WMS Layer Help
I'm new to WMS, so I'm not sure if this is a problem with the map control or a problem with the WMS server, so any help would be appreciated.  I'm trying to connect to
ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wms.Esrimap/encdirect_coastal?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
I add all the layers to my WMS Layer, however I get the following exception:
[ERR0958] Layer with ID 3WEED does not exists.
I think this is because one of the layer names is 3WEED, KELP(WEDKLP), and I'm thinking the comma messes it up.  Any help would be appreciated.
.Ryan.
Hi Ryan,
 I tried your Wms server; one thing is that you need set the layer title as name in the parameter; for name is for people while title is for machine. So here you need to set "3_WEED, KELP_polygon" as layer name instead. On the other hand, this issue is caused by the server. I tried to use some other tool to access this server but the same exception throws.
 Please try the other layers instead or contact the Wms server provider.
 Howard
