WmsRasterLayer - System.Net.WebException
MapSuite Team,
Today I moved an application using WpfDesktopEdition V10 to a Windows R2012 Server. I connected to one of my WMS Providers and was panning/zooming when all of a sudden it crashed. Below is as much information as I have and I realize it is not much. So far I have encountered this exception only one time. I have continued using the application and have not encountered the exception again.
I have been using this same application on a Windows-10 machine and have never encountered this error.
Have you seen this before? Anything you’d recommend that I check for on the machine?
Dennis
From the exception PopUp–>>
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: OriStarWmsClient.exe
Problem Signature 02: 1.0.0.0
Problem Signature 03: 5a57fbfa
Problem Signature 04: System
Problem Signature 05: 4.7.2114.0
Problem Signature 06: 59a63a25
Problem Signature 07: a01
Problem Signature 08: 21a
Problem Signature 09: System.Net.WebException
OS Version: 6.3.9600.2.0.0.400.8
Locale ID: 1033
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: 5f25
Additional Information 4: 5f2531ae070278f893fa99352dadd49e
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Windows EventLog–>>
Application: OriStarWmsClient.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Net.WebException
at ThinkGeo.MapSuite.Wpf.Tile.DrawException(ThinkGeo.MapSuite.Drawing.GeoCanvas, System.Exception)
at ThinkGeo.MapSuite.Wpf.Tile.Draw(ThinkGeo.MapSuite.Drawing.GeoCanvas)
at ThinkGeo.MapSuite.Wpf.Tile.jlY=(System.Object)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
Faulting application name: OriStarWmsClient.exe, version: 1.0.0.0, time stamp: 0x5a57fbfa
Faulting module name: KERNELBASE.dll, version: 6.3.9600.18666, time stamp: 0x58f32841
Exception code: 0xe0434352
Fault offset: 0x00015608
Faulting process id: 0x1130
Faulting application start time: 0x01d38b3a448dddb7
Faulting application path: C:\OriStar\OriStarWmsClient\OriStarWmsClient.exe
Faulting module path: C:\Windows\SYSTEM32\KERNELBASE.dll
Report Id: a862711c-f72d-11e7-80de-0050568f1a26
Faulting package full name:
Faulting package-relative application ID:
Fault bucket 2100417342313100573, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 2138825184691176624
Problem signature:
P1: OriStarWmsClient.exe
P2: 1.0.0.0
P3: 5a57fbfa
P4: System
P5: 4.7.2114.0
P6: 59a63a25
P7: a01
P8: 21a
P9: System.Net.WebException
P10:
C:\Users\wmsadmin\AppData\Local\Temp\WERC9F.tmp.WERInternalMetadata.xml
C:\Users\wmsadmin\AppData\Local\Temp\WER1849.tmp.appcompat.txt
triagedump.dmp
C:\Users\wmsadmin\AppData\Local\Temp\WER1A10.tmp.WERDataCollectionFailure.txt
These files may be available here:
C:\Users\wmsadmin\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_OriStarWmsClient_1b7a55487a926386e8bced61141b77ae90d7cb_5a900305_cab_0e8c2c09
Analysis symbol:
Rechecking for solution: 0
Report Status: 8
Hashed bucket: d4e91eb9527305fced262e71c0a4751d
Hi Dennis,
It looks the information in your exception hadn’t told us what’s the problem, but I found that’s should related with the exception mode.
So please try to modify the exception mode to DrawException instead of ThrowException and see what’s the status.
And you mentioned that works well in Win10 but not in WinServer, I guess that’s related with the user security, because server version set strict rule, you can try to assign higher level right to the account and application folder.
