I have sent a .kmz file to support@thinkgeo.com that I would like to see if it can be used as a layer in Thinkgeo. I extract it out to .kml then I have tried to load it into my map with the following:
var goeClr =newGeoColor(clr.A, clr.R, clr.G, clr.B);sfLayer.StylingType = KmlStylingType.EmbeddedStyling;sfLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle =newLineStyle(newGeoPen(goeClr, 2));sfLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle =newAreaStyle(newGeoPen(goeClr, 2),newGeoSolidBrush(GeoColor.StandardColors.Transparent));sfLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.City3;sfLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Urban1(“NAME”);sfLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.OverlappingRule = LabelOverlappingRule.NoOverlapping;sfLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;if(MapkitMap.Overlays.Contains(GlobalHelpers.DYNAMIC_CABLES_OVERLAY)){FileInfo fi =newFileInfo(sfLayer.KmlPathFilename);
LayerOverlay sqlLayers = (LayerOverlay)MapkitMap.Overlays[GlobalHelpers.DYNAMIC_CABLES_OVERLAY];if(!sqlLayers.Layers.Contains(fi.Name)){ManagedProj4Projection proj4 =newManagedProj4Projection();proj4.InternalProjectionParametersString = Proj4Projection.GetWgs84ParametersString();proj4.ExternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(3857);proj4.Open();sqlLayers.Layers.Add(fi.Name, sfLayer);sfLayer.Open();sfLayer.FeatureSource.Projection = proj4;sfLayer.Close();}sqlLayers.Refresh();}
The issues I am seeing is that the projection doesn’t seem to do anything for the file. It never projects it into the meter projection that I can see. Since it doesn’t project correctly (I have tried a few different parameter strings) I can’t tell in the images are being displayed or not. Is there anything you can see that would make the kml file I sent not display correctly?
