We have a problem with a free WMTS-map that our customers are using. For some reason the map is not loaded. The problem started about two weeks ago. I tried if it works with earlier (ThinkGeo) versions, but the same problem persists with them. I think the issue is that the SendingWebRequest-event is not triggered. When it previously worked that event was continuously fired and the map data received. Do you know why this event is not triggered?
Here is a sample project that illustrates the problem. (Password: wmtsmap) WebService.OnSendingWebRequest is never hit and executed. This is a quite urgent problem for us since our customers use this map⦠Thanks in advance.
