When hiding individual items on the map, all items re-render which causes them to “flash” and is distracting. Using similar logic in WPF, this did not happen only the changed items were updated.
Using the attached source, select one or more items on the map and click the Hide Selected button , all objects on the map flash and the selected objects are hidden. It would be expected that only the changed items would be affected.
This is recreated and fixed in 15.0.0-beta154. Nothing needs to change in your project.
What you will see:
Hiding, showing or restyling through RedrawAsync() no longer blanks the map. The old picture stays up and the new one takes its place in a single step once it is ready.
It is not instantaneous: the server still has to draw the new tiles and send them, so there is a short delay before your change appears. The map simply does not go dark during it.
One thing worth changing on your side
A single “Hide Selected Shapes” currently costs three tile refills across two overlays:
ClearSelectionAsync() immediately after redraws DynamicOverlay a second time
Step 1 recomputes the selection highlight and step 3 discards it two lines later. If you clear the selection before the visibility change rather than after it, you are down to two refills and the update lands sooner.
Give beta154 a try and let us know if it works for you. And FYI: if you need to manipulate features continuously — dragging, toggling, restyling while the user works — a server-drawn tile overlay is the wrong tool for those, since every change is a round trip to the server. We are looking at a client-side vector overlay for that case and that will be more responsive.
I will give it a try as is and we definitely need to be able to drag and drop, hide/show, etc. and also perform a playback which will move multiple features on the map over time based on the data. I am currently writing a method to update the map now over time for the playback.
I think the vector overlay would be the best option for the moving features and then we would send the data changes to the server for other users to get the updates. We are still working out how collaboration is going to work.
We’re in the middle of a major upgrade to our Blazor component, which includes a new client-side Vector Overlay. We were planning to put it in beta after v15.0, we’ll see whether it can be brought forward. I’ll keep you posted here.
Here we wrote a sample for you showing the classic server-side rendering (on the left) vs the new client-side rendering (on the right). We are still working on it but here just show you how more responsive/sharp the client side rendering would be. We are integrating it to the new release.
That is nice. I will have more questions on this later. I am currently working on an animation/playback the to show object movements over time. This would definitely make that smoother, hopefully it will not be too hard to convert later. I will have it finished next week sometime early for a demo. After than I have to start working on a map server. Which is going to add the potential even more server-side layers for to the map itself.
Here is a video showing off the new features. We were thinking of putting them into Blazor after the Desktop release, but we are targeting now to put it into v15 as well. https://youtu.be/aI2tEir4Qvg?si=hyhe9EAX_0VN5wCI
I like the 3D world wrapping and terrain things. Our users currently have those with other applications. As we modernize, we will be adding other layers similar to the heat map, wind speed, wave height etc. Our big issue going forward is it will be running in the government cloud, and subject to security, which is why we will need to host the map server.
Here is what I am working on the demo for now, there are other details I still have to add to it, been working on it for a couple of days though:
No problem. You can deploy on your end with ThinkGeo component. We are also working on a new product - GIS Server - for setting up a server on your end. And just FYI: we provided global offline vector data, you can download test data from ThinkGeo HelpDesk.
We are actively working on the new Blazor and you will see more samples coming up.
