One of our applications is having an issue when we try to run it on Windows 7. It works great on XP. We get a System.Reflection.TargetInvocationException when we call Open on a RasterLayer object. The inner exception on the detail says: {" is not a valid Win32 application. (Exception from HRESULT: 0x800700C1)"}. I have tried versions 4.0 and 4.5 to no avail.
Do you install our DesktopEdition in the same machine? If you do, could you do the following testing? Run our HowDoI samples at installation folder, and find the samples related with imagery rendering under SatelliteImage category.
Yes DesktopEdition is installed and running the HowDoI imagery sample works fine.
A new revelation is that I can get it to work if I target x86 even though it's running on a 64 bit machine. Then I got it to work targeting Any CPU by removing all project references to the x86 dlls. I'm not sure why they were referenced in the first place since it's not required to work with the imagery stuff, but that did the trick. Thanks,
