What occurs to map1.Mode = ModeType.TrackZoomIn?
Well, all is in the title isn't it ?
Patrick.
Patrick,
I think you have something mixed up between V3.0 and V2.0. The property you mentioned is just in V2.0. I think you won’t mind if we move this post to the Map Suite 2.0 forums, right :)
What happened after you set the property to ModeType.TrackZoomIn is:
1. We store the ModeType in a module variable.
2. In the mouse down / move / up events are raised, we will check the ModeType and if it’s TrackZoomIn, we will draw a rectangles shape as the track zoom in rectangle. When mouse up occurs, the drawn rectangle will be adjusted to fit the map control width and height.
3. Set the CurrentExtent as the adjusted rectangle and refresh the map.
Hope it helps.
ThinkGeo Support
Let me clarify.
 I’m currently migrating from v2 to v3 … so the question is for v3.
 How should I implement this v2 feature in v3 … I did not found any similar API.
 Regards
 Patrick.
Patrick,
Sorry for misunderstanding.
You don’t need to specify the Map Mode before doing any mouse operations in V3.0.
The TrackZoomIn and Pan are controlled by the map. If you drag on the map with Ctrl key pressed, map control will track zoom in with drawing a rectangle to represent the extent which you are going to zoom into. If you drag on the map without any key pressed, map control will pan instead. You can see that the V3.0 is smarter and easier to use than V2.0 :)
Also in the upcoming version you will have more controls on mouse operations. You can Enable / Disable mouse pan, or use another key instead of Ctrl key as the TrackZoomIn key.
Following is a list to show how to replace the ModeType in V3.0
For example in V2.0 you set property
map1.Mode = ModeType.Center
to center a map.
In V3.0 you need to call
winformsMap1.winformsMap1.CenterAt()
V2.0                                                 V3.0
ModeType.Center                         winformsMap1.winformsMap1.CenterAt ()
ModeType.ZoomIn                       winformsMap1.ZoomIn();
ModeType.ZoomOut                    winformsMap1.ZoomOut();
ModeType.Pan                              By default it will pan the map when you drag on it.
ModeType.TrackCircle                 winformsMap1.EditOverlay.TrackMode = TrackMode.Circle
ModeType.TrackEllipse               winformsMap1.EditOverlay.TrackMode = TrackMode.Ellipse
ModeType.TrackFreehand          winformsMap1.EditOverlay.TrackMode = TrackMode.Freehand
ModeType.TrackLine                   winformsMap1.EditOverlay.TrackMode = TrackMode.Line
ModeType.TrackPoint                  winformsMap1.EditOverlay.TrackMode = TrackMode.Point
ModeType.TrackPolygon             winformsMap1.EditOverlay.TrackMode = TrackMode.Polygon
ModeType.TrackRectangle         winformsMap1.EditOverlay.TrackMode = TrackMode.Rectangle
ModeType.TrackStraightLine      winformsMap1.EditOverlay.TrackMode = TrackMode.StraightLine
ModeType.TrackZoomIn              Press Ctrl key and drag on the map.
Hope it helps.
ThinkGeo Support
I am also converting and am having issues with converting the following menu option fromV2 to V3
 ModeType.Pan
 so that I can change modes as MapSuite Explorer does.
 I also cannot seems to trackzoomin when I hold the CTRL button (not on MapSuite Explorer either
 Regards
 Ewan
Ewan,
 Thanks for your post!
 The MapSuiteExplorer is built based on Service Edition without any use of Desktop Edition Map Control, so it contains tons of redundant codes.
 In Desktop Edition Map Control, it is built in Mouse & Key operations based on the ExtentInterativeOverlay. If you want, you can write your own ExtentInterativeOveraly to change its behavior.
 Let me know if any more questions.
