Here I am attaching sample for your reference. WrapDateLine.zip (2.9 KB)
2. There is no such property called WrapDateLine in GdiPlusRasterLayer.
But i want to set wrap date line to GdiPlusRasterLayer.
Hi Ethan,
Thanks for your reply.
1.Once GraticuleAdornmentLayer issue of WrapDateline resolved. Just let me know.
2.we have restriction to go with only V9. so can you please fix WrapDateLine in GdiPlusRasterLayer also.that one will helpful for us.
It looks your data is under decimal degree, so our developer switch code to decimal degree and the graticule works well there. So does it necessary to re-projection the layer to meter? Our developer will go on working to solve the problem that it don’t works under meter.
I double check this with our development team, they had already frozen the V9 release, the code won’t get any changed unless heavy bug, this function is an enhancement after V9 frozen, so it won’t be added back to V9 release version. Please choose the V9 development version dlls or V10 dlls.
Hi Ethan,
Greetings of the Day.
I checked in Thinkgeo Web Edition Version 10.1.0.0 for graticule feature layer wrap dateline. But it’s not wrap while in projection.
Please check below sample for your reference. Graticule wrap.zip (3.6 KB)
But if i set wraping mode to overlay with out projection, it’s working fine. I must need to apply projection.
So please fix it ASAP.
Hi Ethan,
Even I cross checked in Web Edition latest Version(10) about Graticule wrap functionality. But it didn’t work.
It’s general reminder for graticule wrap in V10.
The version you choose hadn’t solved this problem, our developer should had fixed that now, please upgrade your package to the version ThinkGeo.MapSuite.Layers.Graticule 11.0.0-beta006 to see whether it works for you.
Hi Ethan,
I tried to use WrapDateline mode to NativeImageRasterLayer in Thinkgeo webedition v10.
But it’s not work out. it’s getting some error message.
Hi Ethan,
I am facing some strange issue. I am applying wrapping for all layers. Initial loading time each layer wrapping fine.
But Some times while panning it’s coming like this.(Features are not rending correctly,it’s moving to some other place)
I don’t know, what’s wrong over there for it. i didn’t even using Map extent changed and mouse move events. Map is rendering automatically whenever pan or zoom it.
The code you attached is not very different than before, so we cannot make sure whether you still use the same data, and how to reproduce it.
Could you please let us know more about the issue? And I suggest you can modify the sample before in this post, and attach it when you met problem, so it can save the communication times.
