ZoomLevel Not Set upon ajax update
I have a map in a Web Application that I don't load until after user input.  I first load a "skeleton map"  Where by I create all the overlays, but they are blank.  After the user logs in I initiate a callback that clears the map, then adds populated overlays of the same name.
I do this because I find that If I simply add overlays that did not previously exist, it wont work.  However, zoomlevels arent set in the layers, even though I set the zoom levels when I redraw and update, must I add blank layers to blank overlays, and set the zoom levels of these blank layers even though I am clearing them and replacing???
Eric,
  We will look at your case in more detail tomorrow. But in the meantime, if you have some more clarifications on what exactely the different steps are in your app, that would help. Thank you.
Eric,
  Can you send ud a little sample app with the different steps ocurring? By reading your description, I am not sure how to create the same conditions as in your case. I think that would help. Thank you.
Hey,
 I am out of the office today, I will get you some more info and code later, thanks for your reply.
 In the meantime I am very curious about another problem in post gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/12/aft/9919/afv/topic/Default.aspx
 Eric
Eric,
 Ok, we are waiting for further details from you. Regarding post 9919 "getBitmap throws error", Gary has been assigned to it and he should give you a response today. Thank you.
