I have two problems.
Problem 1. Which EPSG Code ThinkGeo Supports for polar stereographic projection?
A. I used undermentioned EPSG Code 102018.
"+proj=stere +lat_0=90 +lon_0= 20 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m no_defs <>"
ThinkGeo throws error(Overflow Exception) as shown in the image attached.
B. When I change +lat_0=65, map and route on it is plotted I get distortions as shown in PSG 65.png (attached).
C. When I use LCC proj with lat_1=81 lat_2=81 , result is as in LCC 81.png(attached) . I get distortion on the other side of the globe near Alaska and the graticules are also not spaced evenly as can be seen in LCC 81.png
Problem 2. I want to overlay Polar stereogaphic png images on the ThinkGeo Polar Stereographic map. Sample images are attached. Central longitude of the image can be estimated from the image. What will be latitude of origin ; will it be Bottom Left or Top Left?
Any guidance would be appreciated.
