ZIndex
I have a list of overlays I would like to see in the map as ordered as ZIndex should do. Some overlays contain markers and do not honor the ZIndex behavior. You can verify my assertion adding the following code to your example "ZoomLevelsOnMarker" ; the code add a button and its Clik event to DescInfo window.
What is wrong ?
Thank you in advance.
public partial class ZoomLevelsOnMarker : UserControl {
        private void LabelRotateAMarker_Loaded(object sender, RoutedEventArgs e)
          ...... your code ......
           Button b = new Button();
            b.Width = 100;
            b.Height = 25;
            b.Content = "Set ZIndex";
            ((Canvas)DescInfo.Content).Children.Add(b);
            b.Click += new RoutedEventHandler(b_Click);
        void b_Click(object sender, RoutedEventArgs e)
            foreach (Overlay o in Map1.Overlays)
                if(o.GetType() == typeof(WorldMapKitWmsSilverlightOverlay))
                    o.ZIndex = 200;
                 if(o.GetType() == typeof(InMemoryMarkerOverlay))
                    o.ZIndex = 100;
Hi Enrico,
We have recreated the problem you mentioned, and the reason is that we have a hard coding which set the marker overlay z index to 801. So we have a work around for this which is setting the z index property of the WorldMapKitWmsSilverlightOverlay bigger than 801. And we will consider making some change to this in the next release so that this functionality could be used more convenient.
Sorry for the inconvenience and any more questions please let me know.
Sun
