I somehow got the WorldMapKitRenderLayer to throw the following exception:
System.IO.IOException was unhandled by user code
Message="The process cannot access the file '\\\\sup-amr1\\gis\\wmk5\\LayersBoundingBoxes.ids' because it is being used by another process."
Source="mscorlib"
StackTrace:
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access)
at hhQ=.vFE=.Khk=(String xFE=, RtreeSpatialIndexReadWriteMode xVE=)
at ThinkGeo.MapSuite.Core.RtreeSpatialIndex.OpenCore()
at ThinkGeo.MapSuite.Core.SpatialIndex.Open()
at ThinkGeo.MapSuite.Core.WorldMapKitRenderLayer.OpenCore() in C:\dev\LUT600 2.1.1\OCC600\Source\GIS\Modules\ThinkGeo\ThinkGeoLibrary\Layer\WorldMapKitRenderLayer.cs:line 3240
at ThinkGeo.MapSuite.Core.Layer.Open()
at ThinkGeo.MapSuite.WpfDesktopEdition.LayerTile.DrawCore(GeoCanvas geoCanvas)
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.uhM=(GeoCanvas uxM=)
at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.Draw(GeoCanvas geoCanvas)
InnerException:
When the map got into this state, I had to shut down the application. Before this happened, I started getting a bunch of these errors attached. This is with v5.5.31.0
I have seen this particular error before about the GeoCanvas not drawing but cannot remember what we did to solve it. Attached is the draw core of my WorldMapKitRenderLayer.
Could you guys please look into this Thanks.?
 protected override void DrawCore(GeoCanvas canvas, Collection<SimpleCandidate> labelsInAllLayers)
            try
                RectangleShape extent = canvas.CurrentWorldExtent;
                object image = canvas.NativeImage;
                GeographyUnit unit = canvas.MapUnit;
                bool isInDrawing = canvas.IsDrawing;
                if (isInDrawing)
                    canvas.EndDrawing();
                Collection<string> candidateLayerNames = new Collection<string>();
                if (rtreeSpatialIndex != null)
                    candidateLayerNames = rtreeSpatialIndex.GetFeatureIdsIntersectingBoundingBox(extent);
                WorldMapKitShapeFileFeatureLayer layer = null;
                for (int i = 0; i < staticLayers.Count; i++)
                    layer = staticLayers[i];
                    if (candidateLayerNames.Count == 0 || candidateLayerNames.Contains(Path.GetFileName(layer.ShapePathFileName)))
                        canvas.BeginDrawing(image, extent, unit);
                        layer.Open();
                        layer.Draw(canvas, labelsInAllLayers);
                        //layer.Close();
                        canvas.Flush(); //canvas.EndDrawing();
                for (int i = 0; i < dynamicLayers.Count; i++)
                    layer = dynamicLayers[i];
                        layer.Open();
                        //layer.Close();
                if (isInDrawing)
            catch (Exception ex)
                ActionResponse.LogError(ex, "WMK Render Layer");
