We are upgrading our projects to use ThinkGeo 7, however, this will be a medium long term process. We have to upgrade the projects to .net 4 and that slows down all the projects updates.
Currently we have some project using Thinkgeo 7 and others with Thinkgeo 5.5.
Right now i´m having the unlicensed watermark when running project with TG 5.5. It works well with TG7. I have both versions installed on my machine. How can i run the two versions os Tg in my machine?
regards
Luís Diogo
Working with two versions of thinkgeo
Hi Luis,
We did some test but unlucky haven’t reproduce your problem.
We think that maybe related with your environment, could you please provide more detail information about your envrionment?
For example: what’s your OS version, whether the 5.5 and 7.0 are full version, which browser you are using and whether you have tested after clear cache, have you installed other .net framework in same machine exception 4?
Any information is welcome, they should be helpful to create a test environment.
