Working with kml files
I’m trying to load several kml files with more than 2000 placemarks each.
So far I was able to load it using yours modified KmlExtension sample and using custom styles, but I was not able to find a best way to open a popup window when user clicks on one particular point (icon).
I tried using Layer.QueryTools.GetFeaturesWithin inside MapClick event, but without success , because I have too many points close by.
Please advice for a best and efficient solution to find a feature which user clicked on, taking in consideration that I have several layers and many points closed by.
Vicky
Vicky,
 Thanks for your question!
 If you have a lot of points in your layer I would use the QueryTools.GetFeaturesNearestTo method passing in the point that the user clicked.  By using this method you can specify the maximum number of items you want to return which I think will work well in your case.
 Hope this helps, Thanks!
Thank you for your answer.
In my application, I have multiple layers (separate, not MultipleFeatureLayer).
In MapClick event, I’m looping through each layer and checking for the nearest point user clicked on, if  found, I’m saving it in array.
At the end, I’m picking point from array with the shortest distance.
Maybe you can suggest a different alternative to my code.
Thank you in advance,
Vicky
Vicky,
 That should be a feasible approach, is it still performing to slow?  How long is it taking?   Another possible option although I’m not sure exactly how this would work with KML is to build an InMemoryRTreeIndex on each layer as they may speed things up pretty quickly.
 Here is some sample code on how to create an index on an InMemoryFeatureLayer that may port over to your layers pretty easily.
 gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/16/aft/5266/afv/topic/Default.aspx
