Z value lost when making new PointShape
The following operation (and several similar ones) loses the Z value of PointShape class.
var pt = new PointShape(aX, aY, aZ);
var fea = pt.GetFeature();
var pt2 =(PointShape)fea.GetShape();
I think the constructor needs to have Z value assignment. This is a fairly urgent request. Can you please look into it?
Damian
Hi Damian,
We use WKB to store geometry in Feature, but WKB doesn’t support Z for now. We can store Z value to feature’s column value and restore it to PointShape, like the following methods:
    public Feature ConvertToFeature(PointShape point)
        Feature feature = new Feature(point.X, point.Y);
        feature.ColumnValues.Add("zValue", point.Z.ToString());
        return feature;
    public PointShape ConvertToPointShape(Feature feature)
        string zValue = feature.ColumnValues["zValue"];
        double z;
        PointShape p = feature.GetShape() as PointShape;
        if (p != null && double.TryParse(zValue, out z))
            p.Z = z;
        return p;
Leo
Hi Leo,
My problem is that these points are being stored in sqlite db and the SQLiteFeatureLayer is used to display them. In the db, I am committing using the point.GetWellKnownBinary().
As the database takes byte[] for the geometry field, is it possible to substitute GetWellKnownBinary() with a standard binary formatter like follows:
    public static byte[] ObjectToByteArray(Object obj)
        BinaryFormatter bf = new BinaryFormatter();
        using (var ms = new MemoryStream())
            bf.Serialize(ms, obj);
            return ms.ToArray();
I notice if I serialize and deserialize using this method that the Z value is retained.
Damian
Hi Damian,
GetWellKnownBinary() is crucial in ThinkGeo Map, it would have a big impact if we change it.
In your db, besides featureIdColumn and geometryColumn, you could have another column “zValue” to store z values. When you get features from SQLiteFeatureLayer, you could get features with zValues in columnValues, and you could use method ConvertToPointShape(I replied previously) to create a PointShape with x, y, z.
Leo
Hi Leo,
Sorry for the delayed reply.
I have just done an experiment that I don’t think worked the way it should.
                Feature f = new Feature(channel);
                f.ColumnValues.Add("Elevation", "40");
                byte[] bytes = f.GetWellKnownBinary();
                Feature uf = new Feature(bytes);
Feature uf does not contain the column value Elevation. So, if I ever write the feature f to my sqlite db, I still won’t be able to retrieve the elevation value and your method above can’t work.
Can you verify this is expected? If not and it’s a bug would appreciate knowing if it can be fixed as this would totally solve my problem and extend my program functionality quite a bit further without having to physically add columns to the database tables.
Damian
hi Damian,
It’s not a bug, it’s expected. GetWellKnownBinary only return the well-known binary(see definition of WKB), it doesn’t have any columns value information.
Leo
