Zooming Raster
when using RasterLayer I'm getting an exception. First the RasterLayer will not be drawn and panning the map will raise the exception.
On a different machine it's working fine.
What issue will cause this exception? Could it be depending on network or .net package?
System.ArgumentNullException: Value cannot be null.
Parameter name: ptr
at System.Runtime.InteropServices.Marshal.GetDelegateForFunctionPointer(IntPtr ptr, Type t)
at ohM=.kCo=.kyo=()
at ohM=.kCo=.pio=(Bitmap pyo=, Double[] qCo=, String qSo=, String qio=, Double[] qyo=)
at ohM=.kCo=.lyo=(Bitmap mCo=, RectangleShape mSo=, String mio=, String myo=, RectangleShape nCo=)
at ThinkGeo.MapSuite.Core.ManagedProj4Projection.ConvertToExternalProjectionCore(GeoImage image, RectangleShape imageExtent)
at ThinkGeo.MapSuite.Core.Projection.ConvertToExternalProjection(GeoImage image, RectangleShape imageExtent)
at ThinkGeo.MapSuite.Core.RasterSource.GetImage(RectangleShape worldExtent, Int32 canvasWidth, Int32 canvasHeight)
at ThinkGeo.MapSuite.Core.RasterLayer.DrawCore(GeoCanvas canvas, Collection`1 labelsInAllLayers)
at ThinkGeo.MapSuite.Core.GdiPlusRasterLayer.DrawCore(GeoCanvas canvas, Collection`1 labelsInAllLayers)
at ThinkGeo.MapSuite.DesktopEdition.Overlay.ZxQ=(GeoCanvas aBQ=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.shM=(IEnumerable`1 VRc=, RectangleShape Vhc=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.sBM=(RectangleShape Uxc=, RectangleShape VBc=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.FhQ=(RectangleShape lxc=, Overlay mBc=, Int32 mRc=, Int32 mhc=, GeographyUnit mxc=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.CxQ=(IEnumerable`1 nRc=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.9xM=(RectangleShape jRc=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.5RM=(InteractionArguments fxc=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.0hM=(Object bhc=, zxU= bxc=)
at ThinkGeo.MapSuite.DesktopEdition.MouseEventAnalyzer.OnMouseEvent(zxU= e)
at ThinkGeo.MapSuite.DesktopEdition.MouseEventAnalyzer.uBQ=(Double uRQ=, Double uhQ=, Double uxQ=, Double vBQ=, MapMouseButton vRQ=)
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.fBc=(Object fRc=, MouseEventArgs fhc=)
at System.Windows.Forms.Control.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Regards
Hardy
Hi Hardy,
I am guessing some necessary raster dlls are missing in the machine which will throw the exception. Would you please check whether those dlls
are locating in system folder: C:\Windows\SysWOW64\Map Suite 8.0\GeoRasterProjectionX86(64) or C:\Windows\system32\Map Suite 8.0\GeoRasterProjectionX86(64), more details on the dependencies dlls please refer to wiki.thinkgeo.com/wiki/Map_S…cies_Guide
In case the above is the reason, I think it is worth to try to re-install the Map Suite Unmanaged Dependencies.msi. (this installation is included in the daily dll package now)
Hope it helps and if you have more information, please let us know.
Hi Troy,
the problem is fixed. The dll's where missing on the target machine.
Thanks for helping me.
Regards
Hardy
Okay Hardy,
 Good to hear it helps.
