Hello Peter,
I have two maps on a same page and I add a shape file in both of them. I want to set different zoom level of shape file in both map but both shape files set the same zoom levels which I set first, I have put both shape files in different folder but problem still exists.
Map1 =newMap("map",newSystem.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage), 510);newSystem.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage);WorldMapKitWmsWebOverlay worldMapKitOverlay =newWorldMapKitWmsWebOverlay("WorldMapKitOverlay");Map1.CustomOverlays.Add(worldMapKitOverlay);Map1.MapTools.LoadingImage.ImageUri =newUri(Server.MapPath(@"~/ShapeFiles/loading_logofinal_by_zegerdon-d60eb1v.gif"));Map1.MapTools.LoadingImage.Enabled =true;Map1.MapTools.LoadingImage.Height = 64;Map1.MapTools.LoadingImage.Width = 64;Map1.MapTools.ScaleLine.Enabled =true;Map1.MapUnit = GeographyUnit.DecimalDegree;Map1.MapTools.MouseCoordinate.MouseCoordinateType = MouseCoordinateType.LongitudeLatitude;Map1.MapTools.MouseCoordinate.Enabled =true;Map1.Cursor = CursorType.Pointer;//Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.Swamp);ShapeFileFeatureLayer PakLayer =newShapeFileFeatureLayer(Server.MapPath(@"~/ShapeFiles/PAK_adm0.shp"));PakLayer.ZoomLevelSet.ZoomLevel03.DefaultAreaStyle = AreaStyles.Country1;PakLayer.ZoomLevelSet.ZoomLevel03.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("NAME_ENGLI","Arial", 8, DrawingFontStyles.Italic, GeoColor.StandardColors.Crimson, 3, 3);//TextStyles.Capital3("NAME_1");PakLayer.ZoomLevelSet.ZoomLevel03.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level04;ShapeFileFeatureLayer.BuildIndexFile(Server.MapPath(@"~/ShapeFiles/PAK_adm0.shp"));LayerOverlay staticOverlay2 =newLayerOverlay("StaticOverlay2");staticOverlay.IsBaseOverlay =false;staticOverlay.Layers.Add("PakLayer2", PakLayer);PakLayer.Open();Map1.CurrentExtent = PakLayer2.GetBoundingBox();Map1.CustomOverlays.Add(staticOverlay2);PakLayer.Close();//—Map2Map2 =newMap("map2",newSystem.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage), 510);//new System.Web.UI.WebControls.Unit(100, System.Web.UI.WebControls.UnitType.Percentage);//WorldMapKitWmsWebOverlay worldMapKitOverlay = new WorldMapKitWmsWebOverlay("WorldMapKitOverlay");//Map2.CustomOverlays.Add(worldMapKitOverlay);Map2.MapTools.LoadingImage.ImageUri =newUri(Server.MapPath(@"~/ShapeFiles2/loading_logofinal_by_zegerdon-d60eb1v.gif"));Map2.MapTools.LoadingImage.Enabled =true;Map2.MapTools.LoadingImage.Height = 64;Map2.MapTools.LoadingImage.Width = 64;Map2.MapTools.ScaleLine.Enabled =true;Map2.MapUnit = GeographyUnit.DecimalDegree;Map2.MapTools.MouseCoordinate.MouseCoordinateType = MouseCoordinateType.LongitudeLatitude;Map2.MapTools.MouseCoordinate.Enabled =true;Map2.Cursor = CursorType.Default;Map2.MapBackground.BackgroundBrush =newGeoSolidBrush(GeoColor.StandardColors.SlateGray);ShapeFileFeatureLayer PakLayer2 =newShapeFileFeatureLayer(Server.MapPath(@"~/ShapeFiles2/PAK_adm0.shp"));PakLayer2.ZoomLevelSet.ZoomLevel06.DefaultAreaStyle = AreaStyles.Country1;PakLayer2.ZoomLevelSet.ZoomLevel06.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("NAME_ENGLI","Arial", 8, DrawingFontStyles.Italic, GeoColor.StandardColors.Crimson, 3, 3);//TextStyles.Capital3("NAME_1");PakLayer2.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;ShapeFileFeatureLayer.BuildIndexFile(Server.MapPath(@"~/ShapeFiles2/PAK_adm0.shp"));LayerOverlay staticOverlay2 =newLayerOverlay("StaticOverlay2");staticOverlay2.IsBaseOverlay =false;staticOverlay2.Layers.Add("PakLayer2", PakLayer);PakLayer2.Open();Map2.CurrentExtent = PakLayer2.GetBoundingBox();Map2.CustomOverlays.Add(staticOverlay2);PakLayer2.Close();
Thank you for support.
