Dear All,
I am loaded the shapefile and provide the background color, while panning the map background color changing( if we drag the map color change, while drag leave the it’s came to normal color).
Palani
Dear All,
Palani
Hi Palani,
It looks we hadn’t reproduced that with our latest V10 sample, as below is the test code and how it looks:
You can easily build a sample follow this guide:
http://wiki.thinkgeo.com/wiki/map_suite_project_template_guide
Hi Palani,
We tested BackgroundOverlay, that get the effect just like you mentioned.
Please just try the BackColor instead of BackgroundOverlay.
Dear Don,
BackColor and BackGroundOverlay both different, even though i have checked same result only.
Palani
Hi Palani,
We are not sure your requirements, but BackGroundOverlay works by our design, for your current requirements, you can consider use BackColor.
If you have any advices when using MapSuite, please let’s know that. we will consider that.
Mark
