WmsRasterLayer being static
Hello everyone,
I'm using a WmsRasterLayer in my application but I've got an issue when I try to pan or to zoom on the map.
This is my method to initialize the layer :
public void AddWMSLayer(BackgroundLayer backgroundWMS)
this.MapUnit = GeographyUnit.Meter;
try
WmsRasterLayer worldLayer = new WmsRasterLayer();
worldLayer.Uri = new Uri(backgroundWMS.urlValue);
worldLayer.UpperThreshold = double.MaxValue;
worldLayer.LowerThreshold = 0;
worldLayer.TimeoutInSecond = 60;
worldLayer.Exceptions = "Application/VND.OGC.SE_XML";
#region Passage des parametres
worldLayer.Parameters["REQUEST"] = backgroundWMS.request;
worldLayer.Parameters["OUTPUTFORMAT"] = backgroundWMS.outPutFormat;
worldLayer.Parameters["SERVICE"] = backgroundWMS.serviceOGC;
worldLayer.Parameters["STYLES"] = backgroundWMS.stylesLayers;
worldLayer.Parameters["SRS"] = "EPSG:" + backgroundWMS.projValue;
//Ajout du layer
worldLayer.ActiveLayerNames.Add(backgroundWMS.layers);
//If I can't add these parameters, the layer doesn't work
worldLayer.Parameters["BBOX"] = "550000,60000,660000,140000";
worldLayer.Parameters["WIDTH"] = "800";
worldLayer.Parameters["HEIGHT"] = "582";
#endregion
GoogleMapZoomLevelSet zoomLevelSet = new GoogleMapZoomLevelSet();
zoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
this.ZoomLevelSet = zoomLevelSet;
AddStaticLayer(backgroundWMS.name, worldLayer);
catch (Exception ex)
GeosysLog.Error(ex);
throw new StaticLayerException(32310, string.Format(ResXManager.GetResourceString("mappingWMSError"), backgroundWMS.urlValue), ex);
If I don't add the BBOX, WIDTH and HEIGHT parameters, the layer isn't displayed. If I add them, the layer is displayed but it's static.
When I zoom, only the feature changes. Same thing when I pan the map, only the feature moves. The WMS layer doen't move or zoom.
Do you have any idea about that issue ?
Thanks by advance.
Hi Pierre-Antoine,
 Thanks for your post.
 If you hard coded the prameters BBox,Wdith and height, you will always get the static image, because the client side requires the same extent image everytime. I think that make sence. I didn’t see anything unusual in your code pasted above, but it  will help a lot if you can upload the WMS server side code or a sample to recreate this issue.
 Lee
Hi Lee,
You can find in the attachement a project with my issue.
Thanks by advance.
CartoTestWMS.zip (15 KB)
Hi Pierre-Antoine,
 It looks the problem still be the extent incorrcet caused by projection. So the code as below should works.
private void btWithParameters_Click(object sender, EventArgs e)
            AddLog("");
            AddLog("Loading with parameters START");
            map.Overlays.Clear();
            map.MapUnit = GeographyUnit.Meter;
            try
                worldLayer.Uri = new Uri("wms.geo.admin.ch/");
                worldLayer.Parameters["REQUEST"] = "GetMap";
                worldLayer.Parameters["OUTPUTFORMAT"] = "image/png";
                worldLayer.Parameters["SERVICE"] = "WMS";
                worldLayer.Parameters["STYLES"] = "default";
                worldLayer.Parameters["SRS"] = "EPSG:21781";
                worldLayer.ActiveLayerNames.Add("ch.blw.ursprungsbezeichnungen-spirituosen-eau_vie_poire");
                //worldLayer.Parameters["BBOX"] = "550000,60000,660000,140000";
                worldLayer.Parameters["WIDTH"] = map.Width.ToString();
                worldLayer.Parameters["HEIGHT"] = map.Height.ToString();
                map.ZoomLevelSet = zoomLevelSet;
                if (worldLayer.HasBoundingBox)
                    worldLayer.Open();
                    ManagedProj4Projection proj4 = new ManagedProj4Projection();
                    proj4.InternalProjectionParameters = ManagedProj4Projection.GetDecimalDegreesParametersString();
                    proj4.ExternalProjectionParameters = ManagedProj4Projection.GetEpsgParameters(21781);
                    proj4.Open();
                    map.CurrentExtent = proj4.ConvertToExternalProjection(worldLayer.GetBoundingBox());
                    AddLog("Bbox : " + map.CurrentExtent.GetWellKnownText());
                    worldLayer.Close();
                staticOverlay.Layers.Add("WMS", worldLayer);
                map.Overlays.Add("WMS", staticOverlay);
                map.Refresh();
                AddLog("Loading with parameters END");
                AddLog("ERROR : " + ex.Message);
