WMSOverlay. WrapDateline does not wrap date line
Hi ThinkGeo,
WMSOverlay. WrapDateline does not wrap date line. Is there something I need to do at WMS implementation?
Anil
Anil,
 I tested our WrapDateLineSample of "HowDoISample", the wrap date line works for me.
 Could you let me know how did you use that property?
Hi Don,
 I am using following code where wmsOverlay is of type WmsOverlay
 wmsOverlay.WrapDateline = WrapDatelineMode.WrapDateline;
 Anil
Anil,
 Your code looks just the same as our HowDoISample used.
 Our WrapDateline in web edition from the same function of OpenLayers, so I think that should be related with your using WMS server and setting.
 Could you provide a really simple sample so that we can have a look at that?
Hi ThinkGeo,
 If I use plugin for normal Map (Decimal Degree) then map do wrap across the DateLine.
 However If I use Plginin ussing Spherical Projection "ESPG:90013" then Map boundary stops at Date Line.
 I use following method to define my WSMOverlay which uses 2 URI.
 Anil
 public static WmsOverlay DefineBaseWMSOverlay(Map Map1)
       String keyMapUri = "WmsMapUri";
       String keyMapUri2 = "WmsMapUri2";
       String keyWmsPluginLayer = "WmsPluginLayer";
       String valMapUri = ConfigurationManager.AppSettings[keyMapUri];
       String valMapUri2 = ConfigurationManager.AppSettings[keyMapUri2];
       String valWmsPluginLayer = ConfigurationManager.AppSettings[keyWmsPluginLayer];
       WmsOverlay wmsOverlay = null;
       if ((null != valMapUri) && valMapUri.Length > 0)
         wmsOverlay = new WmsOverlay("MyWMS");
         wmsOverlay.Parameters.Add("LAYERS", valWmsPluginLayer);
         wmsOverlay.Parameters.Add("STYLES", "DEFAULT");
         wmsOverlay.SetBaseEpsgProjection("EPSG:900913");
         wmsOverlay.TileType = TileType.MultipleTile;
         wmsOverlay.TileHeight = 256;
         wmsOverlay.TileWidth = 256;
         wmsOverlay.ServerUris.Add(new Uri(valMapUri));
         if ((null != valMapUri2) && valMapUri2.Length > 0)
           wmsOverlay.ServerUris.Add(new Uri(valMapUri2));
         Map1.CustomOverlays.Add(wmsOverlay);
       return wmsOverlay;
HI ThinkGeo,
 I am getting the same porblem with WorldMapKitWmsWebOverlay using projection  WorldMapKitProjection.SphericalMercator;
 Anil
Hi Anil,
 Thanks for your report.
 It looks we sure have some problem there.
 I will update this post if we make sure that’s a bug and fixed it.
Hi Anil,
 Here we have a workaround.
 Please add the code as below in the head tag of your page:
<script type=“text/javascript”>
        var OnMapCreating = function (map) {
            map.setOptions({ ‘maxExtent’: new OpenLayers.Bounds(-20001365, -20001365, 20001365, 20001365) });
    </script>
 This will makes WrapDateline works well if your mapunit is meter.
