711250007,2942326.005 747359.395624995,2942302.151875 747277.496875003,2942333.624375 747256.738124996,2942269.49875 747244.958124995,2942197.045 747243.658749998,2942134.11499999 747260.480000004,2942000 747265.073750004,2941963.371875 747272.971874997,2941884.875 747273.364999995,2941848.01000001 747262.528750002,2941710.106875 747414.40
 9374997,2941726.764375 747484.260000005,2941735.614375 747573.656874999,2941746.941875 747611.955624998,2941751.794375 747640.367500007,2941755.394375 747721.766874999,2941734.66374999 747935.986874998,2941680.10625 747961.420625001,2941673.62875 747995.844999999,2941664.861875 748001.497500002,2941686.285 748111.209999993,2941659.38249999 748251.071250007,2941622.904375 748273.178124994,2941656.291875 748351.360624999,2941759.496875 748383.939999998,2941797.125625 748415.705624998,2941835.823125 748437.980000004,2941871.66 748462.456249997,2941929.97125 748472.435000002,2941970.96875 748475.020624995,2942000 748496.051874995,2942236.176875 748493.453749999,2942302.94875 748480.670000002,2942399.136875 748458.599999994,2942561.57062501 748453.941249996,2942645.375 748457.173124999,2942708.29000001 748465.550624996,2942730.408125 748479.244375005,2942749.763125 748451.581249997,2942769.82187501 748391.579999998,2942834.081875 748349.923124999,2942872.956875 748191.755624995,2942994.030625 747886.010625005,29428
 30.85187501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1162258.582175</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4614.5212198693</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__149’><BrooklineWMS:OBJECTID>149</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747159.915000007,2942869.151875 747182.802499995,2942885.52500001
  747145.083124995,2942938.405 747085.386250004,2942898.160625 747038.512500003,2942871.666875 746995.714375004,2942845.580625 747003.051249996,2942830.499375 747032.548124999,2942781.85187501 747038.002499998,2942772.733125 747082.533124998,2942715.14812499 747050.901875004,2942689.08625001 747126.214375004,2942607.37625 747161.794375002,2942638.245625 747089.088125005,2942720.201875 747108.170000002,2942734.91312499 747059.845624998,2942800.215625 747081.499375001,2942815.13249999 747159.915000007,2942869.151875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>20363.707046875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>961.757773428171</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__150’><BrooklineWMS:OBJECTID>150</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><
 BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>5</BrooklineWMS:CASE1><BrooklineWMS:CASE2>5</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 746175.987499997,2942800.9075 746165.461875007,2942790.65000001 746130.597499996,2942778.08875 746126.4375,2942774 745948.833749995,2942709.03812499 746020.921875,2942484.76375 746040.873750001,2942490.21187501 746049.736874998,2942463.44125 746064.605000004,2942418.5325 746078.179374993,2942377.53125 746106.096249998,2942280.48125 746209.933125004,2942291.151875 746406.311875001,2942316.02625 746413.223124996,2942318.29062501 746389.874375001,2942397.36562499 746376.358750001,2942437.14749999 746363.496250004,2942475.00562499 746350.206874996,2942514.12 746444.999375001,2942
 545.30312499 746458.160624996,2942507.83750001 746466.822500005,2942483.18062501 746514.344374999,2942499.58812501 746561.479375005,2942515.8625 746526.257499993,2942617.675625 746650.295000002,2942653.34999999 746616.694999993,2942760.35625 746563.760000005,2942930.644375 746491.655625001,2942903.09999999 746175.987499997,2942800.9075</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>263450.229225</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2440.04222716063</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__151’><BrooklineWMS:OBJECTID>151</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</Brookl
 ineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 746616.694999993,2942760.35625 746650.295000002,2942653.34999999 746526.257499993,2942617.675625 746561.479375005,2942515.8625 746514.344374999,2942499.58812501 746466.822500005,2942483.18062501 746458.160624996,2942507.83750001 746444.999375001,2942545.30312499 746350.206874996,2942514.12 746363.496250004,2942475.00562499 746376.358750001,2942437.14749999 746389.874375001,2942397.36562499 746413.223124996,2942318.29062501 746435.421875,2942325.564375 746565.971249998,2942388.454375 746588.723124996,2942393.719375 746654.296250001,2942398.488125 746686.953749999,2942404.893125 746784.844999999,2942466.246875 746860.205624998,2942529.89749999 746878.537499994,2942476.004375 746964.611874998,2942495.28125 746973.348749995,2942491.995625 746994.844999999,29
 42477.55500001 747028.528125003,2942506.825 747092.185000002,2942562.14125 747084.366874993,2942571.06999999 747009.165000007,2942656.86125 747028.84375,2942670.91249999 746982.024375007,2942738.18125001 746946.924999997,2942798.1675 746920.594999999,2942824.35312501 746888.618125007,2942883.07625 746841.518749997,2942862.089375 746793.661249995,2942840.765 746748.412499994,2942820.60250001 746740.980625004,2942817.29125001 746707.887500003,2942802.545625 746683.739374995,2942791.785 746673.168125004,2942787.034375 746616.694999993,2942760.35625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>188880.276910938</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2338.56565885165</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__152’><BrooklineWMS:OBJECTID>152</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>O-2.0(CH)</BrooklineWMS:ZTYPEOLD><Brooklin
 eWMS:SYMBOL>349</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>BUSINESS AND PROFESSIONAL OFFICE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>19</BrooklineWMS:CASE1><BrooklineWMS:CASE2>18</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>O-2.0(CH)</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 746106.096249998,2942280.48125 746078.179374993,2942377.53125 746064.605000004,2942418.5325 746049.736874998,2942463.44125 746040.873750001,2942490.21187501 746020.921875,2942484.76375 745948.833749995,2942709.03812499 745603.5625,2942582.75 745633.9375,2942499 745279.875,2942369 745393.75,2942056.75 745393.290000007,2942056.3 745393.636250004,2942055.673125 745407.438124999,2942030.691875 745507.523750007,2942000 745515.400000006,2942041.666875 745526.753124997,2942087.190625 745539.583749995,2942114.11499999 745557
 .279375002,2942138.125 745595.770624995,2942169.36562499 745622.906874999,2942181.74375001 745711.980000004,2942211.796875 745866.768749997,2942253.35312501 745909.601249993,2942260.28874999 746106.096249998,2942280.48125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>279245.676067188</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2500.36662066761</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__153’><BrooklineWMS:OBJECTID>153</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-15</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>22</BrooklineWMS:CASE1><BrooklineWMS:CASE2>21</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-15</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><
 BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 746878.537499994,2942476.004375 746860.205624998,2942529.89749999 746784.844999999,2942466.246875 746686.953749999,2942404.893125 746654.296250001,2942398.488125 746588.723124996,2942393.719375 746565.971249998,2942388.454375 746435.421875,2942325.564375 746413.223124996,2942318.29062501 746406.311875001,2942316.02625 746209.933125004,2942291.151875 746106.096249998,2942280.48125 745909.601249993,2942260.28874999 745866.768749997,2942253.35312501 745711.980000004,2942211.796875 745622.906874999,2942181.74375001 745595.770624995,2942169.36562499 745557.279375002,2942138.125 745539.583749995,2942114.11499999 745526.753124997,2942087.190625 745515.400000006,2942041.666875 745507.523750007,2942000 745481.873125002,2941864.3 745470.368750006,2941838.00624999 745402.411249995,2941723.58812501 745377.183125004,2941669.85312501 745360.153750002,2941617.958125 745309.041875005,
 2941425.25 745296.801249996,2941398.10312501 745278.135000005,2941374.90000001 745252.556250006,2941356.35312501 745083.316874996,2941233.644375 744942.717500001,2941140.6725 744922,2941126.973125 744852.161874995,2941095.2 744813.629999995,2941080.56 744853.989999995,2940959.076875 744854.586250007,2940954.558125 744886.356875002,2940874.57625 744966.921875,2940705.448125 745004.541875005,2940639.611875 745065.940624997,2940542.81 745045.0625,2940529 744983.873750001,2940480.39875001 744929.331874996,2940437.076875 744873.258750007,2940392.53937501 744817.987499997,2940348.638125 744776.776250005,2940315.905 744768.842500001,2940310.51875 744763.412499994,2940307.00125 744754.893124998,2940301.748125 744749.3125,2940298.47499999 744743.674999997,2940295.300625 744737.983125001,2940292.22499999 744732.238749996,2940289.24875 744726.443124995,2940286.37375 744720.598124996,2940283.59999999 744714.705624998,2940280.92874999 744708.767499998,2940278.360625 744702.784999996,2940275.89687499 744696.760625005,294027
 3.53749999 744687.033749998,2940269.980625 744680.908124998,2940267.89749999 744674.747500002,2940265.92125 744668.553749993,2940264.05249999 744662.328125,2940262.2925 744656.072500005,2940260.641875 744649.789375007,2940259.09999999 744643.480000004,2940257.668125 744637.146874994,2940256.346875 744630.791250005,2940255.13625 744624.415625006,2940254.03687499 744618.021874994,2940253.04875 744609.045625001,2940251.85312501 744602.616249993,2940251.13375001 744596.174999997,2940250.526875 744589.724374995,2940250.031875 744583.266249999,2940249.64937501 744576.801874995,2940249.38 744570.334374994,2940249.22375 744563.864374995,2940249.18062501 744557.395624995,2940249.249375 744550.928124994,2940249.43187501 744544.465000004,2940249.72687501 744538.008750007,2940250.13500001 744531.560000002,2940250.655625 744512.616874993,2940252.843125 744442.478125006,2940262.761875 744379.624375001,2940271.65000001 744312.448750004,2940281.14937501 744238.912499994,2940291.54875 744168.873125002,2940301.453125 744063.926
 249996,2940316.29375 743951.512500003,2940332.190625 743885.221874997,2940341.565 743791.601875007,2940354.80437499 743665.842500001,2940368.505 743105.5,2939826 743004.4375,2939728.25 744557.094999999,2938204.88187499 744644.3125,2938313.5 744679.4375,2938352.75 744781.590625003,2938485.91249999 744813.899375007,2938528.02875 744877.358125001,2938608.034375 744939.126249999,2938685.90875 744981.584999993,2938739.438125 745044.909999996,2938819.27562501 745168.625,2938975.25 745212.625,2939026.75 745507.754999995,2939402.971875 745507.317499995,2939335.450625 745521.054374993,2939281.3175 745522.213125005,2939213.7175 745510.391874999,2939164.62 745500.036874995,2939117.885625 745493.224374995,2939065.32375 745471.266874999,2938994.5425 745475.625,2938952.5 745443.3125,2938854.5 745441.470624998,2938817.2975 745520.667500004,2938731.21125001 745699.545625001,2938750.93000001 745908.341250002,2938773.94625001 746356.113124996,2938823.30625001 746361.774375007,2938781.673125 746464.551249996,2938640.333125 74649
 1.925624996,2938614.360625 746514.511250004,2938592.93187501 746538.211875007,2938570.44562501 746572.568749994,2938537.84875 746608.981250003,2938503.30125 746632.440624997,2938481.04375 746655.959374994,2938458.729375 746677.558125004,2938438.2375 746701.999375001,2938415.0475 746753.600624993,2938366.09 746642.248125002,2938263.479375 746612.404375002,2938211.96187501 746571.359999999,2938141.108125 746679.050624996,2937969.34125 746731.186875001,2937906.03625 746755.245000005,2937870.44625001 746701.359375,2937833.985 746661.203749999,2937808.56812499 746597.683125004,2937767.13 746557.958749995,2937745.485625 746251.116249993,2937588.85124999 746042.415625006,2937485.861875 745681.835624993,2937309.673125 745578.367500007,2937288.1525 745537.819999993,2937268.36812501 745508.426249996,2937266.14812499 746492.375,2936153.25 746869,2935922 747130.867500007,2935665.08687501 747243.252499998,2935774.645 747405.047499999,2935939.860625 747486.25,2936028.75 747523.875,2936060.75 747696.647499993,2936244.111875
 747873.754374996,2936419.155 747895.493125007,2936435.581875 747937.068124995,2936439.658125 747948.816874996,2936448.09875 747997.692499995,2936530.30562501 748031.3125,2936563.25 748048.156874999,2936579.736875 748063.589375004,2936595.05 748222.885000005,2936749.52249999 748267.848749995,2936793.245 748180.310625002,2936871.331875 748159.924374998,2936873.44687501 748148.715000004,2936870.59375 748138.321250007,2936866.31375 748127.112499997,2936865.7025 748113.864374995,2936874.04875 748066.28125,2936989.43000001 748042.057500005,2937048.1675 748041.071250007,2937050.55875 748006.484999999,2937088.82625 747987.272499993,2937110.083125 747947.521249995,2937154.065 747930.738749996,2937172.63375001 747855.053749993,2937256.37375 747838.045000002,2937275.1925 747781.614999995,2937337.628125 747740.756249994,2937382.83562499 747712.439374998,2937414.16625001 747709.189999998,2937417.20874999 747697.703125,2937427.96312501 747651.3125,2937471.39687499 747597.952500001,2937521.35625 747558.080624998,2937558.6868
 75 747515.880624995,2937598.19687501 747446.599374995,2937587.83374999 747425.020624995,2937588.174375 747423.186250001,2937642.996875 747425.631874993,2937671.52875 747430.523124993,2937695.985 747410.077500001,2937695.08 747332.066874996,2937690.70999999 747322.959999993,2937760.389375 747317.224374995,2937804.27562501 747321.935625002,2937845.985 747326.105000004,2937875.028125 747335.258125007,2937938.784375 747420.338125005,2937938.505 747436.667500004,2938012.10875 747446.322500005,2938055.62625 747476.788749993,2938236.200625 747500.025625005,2938228.581875 747570.092500001,2938203.24250001 747717.125624999,2938132.004375 747805.773750007,2938082.48999999 747837.872500002,2938060.81874999 747950.724374995,2937972.488125 748023.146874994,2937910.75624999 748260.602500007,2937669.955 748292.952500001,2937641.46312501 748327.044375002,2937615.08 748399.898750007,2937569.058125 748477.993750006,2937532.629375 748518.615624994,2937518.2025 748734.346874997,2937450.343125 749016.913749993,2937355.581875 74919
 3.176874995,2937288.575625 749287.891874999,2937249.486875 749405.158124998,2937201.3775 749480.328125,2937160.785625 749555.499375001,2937115.683125 749627.663124993,2937064.566875 749770.487499997,2936962.33499999 749857.500624999,2936890.031875 749918.178749993,2936902.25562499 749922.936875001,2936916.53 749939.511875004,2936968.059375 749967.480000004,2937028.97375 749990.853750005,2937068.223125 750080.618125007,2937182.5125 750164.194374993,2937104.50812501 750209.051874995,2937062.465625 750264.208749995,2937010.77 750274.355000004,2937001.260625 750293.276875004,2936983.52562501 750324.988124996,2936949.04875 750350.694999993,2936921.09937499 750418.935000002,2936846.906875 750487.709999993,2936772.13249999 750546.380624995,2936708.34375 750559.848124996,2936693.701875 750552.361874998,2936684.87875 750575.553749993,2936632.935625 750631.666250005,2936632.026875 750658.855625004,2936636.456875 750679.773124993,2936624.33 750718.696875006,2936591.21250001 750702.486874998,2936557.91125 750729.782499999
 ,2936567.26375 750776.751249999,2936583.3575 750858.365624994,2936606.33812501 750961.648750007,2936635.42 751022.848124996,2936652.653125 751094.658124998,2936672.8725 751119.061250001,2936679.74375001 751161.586875007,2936691.718125 751282.254374996,2936725.69562501 751295.655625001,2936729.46875 751342.480625004,2936742.65375 751345.120625004,2936829.5025 751462.663124993,2936661.09875 751555.294375002,2936619.35625 751592.737499997,2936590.729375 751576.878124997,2936612.39125 751569.058125004,2936632.19 751566.461875007,2936653.31812499 751569.253749996,2936674.420625 751706.436250001,2937030.355 751733.898750007,2937092.901875 751771.569999993,2937156.64812499 751659.783124998,2937212.216875 751630.377499998,2937237.3275 751565.226249993,2937210.278125 751514.795000002,2937193.655 751478.546250001,2937244.075 751444.054374993,2937289.93000001 751327.144999996,2937445.35375001 751327.180625007,2937480.09875 751275.208124995,2937555.42749999 751201.458749995,2937602.61562499 751170.233125001,2937639.633750
 01 751150.901250005,2937716.2 751085.475624993,2937780.121875 750953.681250006,2937649.253125 750927.073125005,2937675.44312499 750954.027500004,2937702.35875 750698.104375005,2937983.82625 750180.128749996,2938179.901875 750070.723124996,2938231.81 750033.848124996,2938397.669375 749925.430625007,2938432.72 749879.163124993,2938485.62375 749867.526250005,2938539.455625 749849.090000004,2938588.66249999 749823.766249999,2938659.354375 749737.731875002,2938775.87375 749763.935000002,2938853.276875 749515.165000007,2939222.105 749047.404375002,2939266.10312501 748957.641874999,2939301.59875 748899.706874996,2939361.49187499 748835.214375004,2939409.83 748705.398124993,2939557.356875 748687.807500005,2939573.68187501 748476.5,2939769.78812499 748293.139375001,2939857.2625 748191.133125007,2939959.83750001 747962.586250007,2939743.061875 747943.406874999,2939767.55500001 747915.310000002,2939733.26375 747894.853125006,2939659.19125 747931.748125002,2939631.651875 747935.594374999,2939610.996875 747967.871250004,29
 39558.24187499 747973.811250001,2939466.111875 747980.356250003,2939430.8575 747961.903750002,2939406.15062501 747964.015000001,2939363.080625 747684.430000007,2939521.940625 747504.528750002,2939563.04000001 747396.697500005,2939619.72437499 747144.614374995,2939688.30249999 747205.899375007,2939875.955625 747213.516249999,2939899.761875 747219.526875004,2939918.55 747236.718125001,2939990.481875 747252.538124993,2940104.081875 747270.250624999,2940312.23999999 747297.153750002,2940642.089375 747292.829374999,2940712.65000001 747273.296250001,2940809.71187501 747256.611874998,2940892.74312501 747287.010000005,2940895.17937499 747329.521874994,2940915.828125 747377.234999999,2941004.72562499 747407.453749999,2941048.111875 747449.519374996,2941089.923125 747508.551874995,2941126.70874999 747556.511250004,2941150.291875 747625.871875003,2941176.77312499 747732.713125005,2941209.753125 747986.298749998,2941260.215625 748029.061875001,2941268.84 748063.188124999,2941283.230625 748083.055625007,2941297.08374999 74
 8135.575625002,2941348.581875 748156.581249997,2941384.76625 748220.178749993,2941564.02312499 748243.746875003,2941611.841875 748251.071250007,2941622.904375 748111.209999993,2941659.38249999 748001.497500002,2941686.285 747995.844999999,2941664.861875 747961.420625001,2941673.62875 747935.986874998,2941680.10625 747721.766874999,2941734.66374999 747640.367500007,2941755.394375 747611.955624998,2941751.794375 747573.656874999,2941746.941875 747484.260000005,2941735.614375 747414.409374997,2941726.764375 747262.528750002,2941710.106875 747252.221249998,2941578.92125 747140.483750001,2941595.591875 747090.715000004,2941780.966875 747074.388125002,2941835.78937501 747059.841875002,2941884.63375001 747026.680625007,2941995.983125 747012.306250006,2942044.24875 746998.983125001,2942088.9875 746978.229375005,2942158.67375 746955.907499999,2942229.72750001 746927.856250003,2942319.01625 746900.540625006,2942405.965625 746878.537499994,2942476.004375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs><gml:innerB
 oundaryIs><gml:LinearRing><gml:coordinates> 743964.456874996,2939192.408125 744803.713125005,2940055.80500001 745289.193124995,2939582.206875 744820.249375001,2939058.0325 744657.209374994,2939176.236875 744303.411874995,2938822.439375 743964.456874996,2939192.408125</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>20462452.7611375</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>40917.4148472076</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__154’><BrooklineWMS:OBJECTID>154</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED
 > </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 745393.636250004,2942055.673125 745393.290000007,2942056.3 745019.458749995,2941690.46625 745132.083749995,2941647.801875 745139.664375007,2941644.93187501 745197.628749996,2941622.984375 745188.833124995,2941599.048125 745183.284374997,2941583.948125 745174.015000001,2941558.721875 745171.090625003,2941550.764375 745159.395624995,2941518.938125 745147.294375002,2941486.00562499 745127.517499998,2941457.0775 745122.836875007,2941453.186875 745252.556250006,2941356.35312501 745278.135000005,2941374.90000001 745296.801249996,2941398.10312501 745309.041875005,2941425.25 745360.153750002,2941617.958125 745377.183125004,2941669.85312501 745402.411249995,2941723.58812501 745470.368750006,2941838.00624999 745481.873125002,2941864.3 745507.523750007,2942000 745407.438124999,2942030.691875 745393.63625000
 4,2942055.673125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>149162.796072266</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1900.84148617742</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__155’><BrooklineWMS:OBJECTID>155</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 744717.628124997,2941395.09125 744720.509375006,2941390.3
 725 744734.266874999,2941367.83750001 744755.585624993,2941344.61937501 744781.222499996,2941316.72875001 744805.643124998,2941290.16125 744821.189999998,2941273.2475 744857.522499993,2941233.72125 744863.051249996,2941227.70625 744942.717500001,2941140.6725 745083.316874996,2941233.644375 745252.556250006,2941356.35312501 745122.836875007,2941453.186875 745127.517499998,2941457.0775 745147.294375002,2941486.00562499 745159.395624995,2941518.938125 745171.090625003,2941550.764375 745174.015000001,2941558.721875 745183.284374997,2941583.948125 745188.833124995,2941599.048125 745197.628749996,2941622.984375 745139.664375007,2941644.93187501 745132.083749995,2941647.801875 745019.458749995,2941690.46625 744717.628124997,2941395.09125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>158368.2013125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1679.61790404945</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></
 gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__156’><BrooklineWMS:OBJECTID>156</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 744717.628124997,2941395.09125 744423.75,2941107.5 744313.203125,2940999.66 744318.957499996,2940998.153125 744430.584999993,2940968.92625 744520.408124998,2940948.03749999 744520.709374994,2940940.75624999 744590.752499998,2940940.796875 744599.375624999,2940940.801875 744641.856875002,2940933.844375 744662.40625,2940933.36499999 744
 694.571875006,2940932.85625 744745.432500005,2940932.05125 744745.921875,2940918.78625 744853.989999995,2940959.076875 744813.629999995,2941080.56 744852.161874995,2941095.2 744922,2941126.973125 744942.717500001,2941140.6725 744863.051249996,2941227.70625 744857.522499993,2941233.72125 744821.189999998,2941273.2475 744805.643124998,2941290.16125 744781.222499996,2941316.72875001 744755.585624993,2941344.61937501 744734.266874999,2941367.83750001 744720.509375006,2941390.3725 744717.628124997,2941395.09125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>152522.764121875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1751.41662934527</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__157’><BrooklineWMS:OBJECTID>157</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><Brooklin
 eWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 744318.957499996,2940998.153125 744313.203125,2940999.66 743714.125,2940415.25 743665.842500001,2940368.505 743791.601875007,2940354.80437499 743885.221874997,2940341.565 743951.512500003,2940332.190625 744063.926249996,2940316.29375 744168.873125002,2940301.453125 744238.912499994,2940291.54875 744312.448750004,2940281.14937501 744379.624375001,2940271.65000001 744442.478125006,2940262.761875 744512.616874993,2940252.843125 744531.560000002,2940250.655625 744538.008750007,2940250.13500001 744544.465000004,2940249.72687501 744550.928124994,2940249.43187501 744557.395624995,2940249.24937
 5 744563.864374995,2940249.18062501 744570.334374994,2940249.22375 744576.801874995,2940249.38 744583.266249999,2940249.64937501 744589.724374995,2940250.031875 744596.174999997,2940250.526875 744602.616249993,2940251.13375001 744609.045625001,2940251.85312501 744618.021874994,2940253.04875 744624.415625006,2940254.03687499 744630.791250005,2940255.13625 744637.146874994,2940256.346875 744643.480000004,2940257.668125 744649.789375007,2940259.09999999 744656.072500005,2940260.641875 744662.328125,2940262.2925 744668.553749993,2940264.05249999 744674.747500002,2940265.92125 744680.908124998,2940267.89749999 744687.033749998,2940269.980625 744696.760625005,2940273.53749999 744702.784999996,2940275.89687499 744708.767499998,2940278.360625 744714.705624998,2940280.92874999 744720.598124996,2940283.59999999 744726.443124995,2940286.37375 744732.238749996,2940289.24875 744737.983125001,2940292.22499999 744743.674999997,2940295.300625 744749.3125,2940298.47499999 744754.893124998,2940301.748125 744763.412499994,294030
 7.00125 744768.842500001,2940310.51875 744776.776250005,2940315.905 744817.987499997,2940348.638125 744873.258750007,2940392.53937501 744929.331874996,2940437.076875 744983.873750001,2940480.39875001 745045.0625,2940529 745065.940624997,2940542.81 745004.541875005,2940639.611875 744966.921875,2940705.448125 744886.356875002,2940874.57625 744854.586250007,2940954.558125 744853.989999995,2940959.076875 744745.921875,2940918.78625 744745.432500005,2940932.05125 744694.571875006,2940932.85625 744662.40625,2940933.36499999 744641.856875002,2940933.844375 744599.375624999,2940940.801875 744590.752499998,2940940.796875 744520.709374994,2940940.75624999 744520.408124998,2940948.03749999 744430.584999993,2940968.92625 744318.957499996,2940998.153125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>652408.822357813</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3447.68510178281</BrooklineWMS:Shape.len></BrooklineW
 MS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__158’><BrooklineWMS:OBJECTID>158</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753295.690624997,2940855.24250001 753286.666875005,2940807.84625 753256.078125,2940688.83812501 753198.413124993,2940519.58875 753113.317499995,2940437.44 753042.052499995,2940369.42 752966.991874993,2940297.7775 752905.049374998,2940238.655 752833.211250007,2940170.08812501 752816.189999998,2940157.644375 752857.183125004,2940106.40062501 752887.212
 500006,2940051.666875 752907.186250001,2940013.78375 752926.791875005,2939963.40625 752954.073125005,2939862.21187501 752963.056875005,2939888.708125 752998.870000005,2939986.870625 753013.738749996,2939977.55875 753032.974374995,2939962.651875 753130.096874997,2939869.47499999 753147.308125004,2939852.96250001 753182.224374995,2939838.62875 753193.468125001,2939867.1275 753209.422499999,2939907.564375 753236.974999994,2939977.39812499 753261.436250001,2940039.39624999 753250.189999998,2940043.32875 753278.441249996,2940122.03937501 753301.888125002,2940187.36687499 753316.721249998,2940182.5425 753318.628124997,2940196.11 753320.825625002,2940195.42375 753363.744375005,2940323.13249999 753411.995000005,2940466.708125 753448.491249993,2940575.30562501 753455.822500005,2940597.341875 753462.893124998,2940619.46312501 753465.667500004,2940628.39812499 753475.466250002,2940661.24062499 753484.690624997,2940694.249375 753493.337500006,2940727.41374999 753501.404375002,2940760.72437499 753513.260625005,2940815.0956
 25 753318.635625005,2940852.75624999 753295.690624997,2940855.24250001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>292212.163955469</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2859.78509751978</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__159’><BrooklineWMS:OBJECTID>159</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>25</BrooklineWMS:CASE1><BrooklineWMS:CASE2>24</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753601.40
 3125003,2940088.07375 753599.773124993,2940104.7375 753476.008750007,2940143.81937499 753460.273124993,2940148.78874999 753457.457499996,2940149.80625001 753438.871875003,2940156.52375001 753397.4375,2940171.5 753320.825625002,2940195.42375 753318.628124997,2940196.11 753316.721249998,2940182.5425 753301.888125002,2940187.36687499 753278.441249996,2940122.03937501 753250.189999998,2940043.32875 753261.436250001,2940039.39624999 753236.974999994,2939977.39812499 753209.422499999,2939907.564375 753193.468125001,2939867.1275 753182.224374995,2939838.62875 753147.308125004,2939852.96250001 753130.096874997,2939869.47499999 753032.974374995,2939962.651875 753013.738749996,2939977.55875 752998.870000005,2939986.870625 752963.056875005,2939888.708125 752954.073125005,2939862.21187501 752932.126249999,2939797.4825 752841.390000001,2939529.53625 752838.863749996,2939522.078125 752876.994375005,2939512.14375 752945.208749995,2939488.90125 753003.540000007,2939439.80500001 753017.458749995,2939427.75875001 752989.3106250
 02,2939395.311875 753006.190624997,2939381.405625 753075.858125001,2939320.98625 753068.123125002,2939312.23375 753049.151250005,2939290.7675 753032.181250006,2939271.56625 753010.162499994,2939246.6525 753028.087500006,2939230.8275 753046.103750005,2939214.923125 753082.801874995,2939182.52625 753114.221249998,2939155.0475 753150.359999999,2939123.41500001 753192.817499995,2939086.25125 753224.500624999,2939126.44 753255.952500001,2939166.33437499 753284.569999993,2939202.63500001 753315.836875007,2939242.295625 753348.008125007,2939283.10250001 753412.575000003,2939365.001875 753438.516249999,2939397.9075 753474.756874993,2939438.051875 753525.686875001,2939494.469375 753572.785624996,2939546.641875 753497.817499995,2939611.098125 753527.706874996,2939645.27625 753529.609375,2939647.453125 753554.484375,2939686.703125 753556.921875,2939690.953125 753558.859375,2939693.703125 753560.859375,2939696.453125 753563.109375,2939698.953125 753565.421875,2939701.203125 753568.689999998,2939703.99062499 753633.3774999
 98,2939838.64 753630.170625001,2939892.2775 753613.725624993,2939969.88124999 753613.663749993,2940022.3 753607.560000002,2940025.10312501 753602.272499993,2940079.17937499 753601.403125003,2940088.07375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>489992.865632227</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3375.85472403293</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__160’><BrooklineWMS:OBJECTID>160</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape
 ><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753601.403125003,2940088.07375 753602.272499993,2940079.17937499 753607.560000002,2940025.10312501 753613.663749993,2940022.3 753613.725624993,2939969.88124999 753630.170625001,2939892.2775 753633.377499998,2939838.64 753568.689999998,2939703.99062499 753565.421875,2939701.203125 753563.109375,2939698.953125 753560.859375,2939696.453125 753558.859375,2939693.703125 753556.921875,2939690.953125 753554.484375,2939686.703125 753529.609375,2939647.453125 753527.706874996,2939645.27625 753497.817499995,2939611.098125 753572.785624996,2939546.641875 753525.686875001,2939494.469375 753474.756874993,2939438.051875 753438.516249999,2939397.9075 753412.575000003,2939365.001875 753348.008125007,2939283.10250001 753315.836875007,2939242.295625 753284.569999993,2939202.63500001 753255.952500001,2939166.33437499 753224.500624999,2939126.44 753192.817499995,2939086.25125 753230.915625006,2939052.90375
  753262.865624994,2939024.9375 753301.833124995,2938990.82875 753338.443749994,2938958.7825 753414.828749999,2938891.9225 753453.198125005,2938858.33687501 753635.020624995,2938695.22750001 753694.117500007,2938644.393125 753711.717500001,2938628.44750001 753714.050624996,2938632.891875 753744.681875005,2938698.505 753771.088750005,2938765.93000001 753794.756874993,2938840.52 753815.723124996,2938926.971875 753843.504374996,2939081.105625 753863.178124994,2939158.41187499 753893.661249995,2939238.823125 753951.065624997,2939355.44499999 753994.888125002,2939425.328125 754000,2939434.640625 754052.103125006,2939529.55562501 754100.094999999,2939614.96375 754206.045000002,2939833.18375 754218.203125,2939852.858125 754202.140000001,2939865.471875 754072.313749999,2939984.625 753902.511250004,2939804.24625 753852.268749997,2939851.605 753800.060625002,2939900.81625 753742.573750004,2939955.004375 753601.403125003,2940088.07375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMembe
 r></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>630197.93035625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4102.91267834099</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__161’><BrooklineWMS:OBJECTID>161</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>I-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>477</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>INDUSTRIAL SERVICES</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>7</BrooklineWMS:CASE1><BrooklineWMS:CASE2>7</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>I-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 743964.456874996,2939192.408125 744303.411874995,2938822.439375 744657.209374994,2939176.236875 744820.249375001,2939058.0325 745289.193124995,2939582.206875 744
 803.713125005,2940055.80500001 743964.456874996,2939192.408125</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>749898.422175</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3789.1174464566</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__162’><BrooklineWMS:OBJECTID>162</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>I-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>477</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>INDUSTRIAL SERVICES</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>7</BrooklineWMS:CASE1><BrooklineWMS:CASE2>7</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>I-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747213.516249
 999,2939899.761875 747205.899375007,2939875.955625 747144.614374995,2939688.30249999 747396.697500005,2939619.72437499 747504.528750002,2939563.04000001 747684.430000007,2939521.940625 747964.015000001,2939363.080625 747961.903750002,2939406.15062501 747980.356250003,2939430.8575 747973.811250001,2939466.111875 747967.871250004,2939558.24187499 747935.594374999,2939610.996875 747931.748125002,2939631.651875 747894.853125006,2939659.19125 747915.310000002,2939733.26375 747943.406874999,2939767.55500001 747814.255624995,2939932.48625 747599.335624993,2939723.7675 747213.516249999,2939899.761875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>214515.760265625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2496.91614965089</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__163’><BrooklineWMS:OBJECTID>163</BrooklineWMS:OBJECTID><BrooklineWMS:ZTY
 PEOLD>S-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>21</BrooklineWMS:CASE1><BrooklineWMS:CASE2>20</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 744557.094999999,2938204.88187499 745472.75,2937306.5 745508.426249996,2937266.14812499 745537.819999993,2937268.36812501 745578.367500007,2937288.1525 745681.835624993,2937309.673125 746042.415625006,2937485.861875 746251.116249993,2937588.85124999 746557.958749995,2937745.485625 746597.683125004,2937767.13 746661.203749999,2937808.56812499 746701.359375,2937833.985 746755.245000005,2937870.44625001 746731.186875001,2937906.03625 746679.050624996,2937969.34125 746571.359999999,2938141.108125 74661
 2.404375002,2938211.96187501 746642.248125002,2938263.479375 746753.600624993,2938366.09 746701.999375001,2938415.0475 746677.558125004,2938438.2375 746655.959374994,2938458.729375 746632.440624997,2938481.04375 746608.981250003,2938503.30125 746572.568749994,2938537.84875 746538.211875007,2938570.44562501 746514.511250004,2938592.93187501 746491.925624996,2938614.360625 746464.551249996,2938640.333125 746361.774375007,2938781.673125 746356.113124996,2938823.30625001 745908.341250002,2938773.94625001 745699.545625001,2938750.93000001 745520.667500004,2938731.21125001 745441.470624998,2938817.2975 745443.3125,2938854.5 745475.625,2938952.5 745471.266874999,2938994.5425 745493.224374995,2939065.32375 745500.036874995,2939117.885625 745510.391874999,2939164.62 745522.213125005,2939213.7175 745521.054374993,2939281.3175 745507.317499995,2939335.450625 745507.754999995,2939402.971875 745212.625,2939026.75 745168.625,2938975.25 745044.909999996,2938819.27562501 744981.584999993,2938739.438125 744939.126249999,293868
 5.90875 744877.358125001,2938608.034375 744813.899375007,2938528.02875 744781.590625003,2938485.91249999 744679.4375,2938352.75 744644.3125,2938313.5 744557.094999999,2938204.88187499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>2410137.8564</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7051.1641459394</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__164’><BrooklineWMS:OBJECTID>164</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>Merged L-10 to adjacent T-5</Brookline
 WMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 752942.165000007,2938609.635625 753025.954374999,2938624.0625 753076.111249998,2938632.69875 753094.179374993,2938635.80875 753128.281874999,2938641.68062501 753174.984999999,2938649.721875 753219.235624999,2938657.340625 753268.548749998,2938665.83125 753237.818749994,2938768.44562501 753236.189999998,2938772.2825 753230.091875002,2938788.291875 753319.132499993,2938807.19750001 753345.487499997,2938814.44437499 753414.828749999,2938891.9225 753338.443749994,2938958.7825 753301.833124995,2938990.82875 753262.865624994,2939024.9375 753230.915625006,2939052.90375 753192.817499995,2939086.25125 753150.359999999,2939123.41500001 753114.221249998,2939155.0475 753082.801874995,2939182.52625 753046.103750005,2939214.923125 753028.087500006,2939230.8275 753010.162499994,2939246.6525 753032.181250006,2939271.56625 753049.151250005,2939290.7675 753068.123125002,29393
 12.23375 753075.858125001,2939320.98625 753006.190624997,2939381.405625 752989.310625002,2939395.311875 753017.458749995,2939427.75875001 753003.540000007,2939439.80500001 752945.208749995,2939488.90125 752876.994375005,2939512.14375 752838.863749996,2939522.078125 752763.841875002,2939300.53749999 752747.348124996,2939238.7775 752738.804374993,2939175.42625 752738.457499996,2939124.08125 752738.370625004,2939111.25812501 752741.161874995,2939079.64937501 752752.811875001,2939016.795625 752778.121875003,2938941.58562499 752864.479375005,2938713.279375 752899.678124994,2938612.8075 752903.236874998,2938601.3175 752942.165000007,2938609.635625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>337088.988979492</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2685.7542616055</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__165’><BrooklineWMS:OBJE
 CTID>165</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-15</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>22</BrooklineWMS:CASE1><BrooklineWMS:CASE2>21</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-15</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753414.828749999,2938891.9225 753345.487499997,2938814.44437499 753319.132499993,2938807.19750001 753230.091875002,2938788.291875 753236.189999998,2938772.2825 753237.818749994,2938768.44562501 753268.548749998,2938665.83125 753219.235624999,2938657.340625 753174.984999999,2938649.721875 753128.281874999,2938641.68062501 753094.179374993,2938635.80875 753076.111249998,2938632.69875 753025.954374999,2938624.0625 752942.165000007,2938609.635625 752903.
 236874998,2938601.3175 752956.258125007,2938430.155 752995.416250005,2938296.31999999 753016.007499993,2938300.543125 753346.168750003,2938366.64875001 753453.017499998,2938396.36375 753521.056875005,2938424.376875 753557.990624994,2938443.36937501 753584.926249996,2938461.32062501 753619.576250002,2938490.35312501 753648.613124996,2938519.85875 753671.588750005,2938552.015 753711.717500001,2938628.44750001 753694.117500007,2938644.393125 753635.020624995,2938695.22750001 753453.198125005,2938858.33687501 753414.828749999,2938891.9225</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>258925.342960938</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2265.90162115634</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__166’><BrooklineWMS:OBJECTID>166</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-25</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757<
 /BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>23</BrooklineWMS:CASE1><BrooklineWMS:CASE2>22</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-25</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 753346.168750003,2938366.64875001 753016.007499993,2938300.543125 752995.416250005,2938296.31999999 753001.602500007,2938258.049375 753134.709374994,2938078.26000001 753228.180625007,2937952.00749999 753304.341875002,2937849.135625 753361.666250005,2937771.7075 753536.433125004,2937535.64812499 753618.698750004,2937754.88625 753712.278125003,2938004.27375001 753717.536249995,2938018.28687499 753752.855000004,2938005.01000001 753827.537499994,2937976.935 753946.714375004,2937932.13375001 754071.789375007,2937882.4525 754291.53125,2937794.63249999 754406.225
 624993,2937748.794375 754536.433125004,2937696.75687499 754634.676249996,2937997.5975 754643.186875001,2938021.44499999 754471.868125007,2938065.901875 754366.659999996,2938097 754000,2938230.953125 753961.763750002,2938244.921875 753715.448750004,2938326.36 753614.176874995,2938353.391875 753537.201875001,2938374.018125 753498.480000004,2938378.956875 753418.961250007,2938376.27625 753346.168750003,2938366.64875001</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>629791.540107813</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4386.16080014777</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__167’><BrooklineWMS:OBJECTID>167</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-10</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>21</BrooklineWMS:CAS
 E1><BrooklineWMS:CASE2>20</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-10</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 747476.788749993,2938236.200625 747446.322500005,2938055.62625 747436.667500004,2938012.10875 747420.338125005,2937938.505 747335.258125007,2937938.784375 747326.105000004,2937875.028125 747321.935625002,2937845.985 747317.224374995,2937804.27562501 747322.959999993,2937760.389375 747332.066874996,2937690.70999999 747410.077500001,2937695.08 747430.523124993,2937695.985 747425.631874993,2937671.52875 747423.186250001,2937642.996875 747425.020624995,2937588.174375 747446.599374995,2937587.83374999 747515.880624995,2937598.19687501 747558.080624998,2937558.686875 747597.952500001,2937521.35625 747651.3125,2937471.39687499 747697.703125,2937427.96312501 747709.189999998,2937417
 .20874999 747712.439374998,2937414.16625001 747740.756249994,2937382.83562499 747781.614999995,2937337.628125 747838.045000002,2937275.1925 747855.053749993,2937256.37375 747930.738749996,2937172.63375001 747947.521249995,2937154.065 747987.272499993,2937110.083125 748006.484999999,2937088.82625 748041.071250007,2937050.55875 748042.057500005,2937048.1675 748066.28125,2936989.43000001 748113.864374995,2936874.04875 748127.112499997,2936865.7025 748138.321250007,2936866.31375 748148.715000004,2936870.59375 748159.924374998,2936873.44687501 748180.310625002,2936871.331875 748267.848749995,2936793.245 748222.885000005,2936749.52249999 748063.589375004,2936595.05 748048.156874999,2936579.736875 748031.3125,2936563.25 747997.692499995,2936530.30562501 747948.816874996,2936448.09875 747937.068124995,2936439.658125 747895.493125007,2936435.581875 747873.754374996,2936419.155 747696.647499993,2936244.111875 747523.875,2936060.75 747486.25,2936028.75 747405.047499999,2935939.860625 747243.252499998,2935774.645 747130.8
 67500007,2935665.08687501 748055.421250001,2934758.02500001 748242.3125,2934934.5 748305.75,2935002 748433.3125,2935126.75 748454.625,2935145.25 748457.75,2935148.25 748460.9375,2935150.75 748464.25,2935153.5 748467.625,2935155.75 748471.0625,2935158.25 748474.625,2935160.25 748478.1875,2935162.5 748481.875,2935164.5 748765.883125007,2935438.216875 748848.043125004,2935517.39937501 748968.161874995,2935631.746875 749044.680625007,2935703.22687501 749154.563749999,2935804.24875 749223.724999994,2935872.68000001 749288.539375007,2935936.810625 749302.326250002,2935949.51875 749321.891249999,2935929.95375 749334.216250002,2935945.433125 749446.637500003,2936050.73875 749465.591250002,2936068.49375001 749586.982500002,2936192.004375 749660.351249993,2936266.94374999 749750.334374994,2936353.16125 749739.093125001,2936380.46187501 749821.997500002,2936459.61499999 749861.029375002,2936498.6825 749938.629999995,2936570.36375 749921.950000003,2936618.60875 749912.793750003,2936658.15062501 749904.219999999,2936719.37
 8125 749902.608125001,2936753.49187499 749904.077500001,2936779.984375 749950.691874996,2936798.36562499 749992.036874995,2936753.916875 750050.901250005,2936670.969375 750123.591875002,2936550.078125 750167.290625006,2936463.94875 750205.439999998,2936375.223125 750237.885000005,2936284.25624999 750280.093125001,2936142.68125001 750313.405000001,2936030.94437499 750331.291875005,2935985.51875 750369.606875002,2935908.70125 750377.894999996,2935867.66374999 750379.131874993,2935845.87 750367.465625003,2935791.66 750357.676249996,2935749.17812499 750358.526875004,2935727.301875 750364.336250007,2935703.73999999 750380.406874999,2935673.76000001 750400.484999999,2935652.436875 750426.448125005,2935635.78812499 750451.023750007,2935627.25687499 750471.090000004,2935624.25125 750496.417500004,2935625.345625 750525.308750004,2935621.08625001 750592.401250005,2935586.34999999 750630.351249993,2935536.218125 750710.517499998,2935430.32125001 750816.576875001,2935288.01375 750868.040000007,2935226.485625 751027.106250
 003,2935039.999375 751195.257499993,2935200.394375 751261.223124996,2935128.621875 751317.621250004,2935067.25937501 751373.795000002,2935006.140625 751381.946875006,2934997.27124999 751428.880624995,2934947.310625 751468.727500007,2934904.894375 751561.456874996,2934983.55249999 751715.438124999,2935114.168125 751761.005624995,2935152.82125001 751881.713125005,2935017.19499999 751922.627499998,2934971.22375 751936.026875004,2934956.168125 751996.665000007,2935007.313125 752047.984375,2935050.59875 752086.178749993,2935082.813125 752124.251874998,2935114.925625 752183.819999993,2935165.168125 752335.867500007,2935293.41187499 752457.753124997,2935105.799375 752480.873125002,2935073.01625 752503.893749997,2935105.450625 752538.308750004,2935153.94125 752585.876874998,2935220.96250001 752635.828749999,2935291.343125 752667.835624993,2935336.439375 752679.245625004,2935352.63500001 752714.810625002,2935403.11562499 752719.165625006,2935410.66875 752747.143749997,2935459.19437499 752754.282499999,2935474.32250001
 752792.563124999,2935555.44125 752828.200625002,2935630.95999999 752804.979375005,2935646.48875 752898.109375,2935731.298125 752445.219374999,2936024.41312499 751592.737499997,2936590.729375 751555.294375002,2936619.35625 751462.663124993,2936661.09875 751345.120625004,2936829.5025 751342.480625004,2936742.65375 751295.655625001,2936729.46875 751282.254374996,2936725.69562501 751161.586875007,2936691.718125 751119.061250001,2936679.74375001 751094.658124998,2936672.8725 751022.848124996,2936652.653125 750961.648750007,2936635.42 750858.365624994,2936606.33812501 750776.751249999,2936583.3575 750729.782499999,2936567.26375 750702.486874998,2936557.91125 750718.696875006,2936591.21250001 750679.773124993,2936624.33 750658.855625004,2936636.456875 750631.666250005,2936632.026875 750575.553749993,2936632.935625 750552.361874998,2936684.87875 750559.848124996,2936693.701875 750546.380624995,2936708.34375 750487.709999993,2936772.13249999 750418.935000002,2936846.906875 750350.694999993,2936921.09937499 750324.98812
 4996,2936949.04875 750293.276875004,2936983.52562501 750274.355000004,2937001.260625 750264.208749995,2937010.77 750209.051874995,2937062.465625 750164.194374993,2937104.50812501 750080.618125007,2937182.5125 749990.853750005,2937068.223125 749967.480000004,2937028.97375 749939.511875004,2936968.059375 749922.936875001,2936916.53 749918.178749993,2936902.25562499 749857.500624999,2936890.031875 749770.487499997,2936962.33499999 749627.663124993,2937064.566875 749555.499375001,2937115.683125 749480.328125,2937160.785625 749405.158124998,2937201.3775 749287.891874999,2937249.486875 749193.176874995,2937288.575625 749016.913749993,2937355.581875 748734.346874997,2937450.343125 748518.615624994,2937518.2025 748477.993750006,2937532.629375 748399.898750007,2937569.058125 748327.044375002,2937615.08 748292.952500001,2937641.46312501 748260.602500007,2937669.955 748023.146874994,2937910.75624999 747950.724374995,2937972.488125 747837.872500002,2938060.81874999 747805.773750007,2938082.48999999 747717.125624999,293813
 2.004375 747570.092500001,2938203.24250001 747500.025625005,2938228.581875 747476.788749993,2938236.200625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>7748840.16108438</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>19743.6419083294</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__168’><BrooklineWMS:OBJECTID>168</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-6</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>30</BrooklineWMS:CASE1><BrooklineWMS:CASE2>28</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-6</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygo
 n><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 750954.027500004,2937702.35875 750927.073125005,2937675.44312499 750953.681250006,2937649.253125 751085.475624993,2937780.121875 751150.901250005,2937716.2 751170.233125001,2937639.63375001 751201.458749995,2937602.61562499 751275.208124995,2937555.42749999 751327.180625007,2937480.09875 751327.144999996,2937445.35375001 751444.054374993,2937289.93000001 751478.546250001,2937244.075 751514.795000002,2937193.655 751565.226249993,2937210.278125 751630.377499998,2937237.3275 751659.783124998,2937212.216875 751771.569999993,2937156.64812499 751772.905000001,2937158.906875 751825.234375,2937223.870625 751860.305000007,2937259.845 751983.805000007,2937367.97 752011.870000005,2937396.46375 752037.136250004,2937427.3175 751966.911249995,2937482.685625 751992.401875004,2937555.7625 751837.246250004,2937710.488125 751826.616249993,2937745.6275 751807.434375003,2937765.00875001 751647.294375002,2937926.810625 751633.393124998,2937940.85625 751396.760625005,2938081.
 985625 751157.536249995,2937904.093125 750954.027500004,2937702.35875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>492963.14853125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3232.77986901608</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__169’><BrooklineWMS:OBJECTID>169</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>S-7</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>757</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>16</BrooklineWMS:CASE1><BrooklineWMS:CASE2>16</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>S-7</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 749938.6299
 99995,2936570.36375 749861.029375002,2936498.6825 749821.997500002,2936459.61499999 749739.093125001,2936380.46187501 749750.334374994,2936353.16125 749660.351249993,2936266.94374999 749586.982500002,2936192.004375 749465.591250002,2936068.49375001 749446.637500003,2936050.73875 749334.216250002,2935945.433125 749321.891249999,2935929.95375 749302.326250002,2935949.51875 749288.539375007,2935936.810625 749223.724999994,2935872.68000001 749154.563749999,2935804.24875 749044.680625007,2935703.22687501 748968.161874995,2935631.746875 748848.043125004,2935517.39937501 748765.883125007,2935438.216875 748893.824375004,2935316.36812501 748985.543750003,2935231.199375 749103.469374999,2935126.3775 749159.155625001,2935103.44750001 749319.665000007,2934998.625625 749391.730000004,2934939.66312499 749490.001249999,2934844.668125 749600.802499995,2934760.81812499 749599.381249994,2934759.20125 749449.228125006,2934572.738125 749525.214375004,2934508.909375 749600.555625007,2934404.08687501 749659.518124998,2934295.989375
  749711.928749993,2934155.13437501 749751.237499997,2933965.144375 749820.027500004,2933732.56999999 749906.833124995,2933323.108125 749936.314374998,2933097.08562499 749944.503749996,2932972.609375 749951.055000007,2932943.128125 749910.788749993,2932937.75875001 750288.1875,2932567.5 750571.5625,2932771 750613.5,2932800.5 750623.0625,2932807.25 750661.9375,2932834.75 750668.75,2932839.75 750761.0625,2932901.5 751699.3125,2933554.25 753511.824375004,2935329.65062501 753440.219999999,2935377.488125 753414.861874998,2935395.99187499 753371.383125007,2935427.71875 752989.209999993,2935672.33687501 752898.109375,2935731.298125 752804.979375005,2935646.48875 752828.200625002,2935630.95999999 752792.563124999,2935555.44125 752754.282499999,2935474.32250001 752747.143749997,2935459.19437499 752719.165625006,2935410.66875 752714.810625002,2935403.11562499 752679.245625004,2935352.63500001 752667.835624993,2935336.439375 752635.828749999,2935291.343125 752585.876874998,2935220.96250001 752538.308750004,2935153.94125 7
 52503.893749997,2935105.450625 752480.873125002,2935073.01625 752457.753124997,2935105.799375 752335.867500007,2935293.41187499 752183.819999993,2935165.168125 752124.251874998,2935114.925625 752086.178749993,2935082.813125 752047.984375,2935050.59875 751996.665000007,2935007.313125 751936.026875004,2934956.168125 751922.627499998,2934971.22375 751881.713125005,2935017.19499999 751761.005624995,2935152.82125001 751715.438124999,2935114.168125 751561.456874996,2934983.55249999 751468.727500007,2934904.894375 751428.880624995,2934947.310625 751381.946875006,2934997.27124999 751373.795000002,2935006.140625 751317.621250004,2935067.25937501 751261.223124996,2935128.621875 751195.257499993,2935200.394375 751027.106250003,2935039.999375 750868.040000007,2935226.485625 750816.576875001,2935288.01375 750710.517499998,2935430.32125001 750630.351249993,2935536.218125 750592.401250005,2935586.34999999 750525.308750004,2935621.08625001 750496.417500004,2935625.345625 750471.090000004,2935624.25125 750451.023750007,2935627
 .25687499 750413.868125007,2935620.325 750383.223749995,2935609 750352.580624998,2935581.591875 750303.188749999,2935521.731875 750246.166875005,2935465.720625 750241.363124996,2935497.16875 750236.773750007,2935527.20874999 750208.299999997,2935584.44625001 750155.305000007,2935942.44625001 750131.951875001,2936059.77 750124.918750003,2936089.38625 750280.093125001,2936142.68125001 750237.885000005,2936284.25624999 750205.439999998,2936375.223125 750167.290625006,2936463.94875 750123.591875002,2936550.078125 750050.901250005,2936670.969375 749992.036874995,2936753.916875 749950.691874996,2936798.36562499 749904.077500001,2936779.984375 749902.608125001,2936753.49187499 749904.219999999,2936719.378125 749912.793750003,2936658.15062501 749921.950000003,2936618.60875 749938.629999995,2936570.36375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>7429853.93529531</BrooklineWMS:Shape.area><BrooklineWMS:Shape.l
 en>16106.9380985161</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__170’><BrooklineWMS:OBJECTID>170</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-0.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>8</BrooklineWMS:CASE1><BrooklineWMS:CASE2>8</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-0.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 750124.918750003,2936089.38625 750131.951875001,2936059.77 750155.305000007,2935942.44625001 750208.299999997,2935584.44625001 750236.773750007,2935527.20874999 750241.363124996,2935497.16875 750246.166875005,2935465.720625 750303.188749999,2935521.731875 750352.580624998,2935581.591875 750383.22
 3749995,2935609 750413.868125007,2935620.325 750451.023750007,2935627.25687499 750426.448125005,2935635.78812499 750400.484999999,2935652.436875 750380.406874999,2935673.76000001 750364.336250007,2935703.73999999 750358.526875004,2935727.301875 750357.676249996,2935749.17812499 750367.465625003,2935791.66 750379.131874993,2935845.87 750377.894999996,2935867.66374999 750369.606875002,2935908.70125 750331.291875005,2935985.51875 750313.405000001,2936030.94437499 750280.093125001,2936142.68125001 750124.918750003,2936089.38625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>108902.663288281</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1651.60545798803</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__171’><BrooklineWMS:OBJECTID>171</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-0.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</Brookline
 WMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>10</BrooklineWMS:CASE1><BrooklineWMS:CASE2>10</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-0.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 748765.883125007,2935438.216875 748481.875,2935164.5 748478.1875,2935162.5 748474.625,2935160.25 748471.0625,2935158.25 748467.625,2935155.75 748464.25,2935153.5 748460.9375,2935150.75 748457.75,2935148.25 748454.625,2935145.25 748433.3125,2935126.75 748305.75,2935002 748242.3125,2934934.5 748055.421250001,2934758.02500001 749910.788749993,2932937.75875001 749951.055000007,2932943.128125 749944.503749996,2932972.609375 749936.314374998,2933097.08562499 749906.833124995,2933323.108125 749820.027500004,2933732.56999999 749751.237499997,2933965.144375 749711.9287499
 93,2934155.13437501 749659.518124998,2934295.989375 749600.555625007,2934404.08687501 749525.214375004,2934508.909375 749449.228125006,2934572.738125 749599.381249994,2934759.20125 749600.802499995,2934760.81812499 749490.001249999,2934844.668125 749391.730000004,2934939.66312499 749319.665000007,2934998.625625 749159.155625001,2935103.44750001 749103.469374999,2935126.3775 748985.543750003,2935231.199375 748893.824375004,2935316.36812501 748765.883125007,2935438.216875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1934674.04931406</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>6685.64922212073</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__172’><BrooklineWMS:OBJECTID>172</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</Brookli
 neWMS:ZONEDESC><BrooklineWMS:CASE1>9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756597.945625007,2952313.659375 756342.488124996,2952187.50749999 756365.871875003,2952136.326875 756265.566249996,2952059.51375 756337.191249996,2951965.5975 756295.383125007,2951934.21062499 756363.09375,2951843.6725 756334.878124997,2951826.06937499 756392.271874994,2951740.485 756383.803124994,2951735.608125 756379.703749999,2951732.57875 756431.349999994,2951646.379375 756495.743125007,2951533.06 756558.382499993,2951469.86875001 756543.635625005,2951453.901875 756627.626249999,2951380.17874999 756640.038749993,2951394.05125 756699.745000005,2951300.43125001 756729.393749997,2951273.39125 756723.791250005,2951266.798
 75 756770.873750001,2951222.33750001 756731.534999996,2951180.44312499 756807.508125007,2951107.314375 756783.161874995,2951081.38124999 756768.211250007,2951065.456875 756862.913124993,2950998.3175 756839.371250004,2950966.316875 756960.994375005,2950885.2325 756961.015000001,2950885.21875 757026.505624995,2950839.93062501 757094.273124993,2950793.06937499 757100.840625003,2950788.528125 757142.690624997,2950850.12625 757202.005624995,2950938.87 757125.110624999,2950987.13625 757175.044375002,2951054.0275 757085.066249996,2951119.938125 757102.843125001,2951142.230625 757023.266874999,2951207.81812499 757006.336875007,2951188.13062499 756936.791250005,2951262.245 756983.060000002,2951319.2225 756992.703749999,2951331.11875001 756910.389375001,2951389.325 756921.066249996,2951404.61875001 756831.787499994,2951465.39937501 756863.427499995,2951512.12125 756772.856250003,2951558.93062501 756785.048124999,2951578.41625001 756798.615624994,2951604.985 756710.984375,2951644.13500001 756733.060000002,2951700.25375 7
 56751.637500003,2951747.481875 756665.901875004,2951937.846875 756590.603125006,2952108.51625 756577.418125004,2952138.40125 756580.257499993,2952162.645 756586.088750005,2952212.42812499 756592.008750007,2952262.97375 756597.945625007,2952313.659375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>428324.564645312</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>4356.06756366773</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__173’><BrooklineWMS:OBJECTID>173</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>29</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:
 DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756128.380624995,2952098.864375 756032.683125004,2952223.359375 755941.8125,2952164.75 755856.8125,2952109 755826.625,2952089.5 755741.3125,2952033.25 755657.75,2951978.5 755629.125,2951960 755482.8125,2951864.25 755364,2951786.25 755340.5,2951771 755274,2951733 754916.867500007,2951430.730625 754950.469999999,2951411.03125 754996.254999995,2951389.61875001 755002.060000002,2951386.90375 755052.378124997,2951363.371875 755100.794375002,2951340.72875001 755147.496875003,2951323.730625 755155.771874994,2951320.74250001 755194.511875004,2951306.7525 755209.766874999,2951301.24375001 755241.349999994,2951289.83812501 755265.126249999,2951281.251875 755287.012500003,2951273.348125 755318.019374996,2951262.15062501 755337.454374999,2951255.13249999 755354,2951249.1575 755378.206249997,2951240.395 755385.314999998,29512
 37.82187501 755434.549999997,2951219.999375 755483.334999993,2951202.339375 755492.659999996,2951198.96375 755506.086250007,2951194.10375001 755545.476875007,2951179.968125 755549.789375007,2951178.420625 755596.483125001,2951161.66437501 755606.370625004,2951158.11624999 755656.971874997,2951139.958125 755661.659999996,2951138.27562501 755677.381249994,2951132.63437501 755711.866874993,2951120.47125 755720.139375001,2951117.55374999 755767.760000005,2951100.75875001 755773.598749995,2951098.699375 755829.981875002,2951078.813125 755834.974374995,2951076.97437499 755886.282499999,2951058.07375 755942.766874999,2951037.266875 755997.760625005,2951017.00875001 756041.748125002,2951000.80500001 756051.653750002,2950997.15625 756089.558125004,2950962.99625 756101.143749997,2950975.54000001 756163.890000001,2950916.690625 756176.691249996,2950901.596875 756218.361249998,2950947.35187501 756232.405625001,2950933.683125 756296.903750002,2950874.58562499 756280.540000007,2950857.28749999 756313.625,2950826.4875 756318
 .405000001,2950831.02375001 756347.732500002,2950802.904375 756375.314999998,2950772.0775 756416.019999996,2950734.55374999 756401.528750002,2950718.861875 756423.717500001,2950698.51000001 756463.150625005,2950740.513125 756468.249375001,2950745.94374999 756488.573750004,2950767.59375 756514.568124995,2950795.281875 756537.314999998,2950819.511875 756542.884375006,2950825.44312499 756575.358125001,2950860.03375 756581.223124996,2950866.28125 756619.882499993,2950907.46062499 756658.069374993,2950948.13625 756677.574375004,2950968.91249999 756677.666875005,2950969.01125 756702.079999998,2950995.015 756723.143124998,2951017.45125 756749.746250004,2951045.78749999 756768.211250007,2951065.456875 756783.161874995,2951081.38124999 756807.508125007,2951107.314375 756731.534999996,2951180.44312499 756770.873750001,2951222.33750001 756723.791250005,2951266.79875 756729.393749997,2951273.39125 756699.745000005,2951300.43125001 756640.038749993,2951394.05125 756627.626249999,2951380.17874999 756543.635625005,2951453.90
 1875 756558.382499993,2951469.86875001 756495.743125007,2951533.06 756431.349999994,2951646.379375 756379.703749999,2951732.57875 756383.803124994,2951735.608125 756392.271874994,2951740.485 756334.878124997,2951826.06937499 756363.09375,2951843.6725 756295.383125007,2951934.21062499 756337.191249996,2951965.5975 756265.566249996,2952059.51375 756244.247500002,2952087.55 756197.533124998,2952150.4975 756128.380624995,2952098.864375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1346892.96672969</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>5406.30094577133</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__174’><BrooklineWMS:OBJECTID>174</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:Z
 ONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED>10/03/07</BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>PK/OK Planning4/12/07Amendmant</BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756768.211250007,2951065.456875 756749.746250004,2951045.78749999 756723.143124998,2951017.45125 756702.079999998,2950995.015 756677.666875005,2950969.01125 756677.574375004,2950968.91249999 756787.234999999,2950892.6675 756735.420000002,2950819.47375 756858.079999998,2950734.864375 756961.015000001,2950885.21875 756960.994375005,2950885.2325 756839.371250004,2950966.316875 756862.913124993,2950998.3175 756768.211250007,2951065.456875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>42981.
 447290625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>988.900768675522</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__175’><BrooklineWMS:OBJECTID>175</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>13</BrooklineWMS:CASE1><BrooklineWMS:CASE2>13</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756677.574375004,2950968.91249999 756658.069374993,2950948.13625 756619.882499993,2950907.46062499 756581.223124996,2950866.28125 756575.358125001,2950860.03375 756542.884375006,2950825.44312499 756537.314999998,2950819.511875 756514.56
 8124995,2950795.281875 756488.573750004,2950767.59375 756468.249375001,2950745.94374999 756463.150625005,2950740.513125 756508.860624999,2950708.371875 756507.314999998,2950706.1125 756485.341250002,2950673.9975 756463.729375005,2950642.41187499 756444.828125,2950614.78687499 756430.045000002,2950595.74124999 756529.369375005,2950525.85312501 756735.420000002,2950819.47375 756787.234999999,2950892.6675 756677.574375004,2950968.91249999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>64876.8980285156</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1210.05617003696</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__176’><BrooklineWMS:OBJECTID>176</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:
 ZONEDESC><BrooklineWMS:CASE1>29</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757383.737499997,2952384.18062501 757369.678124994,2952343.125 757330.749375001,2952248.401875 757217.943124995,2952293.708125 757231.745000005,2952331.136875 757233.979375005,2952337.19437499 757238.299374998,2952348.91 757268.991249993,2952428.90625 757176.423749998,2952464.986875 757185.726875007,2952480.831875 757134.957499996,2952498.99312501 757096.053124994,2952508.02312499 757114.098124996,2952560.6925 757125.535624996,2952594.075625 757137.073750004,2952627.750625 757148.831874996,2952662.06937499 757169.978125006,2952719.176875 757134.709999993,2952700.28625 756989.934375003,2952645.833125 756932.771874994,2952779.211
 25001 756919.875,2952775.75 756900.875,2952770.75 756870.0625,2952762.75 756845.3125,2952757.5 756825.5625,2952753.5 756808.1875,2952750.5 756791.0625,2952747.25 756768.0625,2952744.25 756761.65625,2952743.41312499 756742.543750003,2952606.16875 756736.444999993,2952561.69625001 756730.045000002,2952515.0275 756723.736874998,2952469.029375 756717.594999999,2952424.24437501 756711.241249993,2952377.91249999 756705.058750004,2952332.83 756702.830624998,2952316.581875 756648.828125,2952324.49875 756642.048749998,2952302.203125 756598.246250004,2952316.22437499 756597.945625007,2952313.659375 756592.008750007,2952262.97375 756586.088750005,2952212.42812499 756580.257499993,2952162.645 756577.418125004,2952138.40125 756590.603125006,2952108.51625 756665.901875004,2951937.846875 756751.637500003,2951747.481875 756733.060000002,2951700.25375 756710.984375,2951644.13500001 756798.615624994,2951604.985 756785.048124999,2951578.41625001 756772.856250003,2951558.93062501 756863.427499995,2951512.12125 756831.787499994,29
 51465.39937501 756921.066249996,2951404.61875001 756910.389375001,2951389.325 756992.703749999,2951331.11875001 756983.060000002,2951319.2225 756936.791250005,2951262.245 757006.336875007,2951188.13062499 757023.266874999,2951207.81812499 757102.843125001,2951142.230625 757085.066249996,2951119.938125 757175.044375002,2951054.0275 757221.806875005,2951116.669375 757307.736249998,2951051.4325 757340.647499993,2951094.206875 757345.550624996,2951100.579375 757428.980000004,2951037.52124999 757536.443749994,2950945.48 757630.351249993,2950871.0125 757525.903125003,2950733.010625 757672.573125005,2950632.339375 757777.279375002,2950557.02187499 757821.885000005,2950524.93625 757831.147499993,2950517.919375 757932.230000004,2950627.91500001 758044.022499993,2950747.745625 758057.018124998,2950801.09 758073.278125003,2950867.83 758083.727500007,2950910.72 758100.086875007,2950977.86875001 758118.407499999,2951053.064375 758154.651250005,2951201.829375 758164.191874996,2951240.989375 758180.775625005,2951309.06 75819
 5.199375004,2951305.593125 758263.974374995,2951288.71375 758285.545625001,2951283.419375 758309.746250004,2951277.479375 758386.083749995,2951258.74437501 758411.537499994,2951251.63249999 758404.197500005,2951222.608125 758630.465000004,2951237.41875 758647.885625005,2951241.955 758663.058750004,2951251.78 758674.581874996,2951266.13437501 758688.083749995,2951320.26000001 758759.012500003,2951298.020625 758802.041250005,2951283.2775 758812.452500001,2951298.32062501 758845.303749993,2951277.53375 758868.309375003,2951312.204375 758891.235624999,2951346.75624999 758894.073125005,2951351.0325 758905.456874996,2951368.19 758904.845624998,2951388.520625 758904.468125001,2951401.06 758903.633750007,2951428.785625 758902.912499994,2951452.765 758902.483125001,2951467.049375 758901.413124993,2951502.60375001 758901.284999996,2951506.871875 758900.203749999,2951542.814375 758899.980000004,2951550.25375 758899.091875002,2951579.7625 758898.566874996,2951597.22 758897.958124995,2951617.46125001 758896.835624993,29516
 54.75624999 758896.700000003,2951659.25624999 758894.901250005,2951719.059375 758894.578749999,2951729.783125 758892.992500007,2951769.6275 758890.871875003,2951822.91437501 758889.239999995,2951902.77500001 758775.200000003,2951907.76875 758743.310625002,2951902.958125 758562.666250005,2951849.205625 758498.969374999,2951597.344375 758284.65625,2951652.046875 758297.016874999,2951699.739375 758308.808750004,2951745.234375 758317.672499999,2951779.434375 758319.973749995,2951788.311875 758332.575625002,2951836.935625 758342.323125005,2951874.54375 758350.243750006,2951905.10312501 758357.998125002,2951935.02375001 758360.571875006,2951944.95375 758367.976875007,2951973.52187499 758376.563124999,2952006.651875 758593.763125002,2951974.955625 758601.046250001,2952004.406875 758605.358125001,2952033.52249999 758604.480625004,2952058.765625 758602.374375001,2952088.94875 758597.461250007,2952139.136875 758682.128749996,2952149.02562501 758737.769374996,2952155.093125 758799.939374998,2952161.8725 758857.340625003,
 2952168.13187499 758839.974374995,2952232.940625 758818.546250001,2952312.906875 758817.028750002,2952318.608125 758814.290000007,2952328.89875001 758803.646874994,2952368.890625 758799.515000001,2952384.41500001 758785.101249993,2952438.573125 758783.878124997,2952443.16875 758768.960624993,2952499.220625 758547.448125005,2952467.466875 758518.266249999,2952675.395625 758714.100624993,2952705.81874999 758706.836875007,2952733.21250001 758698.155625001,2952765.9575 758690.895624995,2952797.01875 758684.901250005,2952822.66625001 758676.777500004,2952857.42375 758674.502499998,2952867.1575 758664.642499998,2952909.341875 758659.004999995,2952933.46250001 758650.093125001,2952971.5925 758648.875,2952976.80562501 758479.258125007,2952967.063125 758481.991249993,2952933.51000001 758301.613124996,2952949.316875 758314.444999993,2953029.31 758323.683750004,2953088.84999999 758327.678124994,2953114.59125 758332.006249994,2953142.488125 758340.148750007,2953194.96312501 758349.238749996,2953253.545 758313.116874993,29
 53259.39937501 758285.864374995,2953263.81625 758258.075000003,2953268.31999999 758213.796875,2953275.608125 758192.947500005,2953279.995 758085.617500007,2953296.423125 758087.421250001,2953310.48999999 757784.625,2953358.5 757781.875,2953359 757778.5,2953359 757775,2953358.5 757770.5625,2953357.5 757766,2953355.5 757761.25,2953350.75 757758.1875,2953347.75 757755.0625,2953344.75 757749.625,2953339.5 757649.5,2953245.25 757629.189374998,2953228.675 757639.251249999,2953204.28812499 757648.431250006,2953157.33812501 757650.014375001,2953120.393125 757613.748125002,2952847.3775 757555.248750001,2952857.390625 757550.906874999,2952858.035 757541.331874996,2952863.99625 757537.682500005,2952867.29125001 757531.411249995,2952872.954375 757518.820625007,2952884.61 757460.292500004,2952959.7525 757441.163124993,2952943.55500001 757329.905625001,2952860.17125 757321.405000001,2952847.44 757301.108750001,2952789.41374999 757221.431875005,2952556.980625 757272.578749999,2952539.44499999 757304.431250006,2952528.8818749
 9 757321.136250004,2952523.341875 757336.706249997,2952518.17874999 757370.121250004,2952507.0975 757418.465625003,2952487.58437499 757433.196250007,2952530.30312499 757492.040625006,2952507.88875 757502.467500001,2952503.90000001 757564.512500003,2952479.294375 757558.510000005,2952434.61687499 757534.996250004,2952351.76625 757531.746250004,2952324.29125001 757695.653125003,2952261.57187501 757726.368125007,2952244.38062499 757789.21875,2952178.56999999 757834.521874994,2952143.268125 757855.955624998,2952130.21375 757897.968125001,2952253.45874999 757906.134375006,2952250.453125 757941.012500003,2952237.61562499 757971.403125003,2952226.42937499 757975.574375004,2952224.89375 758012.679374993,2952211.236875 758036.989374995,2952202.28874999 758050.104375005,2952197.46125001 758086.103750005,2952184.21062499 758092.747500002,2952181.765 758149.913124993,2952160.72375 758161.832499996,2952156.33687501 758125.421875,2952107.03687499 758090.446875006,2952059.68000001 758075.589375004,2952042.311875 758021.25937
 5006,2951978.8 757988.199375004,2951935.831875 757977.880624995,2951922.42 757963.458749995,2951903.675625 757836.146249995,2951995.89937501 757751.259375006,2952058.121875 757760.584374994,2951973.48999999 757757.011250004,2951921.611875 757623.697500005,2951956.93125001 757620.227500007,2951929.739375 757618.701250002,2951917.78 757616.547499999,2951900.90375 757602.739999995,2951872.340625 757482.653125003,2951918.925625 757488.553749993,2951931.38249999 757492.046875,2951942.21125001 757371.462500006,2951988.451875 757381.828125,2952014.424375 757385.647499993,2952023.99312501 757391.333124995,2952048.64812499 757398.194374993,2952078.69499999 757399.064374998,2952082.50375 757406.819999993,2952116.465625 757410.635000005,2952133.17 757414.430000007,2952149.79062501 757421.580624998,2952181.22375 757537.708749995,2952180.68062501 757538.578125,2952207.08625001 757531.746250004,2952324.29125001 757383.737499997,2952384.18062501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:poly
 gonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>3592441.8802875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>15947.2839330526</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__177’><BrooklineWMS:OBJECTID>177</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757175.044375002,2951054.0275 757125.110624999,2950987.13625 757202.005624995,2950938.87 757321.823125005,2950863.66125 757478.528750002,2950765.528125 757
 525.903125003,2950733.010625 757630.351249993,2950871.0125 757536.443749994,2950945.48 757428.980000004,2951037.52124999 757345.550624996,2951100.579375 757340.647499993,2951094.206875 757307.736249998,2951051.4325 757221.806875005,2951116.669375 757175.044375002,2951054.0275</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>87633.2468421875</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1345.14746576922</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__178’><BrooklineWMS:OBJECTID>178</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWM
 S:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756961.015000001,2950885.21875 756858.079999998,2950734.864375 756950.739999995,2950670.94875 757256.278750002,2950453.933125 757258.633750007,2950452.260625 757258.638125002,2950452.25749999 757392.055625007,2950642.35375001 757396.963750005,2950649.328125 757478.528750002,2950765.528125 757321.823125005,2950863.66125 757202.005624995,2950938.87 757142.690624997,2950850.12625 757100.840625003,2950788.528125 757094.273124993,2950793.06937499 757026.505624995,2950839.93062501 756961.015000001,2950885.21875</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>151443.644764063</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1732.7553778065</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:fea
 tureMember><BrooklineWMS:Zoning fid=‘F1__179’><BrooklineWMS:OBJECTID>179</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-2.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-2.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757591.477500007,2949787.49625 757598.208124995,2949803.17812499 757673.603750005,2949909.264375 757690.976875007,2949933.70937499 757683,2949939.311875 757659.609999999,2949955.74124999 757601.113124996,2949996.828125 757542.833749995,2950037.763125 757553.079999998,2950052.145 757575.605625004,2950083.7625 757494.725624993,2950138.910625 757426.146874994,2950188.61875001 757495.863
 124996,2950284.26375 757449.045000002,2950317.60875 757258.636250004,2950452.25937501 757256.278750002,2950453.933125 756950.739999995,2950670.94875 756858.079999998,2950734.864375 756735.420000002,2950819.47375 756529.369375005,2950525.85312501 756953.873125002,2950225.875625 757051.903125003,2950156.60250001 757283.746875003,2949993.25624999 757356.250624999,2949942.17375 757579.579374999,2949783.25562499 757591.477500007,2949787.49625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>412469.90840625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3303.15888642219</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__180’><BrooklineWMS:OBJECTID>180</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>LOCAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1
 >9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>L-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757525.903125003,2950733.010625 757478.528750002,2950765.528125 757396.963750005,2950649.328125 757392.055625007,2950642.35375001 757456.533124998,2950599.25937501 757501.981250003,2950567.25875001 757506.135000005,2950564.33437499 757584.078749999,2950507.7375 757593.465625003,2950520.954375 757612.496875003,2950509.54125001 757675.332499996,2950464.74375001 757701.951875001,2950445.82375 757701.969999999,2950445.810625 757757.284374997,2950525.11750001 757777.279375002,2950557.02187499 757672.573125005,2950632.339375 757525.903125003,2950733.010625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolyg
 on></BrooklineWMS:Shape><BrooklineWMS:Shape.area>53052.124053125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1031.97235686875</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__181’><BrooklineWMS:OBJECTID>181</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>G-1.75(CC)</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>352</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>GENERAL BUSINESS</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>3</BrooklineWMS:CASE1><BrooklineWMS:CASE2>3</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>G-1.75(CC)</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757831.147499993,2950517.919375 757914.060000002,2950455.108125 757764.209999993,2950248.05125 757772.345624998,2950241.74375001 757699.166875005,2950139.19125 757831.52437
 5007,2950046.17749999 757733.269374996,2949904.003125 757705.621250004,2949923.423125 757690.976875007,2949933.70937499 757673.603750005,2949909.264375 757598.208124995,2949803.17812499 757591.477500007,2949787.49625 757579.579374999,2949783.25562499 757358.867500007,2949704.59875 757342.596874997,2949625.63312501 757336.175624996,2949605.03125 757302.351875007,2949613.308125 757185.838125005,2949641.81812499 757165.314999998,2949646.815625 757162.636250004,2949628.958125 757152.125624999,2949571.49875 757154.173749998,2949568.5425 757099.03125,2949543.425 757118.836250007,2949497.855625 757130.269374996,2949470.361875 757154.115624994,2949435.47437499 757159.583124995,2949421.35375001 757158.458124995,2949405.67874999 757145.105625004,2949369.610625 757133.351249993,2949336.923125 757132.635625005,2949317.18875 757141.084374994,2949295.81 757157.626874998,2949279.25937501 757312.902500004,2949242.979375 757319.128749996,2949267.060625 757336.661874995,2949337.534375 757341.4375,2949356.73 757386.233750001,294
 9349.61125 757421.493125007,2949344.00749999 757462.156874999,2949349.32125001 757499.409374997,2949353.0825 757503.169375002,2949352.98125 757542.215625003,2949345.971875 757551.295625001,2949344.341875 757564.688749999,2949395.300625 757572.724374995,2949425.873125 757646.300624996,2949406.78874999 757661.684375003,2949402.79875 757666.568749994,2949417.04625 757713.400000006,2949431.386875 757708.726249993,2949445.24437501 757726.459999993,2949440.74187499 757757.676874995,2949432.815 757762.113749996,2949450.004375 757772.092500001,2949488.66312499 757785.690624997,2949485.374375 757854.477500007,2949468.736875 757876.114999995,2949464.809375 757929.018749997,2949663.5 758078.711250007,2949708.38 758080.078749999,2949678.656875 758088.484999999,2949647.69875 758096.808750004,2949634.30500001 758110.081249997,2949625.78874999 758562.579374999,2949519.85625 758555.379999995,2949483.86750001 758555.407499999,2949483.8625 758522.776250005,2949347.32375 758526.132499993,2949346.496875 758660.926874995,2949313.2
 7625 758732.251249999,2949300.96250001 758751.054374993,2949323.24875 758831.885625005,2949496.32125001 758946.446250007,2949472.02 758965.220624998,2949468.190625 759005.019374996,2949613.95375 759000,2949614.895625 758896.348749995,2949634.34625 758936.748125002,2949711.08812501 758954.751249999,2949736.20625 759000,2949776.90062501 759071.473749995,2949841.280625 759038.060000002,2949929.404375 759028.484375,2949925.22562499 759025.732500002,2949932.33499999 759190.144374996,2949995.83562499 759150.670625001,2950106.33374999 759168.958749995,2950113.245625 759159.118750006,2950136.78687499 759150.683125004,2950156.96875 759085,2950335.60312501 759099.836250007,2950341.264375 758984.329374999,2950393.44750001 758951.878124997,2950328.91 758794.622500002,2950405.873125 758726.375,2950269.5 758689,2950288 758684.696875006,2950279.109375 758608.666875005,2950330.82125001 758589.219374999,2950301.2775 758569.873125002,2950271.88625 758551.118125007,2950243.394375 758534.866249993,2950218.705 758431.361249998,295
 0288.9375 758442.669375002,2950305.35250001 758360.946875006,2950365.175625 758350.419375002,2950372.590625 758312.443749994,2950399.33875 758265.385000005,2950432.48375 758261.441249996,2950426.84125 758199.698750004,2950471.27124999 758114.191874996,2950531.00125 758100.931250006,2950512.33687501 757932.230000004,2950627.91500001 757831.147499993,2950517.919375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>1389003.5579625</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>7590.83073951689</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__182’><BrooklineWMS:OBJECTID>182</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><Brook
 lineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757627.092500001,2950156.03 757575.605625004,2950083.7625 757553.079999998,2950052.145 757542.833749995,2950037.763125 757601.113124996,2949996.828125 757659.609999999,2949955.74124999 757683,2949939.311875 757690.976875007,2949933.70937499 757705.621250004,2949923.423125 757733.269374996,2949904.003125 757831.524375007,2950046.17749999 757699.166875005,2950139.19125 757772.345624998,2950241.74375001 757764.209999993,2950248.05125 757914.060000002,2950455.108125 757831.147499993,2950517.919375 757821.885000005,2950524.93625 757777.279375002,2950557.02187499 757757.284374997,2950525.11750001 757701.961250007,2950445.8175 757666.697500005,2950395.625 757578.163124993,2950457.55500001 757576.434375003,2950458.749375 757575.9706
 24998,2950458.096875 757541.341250002,2950409.21312501 757711.575000003,2950287.89125 757652.373125002,2950201.4375 757646.428124994,2950193.63312501 757628.234999999,2950158.2525 757628.489999995,2950157.99250001 757627.092500001,2950156.03</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>99098.5693125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2007.71015221</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__183’><BrooklineWMS:OBJECTID>183</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>T-5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>20</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>SINGLE-FAMILY & CONVERTED FOR TWO-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>28</BrooklineWMS:CASE1><BrooklineWMS:CASE2>27</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>T-5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><
 BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756529.369375005,2950525.85312501 756509.918750003,2950493.52187499 756506.078125,2950462.81125 756509.478125006,2950438.14624999 756528.448125005,2950396.67812499 756589.826875001,2950308.298125 756597.035624996,2950299.035625 756581.030000001,2950288.2025 756514.630624995,2950238.48375 756459.986874998,2950169.64937501 756448.260625005,2950152.91625001 756474.406874999,2950130.855625 756458.877499998,2950116.815 756379.155625001,2950021.635625 756403.386250004,2950013.5475 756473.273124993,2949990.218125 756484.998125002,2950003.783125 756516.258125007,2949994.8275 756513.938124999,2949977.90000001 756530.711875007,2949973.613125 756535.019999996,2949948.38187499 756531.791250005,2949931.25875001 756568.043125004,2949895.93062501 756588.853750005,2949853.9375 756579.727500007,2949811.42 756575.388125002,2949791.14812499 75668
 7.758125007,2949763.908125 756833.543750003,2949727.610625 757165.314999998,2949646.815625 757185.838125005,2949641.81812499 757193.428124994,2949702.158125 757190.694374993,2949731.31812499 757209.276250005,2949734.71125001 757281.841875002,2949752.0825 757288.4375,2949761.25 757320.793750003,2949802.40062501 757299.228750005,2949821.484375 757288.905000001,2949830.620625 757260.418125004,2949855.830625 757231.564999998,2949881.36499999 757224.473124996,2949887.64125 757201.570625007,2949907.91 757187.636875004,2949920.23999999 757171.306875005,2949931.6125 757135.511250004,2949956.54125001 757128.855625004,2949961.175625 757077.661874995,2949889.300625 757067.939999998,2949875.688125 757062.566874996,2949879.93062501 756871.515000001,2950022.018125 756830.679374993,2950056.48625 756842.833749995,2950072.970625 756885.310000002,2950132.38187499 756938.028750002,2950206.11937501 756953.873125002,2950225.875625 756529.369375005,2950525.85312501</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polyg
 on></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>334449.0061</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>3294.98807694834</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__184’><BrooklineWMS:OBJECTID>184</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.5</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HOUSE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>14</BrooklineWMS:CASE1><BrooklineWMS:CASE2>14</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.5</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 756830.679374993,2950056.48625 756871.515000001,2950022.018125 757062.566874996,2949879.93062501 757067.939999998,2949875.688125 757077.661874995,
 2949889.300625 757128.855625004,2949961.175625 757135.511250004,2949956.54125001 757171.306875005,2949931.6125 757187.636875004,2949920.23999999 757201.570625007,2949907.91 757224.473124996,2949887.64125 757231.564999998,2949881.36499999 757260.418125004,2949855.830625 757288.905000001,2949830.620625 757299.228750005,2949821.484375 757320.793750003,2949802.40062501 757288.4375,2949761.25 757281.841875002,2949752.0825 757209.276250005,2949734.71125001 757190.694374993,2949731.31812499 757193.428124994,2949702.158125 757185.838125005,2949641.81812499 757302.351875007,2949613.308125 757336.175624996,2949605.03125 757342.596874997,2949625.63312501 757358.867500007,2949704.59875 757579.579374999,2949783.25562499 757356.250624999,2949942.17375 757051.903125003,2950156.60250001 756953.873125002,2950225.875625 756938.028750002,2950206.11937501 756885.310000002,2950132.38187499 756842.833749995,2950072.970625 756830.679374993,2950056.48625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:poly
 gonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>143042.197205469</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2367.24783684111</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__185’><BrooklineWMS:OBJECTID>185</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>THREEE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>F-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED>4/20/08</BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>Changed from M-1.0 (Apt House)</BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 759093.999375001,2951070.9675 759111.375,2951106.64812499 758978.960624993,2951192.72812501 758895.735624999,2951068.925
 758833.832499996,2951110.91187499 758832.719999999,2951111.69625001 758775.965000004,2951025.829375 758868.111874998,2950960.799375 758869.030000001,2950962.135625 758903.784374997,2950938.55562501 758722.318749994,2950674.98625 758876.440624997,2950598.705625 759013.626874998,2950836.784375 759069.733125001,2950934.154375 759069.726249993,2950934.393125 759068.138125002,2950985.94374999 759092.690624997,2951026.558125 759092.903750002,2951048.999375 759093.999375001,2951070.9675</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>106897.629121094</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1705.1166367257</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__186’><BrooklineWMS:OBJECTID>186</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>APARTMENT HO
 USE</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>M-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED> </BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES> </BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 758796.275625005,2951011.49625 758777.499375001,2951024.74875 758775.965625003,2951025.829375 758809.501249999,2951075.1375 758832.719999999,2951111.69625001 758647.885625005,2951241.955 758630.465000004,2951237.41875 758477.990624994,2951227.438125 758404.197500005,2951222.608125 758390.146874994,2951164.72125 758316.423749998,2950859.75125 758289.109999999,2950791.32625 758270.600624993,2950754.761875 758235.043750003,2950697.653125 758403.338125005,2950584.268125 758460.120625004,2950561.438125 758519.993750006,2950537.36499999 758581.558750004,2950508.784375 758601.326250002,2950499.260625 758760.8037499
 93,2950422.425 758794.622500002,2950405.873125 758951.878124997,2950328.91 758984.329374999,2950393.44750001 759000,2950424.613125 759045.833124995,2950515.76375 758876.402500004,2950598.64 758876.440624997,2950598.705625 758722.317499995,2950674.9875 758902.426249996,2950936.5825 758903.784374997,2950938.55562501 758869.030000001,2950962.135625 758868.111874998,2950960.799375 758796.275625005,2951011.49625</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>382047.766089844</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2983.49970883007</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__187’><BrooklineWMS:OBJECTID>187</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>THREE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><Brook
 lineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>F-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED>4/20/08</BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>Chngd Fr M-1.0&M-2.0(Apt Hse)N part on 10/3/7</BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757506.135000005,2950564.33437499 757501.981250003,2950567.25875001 757456.533124998,2950599.25937501 757392.055625007,2950642.35375001 757258.638125002,2950452.25749999 757449.045000002,2950317.60875 757495.863124996,2950284.26375 757426.146874994,2950188.61875001 757494.725624993,2950138.910625 757575.629999995,2950083.75 757628.515000001,2950157.99062499 757628.185625002,2950158.2225 757646.428124994,2950193.63312501 757652.373125002,2950201.4375 757711.575000003,2950287.89125 757541.341250002,2950409.21312501 757575.970624998,2950458.096875 757576.434375003,2950458.749375 757578.163124993,2950457.55500001 757666.697500005,295
 0395.625 757701.951875001,2950445.82375 757675.332499996,2950464.74375001 757612.496875003,2950509.54125001 757593.465625003,2950520.954375 757584.078749999,2950507.7375 757506.135000005,2950564.33437499</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>115417.787653125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1893.89056298372</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__188’><BrooklineWMS:OBJECTID>188</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>M-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>134</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>THREE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>11</BrooklineWMS:CASE1><BrooklineWMS:CASE2>11</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>F-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED>4/21/08</BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>Changed from M-1.0(Apt House)</Bro
 oklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757644.966250002,2947901.77124999 757679.671250001,2947874.52562501 757724.873750001,2947838.675 757715.140000001,2947826.401875 757763.560000002,2947788 757717.560000002,2947730 757758.060000002,2947704.75 757733.25,2947674 757849.310000002,2947602.5 757957.741874993,2947809.43625 757947.784999996,2947813.61875001 757932,2947820.25 757914.5,2947829.5 757901.167500004,2947837.88625 757878.929374993,2947854.765 757752.060000002,2947960.25 757716.197500005,2947990.06812499 757644.966250002,2947901.77124999</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>54646.749303125</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>1126.94850905242</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember><gml:featureMember><BrooklineWMS:Zoning fid=‘F1__18
 9’><BrooklineWMS:OBJECTID>189</BrooklineWMS:OBJECTID><BrooklineWMS:ZTYPEOLD>L-1.0</BrooklineWMS:ZTYPEOLD><BrooklineWMS:SYMBOL>2</BrooklineWMS:SYMBOL><BrooklineWMS:ZONEDESC>THREE-FAMILY</BrooklineWMS:ZONEDESC><BrooklineWMS:CASE1>9</BrooklineWMS:CASE1><BrooklineWMS:CASE2>9</BrooklineWMS:CASE2><BrooklineWMS:ZONETYPE>F-1.0</BrooklineWMS:ZONETYPE><BrooklineWMS:DATE_MODIFIED>10/03/07</BrooklineWMS:DATE_MODIFIED><BrooklineWMS:NOTES>PK/OK Planning4/12/07Amendmant</BrooklineWMS:NOTES><BrooklineWMS:Shape><gml:MultiPolygon srsName=‘EPSG:2249’><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates> 757941.111874998,2948848.904375 757937.182500005,2948829.07250001 757915.349374995,2948744.16500001 757901.988124996,2948702.53 757896.668750003,2948683.341875 757883.313124999,2948635.16875 757874.847499996,2948604.63312501 757869.28125,2948583.13875 757865.473749995,2948568.436875 757929.953749999,2948552.81625 757912.132499993,2948485.670625 757883.650000006,2948378.35250001 757874.334999993,29
 48380.97624999 757863.051874995,2948342.80687501 757844.729375005,2948278.636875 757831.443124995,2948232.10375001 757827.106250003,2948216.91374999 757811.594999999,2948162.58812501 757808.968125001,2948158.246875 758311.162499994,2948024.433125 758323.553749993,2948072.06999999 758357.714375004,2948206.87 758355.546250001,2948248.439375 758380.361249998,2948343.74375001 758365.758125007,2948347.61687499 758370.394999996,2948362.671875 758360.519999996,2948392.769375 758375.820625007,2948451.26625 758379.345624998,2948450.083125 758395.249375001,2948510.51000001 758391.893124998,2948511.361875 758404.619375005,2948558.84125 758398.034374997,2948560.6275 758429.459999993,2948687.52562501 758301.582499996,2948720.9225 758046.464375004,2948789.30374999 758010.363124996,2948802.95625 757970.243125007,2948826.87875 757941.111874998,2948848.904375</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></BrooklineWMS:Shape><BrooklineWMS:Shape.area>340707.16583164
 1</BrooklineWMS:Shape.area><BrooklineWMS:Shape.len>2525.01978078518</BrooklineWMS:Shape.len></BrooklineWMS:Zoning></gml:featureMember></wfs:FeatureCollection>
 It looks like the LastXMLResponse is for the entire dataset and not just the columns, which can be obtained a much more efficient way. If you obtain the column names by analyzing the entire stream, I could introduce you to an URL call that only returns the column names of a dataset? Please do keep me updated though… this functionality is critical to our software that was due out in June and now must be in customer hands by LaborDay…
