I just purchased MapSuite 4.5 with the routing extensions and the World MapKit and I'm a bit disappointed that It looks like I need to do quite a bit of work to get the routing to work with the maps. I was hoping all the files would be there since I'm buying the data from you. What is the best way to create a routing index for the World Map Kit for the US roads? Do you have RTG files for each state that will work for the World Map Kit to save me many days of index creation? If you do I would greatly appreciate being able to get them from you it since I tried creating an RTG file based on the largest SHP file for california and it took 8 hours and then the routing didn't seem to work? Even if you have the files, Do you have sample code for creating the files from the World MapKit? Looking at other posts it looks like you can either create the index from a single shape file or you can create the routing file from different shape files in the hierarchy but I don't see any code showing how to do it or handle it. any help would greatly be appreciated.
