I encountered this problem before; it seems that this problem is related with the machine operating system mode. See following in details. gis.thinkgeo.com/Support/Dis...fault.aspx
Thanks for your answer. I can fix the problem for this projection but our software will be used throughout the world so I can't know in advance all the projections will be used.
About the post you've shown to me, did you rewrite the Proj4 code ?
I agree that it is very tough to know all the projections used at the first beginning, and even know this it is impossible to know which projections have this problem.
Yes, we have managed version proj4 projection now.
Do you have any method included in the library to get a list of availabale projections? I would like to take all projection list to a list box and the user selects the desired projection
I am sorry to say that we have not contains such API to get all the projection string or all the srids can be used in the library.
While, all the information are contained in the following folder files and in a specified format, I think we can try to read and analyze out those lists. C:\Program Files\ThinkGeo\Map Suite Desktop Evaluation Edition 3.0\Documentation\Projections
