When you zoom in to around 40-50 feet on the scale bar White lines appear between the Bing Map Overlays tiles. This is not a problem in iOS
White lines between bing map tiles
Hey @Richard6,
I’m taking a look into this now. I’m not able to recreate with overlay defaults. Do you have custom zoom levels created in your application? And what MapUnit is your map in?
Kyle
Yes – this was another hold over from the version 10 code. We had to use a custom zoom set with that code in order to avoid this very issue. The custom zoom level set was still in place - I switched to the Bingmapzoomlevelset and this issue is now resolved.
Actually the code was put in to address this issue
Base map offset - ThinkGeo UI for Mobile / Android - ThinkGeo Discussion Forums
I will need to take a closer look to see if the offset problem is an issue or not – first glance everything appears OK
