Hi Yale
I am not sure why the runtime error, " The Shape you provided does not pass our simple validation. There are no points in the shape", happens when trying to generate the second WGS84 file. After stopping debugger, the shape file was actually generated and can be seen in Map Explorer without the "no point" problem. What could be wrong?
Please take a look at the attachment. Sorry the attached file was a wrong one. Please use the updated one for reference.
I notices the second shp file generated has certain broken line. But do not understand why it happens after executing the second
conversion command for WGS84_pipeline.shp generation. Could you take a look at the attached?
001_MapFile.txt (1.33 KB)
