White Line in map
We are using mapuite 5.0 silverlight edition.
We observed that sometime white lines are appearing on the map. It looks like map is not fully loaded when there are so many white lines on the map.
How do we load the map fully without any while lines?
Please check the attached snaps showing white lines on map.
-Sunil
Sunil,
 For some reason your attached snap shots are not showing up on the post, can you attach or repost them again so we can take a look?
 I have added the files again.
 please check.
 Sunil
Sunil,
   I still don’t see any pictures.  Are the white lines showing up over satellite images using the GdiPlusRasterLayer or anything?
