XML for different image layers
Is there a way to get images in XML format?
I am trying to get different layers of the images – for Eg:
Actual Image layer
New shapes drawn Layer
I truly appreciate any information/insight on this topic.
Gowri,
 Welcome to the community, hope you enjoy the learning and sharing here.
 I think you are trying to save a layer to an XML and get the layer back from that XML, is that right?  Most of our classes support xml serialization, that means we can easily serialize a class to XML and deserialise its status back from XML. Here is some sample code how to serialize and deserialize.
// Serialize/Deserialize with System.Xml.Serialization.XmlSerializer
private static MemoryStream SerializeXmlViaXmlSerilalizer(object request)
            Type tmp = request.GetType();
            XmlSerializer serializer = new XmlSerializer(tmp);
            MemoryStream memStream = new MemoryStream();
            serializer.Serialize(memStream, request);
            return memStream;
        private static object DeSerializeXmlViaXmlSerilalizer(MemoryStream memStream, Type type)
            XmlSerializer deserializer = new XmlSerializer(type);
            memStream.Position = 0;
            object sr = deserializer.Deserialize(memStream);
            memStream.Close();
            return sr;
// Serialize/Deserialize with System.Runtime.Serialization. DataContractSerializer
        private static MemoryStream SerializeXMLViaDataContractSerializer(object request)
            Type tmpType = request.GetType();
            DataContractSerializer serializer = new DataContractSerializer(tmpType);
            MemoryStream memoryStream = new MemoryStream();
            serializer.WriteObject(memoryStream, request);
            return memoryStream;
        private static object DeSerializeXMLViaDataContractSerializer(MemoryStream memoryStream, Type type)
            memoryStream.Position = 0;
            DataContractSerializer serializer = new DataContractSerializer(type);
            object result = serializer.ReadObject(memoryStream);
            memoryStream.Close();
            return result;
 Have a try and let us know if you have any issues about that.
Hey Ben,
 Thank-you for sharing the XML serialization piece. This is definitely going to help.
 I am new to ThinkGeo and trying to understand how to save the image data in an XML format. I am using CustomOverlay type that has 2 overlays added
 * VirtualEarthOverlay
 * LayerOverlay (this in turn has some layers defined)
 I was wondering if there is a way to serialize the “Overlays” instead of serializing each layer as explained in your earlier sample.
 This way if we prefer to change the Map software to Google earth, I can retrieve the XML from the Database; get the LayerOverlay, deserialize it and map it over the new image.
 I look forward to hear from you.
 Gowri
Gowri,
 I thought Overlay serialization is supported but after a simple test, I’m afraid it’s not. We do support the serialization for simple objects (like shapes(pointShape, Polygon,…), GeoColor,…) but do not support it for high-level classes like Overlays. I’ve added this to our tracking system and we will discuss when to focus on this feature. Thanks for reminding and sorry for the inconvenience now.
