in a custom layer, derived from MapShapeLayer, i draw points, areas an lines.
First i draw all Areas, then the lines and then the Points.
When i use only the outer pen for the line style (set center and inner pen transparent), the Point is completly visible. But when I use the other pens (inner and center) the Line will draw ‘over’ the Point (see attached Pictures).
Is this a bug?
I use Version 14.4.0 - beta 059.
Regards Torsten
