I have a point which represents a vehicle which i want to display in the center of the winformsMap. When I use winformsMap1.CenterAt(feature), it only "Moves the Center of MapControl CurrentExtent to the worldPoint." I rotate the map in the direction in which the vehicle moves and the point(vehicle) gets re-displayed every time it changes position. After a few displays, the layers and point does not display in the window anymore.
How do I center a point in the winformsMap1? Or how do I get the currentExtent to display in the middle of the winformsMap?
The "tricks" here are creating the RectangleShape with the "right" values and the Zoom Level, which is set to 65 here. I had to try a few different values before I got it to look right. Try adjusting these two things and you might get what you want. This map displays the US map, overlayed with cities, and center's the display of the US on Kansas City.
Thanks for the help Nick. It works, but my code is in a loop, so I cannot zoom in every time and I rotate the map every time depending on which direction the train is heading. It seems that the CurrentExtent gets most of the time centered at the point but it does not get centered in the middle of the winformsMap. The point to which i want to center spirals around on the map until it does not display on the map anymore. The point represents a train and each time i get new coordinates, i remove and re-display the train layer.
See the attachment for some screen shots
Here is some of my code:
layerZone = New MapSuite.Core.ShapeFileFeatureLayer(fileName, ShapeFileReadWriteMode.ReadOnly) layerZone.Name = ZONE_LAYER TextStyle.TextColumnName = "ZONE_ID" TextStyle.Font = New GeoFont("Arial", 9) TextStyle.TextSolidBrush = New GeoSolidBrush(GeoColor.SimpleColors.Black) TextStyle.LabelAllPolygonParts = True layerZone.ZoomLevelSet.ZoomLevel04.DefaultTextStyle = TextStyle layerZone.ZoomLevelSet.ZoomLevel04.DefaultAreaStyle = New MapSuite.Core.AreaStyle(New MapSuite.Core.GeoPen(GeoColor.SimpleColors.Black, 2)) Dim transColor As New GeoSolidBrush(GeoColor.FromArgb(80, GeoColor.SimpleColors.PastelGreen)) 'make transparent layerZone.ZoomLevelSet.ZoomLevel04.DefaultAreaStyle.FillSolidBrush = transColor layerZone.ZoomLevelSet.ZoomLevel04.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20 layerZone.FeatureSource.Projection = rotationProjection winformsMap1.StaticOverlay.Layers.Add(ZONE_LAYER, layerZone) 'get the area around the layer Dim tempLayer As ShapeFileFeatureLayer = DirectCast(winformsMap1.StaticOverlay.Layers(ZONE_LAYER), ShapeFileFeatureLayer) tempLayer.Open() extentLayer = tempLayer.GetBoundingBox If extentLayer.GetArea(GeographyUnit.DecimalDegree, AreaUnit.SquareKilometers) > extent.GetArea(GeographyUnit.DecimalDegree, AreaUnit.SquareKilometers) Then extent = extentLayer End If tempLayer.Close() winformsMap1.CurrentExtent = extent 'do this code repeatedly: 'setup the train layer as a point trainPoint = New MapSuite.Core.PointShape(vertexCollectionTrain.Item(0).X, vertexCollectionTrain.Item(0).Y) Feature = New MapSuite.Core.Feature(trainPoint, trainDictionary) trainLayer.InternalFeatures.Clear() trainLayer.Name = TRAIN_LAYER trainLayer.ZoomLevelSet.ZoomLevel04.DefaultPointStyle.PointType = PointType.Symbol trainLayer.ZoomLevelSet.ZoomLevel04.DefaultPointStyle = New PointStyle(PointSymbolType.Circle, New GeoSolidBrush(GeoColor.StandardColors.Red), 8) trainLayer.ZoomLevelSet.ZoomLevel04.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20 trainLayer.InternalFeatures.Add(TRAIN_LAYER, Feature) trainLayer.FeatureSource.Projection = rotationProjection winformsMap1.StaticOverlay.Layers.Add(TRAIN_LAYER, trainLayer) 'center the train on the map winformsMap1.CenterAt(Feature) 'winformsMap1.ZoomIntoCenter(10, feature) 'winformsMap1.ZoomOutToCenter(10, feature) 'rotate the map back to North rotationProjection.Angle = -lastAngle winformsMap1.CurrentExtent = rotationProjection.GetUpdatedExtent(winformsMap1.CurrentExtent) lastAngle = 0 'rotation of the map - heading of the train rotationProjection.Angle = angle winformsMap1.CurrentExtent = rotationProjection.GetUpdatedExtent(winformsMap1.CurrentExtent) lastAngle = angle
Hi Ben, Just to follow up, is the rotation now fixed and released? In which version is it, is it in SilverLight? I really need this feaure now. regards Alta
We want to get the next beta / release candidate out around the end of the month or early next month. We can send a temporary version to you so you can continue with your app. We will send it to you maybe tomorrow by email and please remember that’s just a temporary version and not well tested so may have some problems.
In version 3.0.362, we introduce the lock system when you want to redraw some special overlay; I think you probably missed this point :)
Try following code to see if it works: private void btnRotate_Click(object sender, EventArgs e) { string version = WinformsMap.GetVersion(); double degree = double.Parse(txtDegrees.Text);
No,sorry Yale, that did not help. There was a bug when you rotate the map in the previous version. The point I want to center the map to, gets centered in the CurrentExtent but does not center in the WinFormsMap. The point then spirals away from the middle of the WinFormsMap each time I re-display it until it is "off the map"
Yale, thanks for the example. The rotate works perfectly on its own.
Now, try to add a winformsMap1.CenterAt(x, y) at the end of btnRotate_Click, with x and y any point on the map of USA, eg -122.416656 and 47.45087. After a CenterAt, the USA is not visible on the map anymore.
Maybe the winformsMap1.CurrentExtent is not set correctly. Please help me.
There are two APIs: public void CenterAt(PointShape worldPoint) public void CenterAt(float screenX, float screenY)
so we should use the first API instead of the second one which takes the screen coordainte. winformsMap1.CenterAt(new PointShape(-122.416656494141, .450870513916));
Any more questions please feel free to let me know.
Thanks Yale, but when I add a LineShape repeatedly, the rotate does not work anymore.
I get a few GPS coordinates which I use to draw a line. That represents a train. Each 5 seconds I get the next set of coordinates and I must remove the lineShape and display the new one again and I must rotate the map according to the direction the train is heading and the loco must be in the center of the map.
I used the code you gave me (North Arrow Demo) and added the lineShape, rotate and CenterAt.
If I run the code without the line: c = c + 1, it works.
When I step through the code (debug), it works even if have the c=c+1 line in.
