WMTS layer problem
I tested wmtslayer and I have an error with a message “The input string format is incorrect”.
 I change decimal separator in the configuration panel and I have the same result.
The wmts service comes from IGN organism
Extract of the code :
   private void serviceWMTS_Loaded(object sender, RoutedEventArgs e)
            map.MapUnit = GeographyUnit.Meter;
            var wmsLayer = new WmtsLayer();
            wmsLayer.ServerUris.Add(new Uri(“wxs.ign.fr/clé/geoportail/wmts”));
            wmsLayer.SendingWebRequest += new System.EventHandler<SendingWebRequestEventArgs>(binglayer_SendingWebRequest);
            try
                wmsLayer.Parameters.Add(“layers”, “ORTHOIMAGERY.ORTHOPHOTOS”);
                wmsLayer.Parameters.Add(“crs”, “EPSG:3857”);
                wmsLayer.Parameters.Add(“format”, “image/png”);
                wmsLayer.Parameters.Add(“style”, “Default”);
                wmsLayer.Parameters.Add(“maxHeight”, “256”);
                wmsLayer.Parameters.Add(“maxWidth”, “256”);
                //wmsLayer.ActiveLayerName = “ORTHOIMAGERY.ORTHOPHOTOS”;
                wmsLayer.Parameters.Add(“id”, “xxxx”);
                wmsLayer.Parameters.Add(“password”, “xxxx”);
                wmsLayer.Open();
            catch (Exception ee)
                MessageBox.Show(ee.Message);
            var server = wmsLayer.GetServerLayerNames();
            var ov = new LayerOverlay();
            ov.Layers.Add(wmsLayer);
            map.Overlays.Add(“Test”, ov);
            map.CurrentExtent = wmsLayer.GetBoundingBox();
            map.Refresh();
The code error :
Interception de System.FormatException
  HResult=-2146233033
  Message=Le format de la chaîne d’entrée est incorrect.
  Source=mscorlib
  StackTrace:
       à System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
       à System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
       à System.Convert.ToInt32(String value)
       à ThinkGeo.MapSuite.Core.WmtsLayer.qHU=(XmlNode qXU=, XmlNamespaceManager qnU=)
       à ThinkGeo.MapSuite.Core.WmtsLayer.CzU=(XmlElement pnU=, XmlNamespaceManager p3U=)
       à ThinkGeo.MapSuite.Core.WmtsLayer.pXU=()
       à ThinkGeo.MapSuite.Core.WmtsLayer.OpenCore()
       à ThinkGeo.MapSuite.Core.Layer.Open()
       à Carto_WMS.MainWindow.serviceWMTS_Loaded(Object sender, RoutedEventArgs e) dans c:\Steph_DevEnCours\Carto_WMS\Carto_WMS\MainWindow.xaml.cs:ligne 249
  InnerException:
Have you ever encountered this problem ?
I tested the wmts service with the software Qgis and I don’t have any problem (ie Capture_WMTS_PASOK.jpg)
Thanks for your help.
Regards.
Steph.
Hi Steph,
Sorry we are unable to get the capabilities.xml from wxs.ign.fr/clé/geoportail/wmts?Service=WMTS&Request=GetCapabilities as we don’t have the id and password. Could you please attach the capabilities.xml here.
We did some tests and found that the WmtsLayer doesn’t support the CRS(IGNF:WGS84G) currently, but I’m not sure if this is the issue on you side.
Peter
