WKB/WKT with SQL2008
Has anyone successfully been able to store a shape/feature into SQL2008 using the WKB from from any of the GetWellKnownBinary functions? I have been told that the values I am getting from the thinkgeo shapes use the right hand rule and SQL2008 requires use of the left hand rule. Any polygons I try to store to the db directly from the thinkgeo functions WKT or WKB error out in SQL.
I wrote a quick little function to convert the WKT from right to left. This seems to work fine so far, but WKT is much slower performance wise and I would really like to use WKB to improve efficiency. Has anyone else handled this?
I tried creating a custom class that reverses the points in the WKT when a shape is saved, then use the reversed WKT to create a new shape. The points in the new shape and the resulting WKB appear to reorganized back to use the right hand rule when the shape is created.
David,
 The polygon is composed of one outRing and several  innerRings. Both of them are RingShape type, we can determine whether it’s right hand rule by property “IsCounterClockwise”. The rule can be changed by calling “ReversePoints” method of RingShape. I’m not sure if it’s helpful. Any questions or issues please let us know.
