Bings maps not displaying with v10
https://community.thinkgeo.com/t/requestdrawing-not-redrawing-layer/9886
Due to 2nd problem in the above issue I switched back to v10 in order to get our product to our beta users for iOS. However I ran into an issue with BingMaps where I get the camera icon for all map tiles. This is exhibited in the same test case referenced above where I simply made change to use v10. Attached is the modified project and once again appid needs to be set to a valid appid.
I figure there must be an additional requirement in v10 for bingmaps that is handled automatically in v12 – unfortunately I have no idea what that might be. This is for iOS only.
ThinkgeoTestCase.zip (2.2 MB)
Thanks Richard,
Yes. I can reproduce the issue. I also tested with the v10 released sample https://gitlab.com/thinkgeo/public/thinkgeo-mobile-maps/-/tree/support/v10/samples/iOS/GettingStarted
this one works fine after I changed the layer to bingmap layer. It use a different way to initialize the map. Anyway we will released the V12 xamarin form edition next week. So I recommend use the V12 xamarin form next week as Ben mentioned in the
RequestDrawing not redrawing layer
Frank
